Hi.
I hope anyone can help with this.
My car is VW Touran 2016. I would like to fix the window going up/down in reverse order on right rear door.
I replaced the door control module (used one from ebay with the same parts number) on driver rear (right side rear) as the RR door sometimes doesn’t lock earlier this year.
Now the door locks absolutely fine, but the window switch works in wrong way (Press down to shut, Pull up to open) from main one (on drivers door) and the switch on the door.
Other three doors are all fine. I remember right after the replace the module, the window was opened/closed as it should be (as far as I remember).
I didn’t open the window for months, especially, hardly driving during lockdown, so not notice this till now.
I checked the fault code with VCDS, but nothing comes up on the module.
Not sure if I can do this, but tried to access the module on coding/adaptation, but VCDS says ‘the access refused by module’ (or something like that).
So my question is:
So my question is:
- Can this be solved/programmed by VCDS, telling the module to behave the correct way for rear right door?
- Why the access is refused? Does the part has got CP?
