- Jun 27, 2019
- 19
- 2
- Netherlands
- C?ID=222249
Dear Ross-Tech Users,
I am fitting the H46 MK60EC1 to the golf mk6.
Now ive tried using my old coding and adding 73 and 6A for byte 19
VCDS scan after swap.
VCDS autoscan before swap
Could someone please help me with the coding for this module?
Wednesday,25,November,2020,10:49:18:10011
VCDS Version: 20.4.2.0 (x64)
VIN: WVWZZZ1KZBW183224 License Plate: SJ170T
Mileage: 71870km-44657mi Repair Order:
Chassis Type: 1K-VW36 (7N0)
Scan: 01 02 03 08 09 10 13 15 16 17 19 25 42 44 46 4C 4F 52 5F A5
VIN: WVWZZZ1KZBW183224 Mileage: 71870km-44657miles
15-Airbags -- Status: Cannot be reached 1100
4C-Tire Pressure II -- Status: Cannot be reached 1100
Address 01: Engine (J623-CBZA) Labels:. 03F-906-070-CBZ.clb
Part No SW: 03F 906 070 AK HW: 03F 906 070 B
Component: SIMOS10.12H03 9673
Revision: --H03--- Serial number: 00000000000000
Coding: 002500D6232400080000
ASAM Dataset: EV_ECM12TFS02103F906070AK 004008
ROD: EV_ECM12TFS02103F906070AA_004_VW32.rod
VCID: 6BFB2E2082A2EBDED6-803E
6051 - No Communications with Airbag Control Module
U0151 00 [039] - -
Mileage: 71874 km
Date: 2020.11.25
Time: 19:41:34
Engine speed: 849.00 /min
Normed load value: 13.3 %
Coolant temperature: 41 °C
Intake air temperature: 27 °C
Voltage terminal 30: 14.015 V
Time since engine start: 27.5 s
Engine torque: 29.28125 Nm
Accelerator pedal travel-Accelerator position: 0.00 %
Ignition angle of current cylinder: actual value-Ignition angle: actual: -0.750 °
Readiness: 0110 0101
Address 02: Auto Trans Labels: 0AM-927-769.clb
Part No SW: 0AM 300 050 L HW: 0AM 927 769 D
Component: GSG DSG AG7 403 9033
Revision: 00040034 Serial number: CU501011205939
Shop #: WSC 00191 264 15243
VCID: 3245F344AD087A16D5-8066
Part No SW: 1K0 907 379 BM HW: 1K0 907 379 BM
Component: ESP MK60EC1 H46 0164
Revision: 00H46001
Coding: 0000000000000000000000000000000000000000
VCID: 7EDD1774E9D06E7661-802A
Reset counter: 214
Date: 2020.11.25
Time: 19:41:49
Count: 3
Count: 20992
Count: 195
Count: 50688
Fault Status: 01100101
Reset counter: 214
Mileage: 71874 km
Date: 2020.11.25
Time: 19:41:48
Count: 3
Count: 2
Count: 25088
Count: 212
Count: 50944
Reset counter: 214
Mileage: 71874 km
Date: 2020.11.25
Time: 19:41:48
Count: 3
Count: 2
Count: 25088
Count: 279
Count: 50944
Reset counter: 214
Mileage: 71874 km
Date: 2020.11.25
Time: 19:41:48
Count: 3
Count: 2
Count: 25088
Count: 295
Count: 50944
Reset counter: 214
Mileage: 71874 km
Date: 2020.11.25
Time: 19:41:48
Count: 3
Count: 2
Count: 25088
Count: 270
Count: 50944
00150 - Plausibility Brake Booster System
Reset counter: 214
Mileage: 71874 km
Date: 2020.11.25
Time: 19:41:48
Count: 3
Count: 2
Count: 25088
Count: 398
Count: 51200
Count: 256
Part No SW: 5ND 907 044 E HW: 5ND 907 044 E
Component: Climatronic H03 0404
Revision: 00001K02
Coding: 0000000000
VCID: 44A9A59CCFBCC4A677-8010
9496597 - Sunlight Photo Sensor
B10E8 15 [009] - Open or Short to Plus
Reset counter: 214
Mileage: 71874 km
Date: 2020.11.25
Time: 19:41:57
9496613 - Sunlight Photo Sensor
Reset counter: 214
Mileage: 71874 km
Date: 2020.11.25
Time: 19:41:57
13636352 - Control module not coded
U1013 00 [009] - -
Reset counter: 214
Mileage: 71874 km
Date: 2020.11.25
Time: 19:41:57
13701600 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Reset counter: 214
Mileage: 71874 km
Date: 2020.11.25
Time: 19:41:57
Part No SW: 1K0 937 086 J HW: 1K0 937 086 J
Component: BCM PQ35 M+ 103 0615
Revision: 00103 AD
Coding: 40180A38CC33F390600C0089740081EC47710088736D8D60648060200040
VCID: 3753C250866A9F3EE2-8062
Subsystem 1 - Part No: 5K1 955 119 Labels: 1KX-955-119.CLB
Component: Wischer 04121 26 0512
Coding: 009F95
Component: RLS 161210 05 54 0403
Coding: 0730AD
Reset counter: 214
Mileage: 71874 km
Date: 2020.11.25
Time: 19:42:16
Voltage: 14.00 V
Term 50 Off
03395 - Control Module for High Beam Assistant
Reset counter: 214
Mileage: 71874 km
Date: 2020.11.25
Time: 19:42:16
Voltage: 14.00 V
Term 50 Off
Address 10: Park/Steer Assist (J791) Labels:. 1T0-919-475.clb
Part No SW: 1T0 919 475 P HW: 3T0 919 475 C
Component: PARKHILFE PLA H08 0116
Revision: -------- Serial number: 13991032216273
Coding: 10810A
VCID: 48B1B1ACFB94E0C69B-801C
013 - Check DTC Memory
Fault Status: 01101101
Reset counter: 214
Mileage: 71874 km
Date: 2020.11.25
Time: 19:42:23
Temperature: 16.0°C
Address 13: Auto Dist. Reg
Address 15: Airbags
Part No SW: 5K0 953 507 AJ HW: 5K0 953 549 B
Component: Lenks.Modul 008 0090
Revision: -------- Serial number: WHRPIƒhtHHHfg
Coding: 189A100002
ROD: EV_SMLSNGKUDS_A05.rod
VCID: 78D1016CC3F450462B-802C
Component: E221__MFL-TK6 H07 0022
Serial number: 50000000000000803283
Coding: E30000
267264 - Control Module Incorrectly Coded
U1014 00 [009] - -
Reset counter: 214
Mileage: 71874 km
Date: 2020.11.25
Time: 19:42:41
Part No SW: 5K7 920 882 C HW: 5K7 920 882 C
Component: KOMBI H02 1104
Coding: 111D020000
Shop #: WSC 00040 040 00011
ROD: EV_Kombi_UDS_VDD_RM09_005_VW31.rod
VCID: 3753C2508E6A9F3EE2-8062
12669184 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Reset counter: 214
Mileage: 71874 km
Date: 2020.11.25
Time: 19:41:22
Part No SW: 7N0 907 530 AS HW: 7N0 907 530 AN
Component: J533 Gateway X56 1653
Revision: X56 Serial number: 240812F2001807
Coding: 350002
Shop #: WSC 26072 001 104857
VCID: 01276C88982E118E1C-8054
Reset counter: 214
Mileage: 71874 km
Date: 2020.11.25
Time: 19:42:50
03109 - Tire Pressure Monitoring Control Module 2 (J793)
Reset counter: 214
Mileage: 71874 km
Date: 2020.11.25
Time: 19:42:54
02001 - Data-Bus Automatic Distance Regulation
Reset counter: 214
Mileage: 71874 km
Date: 2020.11.25
Time: 19:42:50
Component: IMMO H02 1104
VCID: 6AF52B248D58F2D6AD-803E
Part No SW: 5K0 959 701 C HW: 5K0 959 701 C
Component: Tuer-SG 009 2119
Coding: 0012342
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 251 3501
Revision: 00H20000
VCID: 3957C468707E894E14-806C
02797 - Control Module for Directional Stabilization Assistance (J759)
Reset counter: 214
Mileage: 71874 km
Date: 2020.11.25
Time: 19:43:07
Voltage: 14.13 V
DU
Temperature: 22.0°C
RPM: 752 /min
Part No SW: 7N0 907 532 HW: 7N0 907 530 AN
Component: EZE_2 X56 1653
Coding: 00000000
VCID: 6FC33A30BEBA17FEFA-803A
Part No SW: 5K0 959 702 E HW: 5K0 959 702 E
Component: Tuer-SG 009 2151
Coding: 0012598
VCID: 354FC8585C666D2EF0-8060
Part No SW: 5C0 035 680 E HW: 5C0 035 680 E
Component: MU-S-ND-ER H31 0368
Serial number: VWZAZ2S5402550
Coding: 02731001AA0000001111120100880A001F0100C4002001000F
Shop #: WSC 35110 790 50316
ROD: EV_MUStd4CTSAT_VW32.rod
VCID: 236B06002AF2E39E2E-8076
Subsystem 1 - Part No SW: 5NA 919 866 AR HW: -----------
Component: ECE AS 20/21 --- 1430
B201A 00 [009] - -
Reset counter: 214
Mileage: 71874 km
Date: 2020.11.25
Time: 19:43:28
Voltage terminal 30: 13.6 V
Status_Software_Version_Management-module_name:
U1101 00 [009] - Active
Reset counter: 214
Mileage: 71874 km
Date: 2020.11.25
Time: 19:43:28
Voltage terminal 30: 13.5 V
1564 - Microphone 1
B129B 13 [009] - Open Circuit
Reset counter: 214
Mileage: 71874 km
Date: 2020.11.25
Time: 19:43:28
Voltage terminal 30: 13.4 V
7201 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Reset counter: 214
Mileage: 71874 km
Date: 2020.11.25
Time: 19:43:30
BAP-BAP_Function_ID: 02
0011 - Digital Radio Antenna
B1103 13 [009] - Open Circuit
Reset counter: 214
Mileage: 71874 km
Date: 2020.11.25
Time: 19:43:28
Status of digital radio antenna 1-Antenna current: 0 mA
Status of digital radio antenna 1-Connection between radio and antenna amplifier: Open circuit
Status of digital radio antenna 1-Connection between antenna amplifier and antenna: Not available
Status of digital radio antenna 1-DAB_Bit_Error_Rate_FIC: 0.000000
Status of digital radio antenna 1-DAB_Bit_Error_Rate_MSC: 0.000000
Address A5: Frt Sens. Drv. Assist
End-------------------------(Elapsed Time: 01:54)--------------------------
Thursday,02,July,2020,13:32:07:10011
VCDS Version: 20.4.1.0 (x64)
Mileage: 62670km-38941mi Repair Order:
Scan: 01 02 03 08 09 10 13 15 16 17 19 25 37 42 44 46 4C 52 56 77
A5
VIN: WVWZZZ1KZBW183224 Mileage: 62670km-38941miles
VCID: 6BFB2E2082A2EBDECE-803E
Readiness: 0010 0001
VCID: 3245F344AD087A16CD-8066
Part No SW: 1K0 907 379 BE HW: 1K0 907 379 BE
Component: ESP MK60EC1 H31 0108
Revision: 00H31001
Coding: 113B200D212A00FD880D04E6841D0040150C00
VCID: 76CD0F54C1E0263621-8022
02186 - Engine <-> ADR Interface
Reset counter: 243
Mileage: 62632 km
Date: 2020.07.02
Time: 11:52:34
Count: 3
Count: 14
Count: 4608
Count: 8206
Count: 50944
Count: 1
Count: 1
Count: 94
Revision: 00001K02
Coding: 0000000000
VCID: 44A9A59CCFBCC4A66F-8010
Reset counter: 243
Mileage: 62632 km
Date: 2020.07.02
Time: 11:54:16
Reset counter: 243
Mileage: 62632 km
Date: 2020.07.02
Time: 11:54:16
U1013 00 [009] - -
Reset counter: 243
Mileage: 62632 km
Date: 2020.07.02
Time: 11:54:16
Revision: 00103 AD
Coding: 40180A38C833F390600C0089740081EC47710088736D8D60648060200040
VCID: 3753C250866A9F3EFA-8062
Coding: 009F95
Coding: 0730AD
Coding: 10810A
VCID: 48B1B1ACFB94E0C683-801C
Address 13: Auto Dist. Reg Labels: 3AA-907-567.clb
Part No SW: 3AA 907 567 A HW: 3AA 907 567
Component: AC201 RDW A 036 0170
Revision: 00036000 Serial number: 00000000546276
Coding: 0010000
Shop #: WSC 05311 000 00000
VCID: 3851C16C4B749046F3-806C
Fault Frequency: 9
Reset counter: 245
Mileage: 62632 km
Date: 2020.07.02
Time: 11:50:08
Count: 2
Reset counter: 245
Mileage: 62657 km
Date: 2020.07.02
Time: 22:01:13
Count: 3
Reset counter: 246
Mileage: 62657 km
Date: 2020.07.02
Time: 22:01:13
Count: 14
Reset counter: 30
Mileage: 62654 km
Date: 2020.07.02
Time: 18:57:49
Count: 34
Part No SW: 5C0 959 655 B HW: 5C0 959 655 B
Component: AirbagVW10 013 0613
Serial number: 003G5R01HZL$
Coding: 00003832
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 3147FC48600E410EB4-8064
Serial number: 3572MSME11636059ZZZO
Serial number: 3582MSME112D5659ZZZ-
Serial number: 3512QSME1250780FZZZT
Serial number: 3522QSME1A2B7920ZZZY
Coding: 189A100002
VCID: 78D1016CC3F4504633-802C
Coding: E30000
117028 - Databus
Reset counter: 28
Mileage: 62632 km
Date: 2020.07.02
Time: 12:14:33
229211 - Cruise Control Switch
B1154 13 [008] - Open Circuit
Reset counter: 28
Mileage: 62632 km
Date: 2020.07.02
Time: 11:55:34
U1014 00 [009] - -
Reset counter: 243
Mileage: 62632 km
Date: 2020.07.02
Time: 11:50:01
Coding: 111D010000
VCID: 3753C2508E6A9F3EFA-8062
12858113 - Implausible Data Received from Cruise Control Front Distance Range Sensor
U0433 00 [008] - -
Reset counter: 31
Mileage: 62632 km
Date: 2020.07.02
Time: 12:07:17
Part No SW: 7N0 907 530 AN HW: 7N0 907 530 AJ
Component: J533 Gateway H51 1642
Revision: H51 Serial number: 18011400F13614
Coding: 35040A
VCID: 7CD91D7CFFCC7C6657-8028
Fault Status: 00110100
Reset counter: 21
Mileage: 62486 km
Date: 2020.06.29
Time: 14:35:46
Mileage: 58778 km
Date: 2020.05.01
Time: 21:26:51
Fault Status: 01110100
Reset counter: 87
Mileage: 58778 km
Date: 2020.05.01
Time: 21:26:55
VCID: 6AF52B248D58F2D6B5-803E
Address 37: Navigation
Coding: 0012598
Part No: 1K0 909 144 M
Component: EPS_ZFLS Kl. 69 3201
Revision: 00H20000
VCID: 3449F55C571C7426DF-8060
Coding: 0012598
VCID: 354FC8585C666D2EE8-8060
Address 56: Radio
Address 77: Telephone
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 3AA-980-654.clb
Part No SW: 3AA 980 654 D HW: 3AA 980 654 A
Component: MFK_Gen1 H09 0300
Serial number: 0194497322
Coding: 01010100010202110001000000000000
ASAM Dataset: EV_47X 001639
ROD: EV_47X.rod
VCID: 3957C468B87E894E0C-806C
2621440 - Databus
Reset counter: 243
Mileage: 62632 km
Date: 2020.07.02
Time: 11:56:14
2686976 - Databus
Reset counter: 243
Mileage: 62632 km
Date: 2020.07.02
Time: 11:56:14
End-------------------------(Elapsed Time: 01:59)--------------------------
