2010 VW Passat 3C - Clock spring replacement, new OEM Partnr. 5K0 953 569 AS upgrade disaster.
RisbergM
Viken, Norway
C?ID=424182
Hi.
I'm new to this forum and are seeking help.
My car has been at the dealer for the last 4 months without getting any closer to a solution.
It all started when the original clock spring broke and I replaced it step by step according to Safety Recall Code: 69L2
The original part nr was: 5K0 953 569 T which is replaced by 5K0 953 569 AS. The Airbag light etc. is now gone, but the MFSW buttons and the horn still doesn't work?
We are not able to code the new coil spring with the original Binary number and any other attempt of alternative coding comes back as out of range (error)?
The Dealer has tried to replace the Clock spring again in case there was a DOA part, but didn't help.
All the wires from the clock spring to the steering column has been physically measured and the signals are going thru.(Even borrowed and tried a complete wiring harness from another vehicle.)
The Steering wheel control module has been replaced, just as a part of trying to fix the issue in case of it being faulty as well. (I have the 8 button MFSW with paddle shift)
The dealer has tried to reinstall the old original parts and done the entire work over again with no luck.
If I can't get this solved my car won't pass the technical inspection and is not legal to use on public roads.
Really hope that any of you you wizards in here can help me solve this issue?
Best regards Martin
Saturday,14,November,2020,14:22:37:09299
Chassis Type: 3C-VW46 (3C0)
Scan: 01 02 03 08 09 10 13 15 16 17 18 19 22 25 36 37 42 44 46 52
          53 55 56 62 65 69 6D 72 77
VIN: WVWZZZ3CZAE138838   Mileage: 211200km-131233miles
04-Steering Angle -- Status: Cannot be reached 1100
37-Navigation -- Status: Cannot be reached 1100
Address 01: Engine (CBB)       Labels: 03L-906-022-CBA.clb
   Part No SW: 03L 906 022 KP    HW: 03L 907 309
   Component: R4 2,0L EDC F000AG  6213
   Revision: 13H03---    Serial number: VWZCZ000000000
   Coding: 0000178
   Shop #: WSC 84224 024 403655
   VCID: 7DA7F2D811F32BD3395-8028
053283 - Please Check Fault Codes in Control Module for Automatic Distance Regulation
               U1023 - 000 -  - Intermittent
                    Mileage: 211209 km
                    Date: 2015.04.07
                    Time: 05:06:46
                    (no units): 0.00
                    (no units): 0.00
                    (no units): 3.0
                    Bin. Bits: 00000111
                    (no units): 0.0
049682 - Steering Column Control Module
               U0212 - 000 - No Communications
                    Mileage: 211209 km
                    Date: 2015.04.07
                    Time: 05:06:46
                    Temperature: 6.3°C
                    Voltage: 11.86 V
                    Bin. Bits: 00000000
                    Torque: 93.0 Nm
                    Temperature: 26.1°C
008213 - Intake Manifold Flap Position Sensor (Bank 1)
               P2015 - 000 - Implausible Signal
                    Mileage: 211209 km
                    Date: 2015.04.07
                    Time: 05:06:46
                    Lambda: 11.0 %
                    Lambda: 6.3 %
                    Voltage: 0.304 V
                    Bin. Bits: 00000000
   Part No SW: 02E 300 013 B    HW: 02E 927 770 AL
   Component: GSG DSG AG6     511 2103
   Revision:    51112    Serial number: 00001003050768
   Shop #: WSC 05311 000 00000
   VCID: 1079BB6C366136BBC23-8044
18036 - Powertrain Data Bus
            P1628 - 000 - Missing Message from Steering Angle Sensor
                    Fault Frequency: 255
                    Mileage: 211209 km
                    Date: 2015.04.07
                    Time: 05:09:37
18275 - Powertrain Data Bus
            P1867 - 000 - Missing Message from Steering Wheel (J527)
                    Mileage: 211209 km
                    Date: 2015.04.07
                    Time: 05:09:37
Address 03: ABS Brakes        Labels:. 3C0-614-109-C4.clb
   Part No SW: 3C0 614 109 AG    HW: 3C0 614 109 AG
   Component: J104    C4 440 V3   0015
   Revision: --025---    Serial number: 00000705327313
   Coding: 0024878
   VCID: 6393A4A09757FD232F1-8036
   Part No SW: 5K0 907 044 CD    HW: 5K0 907 044 CD
   Component: Climatronic   H15 0709
   Revision: 00003001
   Coding: 0000000002
   Shop #: WSC 05311 115 00000
   VCID: 6FBBD890471F4943BB9-803A
   Part No SW: 3C8 937 049 F    HW: 3C8 937 049 F
   Revision: 00H54000    Serial number: 00000003745372
   Coding: EF8A8F4701041A00470A00000F000000000F5D435C000120000000000000
   Shop #: WSC 22323 004 1048576
   VCID: 343117FC62392A9B86B-8060
   Subsystem 1 - Part No: 3C1 955 419 B  Labels: 1KX-955-119.CLB
   Component: Wischer 100310 006  0208
   Coding: 00046997
   Shop #: WSC 22323
   Component: RLS     030516 054  0403
   Coding: 00209069
   Shop #: WSC 22323
Address 10: Park/Steer Assist (J791)       Labels:. 1T0-919-475.clb
   Part No SW: 1T0 919 475 H    HW: 1T0 919 475
   Component: PARKHILFE PLA H07 0110
   Revision: --------    Serial number: 88591007053857
   Coding: 110106
   Shop #: WSC 05314 000 00000
   VCID: 40D94B2C2A81863B123-8014
Address 13: Auto Dist. Reg        Labels: 3C0-907-567.clb
   Part No SW: 3C0 907 567 M    HW: 3C0 907 567 M
   Component: AC201  RDW A    031 0243
   Revision: 00031000    Serial number: 00000000054167
   Coding: 0010000
   VCID: 35372AF869433393B15-8060
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 233
                    Mileage: 211209 km
                    Date: 2015.04.07
                    Time: 05:09:37
                    Count: 4
                    Reset counter: 233
                    Mileage: 211209 km
                    Date: 2015.04.07
                    Time: 05:09:37
                    Count: 74
                    Reset counter: 233
                    Mileage: 211209 km
                    Date: 2015.04.07
                    Time: 05:09:37
                    Count: 80
   Part No SW: 5N0 959 655 H    HW: 5N0 959 655 H
   Component: J234__03H VW10 HI   1916
   Revision: 20013000    Serial number: 003E1P55L9JG
   Coding: 0013128
   VCID: 42DD4124288D942B047-8016
   Subsystem 1 - Serial number: 6332MTS604690620
   Subsystem 2 - Serial number: 6342MTS622580630
   Subsystem 3 - Serial number: 6351HTS66I3F69KR
   Subsystem 4 - Serial number: 6361HTS6HOGL69KR
   Part No SW: 5K0 953 569 AS    HW: 5K0 953 569 AS
   Revision: --X01---    Serial number: 20191127100109
   Coding: 389CA00009
   Shop #: WSC 12345 123 61029
   ASAM Dataset: EV_SMLSNGVOLWS A01004
   ROD: EV_SMLSNGVOLWS_VW46.rod
   VCID: 094F960859BB077305D-805C
365080 - Controls in Steering Wheel
          U108E 00 [009] - No Communications
                    Reset counter: 233
                    Mileage: 211209 km
                    Date: 2020.11.14
                    Time: 05:09:37
   Part No SW: 3C0 920 872 G    HW: 3C0 920 872 G
   Component: KOMBI         H03 0305
   Coding: 161F00
   Shop #: WSC 05314 115 00000
   VCID: 290FF688B97B677325D-807C
Address 18: Aux. Heat        Labels: 1K0-815-007.clb
   Part No: 5K0 963 272 E
   Component: Standheizer     043 4709
   Revision: 00043000    Serial number: 09021534000000
   Coding: 0031012
   Shop #: WSC 12345 111 45725
   VCID: 323D11E4982D24AB947-8066
Address 19: CAN Gateway        Labels:. 3C0-907-530-V3.clb
   Part No SW: 3C0 907 530 P    HW: 3C0 907 951
   Component: J533  Gateway   H13 0172
   Revision:   H13       Serial number: 3720Q1021700EC
   Coding: FDA7FF47420E02002002
   VCID: 2E0505948C15004BF0F-807A
                    Reset counter: 233
                    Mileage: 211209 km
                    Reset counter: 233
                    Mileage: 211209 km
01304 - Radio
                    Reset counter: 233
                    Mileage: 211209 km
   Part No SW: 0BS 907 554 A    HW: 0BS 907 554 A
   Component: Haldex 4Motion      4013
   Coding: 0000005
   VCID: 44D1473C32999A1B36B-8010
                    Reset counter: 138
                    Mileage: 211209 km
                    Date: 2015.04.07
                    Time: 05:09:37
   Part No SW: 3C0 959 799 H    HW: 3C0 959 799 H
   Component:    IMMO         071 0383
   Revision: 00071000    Serial number: VWZCZ000000000
   Shop #: WSC 50509 001 1048576
   VCID: 3E2535D45C75F0CB60F-806A
   Subsystem 1 - Part No: 3C0 905 861 H
   Component:    ELV          028 0380
   3C0905861H     ELV          028 0380
Address 36: Seat Mem. Drvr        Labels: 3C0-959-760.lbl
   Part No SW: 3C0 959 760 E    HW: 3C0 959 760 E
   Component: Sitzverstellung     1101
   Revision: 00005000    Serial number: 00000000000000
   VCID: 2F3B18908B1F0943FB9-807A
Address 37: Navigation
   Part No SW: 3C0 959 701 A    HW: 3C0 959 793 A
   Component: TUER-SG FT    002 0305
   Revision: 12101005    Serial number: 0000630969
   Coding: 0011FF
   ROD: EV_DCU42BroseDriveSide.rod
   VCID: 2615FDB4A865480B08F-8072
   Slave Driver:
   Subsystem 1 - Part No SW: 3C0 959 703     HW: 3C0 959 795   Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  004 0401
   Serial number: 00000001348689
   Coding: 0000D0
   Part No SW: 5N1 909 144 K    HW: 5N1 909 148 G
   Component: J500__APA-BS KL.150 0703
   Revision: 1AH03726    Serial number: 00100710097501
   Coding: 0000258
   Shop #: WSC 07913 003 1048576
   VCID: 3A2D39C4405DDCEB5C7-806E
02546 - Steering Limit Stop
                    Fault Status: 11100101
                    Reset counter: 233
                    Mileage: 211209 km
                    Date: 2015.04.07
                    Time: 05:09:37
                    (no units): 4.0
                    Voltage: 11.90 V
                    Fault Status: 11100100
                    Reset counter: 233
                    Mileage: 211209 km
                    Date: 2015.04.07
                    Time: 05:09:37
                    (no units): 4.0
                    Voltage: 11.90 V
Address 46: Central Conv.        Labels:. 3C0-959-799-46.clb
   Component: 02 KESSY PQ46 R 071 0231
   Coding: 00900A00D1430E76300494157000CF0B605821030424B8
   Part No SW: 3C0 959 702 A    HW: 3C0 959 792 A
   Component: TUER-SG BT    002 0305
   Revision: 14101005    Serial number: 0000602222
   Coding: 0011FE
   ROD: EV_DCU52BrosePasseSide.rod
   VCID: 270BF0B0AF6F5103339-8072
   Slave Passenger:
   Subsystem 1 - Part No SW: 3C0 959 704     HW: 3C0 959 794   Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  004 0401
   Serial number: 00000001351689
   Coding: 0000D0
   Part No SW: 3C8 907 801 E    HW: 3C8 907 801 E
   Component: J540 EPB3  VW-15417 0007
   Revision:   010       Serial number: 00000000211319
   Coding: 0000057
   VCID: 2C010F9CBA09725BDEB-8078
   Component: AFS-Steuergeraet    0142
   Coding: 2344129
   Subsystem 1 - Part No: 7L6 941 329   Labels: 3D0-941-329.CLB
   Component: AFS-Lst.-Modul l    X018
   Coding: 00000035
   Subsystem 2 - Part No: 7L6 941 330
   Component: AFS-Lst.-Modul r    X018
   Coding: 00000035
                    Reset counter: 233
                    Mileage: 211209 km
                    Date: 2015.04.07
                    Time: 05:09:37
                    Voltage: 11.93 V
                        ABS 1
Address 56: Radio
   Component:    RDK              0453
   Coding: 0161211
   Component: Anhaenger     H07 0070
   Revision: 3A001001    Serial number: 00000128176076
   Coding: 410D000100000000
   VCID: 30391BEC9A2116BBE23-8064
Address 6D: Trunk Elect.        Labels: 3C9-827-383.clb
   Part No SW: 3C9 827 383 G    HW: 3C9 827 383 J
   Component: J605  HECKDECKEL    0730
   Revision: 00H27001
   Subsystem 1 - Part No: 3C9 827 384 G
   Component: J756  HECKDECKEL    0730
   Subsystem 2 - Serial number: 1000H27001001C0014ÿ
Address 77: Telephone (J738)       Labels:. 1K8-035-730.clb
   Part No SW: 1K8 035 730 D    HW: 1K8 035 730 D
   Component: Telefon       H08 6900
   Revision: 00008000    Serial number: 00000330917527
   Coding: 012120
   VCID: 2A0D0984BCFD6C6B2C7-807E
01523 - Microphone for Telephone (R38)
                    Reset counter: 233
                    Mileage: 211209 km
                    Date: 2015.04.07
                    Time: 05:09:40
03427 - Right Audio Channel
                    Reset counter: 233
                    Mileage: 211209 km
                    Date: 2015.04.07
                    Time: 05:09:40
01304 - Radio
                    Reset counter: 233
                    Mileage: 211209 km
                    Date: 2015.04.07
                    Time: 05:09:41
End----(Elapsed Time: 02:23, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
langers2k
C?ID=224085
Do you have an autoscan from before the repair?
Your current code doesn't look right compared to 5K0 953 569 T modules in similar cars I found.
   Part No SW: 5K0 953 569 T    HW: 5K0 953 569 T
   Revision: --X01---    Serial number: 20130527101024
   Coding: 118A270002
   Revision: --X01---    Serial number: 20120531100453
   Coding: 5180270002
What codes have you tried which have been rejected?
Previous thread:
RisbergM
Viken, Norway
C?ID=424182
   Coding: 118A270002
   Coding: 5180270002
Hi.
Thanks for your replay @langers2k.
Original Coding was as below.
Component: LENKS.MODUL 009 0122
Coding: B998A7002
This coding is not accepted after the new clock spring was installed.
DGMotors
C?ID=57532
I've had this before the ECU are different are require a completely different coding to original. You can try generating the new code by using the long coding helper and checking all the options you have, but to be honest as I have ODIS I just use that as it quicker and just works without playing around.
RisbergM
Viken, Norway
C?ID=424182
Hi DGMotors, thanks for your replay.
That is part of the problem for me as well.
The dealer here in Norway has ODIS as well, but not able to solve this. They even claim that the Tech support from Germany has been connected to the car online without any result either.
Do you happen to have a code suggestion for me?
As I've mentioned, I have the 8 button MFSW.
Best regards Martin
NEtech
Denmark
C?ID=56995
Coding: B998A7002
Do you have an Autoscan from your car with this Coding, where there is no problem ?
The length of the coding is not correct, maybe it should be: B998A70020
I have doubts that this coding was/is correct for your car, eg. it has not MFSW, Byte 1
Maybe involved parts not correct (365080 - Controls in Steering Wheel).
Yoiu could try this:
3992A70000
RisbergM
Viken, Norway
C?ID=424182
Hi NEtech.
You're right.
The original Code was B998A70002
for some reason i've managed to delete one Zero.
I'll go to the dealer and try your code suggestion tomorrow.
