- Nov 19, 2020
- 18
- 3
- Saudi Arabia
- C?ID=424807
Hi,
1- I searched in modules for something related to "disable welcoming voice" and I couldn't find it. I don't know if this is possible.
A: Found it under module 47 > Adaptation > Channel (but it says ERROR: Channel not available)
2- I had Low Tire Pressure and when I go to: Chassis > 65 > It says "No response from Controller".
Module 03 ABS > Coding > Long Coding Helper > Byte 16/17 "TPMS Installed" I tick these options and they automatically recognize sensors?
It's also found in 09 Cent Elect > Coding > Long Coding Helper > Byte 8 Bit 7 "TPMS Installed".
3- How to make Kessy works to unlock the car even when engine is "ON".
4- Change Language: 17 > Adaptation > Channel: Change Language Version > Arabic > Do it! > Request out of range. Didn't work.
5- How to make backup for the complete modules before I start tweaking process?
I will make a post once I figure some of these issues ..
I didn't use Security Access during my tweaks.
Chassis Type: A3-VW41 (7N0)
Scan: 01 02 03 05 08 09 15 16 17 19 25 2B 2E 36 42 44 46 47 4F 52
56 62 72
VIN: 1VWZZZA3ZFC090110 Mileage: 18750km-11650miles
01-Engine -- Status: Sporadic communication error 1000
05-Acc/Start Auth. -- Status: Sporadic communication error 1000
08-Auto HVAC -- Status: Sporadic communication error 1000
15-Airbags -- Status: Sporadic communication error 1000
16-Steering wheel -- Status: Sporadic communication error 1000
17-Instruments -- Status: Sporadic communication error 1000
25-Immobilizer -- Status: Sporadic communication error 1000
2B-Steer. Col. Lock -- Status: Sporadic communication error 1000
42-Door Elect, Driver -- Status: Sporadic communication error 1000
47-Sound System -- Status: Sporadic communication error 1000
52-Door Elect, Pass. -- Status: Sporadic communication error 1000
62-Door, Rear Left -- Status: Sporadic communication error 1000
72-Door, Rear Right -- Status: Sporadic communication error 1000
