MK7 Jetta GLI factory amp bypass
pyrite-gli
Canada
C?ID=386494
Hello all,
I am in the process of adding aftermarket amps to my 2019 Jetta GLI with beats audio. I am using NAV-TV Zen-V to send optical back to a DSP.
My problem is the factory amp under the seat was not in fact MOST bus - it used speaker wire from the glovebox down the factory amp - then out to the speakers. I currently can not connect to the car using my Hex V2 - I have no k1/k2 power when I test the connection. I am also getting errors/chimes popping up for a few different circuits ex) electronic parking brake fault/ stability control/ assist issues etc etc..
The factory amp has a can hi/lo wire going to it and so I think the instructions that exist for the golf mk7 may not apply to this vehicle...
Any tips/help/direction would be greatly appreciated
South Molton, UK
You need to check the power feed to the OBD connector so that you can get diagnostics working, trying to debug all the issues you mention without an Auto-Scan will be like trying to find a needle in a haystack.
  • Agree
pyrite-gli
Canada
C?ID=386494
found a popped fuse on #7 - a 7.5a - replaced and all good now.....coding complete!!
pyrite-gli
Canada
C?ID=386494
Ok so after fixing the fuse and getting the coding complete for the Zen-V I am having lingering issues in the 5F module - see below.
Also the only things that were changed as per nav-tv are as follows:
byte 11 = 02
byte 19 = check bit 5
byte 04-07 = change to 00 (the only one that needed a change was byte 04 which was AA)
U1014 00 [009] - -
Reset counter: 10
Mileage: 16559 km
Date: 2020.12.03
Time: 15:38:31
Voltage terminal 30: 11.6 V
@pyrite-gli: Hi
As Dave has correctly observed - it's extremely difficult trying to find this specific needle in your particular haystack!! :facepalm:
........................trying to debug all the issues you mention without an Auto-Scan will be like trying to find a needle in a haystack.
pyrite-gli
Canada
C?ID=386494
sorry for the missed auto scan:
Thursday,03,December,2020,20:01:21:41934
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64(Parallels)
VCDS Version 20.12.0.0 (x64)  HEX-V2 CB: 0.4529.4
Data version: 20201124 DS322.0
VIN: 3VW6T7BU8KMxxxxxx   License Plate:
Chassis Type: BU-VW37 (3Q0)
Scan: 01 02 03 05 08 09 13 14 15 17 19 2B 32 36 3C 42 44 47 52 5F
          A5 A9 CA
VIN: 3VW6T7BU8KM166662   Mileage: 16582km-10303miles
47-Sound System -- Status: Cannot be reached 0100
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-DKFA)       Labels: None
   Part No SW: 5G0 906 259 Q    HW: 06K 907 425 J
   Component: 2.0l R4 TFSI  H13 0003
   Revision: --H13---
   Coding: 092500124464012FB000
   Shop #: WSC 00066 790 00387
   ASAM Dataset: EV_ECM20TFS0205G0906259Q 001004
   ROD: EV_ECM20TFS0205G0906259Q.rod
   VCID: 3C21337236E19B0B6FB-8069
Readiness: 1010 0101
   Part No SW: 0GC 300 020 G    HW: 0GC 927 711 H
   Component: GSG DQ381     H06 2403
   Revision: 00H06V07
   ROD: EV_TCMDQ381061.rod
   VCID: 2615F11AD86D31DB29F-8073
   Part No SW: 5Q0 614 517 EC    HW: 5Q0 614 517 BS
   Component: ESC           H82 0108
   Revision: 00000000    Serial number: 50229000000131
   Coding: 70FB6BA150262172857D020660C5A90ED60A84A1400695761841F0D9D2A64B0B0000000012121212B835351919323200
   Shop #: WSC 01383 790 50316
   ROD: EV_Brake1UDSContiMK100IPB_038.rod
   VCID: 76B5E15A484D015B59F-8023
   Part No SW: 3Q0 959 435 L    HW: 3Q0 959 435 L
   Component: VWKESSYMQB    037 1204
   Revision: 00037000    Serial number: 0502706790
   Coding: 132C0C0723
   Shop #: WSC 00066 790 00162
   ASAM Dataset: EV_KessyHellaMQBAB 004046
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 43D3488E4B1FE4F32E1-8017
1057291 - Antenna for Keyless Entry System; Passenger Side
          B1170 13 [137] - Open Circuit
                    Reset counter: 11
                    Mileage: 16582 km
                    Date: 2020.12.03
                    Time: 16:07:49
                    Terminal_15_Kessy_specified_value: OFF
                    Terminal_15_Kessy_actual_value: OFF
                    Terminal_15_central electric_actual_value: OFF
                    Terminal_15red_Kessy_specified_value: OFF
                    Terminal_15red_Kessy_actual_value: OFF
                    Terminal_S_Kessy_specified_value: OFF
                    Terminal_S_Kessy_actual_value: OFF
                    Terminal_S_central electric_actual_value: OFF
                    Terminal_50_Kessy_specified_value: OFF
                    Terminal_50_Kessy_actual_value: OFF
                    ZAT_pressed: OFF
                    Request active: Condition not met
                    Enabling Steering Column Lock: Condition not met
                    Enabling immobilizer: Condition not met
                    Control Module Voltage: 12.949 V
                    Vehicle speed: 0.0 km/h
                    Engine RPM: 0.0 /min
                    Status of vehicle locking: Vehicle unlocked
                    Coding information: coded
                    Coding information: Not coded
                    Driver door: Open
                    Front Passenger Door: closed
                    Left rear door: closed
                    Right rear door: closed
                    Active_LF_scans: Init
                    ID-sensor 1 authentication: status: No response
                    ID-sensor 2 authentication: status: No response
                    ID-sensor 3 authentication: status: No response
                    ID-sensor 4 authentication: status: No response
                    SPN_Byte 0: 00
                    SPN_Byte 1: 00
                    SPN_Byte 2: 00
   Part No SW: 5GM 907 044 R    HW: 5GM 907 044 R
   Component: Climatronic   H05 2009
   Revision: 00001K04
   Coding: 0102001420011800110401401211110C
   ASAM Dataset: EV_ACClimaBHBVW37X 006148
   VCID: 53F378CEBB7F74739E1-8007
   Part No SW: 5Q0 937 087 BB    HW: 5Q0 937 087 BB
   Component: BCM PQ37BOSCH 036 0265
   Revision: --------    Serial number: C864221218028J
   ASAM Dataset: EV_BodyContrModul1UDSBosc 019001
   ROD: EV_BCMBOSCH_019_VW37.rod
   VCID: 7CA1F37276615B0B2FB-8029
   Subsystem 1 - Part No SW: 5Q0 955 547 B    HW: 5Q0 955 547 B  Labels: 5Q0-955-547.CLB
   Component: RLHS  052 0107
   Serial number: SAY18M12D28H14M28S02
   Coding: 0638EE
   Humidity sensor: interior:
   Steering Column Switch:
   Subsystem 3 - Part No SW: 5Q1 953 521 AS    HW: 5Q1 953 569
   Component: Lenks.Modul  H03 0170
   Serial number: 0300310120190C201980
   Subsystem 4 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Component: SysNameFanLin  014 0101
   Serial number: ESE1395143
   Subsystem 5 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Serial number: ESE1393310
   Subsystem 6 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Serial number: ESE1393276
   Subsystem 7 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Serial number: ESE1393626
1050628 - Lamp 1 for Contour Lighting of Door; Front Right
          U1178 00 [009] - No Communications
          [Tür vorne rechts - Slave 1->kein Signal/Kommunikation]
                    Reset counter: 10
                    Mileage: 16559 km
                    Date: 2020.12.03
                    Time: 15:34:54
   Part No SW: 5Q0 907 572 P    HW: 3QF 907 572 A
   Coding: 330007C159FFC428949C810580300600000000000000000004
   VCID: 44D14B924E11E3CB17B-8011
   Serial number: 06111841350215
   ROD: EV_DRCONTITEMIC_VW37.rod
   VCID: 38292F6202D9B72B8B3-806D
   Part No SW: 5Q0 959 655 BM    HW: 5Q0 959 655 BM
   Component: AirbagVW21    005 0403
   Serial number: 003FGM0140J.
   Coding: 8CCCFC00000000005000001AC20800000065
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002164
   VCID: 0C41A3B226C16B8B1FB-8059
   Serial number: IBH00000000000B07JTQ
   Coding: 30344B
   Subsystem 2 - Part No SW: -----------    HW: 480 001 712 18
   Serial number: 35700000000C3B55663N
   Subsystem 3 - Part No SW: -----------    HW: 480 001 712 18
   Serial number: 35800000000D0BC4B63X
   Subsystem 4 - Part No SW: -----------    HW: 480 401 810 18
   Component: SideSensor_Dr  003 6149
   Serial number: 35100019B2C6D4B6C5AP
   Subsystem 5 - Part No SW: -----------    HW: 480 402 310 18
   Component: SideSensor_Pr  004 6149
   Serial number: 3520001142B805B481AX
   Subsystem 6 - Part No SW: -----------    HW: 480 400 901 19
   Serial number: 35500011E2B7F1B212FA
   Subsystem 7 - Part No SW: -----------    HW: 480 400 901 19
   Component: FrontSensor_P  004 6149
   Serial number: 35600011E2B7F1B2E30A
   Part No SW: 17A 920 790 A    HW: 17A 920 790 A
   Component: KOMBI         506 1691
   Coding: 09A4091A778888090288730B50000000A0000000
   ASAM Dataset: EV_DashBoardVDDMQBA0 001026
   ROD: EV_DashBoardVDDMQBA0_VW37.rod
   VCID: 2517F616A56B3AC3205-8071
   Serial number: 11021900841166
   Coding: 030100047F085900FB0002F99C0F00010001070000000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 6E85C93A301D399B91F-803B
   Generator:
   Component: 0-00-0d-00-04
   Subsystem 2 - Part No SW: 5G0 959 442 AE    HW: 5G0 959 442 AE  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H11 0052
   Serial number: 29190000280840019057
   Coding: 2DFFFF
   Serial number: 6594236400
131695 - Digital sound System control module
          U106A 00 [009] - No Communication
          [Timeout Knoten 0x6F / 47 - Steuergerät für digitales Soundpaket]
                    Reset counter: 11
                    Mileage: 16559 km
                    Date: 2020.12.03
                    Time: 15:36:21
                    Terminal 30 power supply: 11.5 V
                    Terminal 15: On
   Part No SW: 2Q0 905 861 A    HW: 2Q0 905 861 A
   Component: ELV-MQBB      H08 0021
   Serial number: 18000398079006
   Coding: 0800000000000000
   ROD: EV_ELVMarqMQBA0_VW37.rod
   VCID: 313F1246E1A36663CCD-8065
Address 32: Differential Locks (J492)       Labels:* 0CQ-907-554.clb
   Part No SW: 0CQ 907 554 P    HW: 0CQ 907 554 P
   Component: Quersperre    H55 8043
   Serial number: HA1-00010.12.18
   Coding: 0001
   ASAM Dataset: EV_LockElectHA1VW37X 001007
   ROD: EV_LockElectHA1VW37X.rod
   VCID: 52FD7DCA84657D7B957-8007
Address 36: Seat Mem. Drvr (J810)       Labels:* None
   Part No SW: 5Q0 959 760 C    HW: 5Q0 959 760 C
   Component: Sitzmemory    H09 0024
   Serial number: Y0006RKG38872
   Coding: 0010000000000500018280808000000000008101000000F400
   ASAM Dataset: EV_SeatMemorDriveSide 002022
   VCID: 3D273E762DFB9203585-8069
Address 3C: Lane Change (J1086)       Labels:* None
   Part No SW: 2Q0 907 686 A    HW: 2Q0 907 686 A
   Component: HRE3_Kl15_Mst H05 0052
   Serial number: 00000503173886
   Coding: 5000C500
   ASAM Dataset: EV_HREntryHellaGen3Kl15 001009
   ROD: EV_HREntryHellaGen3Kl15_001_VW37.rod
   Part No SW: 5Q4 959 593 M    HW: 5Q4 959 593 F
   Component: TSG FS        006 0247
   Serial number: 42038902900032
   Coding: 003D1B200200028000000000
   VCID: 4FFB74BE97571093BA9-801B
   Subsystem 1 - Part No SW: 5Q4 959 811 F    HW: 5Q4 959 811 F  Labels: 5QX-959-81X-V1.CLB
   Component: Fond FHSG DRV  010 0004
   Serial number: 00000000000001731710
   Coding: 011000
   Part No SW: 5QN 909 144 A    HW: 5QN 909 144 A
   Component: EPS_MQB_ZFLS  507 5081
   Coding: 911F0000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 50F977C28A690F6BA33-8005
Address 47: Sound System (J124)       Labels: None
   Part No SW: Not VAG    HW: NAVTVZENV
   Component: ZEN-V v2.2.2 ZEN Aug  3 2020
   Serial number: 215934
   ASAM Dataset: ZEN-V v2.2.2 073020
   ROD: N/A
   VCID: 0F7BB4BE57D75093FA9-805B
No ASAM data for: "ZEN-V v2.2.2" (VW37)
   Part No SW: 5Q4 959 592 M    HW: 5Q4 959 592 F
   Component: TSG BFS       006 0247
   Serial number: 46038904500276
   Coding: 003D13200E00028000000000
   VCID: 4EC569BA905D199BB1F-801B
   Subsystem 1 - Part No SW: 5Q4 959 812 F    HW: 5Q4 959 812 F  Labels: 5QX-959-81X-V1.CLB
   Component: Fond FHSG PSG  010 0004
   Serial number: 00000000000001729077
   Coding: 091000
   Part No SW: 3Q0 035 876 B    HW: 3Q0 035 876 B
   Component: MU-S-NS-US    853 0890
   Coding: 027301020000000041220002001828219F0510F401200405CE
   ROD: EV_MUStd4CDELP_VW26.rod
   VCID: 3333184E1BBF5473BE1-8067
   Subsystem 1 - Part No SW: 5G6 919 605 D    HW: 5G6 919 605 D
   Component: ABT_Std-2_Nav  252 8130
   Serial number: VWZ6ZMW0485463
   Subsystem 2 - Part No SW: 5NA 919 866 E    HW: -----------
   Component: NAR 2018/19  --- 0810
          U1014 00 [009] - -
                    Reset counter: 10
                    Mileage: 16559 km
                    Date: 2020.12.03
                    Time: 15:39:31
7213 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Amplifier (0x2D) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 10
                    Mileage: 16559 km
                    Date: 2020.12.03
                    Time: 15:39:34
                    BAP-BAP_Function_ID: 02
   Part No SW: 3Q0 980 654 L    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H09 0610
   Serial number: 16111815P13085
   Coding: 0003070100020201002213548150490084000E20012000
   ROD: EV_MFKBoschMQBB_002.rod
   VCID: 40D947825A09FFEB333-8015
   Part No SW: 5G0 907 159 F    HW: 4H0 907 159 A
   Component: SAS-GEN 2     H07 0004
   Serial number: 181204200830
   Part No SW: 4K0 907 594 AD    HW: 4K0 907 594
   Coding: 00800073710B
   ROD: EV_SunRoofCONTIAU736_009_VW37.rod
End----------(Elapsed Time: 01:35, VBatt start/end: 12.2V/12.2V)-----------
@pyrite-gli: Arrhh..... that's much better!!!
hmmm...................... I'm not particularly familiar with the NAV-TV Zen-V - but just from the DTC s in your auto-scan, are you sure that the unit is designed to be part of the CAN network when applied to MQB platform cars? Does the factory installation manual instruct that changes should be made to CAN network settings?
If not, and simply as a easy try - why not just revert ALL coding changes back to original (i.e. long-code on hex5F module and remove hex47 module from CAN installation list)?
PS: Admin- is this thread more appropriately located in "Retrofit"?
pyrite-gli
Canada
C?ID=386494
So I tried reverting back to semi stock coding - I plugged the OEM amp back in and changed the coding back but because the Zen-V was still in the most 150 bus loop it did not fully fix things.
I have a support ticket in with Nav-TV to see what they think.
pyrite-gli
Canada
C?ID=386494
So I made a little progress on this issue - I found an adaptation in the 5F for the amplifier - so I turned that off and the code for function restriction to the amp is now gone.
I also tried turning off #47 in the gateway list and that got rid of code in the #19 Gateway for no communication to digital sound system
So all that is remaining is the 5F incorrectly coded issue:
          U1014 00 [009] - -
                    Reset counter: 10
                    Mileage: 16559 km
                    Date: 2020.12.03
                    Time: 15:39:31
@pyrite-gli: Your investigations appear to be moving inexorably and in a positive direction towards total success - well done!!
Now that you have made changes, it's probably prudent for you to post-up an updated auto-scan -and it might be wise to use your VCDS cable rather than the OBD11 dongle (given the nature of this forum)!!
pyrite-gli
Canada
C?ID=386494
Hi Don,
I assure you that I only have a VCDS cable and not an OBD dongle - I don't even own a dongle. I do however connect on my Mac using parallels / windows which is why my scans look off...
pyrite-gli
Canada
C?ID=386494
Monday,14,December,2020,18:12:43:41934
VCDS Version: 20.12.0.0 (x64)  HEX-V2 CB: 0.4529.4
VIN: 3VW6T7BU8KM   License Plate:
Mileage: 16638km-10338mi   Repair Order:
          A5 A9 CA
VIN: 3VW6T7BU8KM   Mileage: 16638km-10338miles
47-Sound System -- Status: Not registered 0001
   Revision: --H13---
   VCID: 3C21337236E19B0B6FB-8068
Readiness: 1110 1101
   Revision: 00H06V07
   VCID: 2615F11AD86D31DB29F-8072
   VCID: 76B5E15A484D015B59F-8022
   Coding: 132C0C0723
   VCID: 43D3488E4B1FE4F32E1-8016
   Revision: 00001K04
   VCID: 53F378CEBB7F74739E1-8006
   VCID: 7CA1F37276615B0B2FB-8028
   Coding: 0638EE
          [T¸r vorne rechts - Slave 1->kein Signal/Kommunikation]
                    Reset counter: 13
                    Mileage: 16638 km
                    Date: 2020.12.14
                    Time: 18:10:30
   VCID: 44D14B924E11E3CB17B-8010
   VCID: 38292F6202D9B72B8B3-806C
   VCID: 0C41A3B226C16B8B1FB-8058
   Coding: 30344B
   VCID: 2517F616A56B3AC3205-8070
   VCID: 6E85C93A301D399B91F-803A
   Generator:
   Coding: 2DFFFF
   VCID: 313F1246E1A36663CCD-8064
   Coding: 0001
   VCID: 52FD7DCA84657D7B957-8006
   VCID: 3D273E762DFB9203585-8068
   Coding: 5000C500
   VCID: 4FFB74BE97571093BA9-801A
   Coding: 011000
   Coding: 911F0000
   VCID: 50F977C28A690F6BA33-8004
   ROD: N/A
   VCID: 0F7BB4BE57D75093FA9-805A
   VCID: 4EC569BA905D199BB1F-801A
   Coding: 091000
   VCID: 3333184E1BBF5473BE1-8066
          U1014 00 [009] - -
                    Reset counter: 13
                    Mileage: 16638 km
                    Date: 2020.12.14
                    Time: 18:10:26
   VCID: 40D947825A09FFEB333-8014
End----(Elapsed Time: 01:36, VBatt start/end: 11.6V/11.6V. VIgn 11.6V)-----
@pyrite-gli: hmm.......... nothing jumps out (at me) as being obviously wrong for the incorrectly coded DTC.
Perhaps another avenue of investigation is the records in VCDS "history" files? Might be worth reviewing the contents of AdpLog.CSV for adaptation channel changes that may have been made in the hex5F module - but I'm guessing (clutching-at-straws, really).
pyrite-gli
Canada
C?ID=386494
Hey Don - I went back and looked at the long coding for the 5F and the only difference I can see is the last byte of the string changing from C6 to CE
Do you know what the difference would be between C6 and CE??
Obviously an adaptation from another module changed this string....hmmm
previous:
02730102AA00000041220003001828219F0510F401200405C6
now:
pyrite-gli
Canada
C?ID=386494
I can confirm that changing the CE back to C6 fixed my incorrectly coded 5F issue!! It was a WLAN option...auto scan below:
Wednesday,16,December,2020,18:31:10:41934
Mileage: 16675km-10361mi   Repair Order:
          A5 A9 CA
VIN: 3VW6T7BU8KM   Mileage: 16675km-10361miles
   Revision: --H13---
   Revision: 00H06V07
   Coding: 132C0C0723
   Revision: 00001K04
   Coding: 0638EE
   Coding: 30344B
   Generator:
   Coding: 2DFFFF
   Coding: 0001
   Coding: 5000C500
   Coding: 011000
   Coding: 911F0000
   ROD: N/A
   Coding: 091000
   Coding: 027301020000000041220002001828219F0510F401200405C6
End----(Elapsed Time: 01:34, VBatt start/end: 11.6V/11.5V. VIgn 11.5V)-----
