A7 S-tronic 0B5 DTC 02-Trans
urgi
Essex, UK
Hi all I saw yesterday yellow gearbox sign on dash - after read of DTC this show
Address 02: Auto Trans Labels: 0B5-927-156.clb
Control Module Part Number: 4G1 927 156 B HW: 0B5 927 156 F
Component and/or Version: 0B5 30 TDIRdW H10 0006
Software Coding: 000001
Work Shop Code: WSC 02311 785 00200
ASAM Dataset: EV_TCMDL501 A02206 (AU57)
ROD: EV_TCMDL501.rod
VCID: 2C5CF8D0470845E69F-8078
17592 - Shift Fork 3
P284F 00 [100] - Uncommanded Movement
Mileage: 254862 km
Date: 2020.12.01
Time: 17:06:32
Engine speed: 1450 /min
Transmission input speed: 1450 /min
Transmission output speed: 366 /min
Engine torque: -40 Nm
Transmission fluid temperature: 13 °C
Accelerator position: 6.8 %
Clutch status: Beide Kupplungen können Moment übertragen
anyone any ideas or suggestion - never had any these DTC before ...
Looks like mechatronic moved gearbox shifter without command...
History :
Gearbox has been repair 5 years ago in Audi for mechatronics issue new flat cable fitted - 90K miles o clock
Last year I done dual clutch and pressure solenoids + oil change 150K miles o clock
Day before yesterday has been gearbox oil checked and still OK on max when 40C now is 158K
Westbury, UK
As always we need to see a full unedited VCDS Auto-Scan not just a small section
urgi
Essex, UK
What give you full scan rest of car ins DTC free
and now is complete car without DTC main think I am asking here if anyone have something similar ;)
LOOKING FOR SOLUTION
Westbury, UK
VAG do running changes on many modules which means knowing how the WHOLE car is configured is important, plus we need to know want VCDS version you are using.
No full scan is likely to result in little help or incorrect help.
If you want a SOLUTION then please post a full unedited VCDS Auto-Scan as requested.
urgi
Essex, UK
Just update year after same issue :eek:
Friday,03,December,2021,19:38:28:00882
VCDS Version: 21.9.0.2 (x64)
VIN: WAUZZZ4G9CN040865 License Plate: AV61JVX
Mileage: 262031 km Repair Order:
VCID: 2C5CF8D0470845E9CD-8078
P284F 00 [096] - Uncommanded Movement
Reset counter: 38
Mileage: 262003 km
Date: 2021.12.03
Time: 17:08:39
Engine RPM: 1623 /min
Transmission input speed: 1623 /min
Transmission output speed: 406 /min
Engine torque: 112 Nm
ATF temperature: 14 °C
Accelerator pedal position: 26.4 %
