Air Quality sensor?
invernesspl
C?ID=345478
Hi,
I've got a 2017 Tiguan and its showing a fault on the air quality sensor? Any ideas what could cause it, or how to resolve it.
Tuesday,01,December,2020,10:53:30:41168
VIN: WVGZZZ5NZHW403044 License Plate:
Chassis Type: 5N-VW37 (3Q0)
Scan: 01 03 08 09 10 13 15 16 17 19 22 42 44 52 5F A5
VIN: WVGZZZ5NZHW403044 Mileage: 61659km-38313miles
Address 01: Engine (J623-DFGA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 026 JC HW: 04L 907 309 P
Component: R4 2.0l TDI H24 3023
Revision: B4H24---
Coding: 0119001203271D082000
ASAM Dataset: EV_ECM20TDI01104L906026JC 004002
ROD: EV_ECM20TDI01104L906026GQ_004.rod
VCID: 74B1DFB81E3122AB46B-8020
Part No SW: 5Q0 614 517 CE HW: 5Q0 614 517 AC
Component: ESC H25 0413
Revision: 00000000 Serial number: 60277000000516
Coding: 0AEE929A34200B6F4777070462C74950492CD0E2E046927D30605078C02A4200002F641A1B13111435351919323200
VCID: 76B5E5B0084D30BB78F-8022
Address 08: Auto HVAC (E87) Labels:| 3V0-907-044.clb
Part No SW: 5NA 907 044 M HW: 5NA 907 044 M
Component: AC Automat H35 4301
Revision: 20K08000 Serial number: 00000B00387115
Coding: 0012010420211001110510000010102A
ASAM Dataset: EV_ACClimaPrehVW37X 002023
VCID: 49CF5E4C29330F43C5D-801C
Subsystem 2 - Part No SW: 3G0 907 049 D HW: 3G0 907 049 D
Component: E265KlimaHeck H02 0201
Serial number: 04031501850571
263425 - Air Quality Sensor
B10AF 04 [009] - Internal System Fault
Reset counter: 114
Mileage: 61659 km
Date: 2020.12.01
Time: 10:53:03
Outside air temperature: 6.5 °C
Voltage terminal 30: 12.4 V
System run time-Engine running time: 94 s
Air quality status: ERROR
Part No SW: 5Q0 937 084 CE HW: 5Q0 937 084 CE
Component: BCM MQBAB M H34 0236
Serial number: 02001703200110
ROD: EV_BCMBOSCH_017.rod
VCID: 7DA7FA9C2D7B63E3395-8028
Subsystem 1 - Part No: 5NC 955 119 Labels: 1KX-955-119.CLB
Component: 326 RL 161214 033 0372
Serial number: 00000001612120463584
Component: RLHS 042 0105
Serial number: S7Y17M02D07H02M24S24
Coding: 00A8DD
Serial number: 000000000ZY170042NPK
Serial number: 00000000000068320510
Part No SW: 3Q0 919 294 A HW: 3Q0 919 294
Component: PDC 8 Kanal H07 0020
Serial number: 001201177478011
Coding: 0071451001
ASAM Dataset: EV_EPHBO18VW3260000 007015
ROD: EV_EPHBO18VW3260000_SK37.rod
VCID: 372B28B44FC789B3A39-8062
Part No SW: 2Q0 907 572 M HW: 2Q0 907 572 B
Component: ACCCONTIMQB H01 0233
Coding: 2A0060C150FF8728749C8145004087
VCID: 3E253D9060FDB8FB60F-806A
Part No SW: 5Q0 959 655 AR HW: 5Q0 959 655 AR
Component: AirbagVW21 003 0317
Serial number: 003TDR2HXP3N
Coding: 98CCC0C00C0000005C5400CF008800000065
VCID: 1079B3280AE97E8BC23-8044
Belt Pretensioner left:
Serial number: 5NC857705C0025R00385
Coding: 80000D
Belt Pretensioner right:
Serial number: 5NC857706C0025R01070
Coding: 80000D
Subsystem 3 - Part No SW: ----------- HW: 480 000 602 17
Serial number: 35700000000AB99D412V
Subsystem 4 - Part No SW: ----------- HW: 480 000 602 17
Serial number: 35800000000B6854012A
Subsystem 5 - Part No SW: ----------- HW: 480 400 602 17
Serial number: 3510001B3247FF95C1DL
Subsystem 6 - Part No SW: ----------- HW: 480 400 602 17
Serial number: 3520001B3247FF96A33D
Subsystem 7 - Part No SW: ----------- HW: 480 400 202 17
Serial number: 3550001A5244A734D7DA
Pedestrian Protection Driver:
Subsystem 8 - Part No SW: ----------- HW: 480 400 202 17
Component: PedP_Sensor_D 000 6149
Serial number: 2280001AB244A735F48A
Subsystem 9 - Part No SW: ----------- HW: 480 400 202 17
Component: PedP_Sensor_P 000 6149
Serial number: 2290001AB244A735831$
Pedestrian Protection Center:
Subsystem 10 - Part No SW: ----------- HW: 480 400 202 17
Component: PedP_Sensor_C 000 6149
Serial number: 2300001AB244A734A42Y
Subsystem 11 - Part No SW: ----------- HW: 480 000 102 17
Serial number: I0M0000000023DA4112X
Subsystem 12 - Part No SW: ----------- HW: 480 000 102 17
Serial number: I0N00000000E85A4A028
Part No SW: 5Q0 953 521 R HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0235
Revision: FF034034 Serial number: 20170203500085
Coding: 0C00
ROD: EV_SMLSVALEOMQB.rod
VCID: 41DF466C1103C7031DD-8014
Part No SW: 5NA 920 951 A HW: 5NA 920 951 A
Component: KOMBI 309 8311
Coding: 27A400006380060001886B031401000000000000
VCID: 3FDB409467F7B1F36B9-806A
Part No SW: 3Q0 907 530 C HW: 3Q0 907 530 C
Component: GW MQB High 418 4286
Revision: -------- Serial number: 0005888040
Coding: 030500045F087300FB07224C0A0F00010001050000000000000000000000
ROD: EV_GatewNF_VW37.rod
VCID: 2F3B10D4B7974173FB9-807A
Subsystem 2 - Part No SW: 5TA 959 442 A HW: 5TA 959 442 A Labels: 3C8-959-537.CLB
Serial number: 0371704185000444AO2B
Coding: 280000
Subsystem 3 - Part No SW: 5QA 915 181 D HW: 5QA 915 181 D
Serial number: 9059452904
Serial number: HA1-00010.01.17
Coding: 0101
VCID: 4ACD61402C35045BCC7-801E
Component: TSG FS 020 0041
Serial number: 211016EJL21975
Coding: 00310220D001048000001000
VCID: 43D34C640B1FD5130F1-8016
Subsystem 1 - Part No SW: 5Q0 959 812 A HW: 5Q0 959 812 A Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000013227000
Coding: 0D0000
Component: EPS_MQB_ZFLS 128 1072
Coding: 9107
ROD: EV_SteerAssisMQB_013.rod
VCID: 45D7527C052BEB23215-8010
Component: TSG BFS 020 0041
Serial number: 060117EA518352
Coding: 00310020DE01048000001000
VCID: 42DD49601405DC1B047-8016
Subsystem 1 - Part No SW: 5Q0 959 811 A HW: 5Q0 959 811 A Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000013045639
Coding: 050000
Part No SW: 3Q0 035 874 B HW: 3Q0 035 874 B
Component: MU-S-ND-ER 840 0751
Coding: 02730601FF00000051110101008808001F0100C601200100CF
ROD: EV_MUStd4CDELP_VW37.rod
VCID: 313F16ACA1A35783EDD-8064
Subsystem 1 - Part No SW: 5G0 919 606 HW: 5G0 919 606
Component: ABT_High H63 0032
Serial number: VWZ8Z9SKL072UT
Subsystem 2 - Part No SW: 5NA 919 866 AG HW: -----------
Component: ECE AS 2020 --- 1310
Part No SW: 3Q0 980 654 G HW: 3Q0 980 654
Component: MQB_B_MFK H06 0231
Serial number: 06021712K10174
Coding: 0003070600000401000213448050A90084000E000020
VCID: 3B23348473EFADD3471-806E
End----------(Elapsed Time: 01:24, VBatt start/end: 12.7V/13.3V)-----------
Tuesday,01,December,2020,10:53:59:41168
VCDS Version: Release 20.4.2 (x64) Running on Windows 8.1 x64
Address 08: Auto HVAC Labels: 3V0-907-044.clb
Control Module Part Number: 5NA 907 044 M HW: 5NA 907 044 M
Component and/or Version: AC Automat H35 4301
Software Coding: 0012010420211001110510000010102A
Work Shop Code: WSC 01357 011 00200
ASAM Dataset: EV_ACClimaPrehVW37X 002023 (VW37)
Reset counter: 114
Mileage: 61659 km
Date: 2020.12.01
Time: 10:53:03
downtime
Finland
C?ID=280813
Change it. Not an expensive part. I have 2017 Tiguan as well and I had the same failure. Clearing the DTC made it go away for a few days and then it came back.
Not sure if RHD car is a mirror image of LHD on fresh air box as well but on LHD car the sensor change was a 10 minute job. The fresh air duct is under the wiper cover. You just need to take out two clips in front of the plastic cover and then lift the cover enough to get access to the fresh air box.
invernesspl
C?ID=345478
Looks like they are £54+VAT from TPS. What does it actually do? It doesn't seem to be affecting anything other than coming up as a fault?
Thanks.
downtime
Finland
C?ID=280813
Yes exactly like Uwe writes. My symptoms were air recirculation activated randomly and this caused some really nice fogging effects especially during winter :)
TFSI
Maryland, USA
C?ID=66650
Thanks.
The sensor detects, for example, smoking car exhaust or other fumes, and based on this input as Uwe said the climate controlled system switches the HVAC to recirc mode until such unpleasant smell disappears. Its fault does not actually impact driveability
South Molton, UK
My experience is that the sensor works OK on gasoline exhaust fumes but seems pretty much useless at detecting diesel fumes, so I was really glad that I still had a manual recirc button on my RS4 :thanks:
