Passat B8 rear brake lining (pad) change
markk_33
C?ID=80485 (NRRT)
Hi,
I'm checking to see whether I can use VCDS to do a DIY rear brake pad change on my 2016 VW Passat. I found and followed the guidance for the Golf, here:
http://wiki.ross-tech.com/wiki/index.php/VW_Golf_VII_(5G/AU)_ABS_Brakes
Battery fully charged and with a trickle charger attached, then
[Select]
[03 - ABS Brakes]
[Basic Settings - 04]
Select Start lining change mode
[Go!]
to activate the Basic Setting.
However, when I click GO after selecting "Start lining change mode" I do not hear the calipers operate as expected, and I see the text "Unknown", then "Not Running". No faults get recorded.
I'm using my HEX+CAN interface, which seems to do most stuff on this car except the sunroof. I've coded a Trailer Hitch (towbar) successfully (if anyone needs help with that).
Any ideas?
Mark
Scan output:
Friday,27,November,2020,14:10:00:02280
VCDS Version: 20.4.2.0
Workshop Code: [redacted]
VIN: WVWZZZ3CZHE0[redacted]   License Plate: [redacted]
Mileage: 51933km-32269mi   Repair Order: 0010
Chassis Type  3C-VW48 (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 42 44 52 5F 69 BB BC
          CA
VIN: WVWZZZ3CZHE0[redacted]   Mileage: 51933km-32269miles
CA-Sunroof -- Status: INTERFACE NOT COMPATIBLE
Address 01: Engine (J623-DFCA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 026 FN    HW: 04L 907 309 M
   Component: R4 2.0l TDI   H24 2011
   Revision: B4H24---
   Coding: 011D0012037505083000
   Shop #: WSC 05311 115 00072
   ASAM Dataset: EV_ECM20TDI01104L906026FN 004002
   ROD: EV_ECM20TDI01104L906026FM_004_VW48.rod
   VCID: 7BFE133FF2ED885E46-802E
   Part No SW: 0D9 300 042 F    HW: 02E 927 770 AQ
   Component: DQ250-6F MQB  H54 4901
   Revision: 06354004    Serial number: TFK01606071127
   ROD: EV_TCMDQ250021.rod
   VCID: 1C3C30A317A32F66EF-8048
   Part No SW: 5Q0 614 517 BK    HW: 5Q0 614 517 AH
   Component: ESC           H62 0736
   Revision: 00000000    Serial number: 61726000003886
   Coding: 0FEC928F34220B71477C060941C849F0492CD0E2608292711862F078C20902
   Shop #: WSC 00015 115 08193
   Part No SW: 3Q0 959 435 D    HW: 3Q0 959 435 D
   Component: VWKESSYMQB    026 0811
   Revision: 00026000    Serial number: 0407908957
   Coding: 002F0F0F0F
   Shop #: WSC 05311 115 00302
   ASAM Dataset: EV_KessyHellaMQBAB 004039
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 3B7ED33FB26D485E06-806E
   Part No SW: 5G0 907 044 BP    HW: 5G0 907 044 BP
   Component: Climatronic   H04 1601
   Revision: 00001K10
   Coding: 1212012420211001101550000010182A
   ASAM Dataset: EV_ACClimaBHBVW37X 006142
   VCID: 76E8020BC9CFD53639-8022
   Air quality sensor:
   Part No SW: 5Q0 937 086 BG    HW: 5Q0 937 086 BG
   Component: BCM PQ37BOSCH 032 0222
   Revision: --------    Serial number: 865819061601WZ
   ASAM Dataset: EV_BodyContrModul1UDSBosc 017002
   ROD: EV_BCMBOSCH_017.rod
   VCID: 000464D39B0BEB8613-8054
   Subsystem 1 - Part No SW: 3G2 955 119 A    HW: 3G1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS    160522  043 0607
   Serial number:         160601123947
   Component: RLHS  042 0105
   Serial number: S5Y16M06D24H03M29S46
   Coding: 00A8DD
   Subsystem 3 - Part No SW: 3G0 941 633     HW: 3G0 941 633
   Serial number: 12 03 2016  10000931
   Subsystem 4 - Part No SW: 5Q0 951 172     HW: 5Q0 951 172
   Serial number: 000000000ZY161510TSC
   Component: Sirene, DWA  005 0313
   Serial number: 00000000000035375679
   Part No SW: 5Q0 919 294 L    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0056
   Revision: --------    Serial number: 39331616509945
   Coding: 0071051911
   VCID: 448CA8C3CF9337A677-8010
   Part No SW: 3Q0 907 572 B    HW: 3Q0 907 572 B
   Component: ACC BOSCH MQB H04 0194
   Coding: 3200478A59FFC428949C804D
   ASAM Dataset: EV_ACCBOSCHVW48X 001009
   ROD: EV_ACCBOSCHVW48X.rod
   VCID: 346CF8039F338726C7-8060
   Part No SW: 3Q0 959 655 BA    HW: 3Q0 959 655 BA
   Component: Airbag VW20   013 0195
   Revision: --------    Serial number: 003SSPC35EVK
   Coding: 98FCC0C0000000005C5400CC008800000065
   Shop #: WSC 05311 000 08193
   ROD: EV_AirbaVW20TS6VW48X.rod
   VCID: 7EF81A2BE1FF9D7661-802A
   Belt Pretensioner left:
   Serial number: 3G2857705E0170Q00621
   Coding: 80000D
   Belt Pretensioner right:
   Serial number: 3G2857706E0168Q01476
   Coding: 80000D
   Subsystem 3 - Part No SW: -----------    HW: 454 001 106 16
   Serial number: 3576U000000C8B804B1K
   Subsystem 4 - Part No SW: -----------    HW: 454 001 106 16
   Serial number: 3586U00000027B804B1A
   Subsystem 5 - Part No SW: -----------    HW: 454 801 106 16
   Serial number: 3516R8F21B10B0000005
   Subsystem 6 - Part No SW: -----------    HW: 454 801 306 16
   Serial number: 3526R2055B50B000000$
   Subsystem 7 - Part No SW: -----------    HW: 454 801 206 16
   Serial number: 3556V1C08170B0000004
   Part No SW: 3Q0 953 521 DJ    HW: 5Q0 953 569 A
   Component: Lenks.Modul   075 0195
   Revision: FF033033    Serial number: 20160331501378
   Coding: 0410
   ROD: EV_SMLSVALEOMQB.rod
   Part No SW: 3G0 920 791 B    HW: 3G0 920 791 B
   Component: KOMBI         404 2153
   Coding: 27A409182780260001886B011000000000000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009052
   VCID: 28541C7353FBF3C67B-807C
   Part No SW: 5Q0 907 530 AM    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2265
   Revision: --------    Serial number: 16061610800933
   Coding: 030300045F087300FB00025C1C0F00010001070000000000000000000000
   ROD: EV_GatewConti_013.rod
   VCID: 7CFC1023F7E38F664F-8028
   Component: E221__MFL-DC1  H17 0040
   Serial number: 29160001209720066242
   Coding: 2DFFFF
   Serial number: 75410803001606072193
   Analog clock:
   Subsystem 4 - Part No SW: 3G0 919 204 C    HW: 3G0 919 204 C
   Component: Analoguhr  111 1004
   Serial number: 3105201600010104
   Serial number: 16000135014004
   Coding: 0800000000000000
   ROD: EV_ELVMarquMQBB.rod
   VCID: 71E23117A0A1F20EEC-8024
   Serial number: 160516EEG16954
   Coding: 003F0A20D001028000001000
   VCID: 438EABDFCA9D309E4E-8016
   Component: EPS_MQB_ZFLS  128 1072
   Coding: 8107
   Shop #: WSC 00015 115 00302
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 458AB5C7C4A90EAE60-8010
   Serial number: 110616EFB11938
   Coding: 003F0020DE01028000001000
   VCID: 4280AEDBD587399645-8016
   Part No SW: 3Q0 035 874 B    HW: 3Q0 035 874 B
   Component: MU-S-ND-ER    840 0743
   Coding: 02840201FF00000051110101008808001F0100E601200000CF
   ROD: EV_MUStd4CDELP_VW37.rod
   VCID: 3162F1176021B20EAC-8064
   Subsystem 1 - Part No SW: 3G0 919 605 D    HW: 3G0 919 605 D
   Component: ABT_Std-2_Nav  H43 4064
   Serial number: VWZ6Z9S1740770
   Subsystem 2 - Part No SW: 5NA 919 866 AR    HW: -----------
   Component: ECE AS 20/21  --- 1430
   Part No SW: 5Q0 907 383 E    HW: 5Q0 907 383 B
   Component: Anhaenger     H14 0137
   Revision: 8C001001    Serial number: 0352832862
   Coding: 0100000202000000
   Shop #: WSC 01286 386 08256
   VCID: 3972C937B8517A4E14-806C
   Serial number: 090616EF90302B
   Coding: 000E00200101028000001000
   Serial number: 090616EF903063
Address CA: Sunroof
Interface not compatible.
Please upgrade to a current Ross-Tech interface.
End-------------------------(Elapsed Time: 05:58)--------------------------
Yes, this should work.
Have you cycled the parking brake on and off successfully just before starting this procedure? Try doing it more than once and make sure you end up with the brakes OFF.
