Audi tt 8S cruise control retrofit
osart123
Poland
C?ID=123885
Hello!
I retrofit my audi TT 8S to cruise control. I generate swap code and unlock function, code ecu 01 and 16 . I need change coding abs, can somebody help me ?
this is coding from another TT
32AA108D0A9915AF40990067C299930EC44C0850A8020043C97023
32AA108D0A9915B14194006DC298970ED04C0850A8820043E9700B
32AA608D0A9915AE4096006AC2998306444C0650A8020043C16022
i think byte 5 is responsible for cruise control but to change it i need change another byte, i think byte 16 is responspible for this . soory for my english, i bee very happy if can help me
this is my full scan . Thanks
Friday,27,November,2020,01:33:52:29124
VCDS Version: 20.4.2.0  HEX-V2 CB: 0.4513.4
VIN: TRUZZZFV5J1010237   License Plate:
Mileage: 58104km-36104mi   Repair Order:
Chassis Type: FV-AU37 (8S0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 42 44 52 55 5F A5
VIN: TRUZZZFV5J1010237   Mileage: 58104km-36104miles
Address 01: Engine (J623-CHHC)       Labels:. 06K-907-425-V1.clb
   Part No SW: 8S0 906 259 K    HW: 06K 907 425 B
   Component: 2.0l R4 TFSI  H13 0001
   Revision: --H13---
   Coding: 0A1D00324424050B3002
   Shop #: WSC 06385 790 00016
   ASAM Dataset: EV_ECM20TFS0208S0906259K 001002
   ROD: EV_ECM20TFS0208S0906259K.rod
   VCID: 45D45BBA9526FA63215-8010
17178 - Databus
          U1123 00 [047] - Received Error Message
                    Fault Frequency: 52
                    Mileage: 57957 km
                    Date: 2020.11.21
                    Time: 14:45:51
                    Engine speed: 2990.00 /min
                    Normed load value: 44.3 %
                    Coolant temperature: 53 °C
                    Intake air temperature: 37 °C
                    Voltage terminal 30: 12.421 V
                    Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration: No
                    Drivetrain coordinator: ACC fault status-ACC active: although TSK passive: No
                    Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set: No
                    Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously: No
                    Drivetrain coordinator: ACC fault status-ACC active: although limiter active: No
                    Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking: No
                    Drivetrain coordinator: ACC fault status-ACC sends undefined signals: No
                    Drivetrain coordinator: ACC fault status-ACC active although main switch off: No
                    Drivetrain coordinator: ACC fault status-ACC is active despite driver braking: No
                    Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling: No
                    Drivetrain coordinator: brake fault status-ESP system error: No
                    SEG_AD_MMV_ER_L[3]: 6.5308 ‰
   Part No SW: 0D9 300 043 E    HW: 02E 927 770 AS
   Component: DQ250-6F MQB  H54 5201
   Revision: 06454104    Serial number: TFK01711300306
   Shop #: WSC 04742 780 00200
   ROD: EV_TCMDQ250021.rod
   VCID: 1C62DEDE462CDBABAEB-8048
   Part No SW: 8S0 907 379 L    HW: 8S0 907 379 F
   Component: ESC           H42 0535
   Revision: 00000000    Serial number: 63397000000322
   Coding: 32AA208D0A9A15A941930067C298830EB34C0450A8820043C170CD
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 060017
   ROD: EV_Brake1UDSContiMK100IPB_060.rod
   VCID: 4ACE6886BC38151BCC7-801E
4161 - Coding invalid
          U10DA 00 [008] - -
          [mismatch between VIN on CAN and VIN in coding word]
                    Reset counter: 135
                    Mileage: 58024 km
                    Date: 2020.11.25
                    Time: 13:40:27
8314 - Check Coding of ECUs on Powertrain Data Bus
          P1647 00 [009] - -
          [FCAN: Coding of ESP and TSK does not fit together]
                    Fault Frequency: 29
                    Reset counter: 99
                    Mileage: 58024 km
                    Date: 2020.11.25
                    Time: 13:40:01
16401 - Tire Pressure Warning
          C102D 00 [008] - -
                    Reset counter: 136
                    Mileage: 58033 km
                    Date: 2020.11.25
                    Time: 20:04:28
   Part No SW: 3Q0 959 435 G    HW: 3Q0 959 435 G
   Component: VWKESSYMQB    037 0907
   Revision: 00037000    Serial number: 0466530209
   Coding: 030C0C1720
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 3E263456F0F0A9BB60F-806A
   Part No SW: 8S0 820 043     HW: 8S0 820 043
   Component: AC Automat    H05 0040
   Revision: 20010000    Serial number: 18080000009000
   Coding: 400040000011001000
   ASAM Dataset: EV_AirCondiVAPrehAU33x 003011
   ROD: EV_AirCondiVAPrehAU33x.rod
   VCID: 6C82CE1ED60CEB2B9EB-8038
   Subsystem 1 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
   Serial number: 7550590900PAG0MUFU03
   Operating and display unit 2 for air conditioning:
   Subsystem 2 - Part No SW: 8S0 820 359 A    HW: 8S0 820 359 A
   Component: E775 BuA_2  H07 0020
   Serial number: 00000000000000024877
   Operating and display unit 3 for air conditioning:
   Subsystem 3 - Part No SW: 8S0 820 359     HW: 8S0 820 359
   Component: E776 BuA_3  H07 0020
   Operating and display unit 4 for air conditioning:
   Subsystem 4 - Part No SW: 8S0 820 359 B    HW: 8S0 820 359 B
   Component: E777 BuA_4  H07 0020
   Part No SW: 5Q0 937 084 CP    HW: 5Q0 937 084 CF
   Component: BCM MQBAB M+  H36 0253
   Serial number: 01001800802317
   ROD: EV_BCMBOSCH_018.rod
   VCID: 084A928EE2B4270B1A3-805C
   Subsystem 1 - Part No SW: 8S1 955 119 B    HW: 8K1 955 119 B  Labels: 5QX-955-119-V1.CLB
   Component: 43x LL 171122  038 0371
   Serial number: 00000001711200302781
   Coding: 1BC7F7
   Serial number: 63176840
   Coding: 00005D
   Serial number: 19 09 2017  00001869
   Part No SW: 5Q0 919 283 F    HW: 5Q0 919 283
   Component: PARKHILFE 4K  H10 0054
   Revision: --------    Serial number: 39261734204015
   Coding: 0000040011
   VCID: 3C223E5EE6ECBBAB4EB-8068
13637426 - Databus
                    Fault Frequency: 11
                    Reset counter: 135
                    Mileage: 58001 km
                    Date: 2020.11.24
                    Time: 18:41:18
   Part No SW: 5Q0 959 655 P    HW: 5Q0 959 655 P
   Component: AirbagVW20    010 0870
   Serial number: 003M7R02BP9K
   Coding: 88CCF0000C8000005C5000CFC04800000065
   ROD: EV_AirbaVW20SMEVW37X_VW48.rod
   VCID: 4DC4639A4D560223E95-8018
   Subsystem 1 - Part No SW: -----------    HW: 480 001 001 18
   Serial number: 3570000000088C753B2S
   Subsystem 2 - Part No SW: -----------    HW: 480 001 001 18
   Serial number: 35800000000699610B2H
   Subsystem 3 - Part No SW: -----------    HW: 480 010 901 18
   Component: SideSensor_Dr  005 0108
   Serial number: 351001A09F966262BF1G
   Subsystem 4 - Part No SW: -----------    HW: 480 402 411 17
   Serial number: 3550002B1252D876015X
   Front Sensor Passenger:
   Subsystem 5 - Part No SW: -----------    HW: 480 402 411 17
   Serial number: 3560002BD252D8725097
   Pedestrian Protection Center:
   Subsystem 6 - Part No SW: -----------    HW: 480 402 010 15
   Component: PedP_Sensor_C  001 6149
   Serial number: 2300002BF1D25F85E1EP
   Subsystem 7 - Part No SW: -----------    HW: 480 001 312 17
   Serial number: I0M000000001A06D6820
   Subsystem 8 - Part No SW: -----------    HW: 480 001 312 17
   Serial number: I0N000000000906D682%
   Part No SW: 8S0 907 129 AL    HW: 8S0 907 129 AL
   Component: Lenks. Modul  H07 0150
   Revision: --------    Serial number: 91335PE300397
   Coding: 281C
   ASAM Dataset: EV_SMLSKLOMQB 050001
   ROD: EV_SMLSKLOMQB_009_SE37.rod
   VCID: 045286BEDE9C036B76B-8050
   Part No SW: 8S0 920 790 C    HW: 8S0 920 790 C
   Component: FBenRDW       H42 0325
   Coding: 04A50140698000080500E8C09000800000000000
   ASAM Dataset: EV_DashBoardBOSCHAU33X 001027
   ROD: EV_DashBoardBOSCHAU33X.rod
   VCID: 392C274AE9DE8E8355D-806C
   Part No SW: 8S0 907 468 G    HW: 8S0 907 468 E
   Component: GW MQB TT3    022 0323
   Serial number: 04011810803133
   Coding: 030100042F025A004B000268080B00000000000000000000000000000001
   Shop #: WSC 00046 000 00000
   ASAM Dataset: EV_GatewContiAU33X 013005
   ROD: EV_GatewContiAU33X_013.rod
   VCID: 44D246BE9E1CC36B36B-8010
   Subsystem 2 - Part No SW: 8S0 951 523 C    HW: 8S0 951 523 C
   Component: J453 MFL  H07 0002
   Serial number: 20171219013529 00073
   Subsystem 3 - Part No SW: 8W0 915 181     HW: 8W0 915 181
   Serial number: 0940176204
8978688 - Authentication of a Function
          B2018 00 [009] - Failed
                    Reset counter: 86
                    Mileage: 57957 km
                    Date: 2020.11.21
                    Time: 14:48:57
                    Supply voltage: Terminal 30: 12.1 V
                    Terminal 15: On
   Serial number: 031217EL137528
   Coding: 001E53225C00040100001402
   VCID: 43D045A29B12C4530F1-8016
   Part No SW: 3Q0 909 144 L    HW: 3Q0 909 144 L
   Component: EPS_MQB_ZFLS  507 5081
   Coding: 111F0000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 3B203D42E3E2BC93471-806E
   Serial number: 021217EKU25851
   Coding: 001E53225E00040100001402
   VCID: 42DE40A68408CD5B047-8016
   Coding: 039A000001000000
   VCID: 75B4EB7A85462AE3715-8020
   Part No SW: 8S0 035 043 J    HW: 8S0 035 043 E
   Component: MU-H-N-EU     054 1133
   Serial number: A713A0JS009558
   Coding: 01330401FF00000011110001000A00002F0000E100700000DE
   ASAM Dataset: EV_MUHig4CGen2HBAS 001115
   VCID: 3432167ECEBC73EB86B-8060
   Subsystem 1 - Part No SW: V03 959 802 DE    HW: -----------
   Component: ECE 2019  --- 0172
   Multimedia Operating Unit:
   Subsystem 2 - Part No SW: 8S0 919 614 M    HW: 8S0 919 614 M
   Component: ControlUnit_H  H30 0206
   Serial number: APVAK118101700010119
   Compact Disc Database:
   Component: Gracenote2  --- 1016
   Part No SW: 5Q0 980 653 G    HW: 5Q0 980 653
   Component: MQB_MFK       H07 0060
   Serial number: 10000640087
   Coding: 0100000001010305000401000000000100
   ROD: EV_MFKBoschAU370.rod
End----------(Elapsed Time: 01:13, VBatt start/end: 12.0V/12.0V)-----------
