Abs coding lost MK60EC1
MezTech
Trinidad and Tobago
C?ID=380032
Hello another car came into the shop yesterday the customer attempted to change the abs pump for whatever reason then decided to reinstall the original pump now he has lost his coding and did not record his original coding as he doesn't have a vaggy (ross tech interface) here is the auto scan thanks
Friday,27,November,2020,11:07:20:62939
VCDS Version: 20.4.2.0 (x64)
VIN: WVWZZZ16ZEM064144      License Plate:
Chassis Type: 16 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 2E 42 44 46 4F 52 56 62 72
Address 01: Engine (J623-CAXA)       Labels: 03C-906-016-CAX2.clb
   Part No SW: 03C 906 016 BT    HW: 03C 907 309 F
   Component: MED17.5.5     H13 7805
   Revision: LCH13---    Serial number: 00000000000000
   Coding: 00250012000400000000
   Shop #: WSC 22345 002 1048576
   ASAM Dataset: EV_ECM14TFS01103C906016BT 001010
   ROD: EV_ECM14TFS01103C906016BT.rod
   VCID: 63CF94406A933C9E6E-8036
4649 - Brake Booster Pressure Sensor
          P0555 00 [175] - Electrical Malfunction
                    Mileage: 53847 km
                    Date: 2072.14.11
                    Time: 06:01:27
Readiness: 1110 0101
Address 02: Auto Trans        Labels: 0AM-300-04x.lbl
   Part No SW: 0AM 300 054 A    HW: 0AM 927 769 D
   Component: GSG DSG AG7     431 3643
   Revision: 00043014    Serial number: CU501403175065
   Coding: 0000024
   Shop #: WSC 66565 257 00032
   VCID: 3E79053469B1317621-806A
   Part No SW: 1K0 907 379 BS    HW: 1K0 907 379 BS
   Component: ESP MK60EC1   H46 0166
   Revision: 00H46001
   Coding: 0000000000000000000000000000000000000000
   Shop #: WSC 30603 001 1048576
   VCID: 7BFFCC20FA23E45E46-802E
03306 - Coding Not Valid
                    Reset counter: 224
                    Mileage: 53847 km
                    Date: 2008.14.12
                    Time: 09:28:30
                    Count: 3
                    Count: 14
                    Count: 24576
                    Count: 4161
                    Count: 44544
                    Count: 512
                    Reset counter: 224
                    Mileage: 53847 km
                    Count: 3
                    Count: 14
                    Count: 12288
                    Count: 195
                    Count: 46336
                    Count: 508
                    Fault Status: 01100101
                    Reset counter: 224
                    Mileage: 53847 km
                    Date: 2008.14.12
                    Time: 07:20:02
                    Count: 3
                    Count: 14
                    Count: 12288
                    Count: 212
                    Count: 50176
                    Count: 512
                    Reset counter: 224
                    Mileage: 53847 km
                    Date: 2008.14.12
                    Time: 07:20:02
                    Count: 3
                    Count: 14
                    Count: 12288
                    Count: 295
                    Count: 50176
                    Count: 512
00150 - Plausibility Brake Booster System
                    Reset counter: 224
                    Mileage: 53847 km
                    Date: 2008.14.12
                    Time: 07:20:03
                    Count: 3
                    Count: 14
                    Count: 12288
                    Count: 398
                    Count: 49920
                    Count: 256
   Part No SW: 3AA 907 044 BP    HW: 3AA 907 044 BP
   Component: Climatronic   H05 0505
   Revision: 00001K02
   Coding: 001001A002
   Shop #: WSC 00066 790 00191
   ROD: EV_ClimaAutoBasis_SE36.rod
   VCID: 7F073830E63BF87E6A-802A
9473137 - Motor for Left Temperature Flap
          B108C 71 [008] - Actuator stuck
                    Reset counter: 6
                    Mileage: 53841 km
                    Date: 2072.14.10
                    Time: 22:51:45
   Part No SW: 5K0 937 086 Q    HW: 5K0 937 086 Q
   Component: BCM PQ35 M    122 0173
   Revision: BC122001
   Coding: 20000A3A982D00C440880080140081640371008870A089205CC000000040
   Shop #: WSC 00066 000 00000
   VCID: 3B7F0C20BAA3245E06-806E
   Component: RLS 110414 05  54  0403
   Coding: 02300A
   Part No SW: 5C0 959 655 C    HW: 5C0 959 655 C
   Component: AirbagVW10    014 0613
   Serial number: 003G6M0DU1MR
   Coding: 00003241
   Shop #: WSC 00066 790 00017
   ROD: EV_AirbaVW10SMEVW360_VW01.rod
   VCID: 3261210465E9E516D5-8066
   Serial number: 3572MSME0D764844ZZZ$
   Serial number: 3582MSME2B363944ZZZ-
   Serial number: 3516KSME5B075C2CZZZ0
   Serial number: 3526KSME274C672CZZZ%
13635840 - Supply voltage
                    Reset counter: 7
                    Mileage: 53847 km
                    Date: 2072.14.11
                    Time: 04:52:28
Address 16: Steering wheel
   Part No SW: 5C6 920 873     HW: 5C6 920 873
   Coding: 171F00
   Shop #: WSC 00066 000 00120
   ROD: EV_Kombi_UDS_VDD_RM09_SE35.rod
   VCID: 69D3866888BF66CEA4-803C
12656896 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Fault Frequency: 12
                    Reset counter: 0
                    Mileage: 53759 km
                    Date: 2069.14.19
                    Time: 00:49:07
   Part No SW: 7N0 907 530 AK    HW: 7N0 907 530 AK
   Component: J533  Gateway H57 1642
   Revision:   H57       Serial number: 07061403001285
   Coding: 351003
   VCID: 3875132C8B950F46EB-806C
                    Fault Status: 00110100
                    Fault Frequency: 12
                    Reset counter: 0
                    Mileage: 53759 km
                    Date: 2005.14.19
                    Time: 00:49:09
   ROD: EV_Immo_UDS_VDD_RM09_VN35.rod
   VCID: 6AD1F9648DB96DD6AD-803E
   Part No SW: 561 959 701 A    HW: 3C0 959 793 C
   Component: TUER-SG FT    002 0515
   Revision: 12110009    Serial number: 0008544040
   Coding: 0016B7
   Shop #: WSC 01383 790 50316
   ROD: EV_TSGFPQ35BRFVW46X.rod
   VCID: 5BBFACA052E3045E26-800E
   Slave Driver:
   Subsystem 1 - Part No SW: 3C0 959 704 B    HW: 3C0 959 794 C  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  009 1508
   Serial number: 00000008710982
   Coding: 000690
67074 - Motors for Central Locking
          B122B 01 [008] - Electrical Failure
                    Fault Frequency: 23
                    Reset counter: 5
67330 - Switch for Central Locking
          B122D 29 [008] - Signal Implausible
                    Fault Frequency: 30
                    Reset counter: 5
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 68     3501
   Revision: 00H22000
   Shop #: WSC 02069 000 90108
   VCID: 346D271C57FDEB26C7-8060
                    Fault Frequency: 41
                    Reset counter: 0
                    Mileage: 53759 km
                    Date: 2005.14.19
                    Time: 00:56:58
                    Voltage: 13.88 V
                        DU
                    Temperature: 34.0°C
                    RPM: 749 /min
                    Speed: 50.0 km/h
                    Speed: 50.0 km/h
                    Fault Status: 00101101
                    Reset counter: 0
                    Mileage: 53759 km
                    Date: 2005.14.19
                    Time: 00:49:31
                    Voltage: 12.38 V
                        DU
                    Temperature: 33.0°C
                    Speed: 50.0 km/h
                    Speed: 50.0 km/h
   Part No SW: 561 959 702 A    HW: 3C0 959 792 C
   Component: TUER-SG BT    002 0515
   Revision: 14110009    Serial number: 0008454026
   Coding: 0017B6
   ROD: EV_TSGBPQ35BRFVW46X.rod
   VCID: 5CBDAFBC57ED03662F-8008
   Slave Passenger:
   Subsystem 1 - Part No SW: 3C0 959 703 B    HW: 3C0 959 795 C  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  009 1508
   Serial number: 00000008755074
   Coding: 000690
132610 - Motors for Rear Central Locking
          B122C 01 [008] - Electrical Failure
                    Reset counter: 2
132866 - Switch for Rear Central Locking
          B122E 29 [008] - Signal Implausible
                    Reset counter: 2
   Part No SW: 1K0 035 186 AN    HW: 1K0 035 186 AN
   Component: RCD310 EU     H06 5007
   Revision: -----10S    Serial number: VWZ4Z2P1370623
   Coding: 05000400040006
   VCID: 234FD44022137C9E2E-8076
03138 - Input AUX IN
                    Reset counter: 221
                    Mileage: 53841 km
                    Date: 2008.14.10
                    Time: 06:06:52
