ABS Bleed - Partial?
JonL
C?ID=421417
Hi there, I've just completed an ABS bleed on a MK4 Golf. It all went fine, but then the final screen started "Partial" in the first box and "Venting Ended" in the next, adjacent box.
Does this mean the operation was only partially successful, or is the wording just referring to the fact that it's only a partial bleed and that you need to continue to manually bleed the brakes?
Many thanks for any advice.
Hi and welcome.
There were at least three different generations of ABS used in Mk.4 Golfs. Please please post an Auto-Scan so people can see which one yours has.
JonL
C?ID=421417
I'm so sorry, I hadn't realised that question would still require an Autoscan. Here you go;
Saturday,28,November,2020,17:11:13:39990
VIN: WVWZZZ1JZ2B10XXXX   License Plate:
Mileage: 289630km-179967mi   Repair Order:
          76
VIN: WVWZZZ1JZ2B10xxxx   Mileage: 289630km-179967miles
Address 01: Engine        Labels: 038-906-019-ASZ.lbl
   Part No: 038 906 019 FG
   Component: 1,9l R4 EDC G000SG  1470
   Coding: 00002
   Shop #: WSC 00046
   VCID: 619FAE8BD85069633DD-4B1E
   WVWZZZ1JZ2B101119     VWZ6Z0A3878042
18072 - Control Circuit for PD Injectors
            P1664 - 35-10 - Electrical Malfunction - Intermittent
17978 - Engine Start Blocked by Immobilizer
            P1570 - 35-00 -
18080 - Coolant Fan Control 1
            P1672 - 35-10 - Open or Short to Ground - Intermittent
Readiness: 0 0 X X X
Address 03: ABS Brakes        Labels: 1C0-907-37x-ASR.lbl
   Part No: 1C0 907 379 K
   Component: ASR FRONT MK60      0103
   Coding: 0021505
   Shop #: WSC 00046 615 1234567
   VCID: 323D11C7C836A2FB947-5184
   Part No: 3B2 907 044 C
   Component: CLIMATRONIC     C 2.0.0
   Coding: 11000
   Shop #: WSC 00046
   VCID: 221DE1879DD6327B647-5184
00792 - A/C Pressure Switch (F129)
            35-00 - -
            37-10 - Faulty - Intermittent
            37-00 - Faulty
   Part No: 1C0 909 605 A
   Component: 27 AIRBAG VW51 01   0004
   Coding: 12855
   Shop #: WSC 00046
   VCID: 221DE1879DD6327B647-5160
   Part No: 1J0 920 926 C
   Component: KOMBI+WEGFAHRS. RB8 V15
   Coding: 05414
   Shop #: WSC 00046
   VCID: 2A0D09A7E5E6EA3B2C7-5160
   WVWZZZ1JZ2B10xxxx     VWZ6Z0A3878042
   Part No: 6N0 909 901
   Coding: 00006
   Shop #: WSC 00046
   VCID: 70B9DBCF03BAD0EBA23-5160
   Part No: 1C0 959 799 B
   Component: 1X Komfortgerát HLO 0003
   Coding: 00258
   Shop #: WSC 00046
   VCID: 36352DD7215EBEDBB8F-4B3C
   Subsystem 1 - Part No: 1C2959802A
   Component: 1X Tõrsteuer.FS KLO 0004
   Subsystem 2 - Part No: 1C2959801A
   Component: 1X Tõrsteuer.BF KLO 0004
   Component: 1X Tõrsteuer.HL KLO 0004
   Component: 1X Tõrsteuer.HR KLO 0004
12 Faults Found:
            36-10 - Open Circuit - Intermittent
00913 - Window Regulator Switch; Front Right Driver (E81)
01359 - Internal Central Locking Switch; Passenger Side (E198)
End----------(Elapsed Time: 04:58, VBatt start/end: 12.6V/12.6V)-----------
[CODE]
OK, so a 2002 with an MK60, ASR only, no ESP.
It should not be necessary to bleed this using a scan tool unless the master cylinder has somehow run dry (or been replaced). There's generally no harm in doing it, but most of the bleeding is accomplished using conventional means, where a pressure or vacuum bleeding system is employed.
If it were mine and I got to the point where clean fluid was coming from all four bleed valves, and the pedal feel was good, I would leave it alone.
JonL
C?ID=421417
Many thanks, yes the master and ABS were dry and so needed the ABS bleed which went fine.
I just wanted to know what the VCDS meant by the word "Partial" as I thought it might be important? Does it mean it somehow deemed the procedure to only have been partially successful, or is it referring to the fact that the ABS bleed is only a partial bleed of the system (as it only bleeds through the front wheels and not the clutch/master cylinder and rear bleed nipples)?
Thanks again.
I don't think that text comes from VCDS. The text you see when doing an ABS bleed Basic Settings on those old module comes directly from the module.
JonL
C?ID=421417
Ok, many thanks for your help Uwe, I'll take it that it wasn't a warning of some sort then.
