- Nov 9, 2020
- 19
- 5
- Miri, Malaysia
- C?ID=392177
Greeting to all,
i have another case which is more complicated and i do hope to seek support again from all expertise here.
below are the progress i have done so far to this vehicle
engine ecu x 2 has been change and programmed
- ecu faulty, ecu unable to communicate, radiator fan automatically switch on when key position at ON.
the engine wont crank via the ignition key, gear display in Neutral.
the engine can manually crank by direct wire to starter motor.
Tuesday,24,November,2020,09:26:49:16992
VCDS Version: 20.4.2.0 HEX-NET CB: 0.4513.4
VIN: WUAZZZ427CN001976 License Plate:
Chassis Type: 42-AU35 (7N0)
Scan: 01 02 03 08 09 10 11 31 14 15 16 17 19 25 2E 37 42 46 47 52
56 61 6C 77 A6
VIN: WUAZZZ427CN001976 Mileage: 20640km-12825miles
11-Engine II -- Status: Malfunction 0010
31-Engine other -- Status: Malfunction 0010
A6-Microphone -- Status: OK 0000
Address 01: Engine (BUJ) Labels:. 07L-910-552-BUJ1.clb
Part No SW: 424 910 552 K HW: 420 907 552 B
Component: 5.2L V10HDZ/4V F ª0010
Revision: F5H10--- Serial number: AUX7Z0KNFNS02T
Coding: 011000001B0F0020
Shop #: WSC 00046 000 00000
VCID: 1B76F71DDAE7A05EE6-804E
12 Faults Found:
Temperature: -40.0°C
Absolute Pres.: 0.0 mbar
Voltage: 0.000 V
012423 - Voltage Supply Relay for Engine Components
P3087 - 004 - Electrical Malfunction - Intermittent
Temperature: 24.0°C
Temperature: 27.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 12.065 V
000256 - Mass Air Flow Sensor (G70)
P0100 - 004 - Supply Voltage - Intermittent
Mileage: 20648 km
Time: 31:63:63
Temperature: 25.0°C
Temperature: 27.0°C
Voltage: 12.065 V
008853 - Fuel Pressure Regulator Valve (N276)
P2295 - 002 - Short to Ground - Intermittent
Mileage: 20648 km
Date: 2020.07.21
Time: 00:00:02
Temperature: 25.0°C
Temperature: 27.0°C
Voltage: 11.811 V
012312 - Valve for Exhaust Flap 1 (N321)
P3018 - 002 - Short to Ground - Intermittent
Mileage: 20648 km
Date: 2020.07.21
Time: 00:06:09
RPM: 126 /min
Load: 73.7 %
Temperature: 25.0°C
Temperature: 28.0°C
Voltage: 11.811 V
001112 - Evap System Purge Control Valve (N80)
P0458 - 002 - Short to Ground - Intermittent
Mileage: 20648 km
Date: 2020.07.21
Time: 00:06:09
RPM: 126 /min
Load: 73.7 %
Temperature: 25.0°C
Temperature: 28.0°C
Voltage: 11.811 V
005171 - Secondary Air Pump Relay (J299)
P1433 - 004 - Open Circuit - Intermittent
Mileage: 20648 km
Date: 2020.07.21
Time: 00:06:09
RPM: 126 /min
Load: 73.7 %
Temperature: 25.0°C
Temperature: 28.0°C
Voltage: 11.811 V
005153 - Secondary Air Injection Solenoid Valve (N112)
P1421 - 002 - Short to Ground - Intermittent
Mileage: 20648 km
Date: 2020.07.21
Time: 00:06:09
RPM: 126 /min
Load: 73.7 %
Temperature: 25.0°C
Temperature: 28.0°C
Voltage: 11.811 V
005494 - Right Engine Mount Solenoid Valve (N145)
P1576 - 002 - Short to Ground - Intermittent
Mileage: 20648 km
Date: 2020.07.21
Time: 00:06:09
RPM: 126 /min
Load: 73.7 %
Temperature: 25.0°C
Temperature: 28.0°C
Voltage: 11.811 V
012425 - Signal Line for Fuel Pump Electronics
P3089 - 004 - Electrical Malfunction
Mileage: 20648 km
Date: 2020.07.21
Time: 00:06:09
RPM: 126 /min
Load: 73.7 %
Temperature: 25.0°C
Temperature: 28.0°C
Voltage: 11.811 V
009525 - Ignition Switch; Run/Start Position Circuit
P2535 - 001 - Short to Plus
Fault Status: 01100001
Mileage: 20648 km
Date: 2020.07.21
Time: 00:11:04
Temperature: 25.0°C
Temperature: 28.0°C
Voltage: 12.065 V
006435 - Please Check DTC Memory of ECU Number 2
P1923 - 008 -
Fault Status: 01101000
Mileage: 20648 km
Date: 2020.08.11
Time: 15:31:18
Temperature: 25.0°C
Temperature: 27.0°C
Voltage: 14.224 V
Readiness: 0110 1101
Address 02: Auto Trans Labels: 420-910-156-V2.clb
Part No SW: 420 910 156 L HW: 420 927 156
Component: SL600 5.2L FSI HDZ 0040
Revision: SBH02001 Serial number: 7LRNK946U
Coding: 0000001
Shop #: WSC 04940 001 00001
VCID: 187CE8112BD1CB46CB-804C
Subsystem 1 - Part No: 420 713 041 C
Component: A11 C02 11.11.11 0A11
Address 03: ABS Brakes Labels: None
Part No SW: 420 907 379 HW: 420 614 517 D
Component: ESP8 quattro H01 0200
Coding: 0000267
Shop #: WSC 02331 785 00200
VCID: 59FAAD15905B124E34-800C
Address 08: Auto HVAC Labels: 420-820-043.clb
Part No SW: 420 820 043 E HW: 420 820 043 E
Component: J255 Klima 1 Zone 0100
Revision: 00H06007 Serial number: 00000001202978
Coding: 1573930
VCID: 0C5484416F0937E67F-8058
Reset counter: 179
Mileage: 20648 km
Date: 2020.08.11
Time: 15:53:04
Address 09: Cent. Elect. (J519) Labels:. 8P0-907-063.clb
Part No SW: 8P0 907 063 AC HW: 8P0 907 063 AC
Component: BCM PQ35 H 112 0715
Revision: AB112715
Coding: 40180A00802100C0000000801400080440FF01FF520101F05C4001000000
VCID: 75A2C1A5DC83562E30-8020
Subsystem 1 - Part No SW: 424 955 113 HW: 424 955 113 Labels: 1KX-955-119.CLB
Component: Wischer AudiR H23 0040
Coding: 005912
Address 10: Park/Steer Assist (J446) Labels:. 8P0-919-475-7X2.clb
Part No SW: 8P0 919 475 N HW: 8P0 919 475 N
Component: PARKHILFE 8K H01 0140
Revision: 11001001 Serial number: 12501132701239
Coding: 30010C
Shop #: WSC 02391 823 56573
VCID: 49DA7D55E0FB62CE84-801C
Address 11: Engine II Labels:. 07L-910-552-BUJ2.clb
Voltage: 0.000 V
004763 - Fuel Pressure Regulator Valve; Bank 2 (N276)
P129B - 004 - Open Circuit - Intermittent
Temperature: 24.0°C
Temperature: 27.0°C
Voltage: 12.065 V
000268 - Mass Air Flow Sensor (G246)
P010C - 004 - Signal too Low - Intermittent
Mileage: 20648 km
Time: 31:63:63
Temperature: 25.0°C
Temperature: 27.0°C
Voltage: 12.065 V
005264 - EVAP Canister Purge Valve 2 (N333)
P1490 - 002 - Short to GND - Intermittent
Mileage: 20648 km
Date: 2020.07.21
Time: 00:06:09
RPM: 114 /min
Load: 73.7 %
Temperature: 25.0°C
Temperature: 28.0°C
Voltage: 11.811 V
005251 - Relay for Secondary Air Injection Pump 2 (J545)
P1483 - 002 - Short to Ground - Intermittent
Mileage: 20648 km
Date: 2020.07.21
Time: 00:06:09
RPM: 114 /min
Load: 73.7 %
Temperature: 25.0°C
Temperature: 28.0°C
Voltage: 11.811 V
005490 - Left Engine Mount Solenoid Valve (N144)
P1572 - 002 - Short to Ground - Intermittent
Mileage: 20648 km
Date: 2020.07.21
Time: 00:06:09
RPM: 114 /min
Load: 73.7 %
Temperature: 25.0°C
Temperature: 28.0°C
Voltage: 11.811 V
Address 14: Susp. Elect. Labels: 8P0-907-376.lbl
Part No SW: 420 910 376 A HW: 420 907 376 A
Component: J250 Raddaempfung 0170
Revision: --H16--- Serial number: 190DPH 1288153
Coding: 0000052
VCID: 116A9535082B1A0E8C-8044
013 - Check DTC Memory
Fault Status: 01101101
Reset counter: 179
Mileage: 20648 km
Date: 2020.08.11
Time: 15:53:01
Voltage: 14.28 V
Voltage: 4.95 V
Address 15: Airbags Labels: 420-959-655.lbl
Part No SW: 420 959 655 HW: 420 959 655
Component: SR Airbag 9.43 H02 0020
Revision: 93H02002 Serial number: 003B8000FHAL
Coding: 0021330
VCID: 5DF2B9058473EE6E58-8008
Subsystem 1 - Serial number: 63328RB40662025A9
Subsystem 2 - Serial number: 63428RB4066202B28
Subsystem 3 - Serial number: 63747RB4067466D8X
Subsystem 4 - Serial number: 63847RB406746710F
Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
Component: J0527 H37 0070
Coding: 0004141
VCID: 41CA657518CBAA8E5C-8014
Component: E0221 H06 0030
Address 17: Instruments Labels: 420-920-xxx-17.clb
Part No SW: 420 920 930 P HW: 420 920 930 P
Component: KOMBIINSTR. VDO H02 0650
Revision: D0H02002 Serial number: 224NK002000727
Coding: 0065828
Shop #: WSC 35809 003 1048576
VCID: 1D72F905C4F3AE6E18-8048
00438 - Fuel Supply Sensor 2 (G169)
010 - Open or Short to Plus
Fault Status: 01101010
Reset counter: 179
Mileage: 20648 km
Date: 2020.08.11
Time: 15:53:02
00771 - Fuel Level Sensor (G)
Reset counter: 179
Mileage: 20648 km
Date: 2020.08.11
Time: 15:53:02
00251 - Fuel Supply Sensor 4 (G393)
Reset counter: 179
Mileage: 20648 km
Date: 2020.08.11
Time: 15:53:02
00439 - Fuel Supply Sensor 3 (G237)
Reset counter: 179
Mileage: 20648 km
Date: 2020.08.11
Time: 15:53:02
Part No SW: 7N0 907 530 N HW: 1K0 907 951
Component: J533 Gateway H43 1623
Revision: H43 Serial number: 261111F2000126
Coding: 354101
VCID: 3B36179DBA27C05E06-806E
Revision: D0H02002 Serial number: AUX7Z0KNFNS02T
Address 2E: Media Player 3 (R199) Labels:. 8T0-035-785.clb
Part No SW: 420 035 785 HW: 420 035 785
Component: SG ext.Player H08 0100
Revision: 00000000
Coding: 020202
VCID: 52E85A390DAD2116F5-8006
Address 37: Navigation Labels: 8E0-035-192-RNSE.clb
Part No SW: 424 035 192 F HW: 424 035 192 F
Component: RNS-E PU EU H06 0200
Revision: 0000012S Serial number: AUZBZ7L6400259
Coding: 0730725
VCID: 14649C213739EF26A7-8040
Address 42: Door Elect, Driver Labels: 8P0-959-801-MAX3.lbl
Part No SW: 420 959 801 H HW: 420 959 801 H
Component: Tuer-SG H04 0103
Coding: 0004733
VCID: 1E70FE09C9F5B57601-804A
Address 47: Sound System Labels: None
Part No SW: 427 035 223 HW: 427 035 223
Component: J525 Amp High H04 0030
Revision: 00H04001 Serial number: 94844000632100
Coding: 0246112
VCID: 4CD444412F8977E6BF-8018
Part No SW: 420 959 802 H HW: 420 959 802 H
Coding: 0004733
VCID: 1F0EC30DCEFFBC7E0A-804A
Address 56: Radio Labels: 8E0-035-192-RNSE.clb
Coding: 0730725
Part No SW: 7N0 907 534 HW: 1K0 907 951
Component: Batt.regelung H43 1623
Coding: F3260148
VCID: 71AAF5B5A8EB7A0EEC-8024
Subsystem 1 - Part No SW: 420 915 181 HW: 420 915 181
Component: J367-BDM H07 0140
Serial number: 00000000005650786849
Address 6C: Back-up Cam. Labels: 420-910-441.clb
Part No SW: 420 910 441 A HW: 7L6 907 441 C
Component: J772__Rearview 0010
Revision: --H13--- Serial number: 525PA8-J1Y601D
Coding: 1020412
VCID: 0A588259657D29D64D-805E
Reset counter: 179
Mileage: 20648 km
Date: 2020.08.11
Time: 15:53:02
Reverse OFF
Count: 3
Part No SW: 8P1 862 335 A HW: 8P1 862 335
Component: FSE_256x BT H44 0660
Revision: 00000000 Serial number: 00000005473112
Coding: 0011492
Shop #: WSC 02556 785 00200
VCID: 352201A55C03162EF0-8060
Address A6: Microphone (J886) Labels:. 420-907-394.clb
Part No SW: 420 907 394 HW: 420 907 394
Component: BELTMICBOX H09 0060
Coding: 0100010202
Shop #: WSC 02331 785 00000
ASAM Dataset: EV_BeltMicAU715 002011
ROD: EV_BeltMicAU715_002.rod
VCID: 56E0A62929453D3619-8002
End----------(Elapsed Time: 01:27, VBatt start/end: 14.4V/14.4V)-----------
