- Mar 6, 2019
- 41
- 10
- London, United Kingdom
- C?ID=314050
Hi Everyone,
Wondering if anyone can assist me with a tweak I would like to disable (Engine cuts out when I open drivers door) feature on a clients Audi A6 4G
I have managed to find / locate one for Audi A4 8K But not sure if this will work on A6 4G Model
1. Select STG 46 (comfort system)
2. STG Long Coding -> Function 07
3. Byte 11
4. Disable bit 2
5. Byte 15
6. Disable bit 0
7. Disable bit 1
8. Disable bit 2
9. Disable bit 3
10. Select STG 05 (access and start authorization)
11. STG Long Coding -> Function 07
12. Byte 1
13. Disable bit 5
3. Byte 11
4. Disable bit 2
5. Byte 15
6. Disable bit 0
7. Disable bit 1
8. Disable bit 2
9. Disable bit 3
12. Byte 1
13. Disable bit 5
Friday,21,August,2020,20:32:12:42869
VIN: WAUZZZ4G3FN033351 License Plate:
Chassis Type: 4G-AU57 (4G8)
Scan: 01 02 03 05 08 09 15 16 17 19 28 30 36 3B 42 44 46 52 53 55
5F 62 6D 72 82 AC
VIN: WAUZZZ4G3FN033351 Mileage: 128920km-80107miles
Address 01: Engine (J623-CRTE) Labels: Redir Fail!
Part No SW: 4G2 907 311 C HW: 4G2 907 401
Component: 3.0TDI EDC17 H33 0007
Revision: 92H33---
Coding: 1A254012042601030800
Shop #: WSC 21493 002 1048576
ASAM Dataset: EV_ECM30TDI0114G2907311C 001007
ROD: EV_ECM30TDI011_AU57.rod
VCID: 25160036756B7173015-8070
21583 - Loss of Crankshaft Synchronization
P191A 00 [096] - -
Part No SW: 4G0 927 166 A HW: 0B5 927 156 K
Component: 0B5 30 TDIRdW H03 0007
Revision: --H03---
Coding: 100001
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_TCMDL501021 001021
ROD: EV_TCMDL501021.rod
VCID: 2B02F60E138F4703D71-807E
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V2.clb
Part No SW: 4G0 907 379 Q HW: 4G0 907 379 Q
Component: ESP9 Premium H01 0420
Coding: 17A69E43E86579C29B00
ASAM Dataset: EV_ESP9BOSCHAU57X 003019
ROD: EV_ESP9BOSCHAU57X_003.rod
VCID: 3FDAB25EF7F7CBA36B9-806A
Part No SW: 4H0 907 064 FN HW: 4H0 907 064 EN
Component: BCM2 2.0 H36 0551
Coding: 01BA704E000000000000
VCID: 7AAC034AACD52E8B1C7-802E
Serial number: 3214000112425013
Part No SW: 4G0 820 043 CD HW: 4G0 820 043 CD
Serial number: 29101400041348
Coding: 36231178310000
VCID: 63925E2E3BDFCF432F1-8036
0557 - A/C clutch
B1488 15 [009] - Open or Short to Plus
Reset counter: 249
Mileage: 128415 km
Date: 2020.08.11
Time: 16:47:18
Voltage terminal 30: 13.37 V
A/C clutch-Remaining run time for play protection: 0.0 s
A/C clutch-Status: On
A/C clutch-Supply voltage: 13.2 V
A/C clutch-Current power consumption: 0.500 A
Part No SW: 4H0 907 063 DH HW: 4H0 907 063 AH
Component: BCM1 2.0 H20 0311
Revision: 15020001 Serial number: 00000932505002
Coding: 0105C01540349FE00101408380001800CF9DC30A27080201000008146110150200400024030000
VCID: 71BE2466F1A36DD3ADD-8024
Subsystem 1 - Part No SW: 4G2 955 119 HW: 4G8 955 119 A Labels: 1KX-955-119.CLB
Component: WWS57X 140919 H37 0080
Serial number: 141008201212
Coding: 0045F7
Component: G397_RLFS H06 0002
Serial number: 23373403
Coding: 02006E
Subsystem 3 - Part No SW: 4G0 941 531 BG HW: 4G0 941 531 BG
Component: E1 - LDS H07 0044
Serial number: 28 10 2014 00000154
Serial number: 64B80657000000000001
Revision: -------- Serial number: 003P10023W3Q
Coding: 30333046313230313039554A305234473853
VCID: 3B22C64EE3EFD783471-806E
Serial number: 3575HRB404R2RDNS98SX
Serial number: 3585HRB40632R6CS6GES
Serial number: 3515JRB400O52Q3299Q9
Serial number: 3525JRB406532020M8QL
Serial number: 3554VRB400C52RD87978
Serial number: 3564VRB400M52QVAFA2%
Part No SW: 4G0 953 568 A HW: 4G0 953 568 A
Component: Lenks.Modul H05 0201
Revision: 00000000 Serial number: 20141023000298
Coding: 000034
VCID: 3038E1623A2924DBE23-8064
Subsystem 1 - Part No SW: 4G0 951 528 A HW: 4G0 951 528 A
Part No SW: 4G8 920 985 L HW: 4G8 920 985 L
Component: TDieGb H07 0043
Revision: 03001036 Serial number: 658211014592005
Coding: 33A702020B432600010100
ASAM Dataset: EV_RBD4K 004048
ROD: EV_RBD4K_AU57.rod
VCID: 40D8B1A28A09B45B123-8014
Part No SW: 4G8 907 468 HW: 4G8 907 468
Revision: -------- Serial number: 00000001608467
Coding: C0CD078118
VCID: 75B61076854B41F3715-8020
Serial number: 5765244703
Voltage stabilizer:
Subsystem 2 - Part No SW: 8K0 959 663 F HW: 8K0 959 663
Component: J532_DCDCStab H23 0021
Serial number: 140811000000000005B5
Part No SW: 4G0 919 158 Q HW: 4G0 919 158 Q
Component: KLIMA FOND H08 0112
Serial number: 25101400040162
Coding: 22
VCID: 3D26C856FDFBD9B3795-8068
Address 30: Special Function II (J843) Labels: 8K0-907-440.clb
Part No SW: 4H0 907 440 HW: 4H0 907 440
Component: STS H06 0030
Revision: S0H06000 Serial number: 00000000071258
Coding: 01010101000000000001000202
VCID: 64905D323E51C87BD6B-8030
Component: MEM-FS H03 0157
Revision: AA000000 Serial number: 00000121935014
Coding: 0078130000006001000001010101102030303232203232
VCID: 77AA1A7E9FC733E3639-8022
Part No SW: 4G0 907 637 H HW: 4G0 907 637 D
Component: SARA 3D H04 0056
Revision: -------- Serial number: EJ1BPA720D847Z
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2.rod
VCID: 3332EE6ECBBF1FC39F1-8066
Part No SW: 4G8 959 793 J HW: 4G8 959 793 G
Component: TSG FA H03 0507
Coding: 011C56034E21620002080402
VCID: 47CAAABEAFA78363D39-8012
02123 - Door Warning Light / Entry Light
Fault Status: 00101100
Fault Frequency: 21
Reset counter: 45
Mileage: 126217 km
Date: 2020.07.21
Time: 13:37:00
Part No SW: 4G0 909 144 M HW: 4G0 909 144 G
Component: RCEPS H41 0011
Revision: 00001000 Serial number: 0016104615
Coding: 101000010001
ASAM Dataset: EV_RCEPS 009010
ROD: EV_RCEPS_009.rod
Revision: 00002001 Serial number: 0349794091
Coding: 013F0622A0B9B800C3200A0400010D470000000000000000000000000000
Subsystem 1 - Part No: 4G0 951 177
Component: DWA-Sensor H01 0010
Subsystem 3 - Part No SW: 4G8 959 252 HW: 4G8 959 252
Component: HSP-SG H11 0029
Serial number: WA109256000009942054
Component: TSG BF H03 0507
VCID: 46D4A7BAA8AD9A6B28F-8012
Reset counter: 15
Mileage: 126217 km
Date: 2020.07.21
Time: 13:45:14
Component: EPB-4 H04 0015
Revision: -------- Serial number: 00000001246123
ROD: EV_ParkiBrake_VW51.rod
VCID: 2D06F8162D9B4933C95-8078
Part No SW: 4H4 907 357 D HW: 7P6 907 357 B
Component: MxB-ECU 001 0081
Coding: 05FE02102A230200
ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005003
Coding: E02000
Coding: E02000
Address 5F: Information Electr. (J794) Labels:* 4G1-035-MIB-HGH2.clb
Part No SW: 4G1 035 021 G HW: 4G1 035 021
Component: MU-H-LND-EU 040 0910
Serial number: A588J0EB000557
Coding: 01750301FF0A000013111101000A00132F000CE7F1700100DF
VCID: 1E642FDA503DA2AB40F-804A
Subsystem 1 - Part No SW: V03 959 801 FD HW: -----------
Component: ECE 2017/2018 --- 0161
Subsystem 2 - Part No SW: 4G1 919 605 HW: 4G1 919 605
Component: DU8 C7 SV H42 0007
Serial number: AUZ8Z9EL80065A
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 4G2 919 610 F HW: 4G2 919 610 F
Serial number: 90349NJH000KN
Compact Disc Database:
Component: Gracenote2 --- 1012
B201A 00 [009] - -
Reset counter: 8
Mileage: 128920 km
Date: 2020.08.21
Time: 20:00:26
Voltage terminal 30: 12.0 V
Status_Software_Version_Management-module_name: MKBD_FC7/KBD
2565 - GPS Antenna
B1054 13 [008] - Open Circuit
[GPS aerial - open circuit]
Reset counter: 48
Mileage: 128920 km
Date: 2020.08.21
Time: 20:00:07
Component: TSG HL H03 0507
Coding: 010814024021620002080002
VCID: 49CEAC86B9B37513C5D-801C
Part No SW: 4G8 959 107 S HW: 4G8 959 107 H
Component: HDSG-Modul H14 0049
Revision: 11014001 Serial number: 295400914
Coding: 0A3305C002
ASAM Dataset: EV_HDSGAu573 001022
ROD: EV_HDSGAu571.rod
VCID: 45D6A0B6952B9173215-8010
Component: TSG HR H03 0507
Address 82: Heads Up Display (J898) Labels:* None
Part No SW: 4G8 919 604 N HW: 4G8 919 604 N
Component: HeadUpDisplay H07 0304
Coding: A20000
ASAM Dataset: EV_HUDContiC7 001025
ROD: EV_HUDContiC7.rod
VCID: 3E24CF5AF0FDC2AB60F-806A
Part No SW: 4G0 907 355 C HW: 4G0 907 355 B
Component: SCR-Stg-G2 H10 0010
Revision: 00000000 Serial number: 142821102
ROD: EV_RDCMA00100.rod
End----(Elapsed Time: 01:55, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
