AINils
In coding there`s some fault like:
This fingerprint: WSD 00012 importer number 007 device number 00075 was rejected by the control unit. The requested operation will most likely fail. Please change your input values.
Is there any know bug or hint. Recognised is man times in Cars with my 20 and 21 most time in BCM. This Scan is done witth 2012 and also this problem. Tried it remote yesterday with our customer
Tuesday,01,December,2020,13:39:17:02162
VCDS Version: 20.12.0.0 HEX-V2 CB: 0.4529.4
Data version: 20201124 DS322.0
Workshop Code: 007 00012 000075
VIN: WV2ZZZ7HZMH027821 License Plate: T6.1
Mileage: 698km-433mi Repair Order:
Chassis Type: 7H-VN46 (3Q0)
Scan: 01 03 08 09 10 13 15 17 18 19 3C 3D 44 55 5F 69 6C 75 A5 D6
D7 810B
VIN: WV2ZZZ7HZMH027821 Mileage: 698km-433miles
3D-Special Function -- Status: OK 0000
810B-Aux. Air Heat. 2 -- Status: OK 0000
Address 01: Engine (J623-CXFA) Labels: None
Part No SW: 04L 906 056 LE HW: 04L 907 445 M
Component: R4 2.0l TDI H01 9704
Revision: 23301001
Coding: 0019401C4354050800000000000000000000000000000000
Shop #: WSC 00012 790 00164
ASAM Dataset: EV_ECM20TDI03004L906056LE 004007
ROD: EV_ECM20TDI03004L906056LE_004.rod
VCID: 7BA20F176365E7F3261-802E
Readiness: N/A
Part No SW: 7LB 614 517 A HW: 7LB 614 517
Component: ESC_base H01 0700
Serial number: 08502439200904
Coding: 10552452C849EE8C085C24A613677776383320B8
ASAM Dataset: EV_Brake1ESP90iBOSCHVN46X 002010
ROD: EV_Brake1ESP90iBOSCHVN46X_002.rod
VCID: 3E24C60330F732DB41F-806A
Address 08: Auto HVAC (J255) Labels:* None
Part No SW: 7LA 907 040 E HW: 7LA 907 040 E
Component: Climatronic H01 0602
Coding: 9030100008101100010009005040010500000000000B1501A04000000000
ASAM Dataset: EV_AirCondiBHTCVN54XT6PA 001002
ROD: EV_AirCondiBHTCVN54XT6PA.rod
VCID: 3D26C10F3DF129C3585-8068
Rear A/C Control Head 1:
Subsystem 1 - Part No SW: 7LA 906 453 A HW: 7LA 906 453 A
Component: E857 H01 0206
Serial number: 00002270820130548104
Rear A/C control head:
Subsystem 2 - Part No SW: 7LA 907 049 F HW: 7LA 907 049 F
Component: E857 H02 0301
Serial number: 00002160720171416605
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 2Q5 937 090 A HW: 2Q5 937 090 A
Component: BCM T6PA Std+ H11 0943
Serial number: 00102027300333
Shop #: WSC 00012 790 00075
ASAM Dataset: EV_BCMA0 206001
ROD: EV_BCMA0_206.rod
VCID: 3536D92F05C1F183905-8060
Subsystem 1 - Part No SW: 5Q0 955 559 C HW: 5Q0 955 559 C Labels: 5Q0-955-547.CLB
Component: RLS 054 0206
Serial number: SAY20M09D23H13M05S20
Coding: 0018EE
Driver door control module:
Subsystem 2 - Part No SW: 7L2 959 405 B HW: 7L2 959 163 B
Component: FHSG_DRV 001 0002
Serial number: 00000000000043694850
Coding: 130007
Front passenger door control module:
Subsystem 3 - Part No SW: 7L2 959 406 B HW: 7L2 959 164 B
Component: FHSG_PSG 001 0002
Serial number: 00000000000043918961
Coding: 090007
Subsystem 4 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
Serial number: 000000000ZY202200DHG
Serial number: 00000000000048673820
Part No SW: 5QA 919 298 K HW: 5QA 919 298 A
Component: PLA 3.0 12K H08 0073
Serial number: 000150057320274
Coding: 8A71167941
ASAM Dataset: EV_EPHVA2CAU3700000 009055
ROD: EV_EPHVA2CAU3700000.rod
VCID: 58E8709BB293ECEB6B3-800C
Part No SW: 2Q0 907 572 R HW: 2Q0 907 572 B
Component: ACCCONTIMQB H03 0372
Coding: 2A04600B49FF8748949C815560508700000000000000000004
Shop #: WSC 00012 790 00027
ROD: EV_ACCMRRCONTIVW376_003_VN54.rod
VCID: 43D2B7F75B155F332E1-8016
Address 15: Airbags (J234) Labels:* None
Part No SW: 2Q0 959 655 AE HW: 2Q0 959 655 AE
Component: VW22Airbag 016 0506
Revision: --------
Coding: 88CCC00000000000400000CF000C40000065
ASAM Dataset: EV_AirbaVW22BPAVW27X 001022
ROD: EV_AirbaVW22BPAVW27X.rod
VCID: 005878FB0A83842B733-8054
Subsystem 1 - Part No SW: ----------- HW: 442 062 909 20
Serial number: 3577Y52B33648C5522C7
Subsystem 2 - Part No SW: ----------- HW: 442 063 009 20
Serial number: 3587Y51C3272ABB474BI
Address 17: Instruments (J285) Labels:* None-SRI3
Part No SW: 7LA 920 320 A HW: 7LA 920 320 A
Component: KOMBI 502 5175
Coding: 00A50000658C00080188620B2001000080601E02
Shop #: WSC 00012 007 00075
ASAM Dataset: EV_DashBoardVDDMQBA0 001044
ROD: EV_DashBoardVDDMQBA0_VW27.rod
Address 18: Aux. Heat (J364) Labels:* None
Part No SW: 5WA 963 272 A HW: 5WA 963 272 A
Component: STH-VW37x 006 0010
Serial number: 000000000000035
Coding: 7543223854121512DCE519
ASAM Dataset: EV_AuxilHeateWOSVW38X 001009
ROD: EV_AuxilHeateWOSVW38X_001_VW27.rod
VCID: 4BC29FD773459773D61-801E
Auxiliary heating remote control:
Part No SW: 3Q0 907 530 AG HW: 3Q0 907 530 C
Component: GW MQB High 521 5423
Serial number: 27092011601355
Coding: 030100544F05730400000258000F00010001070000000000000000000000
ROD: EV_GatewNF_VW27.rod
VCID: 74B0242B4E3BA88B67B-8020
Generator:
Component: 4-00-11-01-04
Subsystem 2 - Part No SW: 3G0 959 442 N HW: 3G0 959 442 N
Component: E221__MFL-PR6 H07 0110
Serial number: PR6-0440071260204285
Coding: 2C0D00
Subsystem 3 - Part No SW: 7E0 915 181 L HW: 7E0 915 181 L
Component: J367-BDMConti H03 1051
Serial number: 7719720000200917003F
Address 3C: Lane Change (J1086) Labels:* None
Part No SW: 2Q0 907 686 B HW: 2Q0 907 686 B
Component: HRE3_Kl15_Mst H06 0150
Serial number: 14520004325370
Coding: 62954640
ASAM Dataset: EV_HREntryHellaGen3Kl15 002001
ROD: EV_HREntryHellaGen3Kl15.rod
VCID: 392ED51F29D915E374D-806C
Address 3D: Special Function (J608) Labels:* None
Part No SW: 2N0 907 427 P HW: 2N0 907 427 H
Component: KFG H24 0306
Serial number: GB24204016561
Coding: 04000000000000200200000860B803A0B8000000
ASAM Dataset: EV_SpeciFunctFlextVN54X 007029
ROD: EV_SpeciFunctFlextVN54X_007_VN46.rod
Subsystem 5 - Part No SW: 7C0 907 155 HW: 7C0 907 155
Component: U13DCAC H05 0870
Serial number: A046929
Subsystem 6 - Part No SW: 7E0 915 181 M HW: 7E0 915 181 M
Serial number: 7719450100200701052D
Address 44: Steering Assist (J500) Labels:| 2N0-909-143.clb
Part No SW: 7LA 909 144 F HW: 7LA 909 144 D
Component: EPS_MQB_ZFLS 751 7150
Coding: 1306
ASAM Dataset: EV_SteerAssisMNB 002012
ROD: EV_SteerAssisMNB.rod
VCID: 45D6A9EF55216103005-8010
Part No SW: 7P6 907 357 E HW: 7P6 907 357 A
Component: AFS-ECU H07 0080
Coding: 0C8A020009200003
Shop #: WSC 00012 790 00154
ROD: EV_HeadlRegulAFSMQBMAX_VW27.rod
VCID: 41DEBDFF41094D233CD-8014
Part No SW: 3G5 035 820 B HW: 3G5 035 820
Component: MU-O-ND-EU H56 0781
Serial number: WG8LGM260920000
Coding: 64600000000020000000000000000000000000000000000000
ASAM Dataset: EV_MUOIMQB 001002
ROD: EV_MUOIMQB_VN46.rod
VCID: 23121777BB557F334E1-8076
Address 69: Trailer (J345) Labels:* None
Part No SW: 5H0 907 383 HW: 5H0 907 383
Component: Anhaenger H09 0040
Serial number: 000000000005575
Coding: 0100000202001300
ASAM Dataset: EV_TrailFunctGener3Hella 001009
ROD: EV_TrailFunctGener3Hella_VW27.rod
VCID: 6B823F5713057773B61-803E
Part No SW: 5Q0 980 568 B HW: 5Q0 980 568 B
Component: RVC Compact+ H09 0250
Coding: 0155000103002017000048
ASAM Dataset: EV_CamSysRVRVCARPANAMQBAB 007012
ROD: EV_CamSysRVRVCARPANAMQBAB_007.rod
VCID: 3C20CC0B26EB20CB6FB-8068
Part No SW: 5WA 035 284 B HW: 5WA 035 284 B
Component: OCUGen3High H20 0035
Serial number: 0000000008VIPAA
Coding: 06462000196898209005460160502607
ASAM Dataset: EV_OCUGen3High 003005
ROD: EV_OCUGen3High_003_SE27.rod
Address A5: Frt Sens. Drv. Assist (R242) Labels:* None
Part No SW: 2Q0 980 653 HW: 2Q0 980 653
Component: MQB MFK 3.0 H13 1030
Serial number: E57829511202620
Coding: 000108881178C020409F00001030002006018000000000000000000000000000
ASAM Dataset: EV_MFK3ValeoMQB 005035
ROD: EV_MFK3ValeoMQB_005_VW27.rod
VCID: 72BC2233342FA6BB757-8026
Part No SW: 992 941 571 AA HW: 992 941 571 A
Component: LED1L H08 9002
ROD: EV_LLPGen3LKEBODPO68X_SK25.rod
VCID: 619E5D7FE1C92D231CD-8034
Component: LED1R H08 9002
Address 810B: Aux. Air Heat. 2 (J604) Labels:* None
Part No SW: 7C0 963 273 B HW: 7C0 963 273 B
Component: LSH_DIESEL 007 0026
Coding: 2200
ASAM Dataset: EV_LSHECCSMNB 002018
ROD: EV_LSHECCSMNB_002.rod
VCID: 2A0CFA53DC7FAE7B0D7-807E
End----------(Elapsed Time: 01:38, VBatt start/end: 12.0V/12.0V)-----------
