AUDI A1 ABS LONG CODING 6R0 907 379 BB (ESP8.2i)
mjautos
C?ID=231691
Hi!
Can anyone help with the ABS long coding for a 2011 Audi A1 1.6 TDI ??
Our coding is set at 0000000000000000000000
6R0 907 379 BB
WAUZZZ8X1CB009203
Many thanks
mjautos
C?ID=231691
Thank you! Here's the scan
Friday,20,November,2020,15:07:05:61517
VCDS Version: 20.4.2.0
Dealer/Shop Name: MJ Autos
VIN: WAUZZZ8X1CB009203   License Plate: TYBURNS
Mileage: 210480km-130786mi   Repair Order:
Chassis Type: 8X-AU21 (8U0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 5F
VIN: WAUZZZ8X1CB009203   Mileage: 210480km-130786miles
   Part No SW: 03L 906 023 KQ    HW: 03L 906 023 KP
   Component: 1,6L R4 CR td H63 8530
   Revision: --H63---    Serial number:
   Coding: 00114016030501080000
   Shop #: WSC 00046 790 00000
   ASAM Dataset: EV_ECM16TDI02103L906023KQ 003009
   ROD: EV_ECM16TDI02103L906023KG.rod
   VCID: 7F0D2F51E60D317E6A-802A
7332 - Mass Air Flow Sensor (G70)
          P0103 00 [173] - Signal too High
                    Mileage: 210191 km
                    Engine speed: 0.00 /min
                    Vehicle speed: 255 km/h
                    Coolant temperature: 82 °C
                    Intake air temperature: 27 °C
                    Voltage terminal 30: 12.085 V
                    Engine speed: 0 /min
                    Battery voltage: 12.0 V
                    EGR Vacuum Regulator Solen.val.: activation-ANG_SP_EGRV[0]: 0.000 %
                    Throttle_actuator_commanded_value-ANG_SP_THR[0]: 96.001 %
                    Air mass: specified value-MAF_SP_MMV: 239.95 mg/stroke
                    Air mass: actual value (mg/stroke)-MAF_MES: 0 mg/stroke
10158 - Cylinder 2 Glow Plug Circuit (Q11)
          P0672 00 [109] - Electrical Fault
                    Mileage: 210191 km
                    Date: 2020.11.11
                    Time: 02:07:59
                    Engine speed: 1505.25 /min
                    Normed load value: 31.0 %
                    Vehicle speed: 1 km/h
                    Coolant temperature: 7 °C
                    Intake air temperature: 8 °C
                    Voltage terminal 30: 11.294 V
                    Glow status-STATE_GLOW: 176
                    Fuel temperature-TFU: 10 °C
                    Sensor for engine block temperature: raw value-Coolant temperature: 9 °C
7196 - Function Restriction due to Faults in Other Modules
          U1113 00 [101] - -
                    Fault Frequency: 14
                    Mileage: 210190 km
                    Date: 2020.11.09
                    Time: 07:45:07
                    Coolant temperature: 74 °C
                    Intake air temperature: 22 °C
                    Accelerator position: normalized-Accelerator position: 0.00 %
                    Battery voltage: 12.1 V
Readiness: 1110 0000
   Part No SW: 6R0 907 379 BB    HW: 6R0 907 379 AH
   Component: ESP8.2i front H07 0001
   Revision: --------
   Coding: 000000000000000000000000000000000000
   Shop #: WSC 00046 000 00000
   VCID: 7F0D2F51EA0D317E6A-802A
03306 - Coding Not Valid
                    Fault Frequency: 36
                    Reset counter: 79
                    Mileage: 210398 km
                    Date: 2020.10.29
                    Time: 06:12:29
                    Hex Value: 0x0007
                    Hex Value: 0x0002
                    Hex Value: 0x1209
                    Hex Value: 0x149A
                    Hex Value: 0x007F
                    Hex Value: 0x7F7F
                    Hex Value: 0x7F00
                    Fault Frequency: 35
                    Reset counter: 79
                    Mileage: 210398 km
                    Date: 2020.10.29
                    Time: 06:12:29
                    Hex Value: 0x0007
                    Hex Value: 0x0002
                    Hex Value: 0x1211
                    Hex Value: 0x149A
                    Hex Value: 0x007F
                    Hex Value: 0x7F7F
                    Hex Value: 0x7F00
00493 - ESP-Sensor Unit (G419)
                    Fault Status: 01100101
                    Fault Frequency: 32
                    Reset counter: 79
                    Mileage: 210398 km
                    Date: 2020.10.29
                    Time: 06:12:29
                    Hex Value: 0x0007
                    Hex Value: 0x0002
                    Hex Value: 0x12E1
                    Hex Value: 0x209A
                    Hex Value: 0x007F
                    Hex Value: 0x7F7F
                    Hex Value: 0x7F00
                    Fault Status: 00101101
                    Fault Frequency: 11
                    Reset counter: 119
                    Mileage: 210486 km
                    Date: 2020.11.09
                    Time: 08:34:27
                    Hex Value: 0x0003
                    Hex Value: 0x0002
                    Hex Value: 0x1107
                    Hex Value: 0x1395
                    Hex Value: 0x007E
                    Hex Value: 0x7F7F
                    Hex Value: 0x8300
Address 08: Auto HVAC (J255)       Labels:* None
   Part No SW: 8X0 820 043 A    HW: 8X0 820 043 A
   Component: Klima 1 Zone  H12 0063
   Serial number: 00000000061219
   Coding: 3420080000
   ASAM Dataset: EV_AirCondiFrontAU210 006031
   ROD: EV_AirCondiFrontAU210_006.rod
   VCID: 326B366565DF2C16D5-8066
   Part No SW: 8X0 907 063 G    HW: 8X0 907 063 G
   Component: BCM PQ35  M   110 0653
   Revision: 00110 AD
   Coding: 0E000A2CA805F100201841E02100015453FB6C0A01EF4122DC0887830045
   Shop #: WSC 00046 123 12345
   VCID: 408F6CADD3738E8653-8014
   Subsystem 1 - Part No SW: 8K0 955 559     HW: 8K0 955 559
   Component: RLS  H04 0003
   Serial number: 11497848
   Coding: 02562D
   Subsystem 2 - Part No: 8X0 951 177
   Component: DWA-Sensor H0  H01 0020
   Part No SW: 8X0 959 655 A    HW: 8X0 959 655 A
   Component: Airbag10.41   H04 0008
   Revision: --------    Serial number: 003JJ002HDZM
   Coding: 30314539303330303034554A305238583053
   ASAM Dataset: EV_Airba1041BPAAU210 001015
   ROD: EV_Airba1041BPAAU210.rod
   VCID: 489F748DF343B6C69B-801C
   Serial number: 3554VRB40590I3GUB1Q.
   Serial number: 3575HRB405H0ISD4BPL6
   Serial number: 3585HRB404R0INGS9H4B
   Rear Impact Crash Sensor:
   Serial number: 3515ZRB405R0H4DQ7G8%
   Part No SW: 5K0 953 569 AL    HW: 5K0 953 569 AL
   Revision: --X01---    Serial number: 20150828200747
   Coding: 7192A04000
   Shop #: WSC 01286 386 08256
   VCID: 020BA6A595FF5C9605-8056
   Subsystem 1 - Part No SW: 4G0 951 528 C    HW: 4G0 951 528 C
   Component: E221 - MFL  H07 0009
   Serial number: 15 05 2011  B0018442
226839 - Turn Signal Switch
          B1144 11 [009] - Short to Ground
                    Fault Frequency: 12
                    Reset counter: 79
                    Mileage: 210485 km
                    Date: 2020.11.09
                    Time: 07:45:06
          B1149 13 [009] - Open Circuit
                    Fault Frequency: 30
                    Reset counter: 79
                    Mileage: 210485 km
                    Date: 2020.11.09
                    Time: 07:45:06
229127 - Cruise Control Switch
          B1154 11 [009] - Short to Ground
                    Reset counter: 79
                    Mileage: 210485 km
                    Date: 2020.11.09
                    Time: 07:45:06
229147 - Cruise Control Switch
          B1154 13 [009] - Open Circuit
                    Reset counter: 79
                    Mileage: 210485 km
                    Date: 2020.11.09
                    Time: 07:45:06
447507 - Tiptronic Upshift Switch/Paddle in Steering Wheel
          B114F 96 [009] - Component internal failure
                    Fault Frequency: 22
                    Reset counter: 79
                    Mileage: 210485 km
                    Date: 2020.11.09
                    Time: 07:45:06
447763 - Tiptronic Downshift Switch/Paddle in Steering Wheel
          B114E 96 [009] - Component internal failure
                    Reset counter: 79
                    Mileage: 210485 km
                    Date: 2020.11.09
                    Time: 07:45:06
   Part No SW: 8X0 920 980 D    HW: 8X0 920 980 D
   Component: KOMBI_MEDIUM  H02 0179
   Coding: 41DE00
   ASAM Dataset: EV_Kombi_UDS_VDD_AU10 A04390
   VCID: 408F6CADDB738E8653-8014
   Part No SW: 8U0 907 468 A    HW: 8U0 907 468 A
   Component: GAT 4CAN 1L M H10 0043
   Revision: 1P030020    Serial number: 2041P1160600D1
   Coding: FBCF005A000100010153
   Subsystem 1 - Part No SW: 8K0 915 181 H    HW: 8K0 915 181 H
   Component: J367-BDM  H07 0171
   Serial number: 00000000007100698419
   Serial number: 11173000651021200181
   Component: IMMO          H02 0179
   Coding: 000002
   ASAM Dataset: EV_Immo_UDS_VDD_AU10 A04110
   ROD: EV_Immo_UDS_VDD_AU10.rod
   Part No SW: 8X0 959 793 D    HW: 8X0 959 793 D
   Component: TSG FA        H09 0409
   Coding: 011E02200101000100
   VCID: 4E934295192768F6D1-801A
   Part No: 6R0 423 156 B
   Coding: 11251
   Shop #: WSC 00046
   VCID: 2F6D3F11EAED01FEBA-807A
   Part No SW: 8X0 959 792 D    HW: 8X0 959 792 D
   Component: TSG BF        H09 0409
   VCID: 4D914599142153EEA8-8018
   Part No SW: 8X0 035 183 E    HW: 8X0 035 183 C
   Component: RMC Cnct      H51 0775
   Coding: 01010001008151070023000103010000010000
   Shop #: WSC 00353 210 91454
   VCID: 39790149B0A9DF4E14-806C
   Subsystem 1 - Part No SW: 8X0 919 603     HW: 8X0 919 603
   Component: DU6 Basic  H42 0084
   Serial number: 9462FS0B0118653
End-------------------------(Elapsed Time: 02:56)--------------------------
iichel
Eindhoven, NB, NL
C?ID=284912
330448E9436D03BBCC2712E2C2D4C0821700
330448E9436D03BBCC2712E2C2D4C0820700
330448E9436D00BBCC2712E2C2D400821700
330448E9436D00BBCC2712E2C2D400820700
mjautos
C?ID=231691
Thanks for the reply. I’ve tried all above but all are rejected.
It comes up;
Coding rejected error 22: conditions not correct or request sequence error
Any ideas??
