Hello!
I retrofit my audi TT 8S to cruise control. I generate swap code and unlock function, code ecu 01 and 16 . I need change coding abs, can somebody help me ?
this is coding from another TT
32AA108D0A9915AF40990067C299930EC44C0850A8020043C97023
32AA108D0A9915B14194006DC298970ED04C0850A8820043E9700B
32AA608D0A9915AE4096006AC2998306444C0650A8020043C16022
i think byte 5 is responsible for cruise control but to change it i need change another byte, i think byte 16 is responspible for this . soory for my english, i bee very happy if can help me
this is my full scan . Thanks
Friday,27,November,2020,01:33:52:29124
VCDS Version: 20.4.2.0 HEX-V2 CB: 0.4513.4
VIN: TRUZZZFV5J1010237 License Plate:
Mileage: 58104km-36104mi Repair Order:
Chassis Type: FV-AU37 (8S0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 42 44 52 55 5F A5
VIN: TRUZZZFV5J1010237 Mileage: 58104km-36104miles
Address 01: Engine (J623-CHHC) Labels:. 06K-907-425-V1.clb
Part No SW: 8S0 906 259 K HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0001
Revision: --H13---
Coding: 0A1D00324424050B3002
Shop #: WSC 06385 790 00016
ASAM Dataset: EV_ECM20TFS0208S0906259K 001002
ROD: EV_ECM20TFS0208S0906259K.rod
VCID: 45D45BBA9526FA63215-8010
17178 - Databus
U1123 00 [047] - Received Error Message
Fault Frequency: 52
Mileage: 57957 km
Date: 2020.11.21
Time: 14:45:51
Engine speed: 2990.00 /min
Normed load value: 44.3 %
Coolant temperature: 53 °C
Intake air temperature: 37 °C
Voltage terminal 30: 12.421 V
Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration: No
Drivetrain coordinator: ACC fault status-ACC active: although TSK passive: No
Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set: No
Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously: No
Drivetrain coordinator: ACC fault status-ACC active: although limiter active: No
Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking: No
Drivetrain coordinator: ACC fault status-ACC sends undefined signals: No
Drivetrain coordinator: ACC fault status-ACC active although main switch off: No
Drivetrain coordinator: ACC fault status-ACC is active despite driver braking: No
Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling: No
Drivetrain coordinator: brake fault status-ESP system error: No
SEG_AD_MMV_ER_L[3]: 6.5308 ‰
Part No SW: 0D9 300 043 E HW: 02E 927 770 AS
Component: DQ250-6F MQB H54 5201
Revision: 06454104 Serial number: TFK01711300306
Shop #: WSC 04742 780 00200
ROD: EV_TCMDQ250021.rod
VCID: 1C62DEDE462CDBABAEB-8048
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 8S0 907 379 L HW: 8S0 907 379 F
Component: ESC H42 0535
Revision: 00000000 Serial number: 63397000000322
Coding: 32AA208D0A9A15A941930067C298830EB34C0450A8820043C170CD
ASAM Dataset: EV_Brake1UDSContiMK100IPB 060017
ROD: EV_Brake1UDSContiMK100IPB_060.rod
VCID: 4ACE6886BC38151BCC7-801E
4161 - Coding invalid
U10DA 00 [008] - -
[mismatch between VIN on CAN and VIN in coding word]
Reset counter: 135
Mileage: 58024 km
Date: 2020.11.25
Time: 13:40:27
8314 - Check Coding of ECUs on Powertrain Data Bus
P1647 00 [009] - -
[FCAN: Coding of ESP and TSK does not fit together]
Fault Frequency: 29
Reset counter: 99
Mileage: 58024 km
Date: 2020.11.25
Time: 13:40:01
16401 - Tire Pressure Warning
C102D 00 [008] - -
Reset counter: 136
Mileage: 58033 km
Date: 2020.11.25
Time: 20:04:28
Part No SW: 3Q0 959 435 G HW: 3Q0 959 435 G
Component: VWKESSYMQB 037 0907
Revision: 00037000 Serial number: 0466530209
Coding: 030C0C1720
ROD: EV_KessyHellaMQBAB.rod
VCID: 3E263456F0F0A9BB60F-806A
Address 08: Auto HVAC (E87) Labels:* None
Part No SW: 8S0 820 043 HW: 8S0 820 043
Component: AC Automat H05 0040
Revision: 20010000 Serial number: 18080000009000
Coding: 400040000011001000
ASAM Dataset: EV_AirCondiVAPrehAU33x 003011
ROD: EV_AirCondiVAPrehAU33x.rod
VCID: 6C82CE1ED60CEB2B9EB-8038
Subsystem 1 - Part No SW: 4H0 907 658 B HW: 4H0 907 658 B
Component: AQ_Hum_Sensor H02 0007
Serial number: 7550590900PAG0MUFU03
Operating and display unit 2 for air conditioning:
Subsystem 2 - Part No SW: 8S0 820 359 A HW: 8S0 820 359 A
Component: E775 BuA_2 H07 0020
Serial number: 00000000000000024877
Operating and display unit 3 for air conditioning:
Subsystem 3 - Part No SW: 8S0 820 359 HW: 8S0 820 359
Component: E776 BuA_3 H07 0020
Operating and display unit 4 for air conditioning:
Subsystem 4 - Part No SW: 8S0 820 359 B HW: 8S0 820 359 B
Component: E777 BuA_4 H07 0020
Part No SW: 5Q0 937 084 CP HW: 5Q0 937 084 CF
Component: BCM MQBAB M+ H36 0253
Serial number: 01001800802317
ROD: EV_BCMBOSCH_018.rod
VCID: 084A928EE2B4270B1A3-805C
Subsystem 1 - Part No SW: 8S1 955 119 B HW: 8K1 955 119 B Labels: 5QX-955-119-V1.CLB
Component: 43x LL 171122 038 0371
Serial number: 00000001711200302781
Coding: 1BC7F7
Component: G397_RLFS H06 0004
Serial number: 63176840
Coding: 00005D
Subsystem 3 - Part No SW: 8V0 941 531 AA HW: 8V0 941 531 AA
Serial number: 19 09 2017 00001869
Address 10: Park/Steer Assist (J446) Labels:| 5Q0-919-283.clb
Part No SW: 5Q0 919 283 F HW: 5Q0 919 283
Component: PARKHILFE 4K H10 0054
Revision: -------- Serial number: 39261734204015
Coding: 0000040011
VCID: 3C223E5EE6ECBBAB4EB-8068
13637426 - Databus
Fault Frequency: 11
Reset counter: 135
Mileage: 58001 km
Date: 2020.11.24
Time: 18:41:18
Part No SW: 5Q0 959 655 P HW: 5Q0 959 655 P
Component: AirbagVW20 010 0870
Serial number: 003M7R02BP9K
Coding: 88CCF0000C8000005C5000CFC04800000065
ROD: EV_AirbaVW20SMEVW37X_VW48.rod
VCID: 4DC4639A4D560223E95-8018
Subsystem 1 - Part No SW: ----------- HW: 480 001 001 18
Serial number: 3570000000088C753B2S
Subsystem 2 - Part No SW: ----------- HW: 480 001 001 18
Serial number: 35800000000699610B2H
Subsystem 3 - Part No SW: ----------- HW: 480 010 901 18
Component: SideSensor_Dr 005 0108
Serial number: 351001A09F966262BF1G
Subsystem 4 - Part No SW: ----------- HW: 480 402 411 17
Serial number: 3550002B1252D876015X
Front Sensor Passenger:
Subsystem 5 - Part No SW: ----------- HW: 480 402 411 17
Component: FrontSensor_P 001 6149
Serial number: 3560002BD252D8725097
Pedestrian Protection Center:
Subsystem 6 - Part No SW: ----------- HW: 480 402 010 15
Component: PedP_Sensor_C 001 6149
Serial number: 2300002BF1D25F85E1EP
Subsystem 7 - Part No SW: ----------- HW: 480 001 312 17
Serial number: I0M000000001A06D6820
Subsystem 8 - Part No SW: ----------- HW: 480 001 312 17
Serial number: I0N000000000906D682%
Part No SW: 8S0 907 129 AL HW: 8S0 907 129 AL
Component: Lenks. Modul H07 0150
Revision: -------- Serial number: 91335PE300397
Coding: 281C
ASAM Dataset: EV_SMLSKLOMQB 050001
ROD: EV_SMLSKLOMQB_009_SE37.rod
VCID: 045286BEDE9C036B76B-8050
Address 17: Instruments (J285) Labels:* Redir Fail!-SRI2
Part No SW: 8S0 920 790 C HW: 8S0 920 790 C
Component: FBenRDW H42 0325
Coding: 04A50140698000080500E8C09000800000000000
ASAM Dataset: EV_DashBoardBOSCHAU33X 001027
ROD: EV_DashBoardBOSCHAU33X.rod
VCID: 392C274AE9DE8E8355D-806C
Part No SW: 8S0 907 468 G HW: 8S0 907 468 E
Component: GW MQB TT3 022 0323
Serial number: 04011810803133
Coding: 030100042F025A004B000268080B00000000000000000000000000000001
Shop #: WSC 00046 000 00000
ASAM Dataset: EV_GatewContiAU33X 013005
ROD: EV_GatewContiAU33X_013.rod
VCID: 44D246BE9E1CC36B36B-8010
Subsystem 2 - Part No SW: 8S0 951 523 C HW: 8S0 951 523 C
Component: J453 MFL H07 0002
Serial number: 20171219013529 00073
Subsystem 3 - Part No SW: 8W0 915 181 HW: 8W0 915 181
Serial number: 0940176204
8978688 - Authentication of a Function
B2018 00 [009] - Failed
Reset counter: 86
Mileage: 57957 km
Date: 2020.11.21
Time: 14:48:57
Supply voltage: Terminal 30: 12.1 V
Terminal 15: On
Component: TSG FS 020 0041
Serial number: 031217EL137528
Coding: 001E53225C00040100001402
VCID: 43D045A29B12C4530F1-8016
Part No SW: 3Q0 909 144 L HW: 3Q0 909 144 L
Component: EPS_MQB_ZFLS 507 5081
Coding: 111F0000
ROD: EV_SteerAssisMQB_015.rod
VCID: 3B203D42E3E2BC93471-806E
Component: TSG BFS 020 0041
Serial number: 021217EKU25851
Coding: 001E53225E00040100001402
VCID: 42DE40A68408CD5B047-8016
Address 55: Headlight Range (J431) Labels:| 5Q0-907-357.clb
Part No SW: 5Q0 907 357 HW: 6R0 907 357 A
Component: LWR-ECU 005 0080
Coding: 039A000001000000
VCID: 75B4EB7A85462AE3715-8020
Address 5F: Information Electr. (J794) Labels:* Redir Fail!
Part No SW: 8S0 035 043 J HW: 8S0 035 043 E
Component: MU-H-N-EU 054 1133
Serial number: A713A0JS009558
Coding: 01330401FF00000011110001000A00002F0000E100700000DE
ASAM Dataset: EV_MUHig4CGen2HBAS 001115
VCID: 3432167ECEBC73EB86B-8060
Subsystem 1 - Part No SW: V03 959 802 DE HW: -----------
Component: ECE 2019 --- 0172
Multimedia Operating Unit:
Subsystem 2 - Part No SW: 8S0 919 614 M HW: 8S0 919 614 M
Component: ControlUnit_H H30 0206
Serial number: APVAK118101700010119
Compact Disc Database:
Component: Gracenote2 --- 1016
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 5Q0-980-653.clb
Part No SW: 5Q0 980 653 G HW: 5Q0 980 653
Component: MQB_MFK H07 0060
Serial number: 10000640087
Coding: 0100000001010305000401000000000100
ROD: EV_MFKBoschAU370.rod
End----------(Elapsed Time: 01:13, VBatt start/end: 12.0V/12.0V)-----------
