Hi all,
In the process of getting verified, bear with me :-). For reference I have a genuine HEX+CAN USB interface purchased about 10 years ago.
I have a 2004 Audi C5 S6 sedan. I bought the car about 5 months ago and noticed immediately after I started driving it that the speedometer seemed to read too fast all the time. The wheels and tyres are standard rolling diameter for the S6 (255/35 R18).
Finally yesterday I got around to checking the instrument cluster coding. The coding is 05783. For my car, that means its coded for "Allroad wheels and tyres" and "80L fuel tank" by having 05 at the start. I have no idea why its coded this way but its obviously wrong, as my car has the standard 70L tank and small wheels (not allroad sized!). I have no other reason to suspect the cluster has been changed in the past either, and it has "S6" in the tachometer.
So, I've tried to recode the module to 00783 just by changing the coding to "00783" and clicking "Do it". The "coding" window closes after I hit "do it", (the window for instrument cluster stays open) communication is maintained but the coding does not change (remains 05783).
My next thought was that I need to "login" to make this coding change.... but I don't actually know if I do need to - if someone could confirm that, it would be good. If I do need to login, is it a generic login or is it the 4 digit SKC? In which case, do I now need to get Vag commander or similar to pull the SKC from the cluster?
Any help would be greatly appreciated!
Aydan
Aydan
