My 09 S5 started throwing these errors after I changed the air intake filter and cabin filter on my car. It seems unrelated to the errors, but I'm pretty sure I got these errors right after or maybe within a day or two. This was about 2 months ago.
I've copy pasted the log below. There seems to be a bunch of other errors too, maybe resetting the system would get rid of them, but I wasnt sure how to. I've only recently started use the Ross Tech tool.
I have some aftermarket parts and tune, which I doubt may be causing some of these, but the car runs and drives fine. and I'm mostly trying to fix the parking brake malfunction and airbag light on the dash.
My initial search about the parking brake malfunc returned that the parking brake switch maybe faulty. This has happened to people who have taken apart the shift boot panel. I did too, a couple of months ago to switch out the shift knob.
It also could be the airbag control module that's known to go bad. The module on some cars of this generation was subject to a product recall but my VIN didn't turn up any recalls on the AUDI websit.
Would appreciate any help! Thanks.
Chassis Type: 8T-AU48 (8T0)
Scan: 01 03 05 06 08 09 15 16 17 19 36 42 46 47 52 53 55 56 65 77
VIN: WAURV78T59A006770 Mileage: 157640km-97952miles
Address 01: Engine (J623-CAUB) Labels: None
Part No SW: 8T0 907 560 UM HW: 8T0 907 560
Component: V.6 JHM H10 0003
Revision: 76H10---
Coding: 01140009180F0120
Shop #: WSC 43231 000 1048576
VCID: 196FC9BC09906D93B5D-804C
004898 - Knock Sensor 3 (G198)
P1322 - 001 - Signal too Large - Intermittent
Fault Status: 00100001
Mileage: 157416 km
Date: 2008.02.09
Time: 14:43:45
RPM: 2846 /min
Load: 26.7 %
Speed: 114.0 km/h
Temperature: 97.0蚓
Temperature: 21.0蚓
Absolute Pres.: 1010.0 mbar
Voltage: 14.224 V
Readiness: 0100 0000
Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V1.clb
Part No SW: 8K0 907 379 AB HW: 8K0 907 379 AB
Component: ESP8 quattro H04 0060
Coding: 110500
Shop #: WSC 06325 000 00000
VCID: 79AFE93CE9D08D9315D-802C
013 - Check DTC Memory
Fault Status: 01101101
Reset counter: 125
Mileage: 152555 km
Date: 2020.10.06
Time: 09:45:35
Hex Value: 0x0040
Hex Value: 0x40A2
Hex Value: 0x0013
Hex Value: 0x02A9
Hex Value: 0x00FF
Part No SW: 8K0 907 289 F HW: 8K0 907 289 F
Component: BCM2.01 H38 0253
Revision: 00003002
Coding: 0B0000
VCID: 3C213028A66278BB4EB-8068
Subsystem 1 - Part No SW: 8T0 959 754 M HW: 8T0 959 754 M
Component: FBSAUDIB8 IDG H34 0050
Serial number: 0107000112197002
Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: ELVAUDIB8 H35 0039
Serial number: 0208000011404003
Address 06: Seat Mem. Pass (J521) Labels:. 8T0-959-760.clb
Part No SW: 8T0 959 760 B HW: 8T0 959 760 B
Component: MEM-BFS H09 0043
Revision: AA000000 Serial number: 00001001106702
Coding: 00017025002C00000000
VCID: 42DD4ED0C4860E4B047-8016
Address 08: Auto HVAC (J255) Labels:. 8Tx-820-043-3Z.clb
Part No SW: 8T1 820 043 AC HW: 8T1 820 043 AC
Component: KLIMA 3 ZONEN H06 0140
Revision: C1000000 Serial number: 0123.06.080043
Coding: 48022000
VCID: 72BDDE10B4A6FECB547-8026
Reset counter: 157
Mileage: 157330 km
Date: 2008.02.08
Time: 00:01:56
Part No SW: 8K0 907 063 D HW: 8K0 907 063 D
Component: BCM1 1.0 H22 0253
Revision: 05022001 Serial number: 00000000167390
Coding: 26001091063CAF010000080300003D3D0F1C13880001016100 0000
VCID: 303914187A2A8CDBE23-8064
Subsystem 1 - Part No SW: 8T1 955 119 C HW: 8J1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 280608 H13 0040
Serial number: SWFBIE 0000060
Coding: 00FD11
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Serial number: 10165662
Coding: 02532C
Subsystem 3 - Part No SW: 8K0 941 531 J HW: 8K0 941 531 J
Component: E1 - LDS H07 0070
Serial number: 00000000002606080808
Subsystem 4 - Part No SW: 8K0 907 410 A HW: 8K0 907 410 A
Component: UGDO HL US H04 0060
Part No SW: 8K0 959 655 C HW: 8K0 959 655 C
Component: AirbagVW-AU10 H26 0410
Serial number: 0039GD125LP9
Coding: 303333333730303030304A55304C38543053
VCID: 3D273D2CBDF871B3795-8068
Subsystem 1 - Part No SW: 8K0 959 339 HW: 8K0 959 339
Component: BF-Gewichtss. H01 0050
Serial number: 5810000R0800000X7V
9 Faults Found:
9437210 - Igniter for Driver's Airbag
B1000 1A [137] - Resistance Too Low
Mileage: 157334 km
Date: 2008.02.08
Time: 02:25:27
9443113 - Driver's Side Airbag Crash Sensor
B1017 29 [137] - Signal Implausible
Fault Frequency: 45
Mileage: 153142 km
Date: 2020.10.14
Time: 15:18:36
9451049 - Crash sensor side airbag; passenger side
B1036 29 [137] - Signal Implausible
Fault Frequency: 58
Mileage: 152578 km
Date: 2020.10.08
Time: 06:36:51
9443881 - Driver's Front Airbag Crash Sensor
B101A 29 [137] - Signal Implausible
Fault Frequency: 137
Mileage: 152555 km
Date: 2020.10.06
Time: 09:45:34
9444137 - Front Passenger's Front Airbag Crash Sensor
B101B 29 [137] - Signal Implausible
Fault Frequency: 127
Mileage: 152555 km
Date: 2020.10.06
Time: 09:45:34
9443369 - Rear Side Airbag Crash Sensor (on driver's side)
B1018 29 [137] - Signal Implausible
Fault Frequency: 113
Mileage: 152555 km
Date: 2020.10.06
Time: 09:45:34
9443625 - Rear Side Airbag Crash Sensor (on front passenger's side)
B1019 29 [137] - Signal Implausible
Mileage: 152555 km
Date: 2020.10.06
Time: 09:45:34
13635840 - Supply voltage
U1011 00 [009] - Voltage too Low
[Powersupply lower threshold fall short of]
Fault Frequency: 119
Reset counter: 165
Mileage: 152578 km
Date: 2020.10.09
Time: 07:13:32
10485833 - Internal Control Module Memory Check Sum Error
B2000 49 [137] - Internal electronic failure
[Electronic Control Unit Malfunction]
Mileage: 155269 km
Date: 2020.10.30
Time: 20:24:46
Part No SW: 8K0 953 568 F HW: 8K0 953 568 F
Component: Lenks.Modul H12 0013
Revision: -------- Serial number: 90304HFQ000DK
Coding: 000016
VCID: 3D273D2CBD7871B3795-8068
Component: E221 - MFL H02 0003
00889 - Horn (H)
Fault Status: 00100111
Reset counter: 157
Mileage: 157330 km
Date: 2008.02.08
Time: 00:45:10
Part No SW: 8T0 920 981 E HW: 8T0 920 981 E
Component: KOMBIINSTR. H30 0221
Revision: 00000000 Serial number: 97S53NY68
Coding: 8B1501000300D705020000
VCID: 3E253A20B07E6AAB60F-806A
Part No SW: 8T0 907 468 H HW: 8T0 907 468 H
Component: GW-BEM 5CAN H06 0091
Revision: GB102039 Serial number: 3900G0861982BA
Coding: 000303
VCID: 46D552C0E8AE326B28F-8012
Subsystem 1 - Part No SW: 8K0 915 181 B HW: 8K0 915 181 B
Component: J367-BDM H04 0150
Serial number: 18028E0A130608
Reset counter: 125
Mileage: 152578 km
Date: 2020.10.09
Time: 07:51:52
Address 36: Seat Mem. Drvr (J136) Labels:. 8T0-959-760.clb
Component: MEM-FS H09 0043
Revision: AA000000 Serial number: 00001001106919
Coding: 00197325002C00000000
Mileage: 152578 km
Date: 2020.10.09
Time: 09:11:06
Part No SW: 8K0 959 793 HW: 8K0 959 793
Component: TSG FA H09 0149
Revision: Serial number: C 8
Coding: 011C03224E002201
VCID: 7DA7FD2CFDF8B1B3395-8028
Revision: 00003002 Serial number: 0110418479
Coding: 0106029A007A444400B000
Shop #: WSC 06342 000 00000
Subsystem 1 - Part No SW: 8K0 959 719 HW: 8K0 959 719
Component: GTO BF H06 0040
Serial number: 00000000000000037724
Component: LIN BACKUP HO H03 1301
Subsystem 3 - Part No SW: 8R0 959 591 HW: 8R0 959 591
Component: J245EE16SKB10 H01 0180
02615 - Fuel Tank Cap; Lock
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 83
Mileage: 131446 km
Date: 2019.12.02
Time: 12:01:23
02616 - Fuel Tank Cap; Unlock
Reset counter: 83
Mileage: 131446 km
Date: 2019.12.02
Time: 21:33:27
Address 47: Sound System
Part No SW: 8T0 959 792 M HW: 8T0 959 792 D
Component: TSG BF H08 1501
Coding: 011C03224000120102
VCID: 52FD7E9014E69ECBB47-8006
Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
Part No SW: 8K0 907 801 E HW: 8K0 907 801 E
Component: EPB Audi B8 H05 0060
Revision: 00000003 Serial number: 00000000159896
VCID: 313F111C712085D3EDD-8064
Fault Status: 11101101
Reset counter: 15
Mileage: 152555 km
Date: 2020.10.06
Time: 09:45:35
Voltage: 14.00 V
Count: 80
Hex Value: 0x02E3
Hex Value: 0x0001
Hex Value: 0x1010
Fault Status: 00101011
Fault Frequency: 82
Reset counter: 231
Mileage: 1048574 km
Voltage: 12.70 V
Count: 38
Hex Value: 0x0160
Hex Value: 0x0008
Hex Value: 0x0101
02442 - Function Lamp in Control Head
Fault Status: 00101001
Reset counter: 179
Mileage: 1048574 km
Voltage: 12.70 V
Count: 72
Hex Value: 0x0170
Hex Value: 0x0008
Hex Value: 0x0101
Address 55: Headlight Range Labels: 8K0-907-357.clb
Part No: 8K0 907 357 B
Component: Dynamische LWR H01 0030
Coding: 0000002
Shop #: WSC 06324 000 00000
VCID: 343118088232B0FB86B-8060
Address 56: Radio (J503) Labels:. 8Tx-035-1xx-56.clb
Part No SW: 8T1 035 195 L HW: 8T1 035 195 L
Component: Symph3 Sirius H02 0211
Revision: 00000004 Serial number: AUZ5Z4H1027016
Coding: 050300020104850043D9070001
VCID: 40D944D8CA8A1C5B123-8014
Subsystem 1 - Part No SW: 8T0 919 603 A HW: 8T0 919 603 A
Component: Display
03138 - Input AUX IN
Reset counter: 34
Mileage: 143130 km
Date: 2008.02.28
Time: 09:36:01
Address 65: Tire Pressure (J502) Labels: 8K0-907-273.clb
Part No SW: 8K0 907 273 A HW: 8K0 907 273 A
Component: J502-RDK H03 0250
Revision: 00001001 Serial number: 12926781248728
Coding: 0CD154
Part No SW: 8T0 862 336 A HW: 8T0 862 336 A
Component: FSE_256x BT H33 0520
Revision: 00000000 Serial number: 00000005004396
Coding: 0010370
VCID: 392F293CA5504D9355D-806C
