Vehicle surging
TMD Auto
C?ID=413117
Customer comes in has vehicle surging at idle smoke tested and
boost tested found nothing any help would be great been at it for a couple days here and there just really c ant find anything out of ordinary
Monday,23,November,2020,10:16:22:55284
VCDS Version: 20.4.2.0 (x64)  HEX-NET2 CB: 0.4527.4
VIN: WAU7FLFF4F1030662   License Plate:
Chassis Type: FF-AU37 (5Q0)
Scan: 01 02 03 08 09 15 16 17 19 22 26 42 44 52 55 5F
VIN: WAU7FLFF4F1030662   Mileage: 210401km-130737miles
26-Auto Roof -- Status: Malfunction 0010
Address 01: Engine (J623-CNTC)       Labels:. 06K-907-425-V1.clb
   Part No SW: 5G0 906 259 A    HW: 06K 907 425 B
   Component: 2.0l R4 TFSI  H13 0004
   Revision: --H13---
   Coding: 0A1D00124426000F2000
   Shop #: WSC 06385 790 00016
   ASAM Dataset: EV_ECM20TFS0205G0906259A 001006
   ROD: EV_ECM20TFS0205G0906259A.rod
   VCID: 2C0A6FE5B686482BDEB-8078
15077 - Idle Control System RPM
          P0507 00 [175] - Higher than Expected.
                    Mileage: 210401 km
                    Date: 2020.11.23
                    Time: 10:04:22
                    Engine speed: 1467.50 /min
                    Normed load value: 14.1 %
                    Coolant temperature: 28 °C
                    Intake air temperature: 12 °C
                    Voltage terminal 30: 14.609 V
                    Engine: operating status: IS
                    STATE_LS_SAE[1]: OL_CDN
                    T_AST_SAE: 10 s
                    MAP_MES_SAE: 41 kPa
                    Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.997 V
                    FAC_TPS_1_SAE: 10.156250 %
                    FUP_H_SAE: 11380.0 kPa
15316 - MAP/MAF <-> Throttle Position Correlation
          P0068 00 [175] - -
                    Mileage: 210401 km
                    Date: 2020.11.23
                    Time: 10:04:20
                    Engine speed: 1376.75 /min
                    Voltage terminal 30: 14.414 V
                    T_AST_SAE: 8 s
                    MAP_MES_SAE: 42 kPa
                    FAC_TPS_1_SAE: 11.718750 %
                    FUP_H_SAE: 10660.0 kPa
Readiness: 1010 1101
   Part No SW: 0D9 300 012 K    HW: 02E 927 770 AQ
   Component: DQ250-6A MQB  H52 4513
   Revision: 05852204    Serial number: TFK01405060245
   Shop #: WSC 04742 780 00200
   ROD: EV_TCMDQ250021.rod
   VCID: 1E6EB52DF03AAABB40F-804A
          P1734 00 [002] - -
   Part No SW: 5Q0 907 379 L    HW: 5Q0 907 379 G
   Component: ESC           H31 0471
   Revision: 00000000    Serial number: 61484000000977
   Coding: 11FF6A9234230A6C017D030681C52988562C5080C08194B4024100588608
   ROD: EV_Brake1UDSContiMK100IPB_033.rod
   VCID: 45DC3A41352C9963215-8010
16401 - Tire Pressure Warning
          C102D 00 [137] - -
                    Reset counter: 231
                    Date: 2020.07.08
                    Time: 13:26:30
   Component: AC Automat    H13 0052
   Revision: 20026000    Serial number: 00000000345152
   Coding: 05000004010000000000000000001400
   VCID: 333874996BB817D39F1-8066
   Serial number: AB290137000000000001
329988 - Motor for Defroster Flap
          B1090 71 [008] - Actuator stuck
                    Reset counter: 239
                    Mileage: 208740 km
                    Date: 2020.10.12
                    Time: 15:00:34
                    Voltage terminal 30: 14.2 V
                    Interior temperature: 29.2 °C
                    Outside air temperature: 16 °C
                    Defroster flap: specified value: 51
                    Defroster flap: actual value: 0
                    Defroster flap: actual value: 0.0 %
   Part No SW: 5Q0 937 085 AB    HW: 5Q0 937 085 AB
   Component: BCM MQBAB MNA H18 0134
   Serial number: 01011414300210
   Coding: 04041A46C04122F541604004511007000100000000000000000000000000
   ROD: EV_BCMBOSCH_013.rod
   VCID: 79A486B109542D8315D-802C
   Component: WWS371 140528  042 0585
   Serial number:         140603042014
   Coding: 0A47F7
   Serial number: 22708665
   Coding: 00006C
   Subsystem 3 - Part No SW: 8V0 941 531 K    HW: 8V0 941 531 K
   Serial number: 04 04 2014  00000483
   Serial number: 00000000000059780390
558100 - Databus
          [Airbag_02 Datenbus empfangener Fehlerwert]
                    Fault Frequency: 56
                    Reset counter: 219
                    Mileage: 207531 km
                    Date: 2020.10.03
                    Time: 16:48:46
   Part No SW: 5Q0 959 655 AC    HW: 5Q0 959 655 AC
   Serial number: 003MNR000B11
   Coding: 9DC0F0C00000A0005000001AC24800000065
   ROD: EV_AirbaVW20SMEVW37X_VW48.rod
   VCID: 0154EE51618475435DD-8054
   Belt Pretensioner left:
   Serial number: 34178313B03061470246
   Coding: 333135
   Belt Pretensioner right:
   Serial number: 34178314B03061440275
   Coding: 333135
   Occupant Detection:
   Serial number: 6940000Y1400014J7306
   Coding: 303139
   Subsystem 4 - Part No SW: -----------    HW: 480 000 206 14
   Serial number: 3570000000019AA4CF0X
   Subsystem 5 - Part No SW: -----------    HW: 480 000 206 14
   Serial number: 3580000000001BA4CF0Q
   Subsystem 6 - Part No SW: -----------    HW: 480 012 705 14
   Component: SideSensor_Dr  004 0108
   Serial number: 351001A01BF91E14ECDT
   Subsystem 7 - Part No SW: -----------    HW: 480 400 804 14
   Serial number: 35500029B1524DC3D349
   Front Sensor Passenger:
   Subsystem 8 - Part No SW: -----------    HW: 480 400 804 14
   Serial number: 3560002C31524DC0921.
9445929 - Seat occupied recognition control module
          B1022 29 [137] - Signal Implausible
                    Fault Frequency: 58
                    Reset counter: 219
                    Mileage: 207531 km
                    Date: 2020.10.03
                    Time: 16:48:50
9577755 - Sensor Mat for Seat Occupied Detection
          B1225 1B [137] - Resistance Too High
                    Fault Frequency: 140
                    Reset counter: 227
                    Mileage: 207531 km
                    Date: 2020.10.03
                    Time: 16:48:45
   Part No SW: 8V0 953 521 CB    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 04061408490507
   Coding: A018
   ROD: EV_SMLSKLOMQB_009_AU37.rod
   VCID: 7CAA9FA5066618AB0EB-8028
617752 - Selector Lever Park Position Lock Switch
          B1162 29 [009] - Signal Implausible
                    Reset counter: 227
                    Mileage: 210111 km
                    Date: 2020.10.31
                    Time: 17:44:31
                    Operating time: 224841 min
                    Supply voltage: Terminal 30: 14.7 V
                    Vehicle speed: 46 km/h
                    Voltage at switch: 4.98 V
                    Terminal 15 status: active
                    System status: 30
   Part No SW: 8V0 920 960 H    HW: 8V0 920 960 H
   Component: KOMBI         H01 4291
   Coding: 0BF410092B80D7050200A8001800000000000000
   VCID: 40D22B552A0EBC4B123-8014
   Part No SW: 5Q0 907 530 T    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2186
   Revision: --------    Serial number: 28051410800892
   Coding: 0101000820085A005B00020C180B00000001010000000000000000000000
   ASAM Dataset: EV_GatewConti 011017
   ROD: EV_GatewConti_011.rod
   VCID: 42D6215D2402AE5B047-8016
   Subsystem 2 - Part No SW: 8U0 951 528 A    HW: 8U0 951 528 A
   Serial number: 26 05 2014  B0022937
   Part No SW: 0CQ 907 554 D    HW: 0CQ 907 554 D
   Component: Haldex4Motion H52 7076
   Serial number: HA1-00031.03.14
   Coding: 0001
   ROD: EV_AllWheelContrHA1VW37X_002.rod
   VCID: 46DE3D4D082A927B28F-8012
Address 26: Auto Roof (J256)       Labels:* None
   Part No SW: 8V7 959 255     HW: 8V7 959 255
   Component: VSG-AU375     H03 0030
   Coding: C00000
   ASAM Dataset: EV_ElectRoofContrMAQAU37X 001005
   ROD: EV_ElectRoofContrMAQAU37X.rod
   VCID: 0842F37542BE440B1A3-805C
0021 - Databus
          [Motor_14 - No Signal]
                    Reset counter: 4
                    Mileage: 210072 km
                    Date: 2020.10.31
                    Time: 01:20:49
0061 - Switch for Tension Bracket; Upper
          B118A 29 [008] - Signal Implausible
                    Reset counter: 253
                    Mileage: 210086 km
                    Date: 2020.10.31
                    Time: 01:37:52
   Part No SW: 5Q0 959 593 C    HW: 5Q0 959 593 B
   Component: TSG FS        020 0026
   Serial number: 26051404081327
   Coding: 00104F724008048000000402
   VCID: 41D42E512104B5431DD-8014
   Subsystem 1 - Part No SW: 5Q0 959 812 C    HW: 5Q0 959 812 C
   Component: FOND_FHSG_DRV  002 0005
   Serial number: 00000000000002739824
   Coding: 110000
   Component: EPS_MQB_ZFLS  123 1043
   Coding: 0102
   ROD: EV_SteerAssisMQB_010.rod
   Part No SW: 5Q0 959 592 C    HW: 5Q0 959 592 B
   Component: TSG BFS       020 0026
   Serial number: 26051406070914
   Coding: 001047724008048000000402
   Subsystem 1 - Part No SW: 5Q0 959 811 C    HW: 5Q0 959 811 C
   Component: FOND_FHSG_PSG  002 0005
   Serial number: 00000000000002742533
   Coding: 090000
   Coding: 012A000101000000
   VCID: 75BC8A81254C49E3715-8020
Address 5F: Information Electr. (J794)       Labels:| 8V0-035-MIB-STD1.clb
   Part No SW: 8V0 035 844     HW: 8V0 035 844
   Component: MU-S-S-US     013 0626
   Serial number: A7A00106141573
   Coding: 01730500FF08000011220001001A00002F0001040100010000
   ASAM Dataset: EV_MUStd6C3PASE 002020
   ROD: EV_MUStd6C3PASE.rod
   VCID: 76BE8D8D384A42FB78F-8022
   Subsystem 1 - Part No SW: 8V0 919 603 C    HW: 8V0 919 603 C
   Component: DU Std  H49 0013
   Serial number: AUZ8Z9EY303VW9
   Multimedia Operating Unit:
   Subsystem 2 - Part No SW: 8V0 919 614 B    HW: 8V0 919 614 B
   Component: ControlUnit_B  H33 0037
   Serial number: C1000023051400010271
1547 - Function Restriction
          B2008 F0 [008] - due to Over-Temp Protection
          [Function restriction due to excessive-temperature protection]
                    Fault Frequency: 8
                    Reset counter: 4
                    Mileage: 208336 km
                    Date: 2020.10.09
                    Time: 19:02:05
                    Voltage terminal 30: 13.9 V
                    Temperature of MMX PC boards-max.value: -50 °C
                    Temperature of MMX PC boards-min.value: 205 °C
                    Temperature of MMX PC boards-Current: 205 °C
                    Temperature of processor circuit board-max.value: -50 °C
                    Temperature of processor circuit board-min.value: -19 °C
                    Temperature of processor circuit board-Current: 81 °C
1548 - Function Restriction
          [Function restriction due to excessive-temperature protection (power stages)]
                    Fault Frequency: 8
                    Reset counter: 4
                    Mileage: 208336 km
                    Date: 2020.10.09
                    Time: 19:02:05
                    Temperature: audio amplifier-max.value: -50 °C
                    Temperature: audio amplifier-min.value: 205 °C
                    Temperature: audio amplifier-Current: 205 °C
          B11CF 53 [009] - Deactivated
                    Reset counter: 231
                    Mileage: 199184 km
                    Date: 2020.07.08
                    Time: 13:26:13
                    Voltage terminal 30: 12.2 V
                    Satellite radio tuner status-Satellite radio antenna status: Electrical OK
                    Satellite radio tuner status-SDARS Flash Regional code: US_Audio_Traffic_Travellink
End----------(Elapsed Time: 01:22, VBatt start/end: 14.7V/14.8V)-----------
NostraJackAss
False air from PCV or open pipe at idle?
Component: 2.0l R4 TFSI H13 0004 <<<<<<<<<<<<<<<<<<<<<<<<<<<<< FIRMWARE UPDATE NEEDED?
Volkswagen
PartVersion
5G0906259A_0004
0005
0006
TMD Auto
C?ID=413117
Thats what i was thinking. i pull the hose of the intake boot and block it off and idle goes normal and vehicle goes into closed loop. i checked for leaks watching my STFT and it stabilized i have a oil sperarator on order from VW hopefully this fixes issue.
