1.9 AFN TDI in a 1990 Vanagon. I am relatively new to 1.9 TDIs, so please be kind. I had low boost and was blowing white smoke intermittently. The vehicle stalled and I could not restart. Here are the codes. Any feed back would be appreciated. I have a new N75 and have replaced vacuum lines.
Chassis Type: 3B - VW Passat B5 (1997 > 2005)
Address 01: Engine Labels: Redir Fail!
Part No: 038 906 018 P
Component: 1,9l R4 EDC 01SG 1629
Coding: 00002
Shop #: WSC 05314
VCID: 2313EBB2B2C099E36F1-4B3C
7 Faults Found:
01268 - Quantity Adjuster (N146)
35-10 - - - Intermittent
00539 - Fuel Temperature Sensor (G81)
00741 - Brake Pedal Monitoring
27-00 - Implausible Signal
00575 - Intake Manifold Pressure
17-10 - Control Difference - Intermittent
00625 - Vehicle Speed Signal
00513 - Engine Speed Sensor (G28)
03-00 - No Signal
Readiness: N/A
End----(Elapsed Time: 05:27, VBatt start/end: 12.9V/13.0V. VIgn 0.0V)------
Thanks in advance.
Coding: 00002
Shop #: WSC 05314
7 Faults Found:
03-00 - No Signal
Readiness: N/A
Thanks in advance.
