- Nov 9, 2019
- 40
- 12
- Trinidad and Tobago
- C?ID=380032
Hello everyone i'm attempting to change the abs module on a customers vehicle to cure a abs issue now I did not install the replacement pump in the car I just disconnected the connector from the original and jacked it in then tried the coding before going through the work of disconnecting brake lines and bleeding the system anyways I get error 12 sub function not supported or invalid format when I use the coding from the original module in the replacement module which part number is 1K0 907 379 BM do I have to have a matching part number for the coding to work? original part number and coding 1K0 907 379 BJ / A63B60F8212800FB651406E5841A0080210000
Friday,27,November,2020,21:52:29:50820
VCDS Version: 20.4.2.0 (x64)
VIN: WVWZZZ16ZCM061911 License Plate:
Chassis Type: 16-VW32 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 2E 42 44 46 4F 52 56 62 72
77
VIN: WVWZZZ16ZCM061911 Mileage: 234340km-145612miles
42-Door Elect, Driver -- Status: Malfunction 1010
52-Door Elect, Pass. -- Status: Malfunction 1010
62-Door, Rear Left -- Status: Sporadic communication error 1000
72-Door, Rear Right -- Status: Sporadic communication error 1000
Address 01: Engine (J623-CAVD) Labels:. 03C-907-309-V1.clb
Part No SW: 03C 906 027 BC HW: 03C 907 309 J
Component: 1.4l R4/4V TS H04 1083
Revision: LGH04--- Serial number: 00000000000000
Coding: 00250012002400000000
Shop #: WSC 00066 000 00186
ASAM Dataset: EV_ECM14TSI01103C906027BC 001002
ROD: EV_ECM14TSI01103C906027BD.rod
VCID: 63CF94406A933C9E6E-8036
7 Faults Found:
14627 - Fuel Pump Control Module
P025A 00 [167] - Electrical Fault
Mileage: 234348 km
Date: 2020.11.26
Time: 20:42:55
Engine speed: 742.50 /min
Vehicle speed: 123 km/h
Coolant temperature: 55 °C
Intake air temperature: 60 °C
Ambient air pressure: 530 mbar
Voltage terminal 30: 6.513 V
4608 - Fuel Pressure Regulator Valve (N276)
P2294 00 [101] - Open Circuit
Mileage: 234348 km
Date: 2020.11.26
Time: 20:42:53
Engine speed: 1078.00 /min
Coolant temperature: 56 °C
Ambient air pressure: 470 mbar
Voltage terminal 30: 43.889 V
4660 - Please Check Fault Codes in Control Module for ABS Brakes
U1017 00 [036] - -
Mileage: 234348 km
Date: 2020.11.26
Time: 20:50:18
Engine speed: 0.00 /min
Vehicle speed: 119 km/h
Coolant temperature: 54 °C
Voltage terminal 30: 55.921 V
4674 - Please Check Fault Codes in Control Module for ABS Brakes
U1017 00 [032] - -
Mileage: 234290 km
Date: 2020.11.26
Time: 15:41:26
Engine speed: 1884.50 /min
Normed load value: 22.7 %
Vehicle speed: 128 km/h
Coolant temperature: 48 °C
Ambient air pressure: 520 mbar
Voltage terminal 30: 54.129 V
4675 - Please Check Fault Codes in Control Module for ABS Brakes
U1017 00 [047] - -
Mileage: 234270 km
Date: 2020.11.26
Time: 14:41:04
Vehicle speed: 120 km/h
2985 - Solenoid Valve for Boost Pressure Control (N75)
P0243 00 [101] - Malfunction
Mileage: 234348 km
Date: 2020.11.26
Time: 23:29:53
Engine speed: 310.50 /min
Vehicle speed: 80 km/h
Coolant temperature: 33 °C
Intake air temperature: 61 °C
Ambient air pressure: 420 mbar
Voltage terminal 30: 40.049 V
4270 - Turbocharger Bypass Valve Control Circuit
P0033 00 [101] - Malfunction / Open Circuit
Mileage: 234348 km
Date: 2020.11.26
Time: 23:29:53
Readiness: 0000 0101
Address 02: Auto Trans Labels: 0AM-927-769.clb
Part No SW: 0AM 300 058 P HW: 0AM 927 769 D
Component: GSG DSG AG7 431 4542
Revision: 00043014 Serial number: CU501511096650
Shop #: WSC 04940 001 00001
VCID: 3E79053469B1317621-806A
006279 - Wheel-Speed Signal from ABS Control Module
P1887 - 000 - Implausible Signal
Reset counter: 10
Mileage: 234348 km
Date: 2015.04.19
Time: 21:27:45
Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
Component: ESP MK60EC1 H31 0121
Revision: 00H31001
Coding: A63B60F8212800FB651406E5841A0080210000
Shop #: WSC 00066 000 00000
VCID: 7BFFCC20FA23E45E46-802E
Reset counter: 98
Mileage: 234274 km
Date: 2015.04.19
Time: 15:06:40
Count: 7
Count: 12288
Count: 65
Count: 49154
Count: 254
Count: 55
Fault Status: 00100011
Reset counter: 98
Mileage: 234290 km
Date: 2015.04.19
Time: 15:41:25
Count: 7
Count: 4096
Count: 67
Count: 49153
Count: 54
Fault Status: 00101110
Reset counter: 58
Mileage: 234243 km
Date: 2015.04.19
Time: 02:05:28
Count: 16391
Count: 12288
Count: 104
Count: 50433
Count: 1
Count: 242
Count: 3146
Reset counter: 58
Mileage: 234307 km
Date: 2015.04.19
Time: 16:54:07
Count: 7
Count: 14
Count: 28672
Count: 128
Count: 36608
Count: 512
Count: 50
01130 - ABS Operation
Fault Status: 01101000
Reset counter: 56
Mileage: 234243 km
Count: 7
Count: 14
Count: 28672
Count: 121
Count: 43264
Count: 6
Count: 51
Fault Status: 01101100
Reset counter: 58
Mileage: 234270 km
Date: 2015.04.19
Time: 14:41:05
Count: 7
Count: 14
Count: 28672
Count: 64
Count: 44032
Count: 65280
Count: 65277
Count: 54
Part No SW: 5K0 907 044 ER HW: 5K0 907 044 ER
Component: Climatronic H18 1112
Revision: 00001004
Coding: 0000004002
Shop #: WSC 00066 000 00119
ROD: EV_ClimaAutoBasis_VW32.rod
VCID: 7F073830E63BF87E6A-802A
13701408 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Reset counter: 96
13701456 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Reset counter: 96
13701488 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Reset counter: 84
Mileage: 233355 km
Date: 2020.11.13
Time: 00:53:19
13701504 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Reset counter: 84
Mileage: 233355 km
Date: 2020.11.13
Time: 00:53:19
13701520 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Reset counter: 84
Mileage: 233355 km
Date: 2020.11.13
Time: 00:53:19
13701536 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Reset counter: 84
Mileage: 233355 km
Date: 2020.11.13
Time: 00:53:19
Part No SW: 5K0 937 086 J HW: 5K0 937 086 J
Component: BCM PQ35 M 011 0048
Revision: BC011001
Coding: 08000A3A802DE1C040080080000001E403000088508089605C8000000040
VCID: 3B7F0C20BAA3245E06-806E
Subsystem 1 - Part No: 1K8 951 171
Subsystem 2 - Part No: 1K8 951 605 B
Component: LIN BACKUP HO H11 9005
9 Faults Found:
00984 - Left Tail Light (M4)
Fault Status: 00101010
Reset counter: 86
Mileage: 233355 km
Date: 2015.04.09
Time: 19:42:26
Voltage: 13.85 V
Reset counter: 96
Mileage: 234243 km
Date: 2015.04.19
Time: 00:00:02
Voltage: 12.00 V
01259 - Fuel Pump Relay (J17)
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 58
Mileage: 234348 km
Date: 2015.04.19
Time: 20:42:35
Term 15 Off
Voltage: 12.60 V
Fault Status: 00100101
Reset counter: 96
Term 15 Off
Voltage: 12.50 V
Reset counter: 84
Mileage: 233355 km
Date: 2015.04.06
Time: 00:53:22
Voltage: 12.15 V
Reset counter: 84
Mileage: 233355 km
Date: 2015.04.06
Time: 00:53:22
Voltage: 12.15 V
Reset counter: 84
Mileage: 233355 km
Date: 2015.04.06
Time: 00:53:22
Voltage: 12.15 V
Reset counter: 84
Mileage: 233355 km
Date: 2015.04.06
Time: 00:53:22
Voltage: 12.15 V
Fault Status: 01101010
Reset counter: 58
Mileage: 234243 km
Date: 2015.04.19
Time: 01:03:36
Voltage: 11.95 V
Address 10: Park/Steer Assist (J446) Labels:| 1Q0-919-475.clb
Part No SW: 5C6 919 475 HW: 7E0 919 475 A
Component: PARKHILFE 8K H10 0005
Revision: -------- Serial number: 84091124304953
Coding: 108101
ASAM Dataset: EV_EPHVA18VW3610000 001003
ROD: EV_EPHVA18VW3610000.rod
VCID: 71E3EE08A06F9E0EEC-8024
12718592 - Databus
Reset counter: 96
Part No SW: 5C0 959 655 C HW: 5C0 959 655 C
Component: AirbagVW10 013 0613
Serial number: 003G6M0139GX
Coding: 00003241
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 3261210465E9E516D5-8066
Serial number: 3572MSME5D632262ZZZW
Serial number: 3582MSME19142562ZZZO
Subsystem 3 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Serial number: 3516KSME13570611ZZZD
Serial number: 3526KSME306B2F11ZZZT
12670208 - No Communication with Instrument Cluster
U0155 00 [008] - -
Reset counter: 96
12666368 - No Communication with Diagnostic Gateway
U0146 00 [008] - -
Reset counter: 96
12674816 - Immobilizer Control Module
U0167 00 [008] - No Communications
Reset counter: 96
Part No SW: 1K5 953 521 AK HW: 5K0 953 569 B
Component: LENKS.MODUL 014 0140
Revision: FF010040 Serial number: 20110724300902
Coding: 088A140000
ROD: EV_SMLSNGVOLWS.rod
VCID: 76E9DD14C901B93639-8022
Subsystem 1 - Part No SW: 5K0 959 542 A HW: 5K0 959 542 A Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H09 0013
Coding: 820000
332564 - Databus
Reset counter: 96
Part No SW: 5C6 920 871 HW: 5C6 920 871
Component: KOMBI H04 0617
Coding: 171A00
VCID: 69D3866888BF66CEA4-803C
9453074 - Fuel Level Sensor 1
B103E 1B [009] - Resistance Too High
Reset counter: 58
Mileage: 234348 km
Date: 2020.11.26
Time: 20:42:53
12604928 - Combination / Chassis CAN Bus (SAE Bus D)
U0056 00 [008] - Performance
Reset counter: 96
Part No SW: 7N0 907 530 K HW: 1K0 907 951
Component: J533 Gateway H40 1620
Revision: H40 Serial number: 10101101291445
Coding: 351003
VCID: 3875132C8B950F46EB-806C
Fault Status: 00110100
Reset counter: 84
Mileage: 233355 km
Date: 2015.04.06
Time: 00:53:23
Reset counter: 84
Mileage: 233355 km
Date: 2015.04.06
Time: 00:53:23
Reset counter: 84
Mileage: 233355 km
Date: 2015.04.06
Time: 00:53:23
Reset counter: 84
Mileage: 233355 km
Date: 2015.04.06
Time: 00:53:23
Component: IMMO H04 0617
VCID: 6AD1F9648DB96DD6AD-803E
Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
Revision: A1001003 Serial number: 7660698868
VCID: 2953C668403FA6CE64-807C
Reset counter: 96
Component: TUER-SG FT 002 0516
Revision: 13110009 Serial number: 0003436494
Coding: 0002B5
Shop #: WSC 01383 790 50316
VCID: 5BBFACA052E3045E26-800E
Slave Driver:
Subsystem 1 - Part No SW: 3C0 959 704 B HW: 3C0 959 794 C Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 006 1508
Serial number: 00000006075222
Coding: 000290
B11EC 54 [008] - Missing Calibration / Basic Setting
Reset counter: 98
67074 - Motors for Central Locking
B122B 01 [008] - Electrical Failure
Fault Frequency: 84
Reset counter: 98
67330 - Switch for Central Locking
B122D 29 [008] - Signal Implausible
Fault Frequency: 13
Reset counter: 98
Mileage: 229174 km
Date: 2020.09.22
Time: 11:16:46
131584 - Motor for Rear Window Regulator
B11EE 54 [008] - Missing Calibration / Basic Setting
Reset counter: 97
Part No: 1K0 909 144 M
Component: EPS_ZFLS Kl. 69 3201
Revision: 00H20000
Shop #: WSC 02069 000 90108
VCID: 346D271C57FDEB26C7-8060
Fault Status: 00101101
Fault Frequency: 9
Reset counter: 98
Mileage: 234348 km
Date: 2015.04.19
Time: 21:03:34
Voltage: 12.25 V
DD
Temperature: 48.0°C
Reset counter: 96
Voltage: 12.00 V
DD
Temperature: 27.0°C
RPM: 110 /min
Part No SW: 7N0 907 532 HW: 1K0 907 951
Component: EZE_2 H40 1620
Coding: 01030100
VCID: 6FE7E870BE5B88FEFA-803A
Subsystem 1 - Part No SW: 5K0 959 591 HW: 5K0 959 591
Component: J245 PS41.022 H09 0007
Serial number: WRH0003BREP
Coding: 180000
Component: TUER-SG BT 002 0516
Revision: 15110009 Serial number: 0003440760
Coding: 0002B4
VCID: 5CBDAFBC57ED03662F-8008
Slave Passenger:
Subsystem 1 - Part No SW: 3C0 959 703 B HW: 3C0 959 795 C Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 006 1508
Serial number: 00000006082849
Coding: 000290
Reset counter: 85
Mileage: 232693 km
Date: 2020.11.01
Time: 17:17:45
Fault Frequency: 18
Reset counter: 87
Mileage: 229174 km
Date: 2020.09.22
Time: 12:00:38
Address 56: Radio (J0503) Labels:. 5M0-035-1xx-56.clb
Part No SW: 5K0 035 190 A HW: 5K0 035 190 A
Component: Radio RCD510 050 0207
Revision: 00000001 Serial number: VWZ1Z3L1631824
Coding: 01000410040006
VCID: 234FD44022137C9E2E-8076
Reset counter: 43
Mileage: 233355 km
Date: 2015.04.06
Time: 00:53:32
00877 - Treble Speaker Rear Right (R16)
Reset counter: 43
Mileage: 233355 km
Date: 2015.04.06
Time: 00:53:32
00856 - Radio Antenna
Reset counter: 58
Mileage: 233355 km
Date: 2015.04.06
Time: 01:17:10
Part No SW: 7P6 035 730 F HW: 7P6 035 730 F
Component: TELEFON H09 2902
Revision: 1B001001 Serial number: 00007660681642
Coding: 0A00000000010100
ASAM Dataset: EV_UHVNA A01719
ROD: UHVNA.rod
VCID: 356B1A189487F22EF0-8060
End-------------------------(Elapsed Time: 03:27)--------------------------
