Hi:
I have a 2010 Audi A4 with an 0B5 DSG transmission. It has developed a fairly severe judder when accelerating gently from low speed in 2nd gear. Reverse also feels 'reluctant' to move off at times. No codes generated.
We suspect the clutch needs changing however my mechanic has suggested I do the Basic Setting' for the transmission and see if it makes any difference before getting into an expensive clutch replacement.
I have tried following the procedure in the Wiki (below) but on the first step (Erase counter for start and stop processes) I am getting 'Error: Request out of Range'. (In park, engine off, ignition on, temp 53.)
Not sure if I am missing a prerequisite step or what. I believe I will need to run this step if I change the clutch so would like to get it sorted.
[Select]
[02 - Auto Trans]
[Basic Settings - 04]
Select Erase counter for start and stop processes
[Go!] to activate the Basic Setting.
After the result of Finished Correctly or Not Running appears click [Stop]
[Done, Go Back]
AutoScan:
[Select]
[02 - Auto Trans]
[Done, Go Back]
AutoScan:
Sunday,22,November,2020,17:23:44:09194
[URL='http://www.Ross-Tech.com']www.Ross-Tech.com[/URL]
VIN: WAUZZZ8K9AA039282 License Plate:
Chassis Type: 8K-AU48 (8T0)
Scan: 01 02 03 05 07 08 09 0E 10 15 16 17 19 1E 37 42 46 47 52 53
55 56 57 62 6C 72
VIN: WAUZZZ8K9AA039282 Mileage: 103560km-64349miles
Address 01: Engine (CL0MA-CDNC) Labels:| 06H-907-115-CAB.clb
Part No SW: 8K2 907 115 AJ HW: 8K2 907 115 D
Component: 2.0l R4/4V TF H15 0002
Revision: E1H15---
Coding: 0104000C240F0060
Shop #: WSC 64849 741 91644
ASAM Dataset: EV_ECM20TFS0118K2907115AJ 001002
ROD: EV_ECM20AVS.rod
VCID: 77ABEFB02F4F7A13639-8022
7144 - Please Check DTC Memory in CAN Gateway (J533)
U1008 00 [032] - -
[Diagnostic interface for databus -J533-please read DTC]
Mileage: 103321 km
Date: 2020.10.23
Time: 10:15:28
Engine speed: 975.50 /min
Normed load value: 10.2 %
Coolant temperature: 78 °C
Intake air temperature: 34 °C
Voltage terminal 30: 11.355 V
Unlearning counter according OBD: 18
Part No SW: 8K0 927 156 F HW: 0B5 927 156 E
Component: 0B5 20TFSIRdW H03 0011
Revision: --H03--- Serial number: 0000001412
Shop #: WSC 06325 000 00000
ASAM Dataset: EV_TCMDL501 A02044
ROD: EV_TCMDL501.rod
VCID: 372B2FB06FCFBA13A39-8062
Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V1.clb
Part No SW: 8K0 907 379 AN HW: 8K0 907 379 AN
Component: ESP8 quattro H04 0100
Coding: 094508
VCID: 0557957865231883615-8050
Part No SW: 8K0 907 064 DS HW: 8K0 907 064 DS
Component: BCM2 1.1 H02 0321
Coding: 051100
VCID: 0451887C6E19218B76B-8050
Subsystem 1 - Part No SW: 8T0 959 754 J HW: 8T0 959 754 J
Component: FBSAUDIB8 IDG H37 0060
Serial number: 0509000032914019
Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: J764 ELV MLB H37 0042
Serial number: 0209000051622009
Address 07: Control Head Labels: 8T0-035-7xx-07-H.clb
Part No SW: 8T0 035 729 S HW: 4E0 035 729 C
Component: Interfacebox H41 2090
Revision: 00000000 Serial number: 337GZ097517527
Coding: 0000108
Shop #: WSC 61020 981 63352
VCID: 49CF594805BB3CE3C5D-801C
Subsystem 1 - Part No: 8T0 919 609 E
Component: E0380 BedienteilH08 0100
Subsystem 2 - Serial number: 00000000335958
Subsystem 3 - Serial number: 0129.07.090000000100010052ÿ
Subsystem 4 - Serial number: 010052ÿ
Address 08: Auto HVAC (J255) Labels:. 8Tx-820-043-3Z.clb
Part No SW: 8T2 820 043 AG HW: 8T2 820 043 AG
Component: KLIMA 3 ZONEN H08 0160
Revision: D1000000 Serial number: 01130720090644
Coding: 64046000
VCID: 77ABEFB02FCF7A13639-8022
03270 - Ventilation Reduced due to Engery Management
Reset counter: 7
Mileage: 103308 km
Date: 2020.10.22
Time: 08:10:48
03269 - Functionality Linited due to Energy Management
Reset counter: 7
Mileage: 103310 km
Date: 2020.10.22
Time: 08:14:15
Reset counter: 8
Mileage: 103322 km
Date: 2009.04.28
Time: 00:02:38
Part No SW: 8K0 907 063 P HW: 8K0 907 063 P
Component: BCM1 1.0 H25 0380
Revision: 10025001 Serial number: 00000000428172
Coding: 260010000030AF010001000300001D0D0F1D430800010141000000
VCID: 3C21309C5669994B4EB-8068
Subsystem 1 - Part No SW: 8K2 955 119 A HW: 8T2 955 119 Labels: 1KX-955-119.CLB
Component: WWS 110709 H05 0070
Serial number: SWF09070110350
Coding: 00FD11
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Serial number: 10545354
Coding: 025028
Subsystem 3 - Part No SW: 8K0 941 531 AL HW: 8K0 941 531 AL
Component: E1 - LDS H08 0090
Serial number: 00000000001007091361
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 8T2 035 110 C HW: 8T2 035 110 C
Component: MP3-Changer H45 0390
Revision: 00045004 Serial number: AUZ5ZBI8842330
VCID: 2B0303C0AF070EF3D71-807E
Address 10: Park/Steer Assist (J446) Labels:. 8K0-919-475.clb
Part No SW: 8K0 919 475 J HW: 8K0 919 475 A
Component: PARKHILFE 8K H06 0050
Revision: 11001001 Serial number: 39840920102112
Coding: 300103
VCID: 40D9446C3A81FDAB123-8014
Part No SW: 8K0 959 655 G HW: 8K0 959 655 G
Component: AirbagVW-AU10 H37 0520
Serial number: 003EFD044SNI
Coding: 30373435363030303030554A3052384B3053
VCID: 41DF4168310BF4A31DD-8014
Serial number: 6334MSME49613201%
Serial number: 6344MSME48614F21F
Serial number: 6352QSME282E441AM
Serial number: 6362QSME5F340532F
Serial number: 63732SME670C3504-
Serial number: 63832SME5F0C1214/
Part No SW: 8K0 953 568 F HW: 8K0 953 568 F
Component: Lenks.Modul H16 0014
Revision: -------- Serial number: 90319IGH000E2
Coding: 000032
VCID: 3D273D984D739043795-8068
Component: E221 - MFL H02 0003
Part No SW: 8K0 920 930 B HW: 8K0 920 930 B
Component: KOMBIINSTR. H19 0253
Revision: 00200000 Serial number: BXJ44FD79
Coding: 2F0609000200000C010000
VCID: 2C0100DCA60909CBDEB-8078
Part No SW: 8T0 907 468 T HW: 8T0 907 468 K
Component: GW-BEM 4CAN-M H09 0101
Revision: EB700052 Serial number: 5200E096308023
Coding: 00C303
VCID: 52FD7E24E4ED7F3BB47-8006
Subsystem 1 - Part No SW: 8K0 915 181 E HW: 8K0 915 181 E
Component: J367-BDM H06 0160
Serial number: 19085C64010709
02252 - Generator
Fault Status: 00101100
Reset counter: 6
Mileage: 103310 km
Date: 2020.10.22
Time: 08:13:55
Bin. Bits: 01111
Voltage: 11.50 V
Count: 6
Address 1E: Media Player 2 (R199) Labels:. 4E0-035-785.lbl
Part No SW: 4E0 035 785 F HW: 4E0 035 785 C
Component: SG ext.Player H20 0850
Revision: 00000000
Coding: 030000
VCID: 2B0303C0A3070EF3D71-807E
Address 37: Navigation (J0401) Labels: None
Part No SW: 8T0 919 888 A HW: 8T0 919 888
Component: J0401 NAV JP H31 0340
Revision: 0000002S Serial number: AUZBZ7G2700170
VCID: 48C95C4C12B1C5EBDA3-801C
Subsystem 1 - Part No SW: 4F0 035 503 C HW: 4F0 035 503 C
Component: ETC-VICS-Ant. H02 0020
Subsystem 2 - Part No SW: 4F0 919 813 C HW: 4F0 919 813 C
Component: Card reader H02 0100
Subsystem 3 - Part No SW: 4E1 910 336 HW: 4E1 862 335
Component: Interface Han H09 0050
Part No SW: 8K0 959 793 H HW: 8K0 959 793 D
Component: TSG FA H11 0306
Revision: Serial number: 0000009092015
Coding: 011C12205001410001
VCID: 45D7557825A3D883215-8010
Revision: 00002001 Serial number: 0119712203
Coding: 01000E22003904810130010000000000
01503 - Bulb for 3rd Brake Light (M25)
Reset counter: 252
Mileage: 102778 km
Date: 2020.09.28
Time: 07:42:58
02615 - Fuel Tank Cap; Lock
Fault Status: 00101001
Reset counter: 22
Mileage: 103508 km
Date: 2009.05.17
Time: 03:23:27
00230 - Transmission Park Selector Switch (F305)
Reset counter: 27
Mileage: 103554 km
Date: 2009.05.26
Time: 22:18:01
Address 47: Sound System (J525) Labels:. 8T0-035-223-ASM.clb
Part No SW: 8T0 035 223 AG HW: 8T0 035 223 G
Component: DSP STD H08 0310
Revision: S2700000
Coding: 010201
VCID: 73B3DBA03BB716335F1-8026
00418 - Front Right DSP Mid-Bass Speaker (R102)
Fault Status: 01111011
Reset counter: 183
Mileage: 102778 km
Date: 2020.09.28
Time: 07:39:54
Voltage: 11.80 V
Temperature: 27.0°C
Bin. Bits: 00000011
Part No SW: 8K0 959 792 H HW: 8K0 959 792 D
Component: TSG BF H11 0306
Revision: Serial number: 0000009105632
Shop #: WSC 64879 741 90783
VCID: 44D1487C2E99E18B36B-8010
Fault Status: 01101000
Fault Frequency: 15
Reset counter: 244
Mileage: 103104 km
Date: 2020.10.12
Time: 08:59:19
Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
Component: EPB Audi B8 H09 0090
Revision: 00000003 Serial number: 00000000413025
VCID: 343118BC7E39510B86B-8060
Address 55: Headlight Range Labels: 8K0-907-357.clb
Part No: 8K5 907 357
Component: Dynamische LWR H01 0010
Coding: 0000004
Shop #: WSC 06324 000 00000
VCID: 77ABEFB023CF7A13639-8022
Part No SW: 4E0 910 541 N HW: 4F0 035 541 K
Component: TUNER Japan H42 0180
Revision: 00000000 Serial number: 338GS097512209
Coding: 0000003
Address 57: TV Tuner Labels: None
Part No SW: 4F0 919 148 A HW: 4F0 919 148
Component: R78 DTV-JP 0150
Revision: R0H06000 Serial number: 79300600666201
Coding: 0000016
Subsystem 1 - Part No: 4F0 919 805
Component: R204 TVKLeser 0150
Subsystem 2 - Serial number: 72800600295607
Subsystem 3 - Serial number: 0014.07.09R0H0700000015154ÿ
Subsystem 4 - Serial number: 015154ÿ
Part No SW: 8K0 959 795 C HW: 8K0 959 795 C
Component: TSG HL H10 0306
Revision: Serial number: 0000101523789
Coding: 010C12204001210001
VCID: 42DD4E64348DEFBB047-8016
Address 6C: Back-up Cam. Labels: 8T0-907-441.clb
Part No SW: 8T0 907 441 C HW: 4L0 907 441 B
Revision: --H03--- Serial number: 525PA8-J9790GX
Coding: 1022006
VCID: 38292C8C6E51B56BAA3-806C
Address 72: Door, Rear Right (J389) Labels:. 8K0-959-795.clb
Component: TSG HR H10 0306
Revision: Serial number: 0000101523800
End----------(Elapsed Time: 01:43, VBatt start/end: 12.1V/12.1V)-----------
