Hello!
I need assistance to diagnose a 2008 VW Polo 1.4L 9N.
The motor is running very rough and VCDS is telling me:
16686 - Cylinder 2
P0302 - 000 - Misfire Detected
Fault Status: 01110000
Fault Priority: 9
Fault Frequency: 0
Reset counter: 0
Date: 2000.01.01
Bin. Bits: 00000000
Load: 32.9 %
Lambda: -16.0 %
Temperature: 79.0°C
Absolute Pres.: 370.0 mbar
RPM: 806 /min
Readiness: 0110 0101
Complete Auto-scan in the end of the post.
The owner has already replaced the spark plugs, the coils and the battery, but no change.
Afterwards we switched coil between no. 2 and 3. No change.
The spark plug will be replaced again as soon as possible, but I actually do not belive the spark plug to be the problem.
So, what should we do? Any measurement blocks I should look at, e.g. fuel injection?
Any suggestions would be highly appreciated.
16686 - Cylinder 2
Fault Priority: 9
Fault Frequency: 0
Reset counter: 0
Date: 2000.01.01
Bin. Bits: 00000000
Load: 32.9 %
Lambda: -16.0 %
Temperature: 79.0°C
RPM: 806 /min
Thursday,26,November,2020,22:55:25:19306
VCDS Version: 20.4.2.0 (x64)
VIN: WVWZZZ9NZ8Y129796 License Plate:
Mileage: 119460km-74229mi Repair Order:
Chassis Type: 9N (9N - VW Polo (2002 > 2010))
Scan: 01 02 03 08 09 15 17 19 25 37 44 45 46 56 76
VIN: WVWZZZ9NZ8Y129796 Mileage: 119460km-74229miles
Address 01: Engine Labels: 03C-906-024-BXW.lbl
Part No SW: 03C 906 024 AD HW: 03C 906 024 F
Component: MARELLI 4HV 0887
Revision: --H05--- Serial number: VWZ7Z0G5930241
Coding: 0000071
Shop #: WSC 00788 785 00200
VCID: 60C55F89B008C98673-513C
16686 - Cylinder 2
Fault Priority: 9
Fault Frequency: 0
Reset counter: 0
Date: 2000.01.01
Bin. Bits: 00000000
Load: 32.9 %
Lambda: -16.0 %
Temperature: 79.0°C
RPM: 806 /min
Address 03: ABS Brakes Labels: 6R0-907-37x-ESP80.clb
Part No SW: 6Q0 907 379 AS HW: 6Q0 907 379 AS
Component: ESP 8.0 front H05 0003
Coding: 0002354
VCID: 0E1951311A1C0FF691-5120
Address 08: Auto HVAC Labels: 6Q0-907-044.lbl
Part No: 6Q0 907 044 E
Component: CLIMAtronic PQ24 3805
VCID: 346DE3D954700526C7-513C
Address 09: Cent. Elect. Labels:. 6Qx-937-049-C.lbl
Part No: 6Q1 937 049 F
Component: 0009 BN-SG. 2S36
Coding: 25774
Shop #: WSC 00788
VCID: 3E79C1F13A3CDF7621-513C
01598 - Drive Battery Voltage
Part No: 1C0 909 605 K
Component: 1G AIRBAG VW51 0T 0010
Coding: 12615
Shop #: WSC 00788
VCID: 2C5DFBB9DC405DE69F-513C
Address 17: Instruments Labels: 6Q0-920-xxx-17.lbl
Part No: 6Q0 920 803 T
Component: KOMBIINSTRUMENT VDO V06
Coding: 01146
VCID: 4183BA0D4BC2A08E5C-515A
Part No: 6N0 909 901
Component: 01K1 GATEWAY CAN 2S36
Coding: 00014
Shop #: WSC 00788
VCID: 70E52FC930E87906E3-515A
Address 25: Immobilizer Labels: 5J0-920-xxx-25.clb
Component: IMMOBILIZER VDO V06
Coding: 01146
VCID: 4183BA0D4BC2A08E5C-513C
WVWZZZ9NZ8Y129796 VWZ7Z0G5930241
Address 44: Steering Assist Labels: 6Q0-423-156.clb
Part No: 6Q0 423 156 AB
Component: LenkhilfeTRW V270
Coding: 10140
Shop #: WSC 00788
VCID: 6FE72CB52DD666FEFA-515A
Address 46: Central Conv. Labels:. 6Q0-959-433.clb
Part No: 6Q0 959 433 E
Component: 3F Komfortgerát 0002
Coding: 00019
Shop #: WSC 00788
VCID: 3D7BC6FD373AC46E38-4B00
Part No SW: 6Q0 035 152 E HW: 6Q0 035 152 E
Component: Radio DE2 0003
Revision: 00001000 Serial number: VWZ4Z4G9030610
Coding: 0040400
VCID: 2C5DFBB98C405DE69F-513C
00856 - Radio Antenna
End-------------------------(Elapsed Time: 03:10)--------------------------
