Is the device compatible with all Audi Vehicles?
PinoySaMI
MI
C?ID=220597
HI,
I have a Hex-Net that i use for my 2011 Audi A4 to reset service notification. We recently acquired a 2018 Audi Q5. Can i use it to reset service notification? Also, can i find or do the same reset steps as with my A4?
Thank you
Bruce
Near Philadelphia, PA, USA
Yes the HN is compatible. As to the steps, they may not be the same and I don't have enough info from you to give a better answer. Please post an autoscan of the car.
This may be useful:
PinoySaMI
MI
C?ID=220597
Sorry for the delay. Attached are our Q5 auto scan.
Mari
C?ID=150535
You can't attach files this way when they are located on your harddisk... just COPY & PASTE the content of the scan between Code-tags by pressing the </> icon...
PinoySaMI
MI
C?ID=220597
Sorry it’s been awhile since I did this. Anyway, below is our Q5 auro
#hndoc:?docid=0000659B&xt=hnh:98D249781FF176E12912691AF46F11E78E5B7D76861EC60B5995C96FEE6B7AED
VCDS Mobile 0.4437.0.4
VIN: WA1ANAFY5J2065130
Scan: 01 02 03 08 09 15 16 17 19 22 29 39 42 44 46 52 5F 69 6C 6D
     81 A5 BB BC
BB-Door Rear Drv Side -- Status: OK 0000
BC-Door Rear Pass Side -- Status: OK 0000
Address 01: Engine  (DAYB J623)    Labels: None
    Part No SW: 80A 906 259 A    HW: 06L 907 425 C
    Component: 2.0l R4 TFSI  H15 0003
    Revision: --H15---
    Coding: 2A6500122536012E74000000000000000000000000000000
    Shop #: WSC 03999 444 00000
    ASAM Dataset: EV_ECM20TFS02080A906259A 001004
    ROD: N/A
    VCID: 29156EA7D063AA3F558C93-807C
    No ASAM data for: "EV_ECM20TFS02080A906259A"
No fault codes found.
Address 02: Auto Trans  (J217)    Labels: None
    Part No SW: 80A 927 155 AJ    HW: 0CJ 927 156
    Component: 0CJ 20TFSINAR H04 0001
    Revision: --H04---
    Shop #: WSC 02391 785 00200
    ASAM Dataset: EV_TCMDL382021 002027
    ROD: N/A
    VCID: 71A546C7383392FFDD7C8B-8024
    No ASAM data for: "EV_TCMDL382021"
Address 03: ABS Brakes  (J104)    Labels: None
    Part No SW: 80A 907 379 B    HW: 80A 907 379
    Component: ESP9 Plus     H11 0766
    Coding: 4CAA40BE28A80A9B919F4894207D4292E4259232021450891204424927A449
    ROD: N/A
    VCID: 2E1F9DBBE98DCD0780DEA8-807B
    No ASAM data for: "EV_ESP9BOSCHCMP"
Address 08: Auto HVAC  (E87)    Labels: None
    Part No SW: 80A 820 043 J    HW: 80A 820 043 J
    Component: Klima Zone 3  H55 0210
    Coding: 640801095544000D10000100080000000000000000000000000000000000
    ROD: N/A
    VCID: 240B7F93B7417757667ADA-8071
    No ASAM data for: "EV_AirCondiBHTCAU491"
    Subsystem 1 -     Part No SW: 4M1-820-021-A
    Component: J126 FLuftV  H08 0003
    Serial Number: 00000000000001783894
    Subsystem 2 -
Address 09: Cent. Elect.  (J519)    Labels: None
    Part No SW: 8W0 907 063 CE    HW: 8W0 907 063 BE
    Component: BCM1 MLBevo   H13 0267
    Coding: C2500362C0081CCD051487149C3E10B9100B3D08000000000000000000001A0001600002001204
    ROD: N/A
    VCID: 8043930383990B77A212D6-80D5
    No ASAM data for: "EV_BCM1BOSCHAU736"
    Subsystem 1 -     Part No SW: 80B-955-119
    Component: 426 LL 170707040 0570
    Serial Number: 00000001707012102236
    Coding: 5FC7F7
    Subsystem 2 -     Part No SW: 81A-955-555-A
    Component: G397_RLFSS   H06 0002
    Serial Number: 20577280X81A955555A0
    Coding: 02006E
    Subsystem 3 -     Part No SW: 4M0-941-531-AA
    Component: E1 - LDS     H06 0008
    Serial Number: 08 09 2017  72510041
    Subsystem 4 -     Part No SW: 4M0-907-410-A
    Component: USHL5        H08 0050
    Serial Number: 0000009600363Z00UU02
    Coding: 350000
    Subsystem 5 -     Part No SW: 4M0-959-719-A
    Component: GTO BF       H01 0010
    Serial Number: 20170830135950 00794
    Subsystem 6 -     Part No SW: 8W0-857-511-B
    Component: Y7_InnenspiegH01 0002
    Serial Number: GX1CE129081723510035
    Coding: 030000
    Subsystem 7 -     Part No SW: 80A-947-135-M
    Component: Dachmodul Q5 H31 0310
    Serial Number: Q00000707
    Coding: 010104
    Subsystem 8 -     Part No SW: 8W0-925-301-BA
    Component: SL-B9/Q5NF   H17 0010
    Serial Number: 2617000170606002
Address 15: Airbags  (J234)    Labels: None
    Part No SW: 80A 959 655 L    HW: 80A 959 655 L
    Component: AirbagVW30    023 0513
    Coding: AECCFCC000800000A000003FF20C40000065
    ASAM Dataset: EV_AirbaVW31SMEAU65x 001006
    ROD: N/A
    VCID: 3C3BA7F32FF12F973E4AC2-8069
    No ASAM data for: "EV_AirbaVW31SMEAU65x"
    Subsystem 1 -     Part No SW: 4M0-980-945-B
    Component: BeltPretRevFL306 2033
    Serial Number: 80A857705F0198R00450
    Coding: 80000D
    Subsystem 2 -     Part No SW: 4M0-980-946-B
    Component: BeltPretRevFR306 2033
    Serial Number: 80A857706F0199R00158
    Coding: 80000D
    Subsystem 3 -     Part No SW: 4M0-959-339
    Component: BF-Gewichtss.H11 0022
    Serial Number: IBH0000J170007SDO40K
    Coding: 303032
    Subsystem 4 -     Part No SW: --------------
    Component: SideSensor_Df001 0887
    Serial Number: 35700000000D55C0E52S
    Subsystem 5 -     Part No SW: --------------
    Component: SideSensor_Pf001 0887
    Serial Number: 3580000000075825352A
    Subsystem 6 -     Part No SW: --------------
    Component: SideSensor_Dr002 0149
    Serial Number: 351000C24C6D6A406B4D
    Subsystem 7 -     Part No SW: --------------
    Component: SideSensor_Pr002 0149
    Serial Number: 352000C24E0994504BA8
    Subsystem 8 -     Part No SW: --------------
    Component: FrontSensor_D002 0149
    Serial Number: 355000C24E0BDE70E94V
    Subsystem 9 -     Part No SW: --------------
    Component: FrontSensor_P002 0149
    Serial Number: 356000C24E0BD1209ABH
    Subsystem 10 -     Part No SW: --------------
    Component: CentrSensorXY000 0108
    Serial Number: I0O00019B2538155660I
Address 16: Steering wheel  (J527)    Labels: None
    Part No SW: 80A 907 129 AP    HW: 80A 907 129 AP
    Component: Lenks.Modul   H02 0003
    Shop #: WSC 00000 000
    ROD: N/A
    VCID: 76AF75DB515DB5C7088E40-8023
    No ASAM data for: "EV_SMLSKLOAU736"
Address 17: Instruments  (J285)    Labels: None
    Part No SW: 80A 920 840 A    HW: 80A 920 840 A
    Component: MMQ5M18BENUS  H03 0512
    Revision: 0512v0.2
    Coding: 09E48EC5A080CF050203A8601800200000000000
    ASAM Dataset: EV_DashBoardAU736 001022
    ROD: N/A
    VCID: 21057687A853627F0D5C3B-8074
    No ASAM data for: "EV_DashBoardAU736"
Address 19: CAN Gateway  (J533)    Labels: None
    Part No SW: 4M1 907 468 E    HW: 4M1 907 468 E
    Component: Gateway       H22 0119
    Revision: 6X060004
    Coding: 030100010000064029070000005900304C3A0007100000000100000000000000
    ASAM Dataset: EV_GatewCONTIAU736 003092
    ROD: N/A
    VCID: 3935BEE720C31ABF252C23-806C
    No ASAM data for: "EV_GatewCONTIAU736"
    Subsystem 1 -     Part No SW: 80A-951-523-D
    Component: J453 MFL     H06 0002
    Serial Number: 20170909180549 00699
    Subsystem 2 -     Part No SW: 8S0-915-181-C
    Component: J367-BDMHellaH10 9070
    Serial Number: 3432575100
Address 22: AWD  (J492)    Labels: None
    Part No SW: 80A 927 755    HW: 0CJ 927 749
    Component: Q5_DL3_N_SD4  H18 0004
    Coding: 11070000
    ASAM Dataset: EV_AWDCQUOD31 001048
    ROD: N/A
    VCID: EC9BD7B39F11FF176E2A72-80B9
    No ASAM data for: "EV_AWDCQUOD31"
Address 29: Left Light  (J1018)    Labels: None
    Part No SW: 80A 907 397 A    HW: 80A 907 397 A
    Component: LCM_MLBevo    H06 0017
    ROD: N/A
    VCID: 2D1D9AB7E48BB61FB9D4A7-8078
    No ASAM data for: "EV_LCMLeftCONTIAU426"
Address 39: Right Light  (J1023)    Labels: None
    ROD: N/A
    No ASAM data for: "EV_LCMRightCONTIAU426"
Address 42: Door Elect, Driver  (J386)    Labels: None
    Part No SW: 8W1 959 593    HW: 8W1 959 593
    Component: TSG FS
    Coding: 001F0B004000148000000082
    ROD: N/A
    VCID: 08530B232BA9B3376A420E-805D
    No ASAM data for: "EV_DCU2DriveSideMAXHKLO"
Address 44: Steering Assist  (J500)    Labels: None
    Part No SW: 4M0 909 144 H    HW: 4M0 909 144 B
    Component: EPS_MLBEVO1BS H22 0005
    Coding: 90002001000100
    ASAM Dataset: EV_EPSVWBSAU736 009023
    ROD: N/A
    VCID: 342B8FD307A1E7D7F61A6A-8061
    No ASAM data for: "EV_EPSVWBSAU736"
Address 46: Central Conv.  (J393)    Labels: None
    Part No SW: 8W0 907 064 DM    HW: 8W0 907 064 DM
    Component: BCM2 MLBevo   019 0366
    Coding: 013400004F3100C0650380000201D80033000000810022502F00000000040030001E0001000000
    ASAM Dataset: EV_BCM2HellaAU736 013013
    ROD: N/A
    VCID: 8A57B12BB5A54127FC76A4-80DF
    No ASAM data for: "EV_BCM2HellaAU736"
    Subsystem 1 -     Part No SW: 5Q0-951-177
    Serial Number: 000000000ZY1719015HU
    Subsystem 2 -     Part No SW: 5Q0-951-605-A
    Serial Number: 00000000000070164602
065906 - ROD - Unknown faultcode
        Fault Frequency: 8
        Reset Counter: 1
        Mileage: 131614 km
Address 52: Door Elect, Pass.  (J387)    Labels: None
    Part No SW: 8W1 959 592    HW: 8W1 959 592
    Component: TSG BFS
    Coding: 001F0B004000148000000080
    ROD: N/A
    VCID: 0751081F26B7BC4F635805-8052
    No ASAM data for: "EV_DCU2PasseSideMAXHKLO"
Address 5F: Information Electr.  (J794)    Labels: None
    Part No SW: 8W0 035 664 C    HW: 8W0 035 664 A
    Component: MU-HS--US     050 0158
    Coding: 01240600FF0A000013220001061A00002F003AC401F001040A
    ROD: N/A
    VCID: 3A37A1EB25C511A72C56D4-806F
    No ASAM data for: "EV_MUHigScl6C3DELP"
    Subsystem 1 -     Part No SW: 80A-919-604
    Component: AU426_DU_STD H42 0008
    Serial Number: AUZ8Z9HBM010AY
    Subsystem 2 -     Part No SW: 80A-919-614-A
    Component: ControlUnit_BH20 0200
    Serial Number: AMXAM123091700010158
005633 - ROD - Unknown faultcode
        Fault Status: 00010110
        Fault Frequency: 8
        Reset Counter: 1
        Mileage: 66113 km
Address 69: Trailer  (J345)    Labels: 4M-69.clb
    Part No SW: 4M0 907 383 D    HW: 4M0 907 383 B
    Component: Anhaenger     H20 0216
    Revision: 9A001003
    Coding: 0210000200000000
    ROD: N/A
    VCID: 33298CCF02AFE0EFEF1061-8066
    No ASAM data for: "EV_TrailFunctGener2Hella"
Address 6C: Back-up Cam.  (J772)    Labels: None
    Component: RVC Compact   H12 0250
    Coding: 0224060101002005400040
    ROD: N/A
    No ASAM data for: "EV_CamSysRVRVCPANAMLBEv"
Address 6D: Trunk Elect.  (J605)    Labels: None
    Part No SW: 8W8 959 107 B    HW: 8W8 959 107
    Component: HDSG-Modul    H13 0161
    Revision: --------
    Coding: 0790
    Shop #: WSC 00003 444 00000
    ROD: N/A
    VCID: 48D3CB236B297337AAC24E-801D
    No ASAM data for: "EV_DeckLidCONTIAU736"
Address 81: Gear Shift  (J587)    Labels: None
    Part No SW: 80B 713 041 G    HW: 80B 713 041 G
    Component: GSM-LL        H09 0077
    Revision: 0L0D5012
    ROD: N/A
    No ASAM data for: "EV_GSMWaehlZFAU736"
PinoySaMI
MI
C?ID=220597
I don’t have windows based computer. I am using iPhone together with my hex net.
should I go to OPTIONS?
Then you will have to do the Adaptation Channels manually.
PinoySaMI
MI
C?ID=220597
When I click SELECT - COMMON- INSTRUMENTS, it ask me to update ASAM.
should I update the ASAM?
PinoySaMI
MI
C?ID=220597
Well, you will definitely need ASAM data for your instrument cluster in the HEX-NET in order to access Adaptation channels.
PinoySaMI
MI
C?ID=220597
what channels should i be resetting to zero?
PinoySaMI
MI
C?ID=220597
This shows after I clicked to update the ASAM files.
Warning
No ASAM data found locally
No ASAM data found. This module
may not currently be supported,
or this could be a ReDir fail.
You may continue anyway but
without current ASAM data,
functionality will be extremely limited.
PinoySaMI
MI
C?ID=220597
I also can’t update the firmware. I failed during reboot. It say cannot find WiFi.
Shaun
The wifi error may just be your phone complaining because the interface restarted.
Try to reconnect to it and see if the versions are updated.
That being said, it is probably best and easiest if you check for updates with VCIConfig and make sure that your interface is all up to date before trying to do the service reset.
PinoySaMI
MI
C?ID=220597
I even tried using an iPad and also using a cable attached to a Mac computer. Same thing. WiFi error during reboot.
