- Nov 12, 2016
- 10
- 6
- South Africa
- C?ID=221489
good day
a customer brought his polo in for a abs light that is flashing upon running a scan on the vehicle and finding out more information from the customer
we found the customer has had a accident and repaired the vehicle by changing abs pump and wiring
ran a scan on the vehicle and found the abs has lost its coding and i need assistants in coding the abs module please
kind regards
kind regards
Thursday,26,November,2020,19:26:25:41537
VCDS Version: 20.4.2.0 (x64)
VIN: AAVZZZ6RZAU068275 License Plate:
Mileage: 267330km-166111mi Repair Order:
Chassis Type: 6R-VW25 (6N0)
Scan: 01 03 08 09 15 17 19 25 44 56
VIN: AAVZZZ6RZAU068275 Mileage: 267330km-166111miles
Address 01: Engine (J623-CLSA) Labels: Redir Fail!
Part No SW: 03C 906 014 F HW: 03C 906 014
Component: CLSA-MM7GV H02 7308
Revision: --H02--- Serial number:
Coding: 00110014000400080000
Shop #: WSC 31414 790 31414
VCID: 204902C03061A28633-5178
Readiness: N/A
Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ABS82.clb
Part No SW: 6R0 907 379 AD HW: 6R0 907 379 AB
Component: ABS8.2 front H03 0001
Revision: --------
Coding: 000000000000000000000000000000000000
VCID: 0009624097A1428613-8054
Fault Frequency: 8
Reset counter: 167
Mileage: 267335 km
Date: 2015.04.19
Time: 10:35:49
Hex Value: 0x0005
Hex Value: 0x0000
Hex Value: 0x3013
Hex Value: 0x1487
Hex Value: 0x00FF
Hex Value: 0x007F
Hex Value: 0x7F00
Hex Value: 0x0000
Address 08: Auto HVAC (J301) Labels: 6R0-820-045-9AP.clb
Part No SW: 6R0 820 045 J HW: 6R0 820 045 J
Component: Climatic 25 0660
Revision: 00 11 25
VCID: 3567C3949CE3372EF0-8060
Address 09: Cent. Elect. (J519) Labels:. 6R0-937-08x-09.clb
Part No SW: 6R0 937 087 D HW: 6R0 937 087 D
Component: BCM PQ25 H+4 H46 0207
Revision: BF046001 Serial number: 0147 139100957
Coding: 3DB02BBF08F3240092380000342B0CD00040410F60040000200000000000
VCID: 3E75DCB8A9D5F47621-806A
Subsystem 1 - Part No SW: 6R0 959 802 R HW: 6R0 959 802 R Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 006 0903
Serial number: KU0-KU005.05.1014265
Coding: 18BC30
Subsystem 2 - Part No SW: 6R0 959 801 T HW: 6R0 959 801 T Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 006 0902
Serial number: KU0-KU005.05.1011829
Coding: 08BC30
Subsystem 3 - Part No: 1K8 951 171 A
Component: DWA-Sensor 00 001 0103
Component: LIN BACKUP HO H11 9004
Subsystem 5 - Part No: 1K8 951 171 A
Subsystem 6 - Part No SW: 5K0 959 542 HW: 5K0 959 542
Component: E221__MFL-TAS H05 0010
Serial number: 0000503
Coding: 020000
Subsystem 7 - Part No SW: 6R0 959 811 F HW: 6R0 959 811 F
Component: J388__TSG_HL 006 0902
Serial number: KU0-KU010.05.1014744
Coding: 08BC32
Subsystem 8 - Part No SW: 6R0 959 812 F HW: 6R0 959 812 F
Component: J389__TSG_HR 006 0902
Serial number: KU0-KU020.05.1014431
Coding: 08BC32
Part No SW: 6R0 959 655 L HW: 6R0 959 655 L
Component: VW10Airbag00P H08 0020
Revision: -------- Serial number: 003GY000F23U
Coding: 003050
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 4B93856CE26751DEB6-801E
Serial number: 3572SRB40000B6C92A08
Serial number: 3582SRB40000B734E0CA
Serial number: 3515RRB405P6SD5OIO5L
Serial number: 3525RRB40516R0C2HGEC
Part No SW: 6R0 920 860 D HW: 6R0 920 860 D
Component: KOMBI H03 0207
Coding: 140800
Shop #: WSC 31414 790 50316
VCID: 3567C39494E3372EF0-8060
Part No SW: 6N0 909 901 HW: 6R0 937 087 D
Component: GW-K-CAN TP20 0207
Coding: 002300
VCID: 70E93280A3015206E3-8024
Component: IMMO H03 0207
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03006
VCID: 6ADD20E88DDDA8D6AD-803E
Address 44: Steering Assist Labels: 6Q0-423-156.clb
Part No: 6Q0 423 156 AB
Component: LenkhilfeTRW V270
Coding: 10110
Shop #: WSC 31414
VCID: 6FEB31FC2A3F4DFEFA-803A
Part No SW: 5M0 035 156 B HW: 5M0 035 156 B
Component: Radio 510 0521
Revision: R0510002 Serial number: VWZ5Z1K0327013
Coding: 0500040002
Shop #: WSC 00000 000 31414
VCID: 28591AE05B515AC67B-807C
End-------------------------(Elapsed Time: 02:49)--------------------------
