- Nov 11, 2020
- 4
- 2
- Rochester NY, USA
- C?ID=385831
Recently purchased a 2010 Golf 2.5l auto-tragic with with 87k miles on it with a few electrical issues. Primary issue is the ABS module appears to be bad. Checked all fuses and connections to the module and everything looks good.
My main question is has anyone had any experience using a slightly different ABS module? Is there any coding that would need to be done to replace the module with the correct part number or an alternative? The module is quite expensive so I set out to find a used one in the local U-Pull yard. I've used the VW parts website to try and determine which cars would be compatible and pulled a few ABS modules from different cars what should have been compatible but the part numbers don't match.
Parts installed in the car-
ABS Control Module- 1K0 907 379 AH
ABS Pump- 1K0 614 517 AS
Assembly pulled from 2009 Jetta- (Pump Listed as compatible from VW parts site)
ABS Control Module- 1K0 907 379 AD
ABS Pump- 1K0 614 517 BD
Assembly pulled from 2011 Jetta- (Module listed as compatible VW parts site)
ABS Control Module- 1K0 907 379 BJ
ABS Pump- 1K0 614 517 DL
Two other errors appear to be the passenger seat occupancy module and passenger side door tweeter. I ordered another occupancy module I'm not sure if this needs to be coded in as well.
Also this scan was not taken with my cable it was taken with another official VCDS cable that belongs to my friend who picked up the car for me and is driving it from FL to NY
Tuesday,17,November,2020,20:22:19:22433
VIN: WVWBA7AJ2AW272134 License Plate: 2010 GOLF
Mileage: 140710km-87433mi Repair Order:
Chassis Type: AJ-VW36 (1K0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 42 44 46 52 56 65
VIN: WVWBA7AJ2AW272134 Mileage: 140710km-87433miles
Address 01: Engine (CBT) Labels: 07K-906-055-CBT.clb
Part No SW: 07K 906 055 AH HW: 07K 906 055 M
Component: 2,5l R5/4V G 9970
Revision: G6H03--- Serial number:
Coding: 0000075
Shop #: WSC 05053 444 101406
VCID: 74B1DB2192BE55BB46B-8020
Readiness: 0110 0101
Part No SW: 09G 927 750 HG HW: 09G 927 750 HG
Component: AQ 250 6F 1631
Revision: 00H76000 Serial number:
Coding: 0000840
VCID: 7DA7FE05A1F414F3395-8028
Part No SW: 1K0 907 379 AH HW: 1K0 907 379 AH
Component: ESP MK60EC1 H30 0107
Revision: 00H30001
Coding: 114B400C492900FC880C02E7921D0041300000
VCID: 78A9EF1182D631DB6A3-802C
Fault Status: 00101110
Reset counter: 3
Mileage: 140715 km
Date: 2020.11.17
Time: 22:02:45
Count: 7
Count: 4608
Count: 104
Count: 50718
Count: 512
01130 - ABS Operation
Fault Status: 01101000
Reset counter: 3
Mileage: 140715 km
Date: 2020.11.17
Time: 07:35:43
Count: 7
Count: 12
Count: 12288
Count: 100
Count: 43520
Count: 1
Count: 256
Part No SW: 3C8 907 336 AH HW: 3C8 907 336 AH
Component: Climatic H14 0305
Revision: 00009001
Coding: 0000001002
ROD: EV_ClimaBasis_VW36.rod
VCID: 73B3D83D9B3052835F1-8026
Address 09: Cent. Elect.
Part No SW: 5K0 959 655 B HW: 5K0 959 655 B
Component: AirbagVW10G 021 0706
Serial number: 003C4D0A8C1K
Coding: 00003031
ASAM Dataset: EV_AirbaVW10SMEVW360 A01012
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 392F2A15F9DCE8D355D-806C
Subsystem 1 - Part No SW: 5K0 959 339 HW: 5K0 959 339
Component: BF-Gewichtss. 007 0002
Serial number: ---0000R--0004YJTL00
Serial number: 3572MSME5527764EZZZ0
Serial number: 3582MSME7643004FZZZX
Serial number: 3512QSME3C38455CZZZ0
Serial number: 3522QSME1E27455EZZZ1
Serial number: 35527SME7B16421FZZZN
Serial number: 35627SME2C357128ZZZH
B10B3 00 [008] - Function Restriction due to Implausible Message(s)
Reset counter: 43
Mileage: 140715 km
Date: 2020.11.17
Time: 07:51:54
Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
Part No SW: 1K0 953 549 CP HW: 1K0 953 549 CP
Component: J0527 053 0111
Coding: 0001034
VCID: 025D8DF9D80A6B0B447-8056
Part No SW: 5K0 920 970 P HW: 5K0 920 970 P
Component: KOMBI H03 0305
Coding: 270D00
VCID: 3B23301DF3E0DAC3471-806E
Part No SW: 1K0 907 530 AD HW: 1K0 907 951
Component: J533 Gateway H07 0112
Revision: H07 01 Serial number: 040110F2001721
Coding: ED801F07001202000000
VCID: 698FBA55C57C9853E5D-803C
Part No SW: 5N0 919 879 HW: 5N0 919 879
Component: Kompass 001 0001
Revision: 00001000 Serial number: 1225223T75QP04
Coding: 0000002
VCID: 7EA5F909ACF20FEB20F-802A
Component: IMMO H03 0305
VCID: 6A8DC559CCFA934BEC7-803E
Part No SW: 5K0 959 701 D HW: 5K0 959 701 D
Component: Tuer-SG 009 2137
Coding: 0001076
VCID: 3333183DD73012839F1-8066
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 70 3001
Revision: 00H17000
VCID: 313F12352D2C2093EDD-8064
Address 46: Central Conv.
Part No SW: 5K0 959 702 B HW: 5K0 959 702 B
Component: Tuer-SG 009 2111
Coding: 0001076
VCID: 323D1D39282A1B8B947-8066
Address 56: Radio Labels: 1K0-035-161.lbl
Part No SW: 1K0 035 161 D HW: 1K0 035 161 D
Component: Radio DE2 020 0022
Revision: 00020000 Serial number: VWZ4Z7J6443239
Coding: 0040401
VCID: 2019E77176C6991B723-8074
00875 - Treble Speaker Front Right (R22)
Address 65: Tire Pressure (J502) Labels:. 1K0-937-08x-65.clb
Part No SW: 1K0 937 085 G HW: 1K0 937 085 G
Component: RDK 103 0521
Coding: 018705
VCID: 3333183DDB3012839F1-8066
End----------(Elapsed Time: 00:57, VBatt start/end: 12.3V/12.3V)-----------
