ABS 2004 Beetle 1.8L Turbo
hamburg3r
Saint Robert, MO, USA
C?ID=425843
I was gifted a 2004 Beetle GLS 1.8L Turbo with a few issues. The first issue I'm trying to tackle is the ABS light is on. I've connected a code reader to it and I get the error code U0121. I was also told that a VW dealership has previously diagnosed this car with a faulty ABS control modular.
After I got the the U0121 code I disconnected the ABS from the car and ordered a replacement used part (same part numbers).........After researching the ABS system a little more I realize I should have used the VAG system to scan the car prior to disconnecting everything to help determine the long coding for the ABS.
Flash forward. I have purchased the VCDS with Hex-V2. My question is should I reinstall the old ABS (has a failure to communicate modular) to maybe get the "long code" OR would I be able to determine the long code in order to program the new ABS to work with my beetle?
Jef
HQ
When asking for assistance, you need to include a full Auto-Scan from the car so we have more details. If the original ABS module is dead, then have the replacement ABS module installed and post that Auto-Scan. 2004 Beetle won't have "long coding" which are Hexadecimal values. This car will use short coding which are 5 or 7 digits long, 0 to 9 values. We should be able to sort it out once we see a complete Auto-Scan.
hamburg3r
C?ID=425843
Once the part comes in, I will install and conduct a auto-scan. I will follow up then. Thanks for the quick reply
hamburg3r
C?ID=425843
So I've installed the ABS control modular/pump. It had the same part numbers as the original. Replacing it, removed the ABS warning light and check engine light from the dashboard. A new light came on, looks like it might be a Traction control light. It's a triangle with circled arrow around it. I've also ran and attached the Auto-Scan. Looks like there are a couple of other issues I need to take a look at as well.
The ABS came off a 2005 new beetle, how do I know if it's setup correctly for my 2004 model?
Here is the scan:
Friday,27,November,2020,15:50:46:36139
VIN: 3VWCD21Y14M308022   License Plate:
Mileage: 232090km-144214mi   Repair Order:
Chassis Type: 1Y (1Y - VW New Beetle Cab (2003 > 2010))
Scan: 01 02 03 08 15 17 19 25 26 29 35 37 39 46 54 56 65 75
VIN: 3VWCD21Y14M308022   Mileage: 232090km-144214miles
Address 01: Engine        Labels: 06A-906-032-AWV.lbl
   Part No: 06A 906 032 PS
   Component: 1.8l 5VT NBC AG6G   5107
   Coding: 00004
   Shop #: WSC 00066
   VCID: 7EA5F59159EFA74B20F-513C
   3VWCD21Y14M308022     VWZ5Z0C6192069
Readiness: 0110 1101
Address 03: ABS Brakes        Labels: 1C0-907-37x-ESP-F.lbl
   Part No: 1C0 907 379 M
   Coding: 0019970
   Shop #: WSC 00066 000 00000
   VCID: 343117B92223BD1B86B-5160
Address 15: Airbags        Labels: 1T0-909-605.lbl
   Part No: 6Q0 909 605 AC
   Component: 0F AIRBAG VW71      0507
   Coding: 0012358
   VCID: 78A9E3897ECB997B6A3-513C
No Faults Found
Address 17: Instruments        Labels: 1C0-920-x4x.lbl
   Part No: 1C0 920 951 N
   Component: KOMBI+WEGFAHRS. M73 V02
   Coding: 09234
   Shop #: WSC 19400
   VCID: 2C010FD9FF13E5DBDEB-4B00
   Part No: 6N0 909 901
   Component: Gateway K<->CAN    V022
   Coding: 00006
   Shop #: WSC 00066
   VCID: 70B9DBA913BBC13BA23-4B00
Address 26: Auto Roof        Labels: 1Y0-959-255-HYD.lbl
   Part No: 1Y0 959 255
   Component:  VSG  NBC       ü
   VCID: 7DA7F29D51E9BC53395-513C
02000 - Switch Position
02460 - Position Sensor for Left Linkage Flap Position Sensor (G442)
            009 - Open or Short to Ground
02469 - Motor for Right Convertible Top Locking (V292)
   Part No: 1C0 959 799 G
   Component: 6J Komfortgerát HLO 0004
   Coding: 00256
   Shop #: WSC 00066
   VCID: 3B233C850A7D7263471-4B00
   Subsystem 1 - Part No: 1Y1959801
   Component: 6J Tõrsteuer.FS KLO 0001
   Subsystem 2 - Part No: 1Y1959802A
   Component: 6J Tõrsteuer.BF KLO 0001
   Subsystem 3 - Part No: 1Y0959811
   Component: 6J Tõrsteuer.HL KLO 0001
   Subsystem 4 - Part No: 1Y0959812
   Component: Tõrsteuer.HR KLO 0005
            37-00 - Faulty
            62-10 - No or Incorrect Adjustment - Intermittent
End----(Elapsed Time: 03:50, VBatt start/end: 11.5V/11.5V. VIgn 11.4V)-----
Jef
HQ
So um... this was a manual swap?
3VWCD21Y14M308022
Transmission specificationG1A6-speed automatic transmission
hamburg3r
C?ID=425843
3VWCD21Y14M308022
From what I understand it still has the original transmission. The engine was replaced a few years ago, but it's always been an automatic trans. Where are you pulling this info from?
You need to do a Steering Angle Sensor calibration.
See here:
I followed the calibration, it cleared the fault. Thanks.
Jef
HQ
I ran the VIN through Partslink24 and it shows the trans being an automatic, but your Auto-Scan doesn't have a transmission in it.
hamburg3r
C?ID=425843
Would there be a reason why the transmission wasn't included? I ran a few others with similar reports.
NostraJackAss
Yeah sure something going on being nefarious FOD or with the K line because of the ABS module creating interference?
Unplug ABS and see if Trans wakes up in scan yet?
Ecu is for automatic and correct + coded for it.
ABS module correct part number too!
Wiring harness issue likely did you qualify tracks?
Why was ABS module changed, have a legacy scan?
hamburg3r
C?ID=425843
Can I just remove power to the ABS module (fuse box connector) or do I have to remove the larger connector on the module? It's a PITA to get at the module connector. Also I don't have previous scans or history on why the original ABS quit communicating with ECU.
I haven't started tracing wires yet, but it looks like I might have to start investigating the harness.
Jef
HQ
I suspect the TCM is talking to some extend otherwise ECM, cluster and Gateway most likely would be flagging codes for no TCM.... but is the TCM talking to a scan tool?
Start VCDS, then [Select] followed by [02-Auto Trans] and see if you get communication.
NostraJackAss
:p
