Tiguan 2009 TDI (Right Hand Drive Australia) - Error Code V282
TomAus
Australia
C?ID=201852
HI All
So yes I have searched on the forum for error code "02432 - Supply Voltage for Left Parking Brake Motor (V282)" and have tried what suggests there were.
(when it talks about LEFT and RIGHT in error code is that when sitting in the drivers seat or when standing in front of the car??)
How my issue started will try to make the story as short as possible.
Last Thursday had to get road side assist out to help with a ignition\steering lock issue where I couldn't turn the key at all for 20-30min not even to accessories (this is important as no power to the EPB)
As the car was parked under ground carpark tow truck couldn't get in there so. They disable the e-brake manually. During this process the road side assist drop the ebrake motor from passenger side ( US Drive side). Then got the car towed home finally 3 hours later
Next day got the ignition\steering lock issue fixed car start sweet.
Jump on the VCDS to get the ebrake sorted as getting hand brake button is flashing yellow the hand brake symbol on the dash yellow solid and red light flashing and beeeeeeeping noise (see image)
The first time I connect the VCDS I saw error code "02433 - Supply Voltage for Right Parking Brake Motor (V283)" and 02432 - Supply Voltage for Left Parking Brake Motor (V282)
I remember the road side assist said that the ebrakes need to be reconnected. So jacked up the car and found that the D Connecter was off on Drivers side (US Passenger side)
As the ebrake was manually open by the Road side assist I tried to follow Ross Tech video Electro-Mechanical Parking Brake (EPB), rear brake pad service - YouTube
Connect Battery charge and then went in to do this process VW Tiguan (5N) Parking Brake - Ross-Tech Wiki (ross-tech.com)
But in VCDS I get the follow error for 006 007 and 010
So I took the car for a drive to see if it will make a different and for some reason it did, now the Driver side (US Passenger side) work engaging no problem.
Connected VCDS and found error code V283 has gone. :)
Thought great will do the same on the other side jacked up the car and reconnected the D connector went for a drive same loop no more the 40km\h (not sure in miles).
Came back and that side didn;t engage (US Driver side)
Got a second hand EPB motor and installed it no difference so then did the v12 test on the old motor I pulled out and it works (probably shouldn't have bought the second hand one.)
Here is a copy of my full scan from this morning (yes I know need to replace the secondary fan as well another long story there)
Tuesday,24,November,2020,07:52:27:46862
VCDS Version: 20.4.2.0 (x64)
[URL='http://www.ross-tech.com/']www.Ross-Tech.com[/URL]
VIN: WVGZZZ5NZAW013922 License Plate: FULLSCAN
Mileage: 158340km-98387mi Repair Order: Tiguan2009
Chassis Type: 5N-VW36 (1K0)
Scan: 01 02 03 08 09 10 15 16 17 19 22 25 2E 42 44 46 47 52 53 55
56 62 72
VIN: WVGZZZ5NZAW013922 Mileage: 158340km-98387miles
Address 01: Engine (CBA) Labels: 03L-906-022-CBA.clb
Part No SW: 03L 906 022 RP HW: 03L 906 022 RP
Component: R4 2.0l TDI G000AG 9978
Revision: 13H02--- Serial number:
Coding: 0000175
Shop #: WSC 40384 002 1048576
VCID: 042969F647AC11A637-8050
006481 - Radiator Fan 2 (V177)
P1951 - 000 - Movement Restricted / Jammed - Intermittent
Fault Frequency: 41
Mileage: 157846 km
Date: 2015.04.17
Time: 11:20:07
RPM: 1633 /min
Speed: 43.0 km/h
Temperature: 35.1°C
Temperature: 68.4°C
Temperature: 24.3°C
Lambda: 41.0 %
Lambda: 0.0 %
Part No SW: 09G 927 750 FD HW: 09G 927 750 FD
Component: AQ 250 6F 1124
Revision: 00H76000 Serial number:
Coding: 0000328
Shop #: WSC [URL='http://wiki.ross-tech.com/wiki/index.php/01324']01324[/URL] 020 [URL='http://wiki.ross-tech.com/wiki/index.php/00200']00200[/URL]
VCID: 78D10D060B6445462B-802C
Address 03: ABS Brakes Labels: 5N0-614-517.lbl
Part No SW: 5N0 614 517 N HW: 5N0 614 517 N
Component: J104 C2 450 V2 0008
Revision: --H13--- Serial number: 00000002133068
Coding: 0006434
VCID: 3957C80270EE9C4E14-806C
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No SW: 1K0 907 044 CT HW: 1K0 907 044 CT
Component: ClimatronicPQ35 133 1213
Revision: 00133026 Serial number: 00000000000000
VCID: 7BDB120A3A526E5E46-802E
Address 09: Cent. Elect. (J519) Labels:. [URL='http://wiki.ross-tech.com/wiki/index.php/VW_Golf_(5K)_Body_Control_Module']1K0-937-08x-09.clb[/URL]
Part No SW: 5K0 937 087 HW: 5K0 937 087
Component: BCM PQ35 H 008 0019
Revision: BE008001
Coding: 40180A3B902518C0400800803400092441553088736D81605C8000000000
VCID: 72C53F2EAD182F1615-8026
Subsystem 1 - Part No SW: 5N2 955 119 HW: Labels: 1KX-955-119.CLB
Component: Wischer 17070 012 0203
Serial number: N2955119 °203!
Coding: 009795
Component: RLS 170709 05 54 0402
Coding: 03304D
Address 10: Park/Steer Assist (J791) Labels:. 1T0-919-475.clb
Part No SW: 1T0 919 475 H HW: 1T0 919 475
Component: PARKHILFE PLA H07 0110
Revision: -------- Serial number: 88520918301449
Coding: 101103
VCID: 40A1A5E6D334CD8653-8014
Part No SW: 5N0 959 655 J HW: 5N0 959 655 J
Component: J234__202 VW10 HI 1916
Revision: 20013000 Serial number: 003E2PD5JCRY
Coding: 0012338
VCID: 44A9A9F6072CD1A677-8010
Subsystem 1 - Serial number: 6332MTS637951769
Subsystem 2 - Serial number: 6342MTS650211759
Subsystem 3 - Serial number: 6351HTS6TTGP26KJ
Subsystem 4 - Serial number: 6361HTS6U7TSU8KJ
Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
Part No SW: 1K0 953 549 CD HW: 1K0 953 549 CD
Component: J0527 055 0111
Coding: 0001132
VCID: 76CD033E0170333639-8022
Component: E0221 002 0030
Part No SW: 5N0 920 871 B HW: 5N0 920 871 B
Component: KOMBI H05 0206
Coding: 110F00
VCID: 3041F5266B945D06A3-8064
Part No SW: 1K0 907 530 AA HW: 1K0 907 951
Component: J533 Gateway H07 0081
Revision: H07 01 Serial number: 080709F1001962
Coding: FDA37F06100212006003
VCID: 66ED537E51D0C3B689-8032
Address 22: AWD Labels: 0AY-907-554-V1.clb
Part No SW: 0AY 907 554 C HW: 0AY 907 554 C
Component: Haldex 4Motion 0041
Coding: 0000005
VCID: 4BBB82CA2A721EDEB6-801E
Address 25: Immobilizer (J334) Labels:. 5K0-920-xxx-25.clb
Component: IMMO H05 0206
Part No SW: 5N0 035 342 B HW: 5N0 035 342 B
Revision: A1001003 Serial number: 7667508289
VCID: 266D137E515003B649-8072
Part No SW: 5N0 959 701 B HW: 5N0 959 701 B
Component: Tuer-SG 008 2006
Coding: 0000700
VCID: 3449F936578C6126C7-8060
Part No: 5N0 909 144 H
Component: EPS_ZFLS Kl. 202 2901
Revision: 00H17000
Shop #: WSC [URL='http://wiki.ross-tech.com/wiki/index.php/01324']01324[/URL] 785 [URL='http://wiki.ross-tech.com/wiki/index.php/00200']00200[/URL]
VCID: 364DC33E41F07336F9-8062
Address 47: Sound System (R12) Labels: None
Component: KonzernAmp 8K H06 0340
Revision: -------- Serial number: BP218198609623
ASAM Dataset: EV_AudioVerst8KanalBNO1 A01003
ROD: EV_AudioVerst8KanalBNO1.rod
VCID: 558F64B234B6582E10-8000
Part No SW: 5N0 959 702 B HW: 5N0 959 702 B
Coding: 0000700
VCID: 354FC4325CF6782EF0-8060
Address 53: Parking Brake Labels: 5N0-907-801.clb
Part No SW: 5N0 907 801 E HW: 5N0 907 801 E
Component: J540 EPB3 VW-13948 0008
Revision: H10 Serial number: 00000000021539
Coding: 0000057
VCID: 3147F022A89E540EAC-8064
[URL='http://wiki.ross-tech.com/wiki/index.php/02432']02432[/URL] - Supply Voltage for Left Parking Brake Motor (V282)
Fault Status: 00101100
Reset counter: 197
Mileage: 158346 km
Voltage: 12.30 V
Count: 22
Hex Value: 0x12E0
Hex Value: 0x0011
Hex Value: 0x0202
Address 55: Headlight Range Labels: 5M0-907-357-V2.lbl
Component: AFS-Steuergeraet 0142
Coding: 1361350
Subsystem 1 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB
Coding: 00000020
Subsystem 2 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB
Coding: 00000020
Address 56: Radio (J0503) Labels:. 5M0-035-1xx-56.clb
Part No SW: 3C8 035 195 HW: 3C8 035 195
Component: Radio RCD510 037 0144
Revision: 00000001 Serial number: VWZ1Z3I4285770
Coding: 0101000001
VCID: 65EF54726CD6C8AE80-8030
Part No SW: 5N0 959 703 B HW: 5N0 959 703 B
Component: Tuer-SG 007 2001
Coding: 0000144
Shop #: WSC [URL='http://wiki.ross-tech.com/wiki/index.php/01324']01324[/URL] 020 1012552
Part No SW: 5N0 959 704 B HW: 5N0 959 704 B
Coding: 0000144
VCID: 3753CE3A46FA8A3EE2-8062
End-------------------------(Elapsed Time: 01:49)--------------------------
TomAus
Australia
C?ID=201852
One think I did forget to mention on the above post I did try the steps in this URL
02432 - Ross-Tech Wiki (ross-tech.com)
Even the clearing of the code while the car was running.
Still no luck :(
South Molton, UK
Left and Right always refer to as seen when seated in the drivers seat.
Bruce
Near Philadelphia, PA, USA
damaged pin(s) in the connector? Only thought I have at the moment.
TomAus
Australia
C?ID=201852
Lucky I took photos of both connection and I just looked at the photo on phone and can’t see any damage. But will upload images tomorrow. 11pm here.
Here are the photos of the connectors look fine to me.
TomAus
Australia
C?ID=201852
Images upload above pins and connector look fine :(
TomAus
Australia
C?ID=201852
Well finally got the brake sorted.
For any one in the future having the same issue as above this is how it was solved for me.
I found the EPB was in the opposite state to what the caliper was in.
So disconnecting the EPB from the caliper and then turn on the car on clear the error code and then disengage the break only then reconnect to caliper the test again and re-engaged. (It may need to bed done in revers for you).
this worked for me so hope it helps someone else.
