RETROFIT GOLF 7 GTD 2015 WITH MIB1 VS DISCOVER PRO MIB 2.5
   #21
cdr38
France
C?ID=58450
Ok, some more coding fixes
Instruments 17, put this code in, it enables traffic sign recognition and navigation menu :
27AD01006F84000803884E031400000000000000
Then A5 camera, this coding. It also enables traffic sign recognition and tells to the camera that there is navigation installed :
0101020101020308000300000100000100
These changes should reduce the number of faults in 5F as well
Thank you for this addition of options.
on the other hand following the coding I now have an error in A5
I post the log of 17 and A5.
Do you have an idea or maybe an adaptation to do?
Friday,27,November,2020,10:52:16:12319
VCDS Version: 20.4.2.0 (x64)
VIN: WVWZZZAUZFW299913   License Plate:
                Address 17: Instruments       Labels: 5G0-920-XXX-17.clb-SRI3
Control Module Part Number: 5G1 920 757     HW: 5G1 920 757
  Component and/or Version: KOMBI         301 4310
           Software Coding: 27AD01006F84000803884E031400000000000000
            Work Shop Code: WSC 01369 210 40505
              ASAM Dataset: EV_DashBoardVDDMQBAB 009043 (VW37)
                      VCID: 6BDE798482B5EFDED6-803E
Friday,27,November,2020,10:52:47:12319
                Address A5: Frt Sens. Drv. Assist       Labels: 5Q0-980-653.clb
Control Module Part Number: 5Q0 980 653 F    HW: 5Q0 980 653
  Component and/or Version: MQB_MFK       H06 0052
           Software Coding: 0101020101020300000300000100000100
              ASAM Dataset: EV_MFKBoschAU370 001001 (VW37)
                       ROD: EV_MFKBoschAU370.rod
                      VCID: 3B7E89C4B255BF5E06-806E
2555904 - Databus
                    Reset counter: 37
                    Mileage: 136775 km
                    Date: 2020.11.27
                    Time: 10:30:17
                    Control Module temperature: 34 °C
                    Outside air temperature: 11.0 °C
                    Vehicle speed: 0.00 km/h
                    Voltage terminal 15: 12.1 V
                    Terminal 15 on: 916.3 s
Address A5: DTCs cleared
[/QUOTE]
cdr38
France
C?ID=58450
on the other hand, the number of faults in 5F has not changed
                Address 5F: Information Electr.       Labels: 5G0-035-MIB-HGH2.clb
Control Module Part Number: 5NA 035 043 D    HW: 5NA 035 043
  Component and/or Version: MU-H-N-EU     H55 1367
           Software Coding: 02730001FF0000004111000100080A201F0103C401200500FE
              ASAM Dataset: EV_MUHig4CGen2HBAS 001001 (VW37)
                      VCID: 377695F48E7D9B3EE2-8062
10 Faults Found:
          U1101 00 [009] - Active
                    Reset counter: 37
                    Mileage: 136775 km
                    Date: 2020.11.26
                    Time: 12:50:53
                    Voltage terminal 30: 12.2 V
0512 - Rear Right Bass Speaker
          B1067 13 [009] - Open Circuit
                    Reset counter: 37
                    Mileage: 136775 km
                    Date: 2020.11.26
                    Time: 12:50:59
0513 - Rear Right Treble Speaker
          B1068 13 [009] - Open Circuit
                    Reset counter: 37
                    Mileage: 136775 km
                    Date: 2020.11.26
                    Time: 12:50:57
0527 - Rear Left Bass Speaker
          B1065 13 [009] - Open Circuit
                    Reset counter: 37
                    Mileage: 136775 km
                    Date: 2020.11.26
                    Time: 12:50:59
0528 - Rear Left Treble Speaker
          B1066 13 [009] - Open Circuit
                    Reset counter: 37
                    Mileage: 136775 km
                    Date: 2020.11.26
                    Time: 12:50:57
0006 - Antenna Amplifier 2 for Radio
          B126E 13 [009] - Open Circuit
                    Reset counter: 37
                    Mileage: 136775 km
                    Date: 2020.11.26
                    Time: 12:50:53
                    Status of antenna 2 for radio-Antenna current: 0 mA
                    Status of antenna 2 for radio-Connection between radio and antenna amplifier: Open circuit
                    Status of antenna 2 for radio-Connection between antenna amplifier and antenna: Not available
                    Status of antenna 2 for radio-Reception level antenna 2: 255 dBµV
2564 - GPS Antenna
          B1054 11 [009] - Short to Ground
                    Reset counter: 37
                    Mileage: 136775 km
                    Date: 2020.11.26
                    Time: 12:50:53
7170 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 37
                    Mileage: 136775 km
                    Date: 2020.11.26
                    Time: 12:50:54
                    BAP-BAP_Function_ID: 02
7201 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 77
                    Mileage: 136775 km
                    Date: 2020.11.26
                    Time: 12:50:54
7223 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 37
                    Mileage: 136775 km
                    Date: 2020.11.26
                    Time: 12:50:54
   #23
downtime
C?ID=280813
Hmm. Try to get them read with newer interface so we'll see what are the missing messages it complains about
   #24
cdr38
France
C?ID=58450
Ok, I ordered official VCP PRO, I will come back after receiving the tool, in about 3 days ...
J'ai pu supprimer un code d'erreur en mettant à jour l'écran du MIB dans GTD qui était sur GTI. octet 18 hex 03 / hex02 ...
           Software Coding: 02730001FF00000051110001000808201F0100C401200500FE
9 Faults Found:
                    Reset counter: 37
                    Mileage: 136775 km
                    Date: 2020.11.27
                    Time: 15:42:32
                    Voltage terminal 30: 12.1 V
                    Reset counter: 37
                    Mileage: 136775 km
                    Date: 2020.11.27
                    Time: 15:42:38
                    Reset counter: 37
                    Mileage: 136775 km
                    Date: 2020.11.27
                    Time: 15:42:36
                    Reset counter: 37
                    Mileage: 136775 km
                    Date: 2020.11.27
                    Time: 15:42:38
                    Reset counter: 37
                    Mileage: 136775 km
                    Date: 2020.11.27
                    Time: 15:42:36
                    Reset counter: 37
                    Mileage: 136775 km
                    Date: 2020.11.27
                    Time: 15:42:32
2564 - GPS Antenna
                    Reset counter: 37
                    Mileage: 136775 km
                    Date: 2020.11.27
                    Time: 15:42:32
          U1111 00 [009] - -
                    Reset counter: 37
                    Mileage: 136775 km
                    Date: 2020.11.27
                    Time: 15:42:33
          U1111 00 [009] - -
                    Reset counter: 37
                    Mileage: 136775 km
                    Date: 2020.11.27
                    Time: 15:42:33
   #25
cdr38
France
C?ID=58450
9 Faults Found:
                    Reset counter: 37
                    Mileage: 136775 km
                    Date: 2020.11.27
                    Time: 15:42:32
                    Reset counter: 37
                    Mileage: 136775 km
                    Date: 2020.11.27
                    Time: 15:42:38
                    Reset counter: 37
                    Mileage: 136775 km
                    Date: 2020.11.27
                    Time: 15:42:36
                    Reset counter: 37
                    Mileage: 136775 km
                    Date: 2020.11.27
                    Time: 15:42:38
                    Reset counter: 37
                    Mileage: 136775 km
                    Date: 2020.11.27
                    Time: 15:42:36
                    Reset counter: 37
                    Mileage: 136775 km
                    Date: 2020.11.27
                    Time: 15:42:32
2564 - GPS Antenna
                    Reset counter: 37
                    Mileage: 136775 km
                    Date: 2020.11.27
                    Time: 15:42:32
          U1111 00 [009] - -
                    Reset counter: 37
                    Mileage: 136775 km
                    Date: 2020.11.27
                    Time: 15:42:33
          U1111 00 [009] - -
                    Reset counter: 37
                    Mileage: 136775 km
                    Date: 2020.11.27
                    Time: 15:42:33
I was able to remove a code by updating the MIB screen in GTD which was on GTI. byte 18 hex 03 / hex02 ...
As already said please post in English :thanks:
Google translate said:
I was able to remove an error code by updating the MIB screen in GTD which was on GTI.
   #27
cdr38
France
C?ID=58450
I realized this and brought the translation at the bottom of the message
   #28
Unfortunately as you included the translation in the QUOTE box it doesn't appear as the QUOTE box is minimized by the forum software so the translation is hidden unles the reader clicks on 'Expand'
   #29
I've fixed the tags. :)
DV52
C?ID=194404
                    Reset counter: 37
                    Mileage: 136775 km
                    Date: 2020.11.26
                    Time: 09:09:51
                    Reset counter: 37
                    Mileage: 136775 km
                    Date: 2020.11.26
                    Time: 09:09:48
                    Reset counter: 37
                    Mileage: 136775 km
                    Date: 2020.11.26
                    Time: 09:09:51
                    Reset counter: 37
                    Mileage: 136775 km
                    Date: 2020.11.26
                    Time: 09:09:48
You need to check the wiring. This is clearly a wiring issue. Either the wiring behind the unit or wiring to both rear doors is having issues. If you don't have other issues with rear doors then I would check the wiring behind the unit.
This might be still a coding issue, I'll reiterate the coding
@downtime: Hi. I've checked the WD for the DTC s above and I can confirm that the terminations for the 2 x rear speaker channels on the quad-connector on J794 is the same for both 2 x door and 4 x door vehicles (not surprisingly). The difference between the 2 x body-shapes is simply the wiring route from the hex5F module and the physical speakers. This, and the fact that both rear channels appear to be in error - implies (to me) that perhaps your second suggestion might be more correct - maybe? Or, perhaps the DTCs are a quirk of the CP error (as we both are aware, odd things can happen to hacked hex5F units)?
   #31
downtime
C?ID=280813
Thanks Don for the checkup.
Most likely it’s a parameter problem. CP has not caused these errors for me ever. What OP wrote earlier, indicates this unit was for Passat and most likely it has Passat dataset in thus the problems with speakers.
   #32
George Ab
C?ID=232965
I forgot to say that I no longer have access to drive select either.
I have, however, activated the corresponding bit in the BCM.
I recently replaced the MIB2 3Q0035844 head unit which I swapped with a 3Q0035844B due to a problem with the unit draining battery
https://www.golfmk7.com/forums/index.php?threads/infotainment-unit-draining-battery.379517/ After CP removal and FeC installation, my "driving modes" pop up menu did not function when pressing driving mode button. You need to change this line of adaptations code to active to get driving modes pop up menu to work
ENG122229-ENG117736-Car_Function_List_BAP_Gen2-charisma_0x17"
One of the things I did when going from a unit that came out of an Atlas to a GTI is I used VCDS to save all of the adaptations settings (VCDS Applications, Cotroller Channel Map), in original unit and then save adaptations in new unit. Put them in spreadsheet and look at which ones are different to see if they are affecting. Also for the actual coding, you can put in original unit. Look at coding, long coding and go through bit by bit looking at settings. Take notes. Then put in new unit and go through each bit in long coding and make sure they are aligned with your original unit.
