Golf 7 Retrofit Golf R-Line headlights
distrub
Norway
C?ID=192694
Hello
At first my English is not that good, so bear with me.
My front headlight on my 2013 Golf 7 was hit by a large rock while driving. It left a big hole in it, so it need replacement.
Got my hand on two headlights from a Golf R-line. Almost similar headlights, but these headlights had one extra LED driver ECU.
That’s ok. Mounted the headlights and worked th VCDS.
A little google time, and many had worked tis issues out before me. Some adaptions has to be made and almost everything works.
My car has bi-xenon whit adaptive lights and light assist original, so this is not retrofit of these functions.
Now i can’t get the xenon high beam shutter to work. The high beam light in the instrument cluster lights up, but nothing happens in the headlight.
I haven’t got my hands on any wiring diagram, so I’m not sure if I’m missing any wires. I’m not sur if this is hardware related in any of my ECU. In my head, this high beam signal i sent to the headlight by Can Bus.
I wonder if anyone can point me in the right directions? Is there any adaptions channels i have missed?
Part. Number of the left original headlight: 5G1941043
Part number on one of the R-Line headlight: 5G1941043E
I have changed both headlight.
Morten
Sunday,22,November,2020,17:43:34:44240
VCDS Version: 20.4.2.0 (x64)
VIN: WVWZZZAUZDW014351   License Plate:
Mileage: 155998km-96932mi   Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 18 19 2B 42 44 52 55 5F 69
          A5
VIN: WVWZZZAUZDW014351   Mileage: 155998km-96932miles
Address 01: Engine (J623-CRBC)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 DT    HW: 04L 907 309 D
   Component: R4 2,0L EDC   X21 4943
   Revision: 83X21---
   Coding: 011D001A047405083000
   Shop #: WSC 39309 001 1048576
   ASAM Dataset: EV_ECM20TDI01104L906021DT 002003
   ROD: EV_ECM20TDI01104L906021DT_002.rod
   VCID: 7AFB1CE1FD7389565D-802E
Readiness: 0 0 0 0 X
   Part No SW: 0D9 300 040 A    HW: 02E 927 770 AN
   Component: DQ250-6F MQB  H52 3613
   Revision: 05652103    Serial number: TFK01209041662
   ROD: EV_TCMDQ250021.rod
   VCID: 15212F5DF42D462ED0-8040
          P1734 00 [002] - -
   Part No SW: 5Q0 907 379 AD    HW: 5Q0 907 379 E
   Component: ESC           H75 0537
   Revision: 00000000    Serial number:
   Coding: 01FA62A120210A70037A060501C42980460450C0608094F3F86A5028C1
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 008020
   ROD: EV_Brake1UDSContiMK100IPB_008.rod
   VCID: 7EF310F1E15BA57661-802A
   Part No SW: 5Q0 959 435     HW: 5Q0 959 435
   Component: VWKESSYMQB    021 0500
   Revision: 00021000    Serial number: 0184755210
   Coding: 030C0C
   VCID: 79F903EDF875824E54-802C
   Part No SW: 5G0 907 044 S    HW: 5G0 907 044 S
   Component: Climatronic   H02 0503
   Revision: 00001K06
   Coding: 00020114204101011105000000101000
   ASAM Dataset: EV_ACClimaBHBVW37X 002017
   ROD: EV_ACClimaBHBVW37X_002_VW37.rod
   VCID: 377DC5D58EE1543EE2-8062
   Part No SW: 5Q0 937 084 L    HW: 5Q0 937 084 L
   Component: BCM MQBAB H   H14 0103
   Serial number: 00011228200389
   Coding: 001B1346C24122FB0FA44000001807080C0A000000000000000000000000
   ASAM Dataset: EV_BCMCONTI 010001
   ROD: EV_BCMBOSCH_010.rod
   VCID: 4189AB0DD0251A8E5C-8014
   Component: WWS    120906  042 0551
   Serial number:         120921153254
   Coding: 0E4DD5
   Component: RLFS  024 0042
   Serial number: Y12M10D12H11M41S09S1
   Coding: 00A8DD
   Garage Door Opener Operating Unit:
   Sun Roof:
   Subsystem 5 - Part No SW: 8V3 959 591     HW: 8V3 959 591
   Component: J245 PS73.009  H02 0007
   Serial number:     WOO18359415
   Coding: 181901
534549 - Databus
                    Reset counter: 147
                    Mileage: 155998 km
                    Date: 2020.11.22
                    Time: 17:36:41
   Part No SW: 5Q0 919 294 B    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  002 0026
   Revision: --------    Serial number: 94231228307629
   Coding: 0071151111
   ASAM Dataset: EV_EPHVA18AU3700000 002016
   VCID: 3A7BDCE1BDF349561D-806E
Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-567.clb
   Part No SW: 5Q0 907 567 J    HW: 5Q0 907 567 J
   Component: ACC3          H10 0396
   Serial number: 13021603090613
   Coding: 001E1D00FE0309
   ASAM Dataset: EV_ACCBoschMQB 001023
   ROD: EV_ACCBoschMQB_VW37.rod
   VCID: 428BA401D523019645-8016
   Part No SW: 5Q0 959 655 M    HW: 5Q0 959 655 M
   Component: AirbagVW20    011 0361
   Serial number: 003M1R001CF
   VCID: 4A9B8C21ED13D9D68D-801E
   Belt Pretensioner left:
   Subsystem 1 - Part No SW: 5G0 980 945     HW: 5G0 980 945
   Component: BeltPretRevFL  H07 0022
   Serial number: 34120597B09101240274
   Belt Pretensioner right:
   Subsystem 2 - Part No SW: 5G0 980 946     HW: 5G0 980 946
   Component: BeltPretRevFR  H07 0022
   Serial number: 34120596B08101240632
   Subsystem 3 - Part No SW: -----------    HW: 480 000 810 12
   Serial number: 35767000000C61B8DB04
   Subsystem 4 - Part No SW: -----------    HW: 480 000 810 12
   Serial number: 3586700000062C45EB0/
   Subsystem 5 - Part No SW: -----------    HW: 480 400 910 12
   Serial number: 3516502C10D0E4725374
   Subsystem 6 - Part No SW: -----------    HW: 480 400 910 12
   Serial number: 3526502C10D0E474C36D
   Subsystem 7 - Part No SW: -----------    HW: 480 400 210 12
   Serial number: 3556502A70D19C362227
Address 16: Steering wheel (J527)       Labels:. 5Q0-953-549.clb
   Part No SW: 5Q0 953 507 BM    HW: 5Q0 953 549
   Revision: --------    Serial number: 090912000300K6
   Coding: 0C10
   VCID: 020B640195A3C19605-8056
No ASAM data for: "EV_SMLSKLOMQB" (VW37)
   Part No SW: 5G0 920 870 A    HW: 5G0 920 870 A
   Component: KOMBI         336 0555
   Coding: 03AD01186F8000081D886E03040000
   ASAM Dataset: EV_DashBoardVDDMQBAB 008026
   VCID: 275D15955E41C4BE72-8072
Address 18: Aux. Heat (J364)       Labels:| 5Q0-963-272.clb
   Part No SW: 5Q0 963 272 A    HW: 5Q0 963 272 A
   Component: STH-MQB       005 0066
   Coding: 9309
   ASAM Dataset: EV_AuxilParkiHeateWOS 002012
   VCID: 3467F2D99F97BF26C7-8060
   Subsystem 1 - Part No SW: 5Q0 963 513     HW: 5Q0 963 513
   Component: R149 T91-LIN  003 0301
   Serial number: 00000000000000445923
   Part No SW: 5Q0 907 530 F    HW: 5Q0 907 530 F
   Component: GW MQB High   122 1109
   Revision: --------    Serial number: 0000116511
   Coding: 030100340B087300EF00065E1C0F00010001000000000000000000000000
   ASAM Dataset: EV_GatewLear 006010
   ROD: EV_GatewLear_006.rod
   Component: E221__MFL-DC1  H12 0034
   Serial number: 23120002081880040291
   Coding: 2D0000
   Subsystem 3 - Part No SW: 5Q0 915 181 C    HW: 5Q0 915 181 C
   Component: J367-BDMHella  H03 8042
   Serial number: 7968818201
   Part No SW: 5Q0 905 861     HW: 5Q0 905 861
   Component: ELV-MQBA      H06 0010
   Revision: 00000000    Serial number: 12000140555002
   Coding: 4900000000000000
   ASAM Dataset: EV_ELVMarquMQB 003008
   ROD: EV_ELVMarquMQB_003.rod
   VCID: 73E531C5DA19F81E1E-8026
   Part No SW: 5Q0 959 593 A    HW: 5Q0 959 593
   Component: TSG FS        H12 0006
   Serial number: 05101200010141
   Coding: 003B1220D000040000001000
   VCID: 3F8DADF5A6D16C7E2A-806A
   Subsystem 1 - Part No SW: 5Q4 959 811 A    HW: 5Q4 959 811 A  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000000212568
   Part No SW: 5Q0 909 144 L    HW: 5Q0 909 144 K
   Component: EPS_MQB_ZFLS  119 1021
   Coding: 11
   ROD: EV_SteerAssisMQB_008.rod
   VCID: 3D71D7FDACDD7E6E38-8068
   Part No SW: 5Q0 959 592 A    HW: 5Q0 959 592 A
   Component: TSG BFS       H12 0006
   Serial number: 28091200010259
   Coding: 003B1020DE00040000801000
   VCID: 3E73D0F1A1DB657621-806A
   Subsystem 1 - Part No SW: 5Q4 959 812 A    HW: 5Q4 959 812 A  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000000234906
   Coding: 090000
   Part No SW: 7P6 907 357 A    HW: 7P6 907 357 A
   Coding: 029A00104F000200
   Subsystem 1 - Part No SW: 3D0 941 329 A    HW: 3D0 941 329 A  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H05 0012
   Coding: 900000
   Subsystem 2 - Part No SW: 3D0 941 329 A    HW: 3D0 941 329 A  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H05 0012
   Coding: 900000
   Part No SW: 5G0 035 858     HW: 5G0 035 858
   Component: MU-S-ND-ER    038 0421
   Serial number: V5F01909120057
   Coding: 02730001FF0000001111120100A800001F0100940100010045
   ROD: EV_MUStd4CPASE_VW37.rod
   VCID: 69D953AD88D532CEA4-803C
   Subsystem 1 - Part No SW: 5G0 919 605 D    HW: 5G0 919 605 D
   Component: ABT_Std_Nav  H44 0022
   Serial number: VWZ8Z9M34008KA
   Subsystem 2 - Part No SW: 5G0 919 866     HW: -----------
   Component:  2012/2013  --- 0018
   Part No SW: 5Q0 907 383 A    HW: 5Q0 907 383 A
   Component: Anhaenger     H11 0030
   Revision: 6B001003    Serial number: 00000185448462
   Coding: 0100000200000000
   ASAM Dataset: EV_TrailFunctPivotHella 001001
   ROD: EV_TrailFunctDemouHella.rod
   VCID: 3561CFDD94EDA62EF0-8060
656650 - Bulb for Right Turn Signal on Trailer
          C10F6 15 [137] - Open or Short to Plus
                    Reset counter: 113
                    Mileage: 154566 km
                    Date: 2020.11.02
                    Time: 17:38:37
656906 - Bulb for Left Turn Signal on Trailer
          C10F7 15 [137] - Open or Short to Plus
                    Reset counter: 113
                    Mileage: 154566 km
                    Date: 2020.11.02
                    Time: 17:38:37
   Part No SW: 5Q0 980 653 C    HW: 5Q0 980 653
   Component: MQB_MFK       H04 0032
   Serial number: 00000011417
   Coding: 0100020001020304000400000100000101
   ROD: EV_MFKBoschAU370.rod
   VCID: 387FC6E983FF5B46EB-806C
End-------------------------(Elapsed Time: 05:05)--------------------------
downtime
Finland
C?ID=280813
Please have a look here, almost identical problem to yours:
Our very own Godfather Mr. Don has resolved the issue for the OP :)
distrub
Norway
C?ID=192694
I will have a look. Thanx
distrub
Norway
C?ID=192694
Yea, this thread i have read and tested out. I don’t have these options in my ecu. What I don’t understand is that my bi-xenon light functions before the retrofit. Isn’t my new retrofit headlight bi-xenon as well?
South Molton, UK
Yes, but as you said yourself:
so there are likely to be some pinout differences between the two types of headlight.
distrub
Norway
C?ID=192694
Yes, i can understand that. But like i said, i dont have access to wiring diagram, so if anyone know and can share...
I have the elsawin wiring diagram for golf 7 in PDF format.
Two things:
1) They are copyrighted material.
2) You don't really think that every Golf 7 made has exactly the same wiring, do you?
siLc
Tallinn, Estonia
C?ID=330192
5G1941043 and 5G1941043E are both Xenon DLA headlights, the latter is from the Golf R.
I would look through the reference scans section and find any 2014-2016 Golf R autoscans to compare codings of module 55 to.
Actually what did you change in the first place after installing the new lights? Since the functioning of xenon parts of these lights should be similar, your problem of high beam not functioning could be because of it.
cdr38
France
C?ID=58450
Two things:
The sharing was done privately.
All the useful details are on what I sent to our friend in order to help him ...
distrub
Norway
C?ID=192694
Thanx for yor reply.
I only changed the headlights. The only differens to my old hesdlight is thet the 5G1941043E has on mor LED driver ecu whit partnumber 4G0907697F. I had to alter the adaption valu on the turnlight to make the work properly.
So now everthing is working but not the hugh beam.
cdr38
France
C?ID=58450
your TFL led is powered by 4G0907697F.
Does it work?
if they are R golf headlights you have 2 TFL leds
m87a
Bosnia and Herzegovina
C?ID=156900
in your scan afs modules on the headlights are 3D0 941 329 A which if I remember correctly doesn't support DLA headlights, I'm gonna assume these came with lights? If so you just have to replace these with yours to get high beam, yours are probably 3D0 941 329 D
@distrub: Hi.
Here is a better view of the BCM long-code string from the auto-scan on your first post:
ByteHex    Binary
0    00    00000000
1    1B    00011011
2    13    00010011
3    46    01000110
4    C2    11000010
5    41    01000001
6    22    00100010
7    FB    11111011
8    0F    00001111
9    A4    10100100
10    40    01000000
11    00    00000000
12    00    00000000
13    18    00011000
14    07    00000111
15    08    00001000
16    0C    00001100
17    0A    00001010
18    00    00000000
19    00    00000000
20    00    00000000
21    00    00000000
22    00    00000000
23    00    00000000
24    00    00000000
25    00    00000000
26    00    00000000
27    00    00000000
28    00    00000000
29    00    00000000
At the risk of boring everyone by repeating the stuff in @downtime link (Godfather? - I think not - I definately prefer horse-heads to remain attached to their bodies :D) , the important software switches for DLA headlights for the BCM are on Byte 2, Bits 0-2.
As you can see from the values above, your BCM value for Byte 2 = hex13 - so, Bits 0-2 =hex03. If you look the LCH screen on the @downtime link, you appear to face exactly the same problem as @cdr38 (i.e. he/she also had a BCM where Byte 2, Bits 0-2 =hex03)
So, as a suggestion - try the same solution as in @cdr38 case; change Byte 2, Bits 0-2 to hex 06 . For your BCM, this means that Byte 2 = hex16 after the change.
After making the change, clear the DTCs and see if the problem is solved. If errors persist, and given the similarity between the equipment types in the auto-scans for the 2 x cases - you may need to tell the BCM to NOT control the shutters (i.e. the hex55 module may do this in the new headlight fittings - as in @cdr38 case), So, perhaps @cdr38 solution for Byte 06 might also be worth trying; set Byte 6, Bits 5-6 =hex0. This means that Byte 6=hex02 after the change.
And finally, to complete the disabling of the headlight shutter control by the BCM - the last part of @cdr38 solution is also worth a shot; shut-down the 2 x Leuchte-sets for the Shutters in the BCM
distrub
Norway
C?ID=192694
DLA works fine whit this setup. I moved over all the ecu from my original headlights + the one extra LED ecu.
siLc
Tallinn, Estonia
C?ID=330192
Does it work?
Its fine. WD says the additional LED driver is in the same circuit as the original one, so you should be good.
