Hi guys, I have retrofitted cruise control (new stalks and wiring to ecu). I have done this without issues on 4 other VAG cars, the equipment came from a reputable german ebay company that I have used before, very helpful but the language barrier can confuse things. I have activated the cruise control via the engine controller but there is no response from steering wheel controller. My scan shows many faults as I initially had not properly reconnected the plugs to the central electrics box below the dash, all codes are now gone except: 6117 - Function Restriction due to Implausible Message(s); Cruise Control System (CCS): switch position-STATE_CRU_SWI_POS: 00000010 .
Any help will be much appreciated.
Friday,27,November,2020,10:23:11:13476
VCDS -- Windows Based VAG/VAS Emulator Running on Windows XP x86(VMWare)
VCDS Version 18.9.1.0
VIN: TMBFS25J2C3131273 License Plate: MUMMY
Mileage: 150710km-93646mi Repair Order:
Chassis Type: 5J-SK25 (6N0)
Scan: 01 03 08 09 15 17 19 25 44 56 69
VIN: TMBFS25J2C3131273 Mileage: 150710km-93646miles
Address 01: Engine (J623-CAYA) Labels:. 03L-906-023-CAY.clb
Part No SW: 03L 906 023 NH HW: 03L 906 023 LK
Component: 1,6l R4 CR td H33 8885
Revision: --H33--- Serial number:
Coding: 00114016002500080000
Shop #: WSC 13765 031 00017
ASAM Dataset: EV_ECM16TDI02103L906023NH 003004
ROD: EV_ECM16TDI02103L906023LL.rod
VCID: 79FF8142F8EDF6829A-802D
6056 - No Communications with HVAC Control Module (J301)
U0164 00 [040] - -
Fault Frequency: 17
Mileage: 150688 km
Engine speed: 0.00 /min
Coolant temperature: 6 °C
Intake air temperature: 6 °C
Voltage terminal 30: 10.842 V
Driver request torque-TQI_DRIV_SUB: 0.00 Nm
Control Module temperature-TECU: 5 °C
7430 - No Communication with Diagnostic Gateway
U0146 00 [040] - -
Fault Frequency: 17
Mileage: 150688 km
6070 - No Communication with Diagnostic Gateway
U0146 00 [040] - -
Fault Frequency: 17
Mileage: 150688 km
U1112 00 [037] - -
Mileage: 150688 km
Date: 2020.11.27
Time: 00:10:19
Engine speed: 812.25 /min
Normed load value: 14.1 %
Coolant temperature: 18 °C
Intake air temperature: 7 °C
Voltage terminal 30: 10.616 V
Accelerator position: normalized-Accelerator position: 0.00 %
Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ABS82.clb
Part No SW: 6R0 907 379 S HW: 6R0 907 379 AB
Component: ABS8.2 front H03 0001
Revision: --------
Coding: 400100DB007000B3022700E900D400000000
Shop #: WSC 13765 790 00017
VCID: 4E95029E1DE3813A1F-801B
Fault Frequency: 21
Reset counter: 196
Hex Value: 0x0005
Hex Value: 0x0000
Hex Value: 0x12D4
Hex Value: 0x168B
Hex Value: 0x00FF
Hex Value: 0x007F
Hex Value: 0x7E00
Hex Value: 0x0000
Address 08: Auto HVAC (J301) Labels: 6R0-820-045-9AB.clb
Part No SW: 5J0 820 045 D HW: 5J0 820 045 D
Component: Man AC H02 0202
Revision: 0004SH02
VCID: 26459A3E51D3A97A87-8073
Fault Frequency: 9
Reset counter: 196
00457 - Control Module for Network (J519)
Fault Frequency: 9
Reset counter: 196
Fault Frequency: 8
Reset counter: 196
Address 09: Cent. Elect. (J519) Labels:. 6R0-937-08x-09.clb
Part No SW: 6R7 937 087 K HW: 6R7 937 087 K
Component: PQ25 BCM H27 0532
Revision: -1------ Serial number: 1009009900
Coding: 25980B3808C92400922008002C2B08C00000400F60000000020000000000
VCID: 4C910896EFFFB32A71-FFFF
Subsystem 1 - Part No: 6R0 959 802 M Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 6R 3211
Coding: 030000
Part No SW: 6R0 959 655 K HW: 6R0 959 655 K
Component: VW10AirbagT2C H09 0020
Revision: -------- Serial number: 003GX012V077
Coding: 003243
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 4A9D0E8EED8BAD1A43-801F
Serial number: 3495RRB405514E7CIGNN
Serial number: 3505RRB405114E7C80GL
Part No SW: 5J0 920 911 D HW: 5J0 920 911 D
Component: KOMBI H03 0305
Coding: 420A00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
VCID: 295F910248CD8602AA-807D
12664832 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Reset counter: 196
Part No SW: 6N0 909 901 HW: 6R7 937 087 K
Component: GW-K-CAN TP20 H27 0532
Revision: -1------
Coding: 032300
VCID: 70E9BC66A397B7CA2D-8025
Component: IMMO H03 0305
ROD: EV_Immo_UDS_VDD_RM09.rod
VCID: 6ADDAE0E8D4B4D1A63-803F
Address 44: Steering Assist Labels: 6Q0-423-156.clb
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 10110
Shop #: WSC 13765
VCID: 2F6B7F1AEA29E83274-807B
Part No SW: 5J0 035 161 D HW: 5J0 035 161 D
Component: Radio-SWING 001 0003
Revision: -----04S Serial number: SKZ4Z2M1127228
Coding: 050004000006
VCID: 2343832A22E15C52E0-8077
00856 - Radio Antenna
Reset counter: 141
Mileage: 44223 km
Date: 2015.04.29
Time: 12:01:34
00849 - S-contact at Ignition/Starter Switch (D)
Fault Frequency: 20
Reset counter: 196
Component: Anhaenger H09 0100
Revision: 3A001001 Serial number: 00008030020881
Coding: 410D000100000000
VCID: 30697C666317F7CA6D-8065
Reset counter: 196
Reset counter: 196
End-------------------------(Elapsed Time: 02:34)--------------------------
Address 17: DTCs cleared
Address 01: DTCs cleared
Address 01: Engine Labels: 03L-906-023-CAY.clb
Control Module Part Number: 03L 906 023 NH HW: 03L 906 023 LK
Component and/or Version: 1,6l R4 CR td H33 8885
Software Coding: 00114016002500080000
Work Shop Code: WSC 13765 031 00017
ASAM Dataset: EV_ECM16TDI02103L906023NH 003004 (SK25)
U1112 00 [037] - -
Mileage: 150689 km
Date: 2020.11.27
Time: 00:16:52
Coolant temperature: 35 °C
Intake air temperature: 8 °C
Voltage terminal 30: 11.972 V
Readiness: 1110 1000
U1112 00 [037] - -
Mileage: 150689 km
Date: 2020.11.27
Time: 00:16:52
Address 03: DTCs cleared
Address 09: DTCs cleared
Address 56: DTCs cleared
Address 69: DTCs cleared
Address 08: DTCs cleared
