Problems are what the title says.
Passed Uk Mot test yesterday although the Lambda struggled to get into the Green zone for a while.
Ran fine on the way home and this morning began to misfire from cold.
On Parking the Red Steering Wheel light came on and no power steering assistance at all. Engine MIL on.
Turned it off, Dug out the VCDS and started the car again. Power steering working no misfire MVBs for the engine all in the Green.
J500 Intermittent Fault showing.
The 09 Interior lights and 56 Radio faults are known issues that I can't do anything about till my hand works again
Car has been standing for about 4 months due to lockdown and a hand operation. I'm hoping corrosion on a plug somewhere.
If the steering Rack had died it would stay dead??
I do realise that these are likely to be two different issues.
Any thoughts, opinions or previous experience would be gratefully received
Thanks, Graham
Thanks, Graham
Thursday,26,November,2020,13:40:22:45305
VIN: WAUZZZ8P64A064818 License Plate:
Chassis Type: 8P (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56
VIN: WAUZZZ8P64A064818 Mileage: 179630km-111616miles
44-Steering Assist -- Status: Sporadic communication error 1000
Address 01: Engine Labels: 06F-906-056-AXW.lbl
Part No SW: 06F 906 056 BT HW: Hardware No
Component: MED9.5.10 G00 5340
Revision: 00000000 Serial number: AUX7Z0C7FNK0B3
Coding: 0000072
Shop #: WSC 06435 000 00000
VCID: 7CA1F33D6AE0687B0EB-8028
Subsystem 1 - Part No: 06F 907 807 A
Component: NOX 0308250111 004 3608
06F907807A NOX 0308250111 004 3608
16576 - Fuel Pressure Sensor (G247)
P0192 - 002 - Short to GND - Intermittent - MIL ON
Readiness: 0000 0001
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No: 1K0 907 379 D
Coding: 0053894
VCID: 33331801073E67039F1-8066
Part No SW: 8P0 820 043 HW: 8P0 820 043
Component: KlimavollautomatH11 0130
VCID: 698FBA691572EDD3E5D-803C
Address 09: Cent. Elect. Labels:. 8P0-907-279-23-H.lbl
Part No SW: 8P0 907 279 A HW: 8P0 907 279 A*
Component: Bordnetz-SG 1.0 H29 0501
Revision: 00029000 Serial number: 00000000138663
Coding: 018C4F00A0141000000000000000000000
VCID: 3B2330212F6EAF43471-806E
Subsystem 1 - Part No: 8P2 955 119 C Labels: 1TX-955-119.CLB
Component: Wischer WWS Audi350 0180
Coding: 16711696
02399 - Control Circuit for Terminal 30 for Interior Illumination
009 - Open or Short to Ground
Address 15: Airbags Labels: 8P0-959-655-84.lbl
Part No SW: 8P0 959 655 F HW: 8P0 959 655 F
Component: Airbag 8.4ED H01 0130
Coding: 0011602
VCID: 45D756D959AAE9B3215-8010
Address 16: Steering wheel Labels: 8P0-953-549.lbl
Part No SW: 8P0 953 549 HW: 8P0 953 549
Component: Lenks‰ulenmodul H09 0020
Coding: 0000042
VCID: 7BA3F0216FEE6F43071-802E
Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
Part No SW: 8P0 920 980 J HW: 8P0 920 980 J
Component: KOMBIINSTR. VDO H25 0080
Revision: D06 Serial number: 2247CD06001118
Coding: 0004403
Shop #: WSC 01019 210 136528
VCID: 3E2539353C7CBA6B60F-806A
Address 19: CAN Gateway Labels:. 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 B HW: 1K0 907 951
Component: Gateway H08 0090
Revision: 08 Serial number: 2400103723B0E3
Coding: 3D0F0342070101
VCID: 2615F155C4EC02AB08F-8072
Reset counter: 175
Mileage: 179631 km
Date: 2020.11.26
Time: 12:26:04
Revision: D06 Serial number: AUX7Z0C7FNK0B3
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN1.lbl
Part No: 8P0 959 801 A
Component: Tuersteuerger. H10 0010
Coding: 0000048
VCID: 392F2A2925529D5355D-806C
Address 44: Steering Assist Labels: 1Kx-909-143-GEN1.clb
Part No: 1K1 909 143 L
Component: EPS_ZFLS Kl.6 0402
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433
Component: KSG H02 0040
Coding: 008800186D288505485AC63000
Shop #: WSC 01019 210 175693
VCID: 79AFEA2965D25D5315D-802C
Subsystem 2 - Part No: 1K0 907 719
Component: Neigungssensor 002 0002
Subsystem 3 - Part No: 8P0 951 177
Component: Innenraumueberw.H02 0010
Address 47: Sound System Labels: 8Px-035-382.lbl
Part No SW: 8P3 035 382 HW: 8P3 035 382
Component: AB2 SUBWOOFERBOXH23 0100
Revision: 00001 Serial number: 10000001043808
VCID: 70B9D70D36A81C1BA23-8024
Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN1.lbl
Part No: 8P0 959 802 A
Coding: 0000048
VCID: 3A2D35252054964B5C7-806E
Address 56: Radio Labels: 8P0-035-1xx-56.lbl
Part No SW: 8P0 035 186 HW: 8P0 035 186
Component: concert II EU H53 0060
Revision: 07S Serial number: AUZ2Z3C1397642
Coding: 0001001
VCID: 6FBBD4712B9603E3BB9-803A
Reset counter: 175
Time Indication: 15
Bin. Bits: 10
Reset counter: 175
Time Indication: 15
End----------(Elapsed Time: 00:59, VBatt start/end: 14.2V/14.3V)-----------
