We have a caddy that the DPF seems to be regenerating every couple of days, its used for short journeys but we've only had it for about 2 weeks as an approved VW used so its under dealer warranty
My suspicion is there is either a faulty sensor or the DPF is very clogged, I've run a scan along with the MVB's from the DPF can anyone shed any light as the milege since regen seems greater than the mileage on the van?
Thanks in advance
Thanks in advance
Thursday,26,November,2020,19:21:48:17347
VCDS Version: 20.4.2.0 (x64)
VIN: WV1ZZZ2KZGX086300 License Plate: KU16DZH
Address 01: Engine (04L 906 016 HA)
19:21:32
IDE00430-ENG57549 Particle filter: field regeneration request status-Bits 0-7 0
IDE00431-ENG57549 Particle filter: field regeneration lock status-Bits 0-7 0
IDE00432 Particle filter: time since last regeneration 15358 s
IDE00433 Particle filter: oil ash volume 0.06 l
IDE00434 Particle filter: soot mass calculated 18.76 g
IDE00435 Particle filter: soot mass measured 8.38 g
IDE00436 Particle filter: kilometers since last regeneration 132439 m
IDE01407 Particle filter: fuel consumption since last regeneration 7.66 l
IDE03405-ENG57549 Particle filter field regeneration: cancel conditions-Bits 0-7 0
IDE03405-ENG57549 Particle filter field regeneration: cancel conditions-Bits 0-7 2
Chassis Type: 2K-VN35 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 42 44 46 52 5F 61
VIN: WV1ZZZ2KZGX086300 Mileage: 108070km-67151miles
Address 01: Engine (J623-DFSD) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 016 HA HW: 04L 907 309 K
Component: R4 2.0l TDI H20 4646
Revision: 8AH20---
Coding: 011D001204250D090000
Shop #: WSC 00287 210 00000
ASAM Dataset: EV_ECM20TDI01104L906016HA 004004
ROD: EV_ECM20TDI01104L906016GR_004.rod
VCID: 6FEA7222B6DECFFEFA-803A
Part No SW: 02E 300 063 J HW: 02E 927 770 AL
Component: GSG DSG AG6 531 4934
Revision: 06253104 Serial number: 00001512041263
Shop #: WSC 35110 377 00141
VCID: 1D3678EAC4F20D6E18-8048
Address 03: ABS Brakes (J104) Labels: 7E0-907-37x-MK100ESC.clb
Part No SW: 7E0 907 379 P HW: 7E0 907 379 M
Component: ESC H05 0132
Revision: 00000000 Serial number: 43545000001133
Coding: 1079409B926AA48408780276498225E3790000
Shop #: WSC 35110 790 50316
VCID: 3F8AE262A63E7F7E2A-806A
Part No SW: 1K8 907 426 AF HW: 1K8 907 426 AF
Component: AC Manuell H20 0808
Revision: 00001002
Coding: 0010004003
VCID: 77FA4A42CE8E873E22-8022
Part No SW: 5K0 937 086 AA HW: 5K0 937 086 AA
Component: BCM PQ35 M+ 122 0183
Revision: BD122001
Coding: 491A583E8025E16A088800829400016403510008426F8360648087000041
VCID: 73E27E52D2F6EB1E1E-8026
Subsystem 1 - Part No: 2K2 955 119 D Labels: 1KX-955-119.CLB
Component: Wischer 14121 26 0512
Coding: 009795
Subsystem 2 - Part No: 5K7 955 559 B Labels: 5K7-955-559.CLB
Component: RLS 231215 03 37 0059
Coding: 0228DD
Component: Sensor, DWA 0 005 0502
Fault Status: 00101011
Reset counter: 162
Mileage: 107298 km
Date: 2020.11.07
Time: 11:09:30
Term 15 Off
Voltage: 12.30 V
Fault Status: 00100111
Reset counter: 162
Mileage: 107298 km
Date: 2020.11.07
Time: 11:09:30
Term 15 Off
Voltage: 12.30 V
01830 - Bulbs for Fog-Lamps; Rear
Fault Status: 00101010
Reset counter: 162
Mileage: 107298 km
Date: 2020.11.07
Time: 11:14:26
Voltage: 12.05 V
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-283.clb
Part No SW: 1K8 919 465 HW: 5Q0 919 283
Component: PARKHILFE 4K H10 0479
Revision: -------- Serial number: 39291534500153
Coding: 0001050011
ASAM Dataset: EV_EPHVA14VW364GP00 001006
ROD: EV_EPHVA14VW364GP00_VW36.rod
VCID: 76E44746C984FE3639-8022
Part No SW: 2K5 959 655 HW: 2K5 959 655
Component: VW10Airbag019 008 0016
Revision: -------- Serial number: 003QV001AN9H
Coding: 000000000000000000000000000000003139
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 79FE4C7AF89A914E54-802C
Serial number: 3497ARB400O555858J4T
Serial number: 3507ARB405H3PEPG1HFX
Part No SW: 5K0 953 521 FF HW: 5K0 953 569 BB
Component: LENKS.MODUL 018 0230
Revision: FF010042 Serial number: 20151209301576
Coding: 5880160010
ROD: EV_SMLSNGVOLWSR8C.rod
VCID: 75E6404AD482F52E30-8020
Part No SW: 2K5 920 976 A HW: 2K5 920 976 A
Component: KOMBI H04 1009
Coding: 480A001200
ROD: EV_Kombi_UDS_VDD_RM09_005_VW31.rod
VCID: 3460BD4E9F78AC26C7-8060
Part No SW: 7N0 907 530 BE HW: 7N0 907 530 AL
Component: J533 Gateway H58 1674
Revision: H58 Serial number: 091215F1000535
Coding: 357421
Shop #: WSC 00000 288 1392243
VCID: 74E07D4ED7F8EC2607-8020
Component: IMMO H04 1009
VCID: 6ADC63368D3C2AD6AD-803E
Part No SW: 2K5 959 701 HW: 2K5 959 701
Component: Tuer-SG 009 2144
Coding: 0131632
VCID: 71EE745A68EAD90EEC-8024
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 140 3501
Revision: 00H22000
VCID: 397E8C7A701A514E14-806C
Part No SW: 2K5 959 702 HW: 2K5 959 702
Coding: 0131632
VCID: 72EC7B566DECE21615-8026
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-ENT2.clb
Part No SW: 1K8 035 150 E HW: 1K8 035 150 E
Component: MU-E-D-ER 857 6495
Serial number: 09121500013085
Coding: 063307002800000041111101008000001F0000C60000010001
ASAM Dataset: EV_MUEnt4CGen2LGE 001025
ROD: EV_MUEnt4CGen2LGE_VW32.rod
VCID: 275A5A025EAED7BE72-8072
U1014 00 [008] - -
Reset counter: 162
Mileage: 107250 km
Date: 2020.11.05
Time: 14:27:07
Voltage terminal 30: 11.9 V
Part No SW: 7N0 907 534 HW: 7N0 907 530 AL
Component: Batt.regelung H58 1674
Coding: 030F1873
VCID: 71EE745AA8EAD90EEC-8024
Subsystem 1 - Part No SW: 1K0 915 181 K HW: 1K0 915 181 K
Component: J367-BDM H07 0223
Serial number: 42344K45578761258991
End-------------------------(Elapsed Time: 02:41)--------------------------
