I ordered air bag control module for this vehicle & would like to confirm factory VW ODIS system will be needed to program & code new module
If someone provide insights or procedures for this procedure
Thank You
Daniel Scarafone
Thank You
Daniel Scarafone
Friday,20,November,2020,10:25:48:64419
VCDS Version: 20.4.2.0 (x64) HEX-NET CB: 0.4513.4
VIN: 1V2XR2CA4KC549012 License Plate:
Mileage: 44334km-27547mi Repair Order:
Chassis Type: CA-VW41 (3Q0)
Scan: 01 02 03 05 08 09 13 15 17 19 22 2B 3C 42 44 4B 52 5F 69 6C
6D 75 A5 CA D6 D7
VIN: 1V2XR2CA4KC549012 Mileage: 44334km-27547miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-CDVC) Labels:. 03H-907-309-V1.clb
Part No SW: 03H 906 026 AA HW: 03H 907 309 K
Component: VR6 3.6l FSI H21 9970
Revision: 52H21000
Coding: 012A001244740108B0000000000000000000000000000000
Shop #: WSC 06485 444 00000
ASAM Dataset: EV_ECM36FSI01103H906026AA 001007
ROD: EV_ECM36FSI01103H906026AA.rod
VCID: E484CF29EFA09CA617-80B0
CAN Converter 01:
Readiness: 1110 0101
Address 02: Auto Trans (J217) Labels: 09G-927-749-V2.clb
Part No SW: 09G 927 158 DR HW: 09G 927 158
Component: AISIN AQ8 206 3536
Coding: 0000000100000000000000000000000000000000
Shop #: WSC 06050 062 00200
ROD: EV_TCMAQ450031_VW37.rod
VCID: 8640F5A139DC0EB6A9-80D2
Part No SW: 5Q0 614 517 DT HW: 5Q0 614 517 BP
Component: ESC H35 0108
Revision: 00000000 Serial number: 50509000001260
Coding: 44FC6B8D80241A75C5770301A2C56922D60158A3C045967618415058D2AA4A0B004023641C12141A1D8DDB45506CC8CF
ROD: EV_Brake1UDSContiMK100IPB_038.rod
Part No SW: 3Q0 959 435 L HW: 3Q0 959 435 L
Component: VWKESSYMQB 037 1204
Revision: 00037000 Serial number: 0503361793
Coding: 1F20000723
ASAM Dataset: EV_KessyHellaMQBAB 004046
ROD: EV_KessyHellaMQBAB.rod
VCID: C3C62CB54A6EFB9ECE-8096
Address 08: Auto HVAC (J255) Labels:* None
Part No SW: 3CN 907 044 L HW: 3CN 907 044 L
Component: Climatronic H04 2009
Revision: 00001K03
Coding: 1602002620001C00110421005210142C
ASAM Dataset: EV_ACClimaBHBVW416 002012
ROD: EV_ACClimaBHBVW416.rod
VCID: C8DC3B997348D8C61B-809C
Fresh Air Blower Back:
Part No SW: 5Q0 937 085 BT HW: 5Q0 937 085 BG
Component: BCM MQBAB HNA H38 0273
Serial number: 9041012402ÿÿÿÿ
ROD: EV_BCMBOSCH_019.rod
VCID: 8C54C78927B074E6FF-80D8
Subsystem 1 - Part No SW: 5Q0 955 555 HW: 5Q0 955 555
Component: RLHSS 052 0122
Serial number: S7Y19M01D07H23M36S19
Coding: 00382D
Subsystem 2 - Part No SW: 4M0 907 410 A HW: 4M0 907 410 A
Component: USHL5 H08 0050
Serial number: 0000009600363Z01MK02
Coding: 150000
Garage Door Opener Operating Unit:
Subsystem 3 - Part No SW: 3CN 959 719 HW: 3CN 959 719
Component: GTO BF H06 0007
Serial number: 8MW00123111800010309
Steering Column Switch:
Subsystem 4 - Part No SW: 5Q1 953 521 M HW: 5Q1 953 569
Component: Lenks.Modul H03 0170
Serial number: 0300190120190C209880
Address 13: Auto Dist. Reg (J428) Labels:| 3Q0-907-572.clb
Part No SW: 5Q0 907 572 P HW: 3QF 907 572 A
Coding: 320007C911FFC728949C810530401600000000000000000004
VCID: C4C42FA94F60FCA6F7-8090
Part No SW: 3Q0 959 655 DB HW: 3Q0 959 655 DB
Component: Airbag VW21 006 0720
Revision: -------- Serial number: 00310M35DSOD
Coding: 8CCCDC00000000005000001A420800000065
ROD: EV_AirbaVW21TS6VW48X.rod
VCID: 814AE6BD10F2298E9C-80D4
Occupant Detection:
Component: Occ.Detection H13 0022
Serial number: IBH0000J19000B1U8F0B
Coding: 303030
Subsystem 2 - Part No SW: ----------- HW: 454 000 912 18
Serial number: 35700000000DF628973Z
Subsystem 3 - Part No SW: ----------- HW: 454 001 812 18
Serial number: 358000000000E848973Q
Subsystem 4 - Part No SW: ----------- HW: 454 801 202 19
Serial number: 3510051B1A6170000008
Subsystem 5 - Part No SW: ----------- HW: 454 800 901 19
Serial number: 352003FC87017000000K
Subsystem 6 - Part No SW: ----------- HW: 454 801 302 19
Serial number: 355007BB74917000000R
Front Sensor Passenger:
Subsystem 7 - Part No SW: ----------- HW: 454 801 302 19
Component: FrontSensor_P 304 0149
Serial number: 356002BB34917000000J
16755714 - Internal Control Module Memory Check Sum Error
B2000 00 [008] - -
[Electronic Control Unit Malfunction]
Reset counter: 180
Mileage: 44334 km
Date: 2020.11.19
Time: 11:05:06
16755715 - Internal Control Module Memory Check Sum Error
B2000 00 [008] - -
Reset counter: 180
Mileage: 44334 km
Date: 2020.11.19
Time: 11:05:06
Address 17: Instruments (J285) Labels:* None-SRI3
Part No SW: 3CN 920 850 B HW: 3CN 920 850 B
Component: KOMBI 351 2700
Coding: 0BA4171DEF88CF0502886B0B50000000A0000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009068
VCID: BE305D41218C9676A1-80EA
Part No SW: 3Q0 907 530 AA HW: 3Q0 907 530 C
Component: GW MQB High 521 5366
Serial number: 21011900840952
Coding: 030500347F087300FB0322581E0F00010001070000000000000000000000
ROD: EV_GatewNF_VW37.rod
VCID: EE90AD01316C26F671-80BA
Component: 0-01-0e-01-04
Subsystem 2 - Part No SW: 5G0 959 442 AB HW: 5G0 959 442 AB Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H17 0052
Serial number: 33190000106320011439
Coding: 2CFFFF
Subsystem 3 - Part No SW: 5QA 915 181 D HW: 5QA 915 181 D
Serial number: 2415546300
Part No SW: 0CQ 907 554 J HW: 0CQ 525 130
Component: Haldex4Motion H55 7084
Serial number: HA1-00011.12.18
Coding: 0301
VCID: CCD40789673034E63F-8098
Part No SW: 3Q0 905 861 B HW: 3Q0 905 861 B
Component: ELV-MQBB H05 0020
Serial number: 18000382861003
Coding: 0800000000000000
ROD: EV_ELVMarqMQBA0_VW41.rod
VCID: B3267C751ACE4B1E5E-80E6
Address 3C: Lane Change (J1086) Labels:| 5Q0-907-686.clb
Part No SW: 5Q0 907 686 C HW: 5Q0 907 686 C
Component: HRE_Master H12 0081
Serial number: 0505928933
Coding: 01012103
ROD: EV_HREntryHella_VW27.rod
VCID: BD325A4D2C8A8D6EB8-80E8
Lane Change Assistant 2:
Subsystem 1 - Part No SW: 5Q0 907 685 C HW: 5Q0 907 685 C
Component: HRE_Slave H12 0081
Serial number: 0504266223
Coding: 010121
Part No SW: 5Q0 959 593 F HW: 5Q0 959 593 F
Component: TSG FS001 0287
Serial number: YA008SAE001N2
Coding: 00341B200000020000000000
Subsystem 1 - Part No SW: 5Q4 959 812 G HW: 5Q4 959 812 G
Component: Fond FHSG DRV 010 0004
Serial number: 00000000000001721661
Coding: 011000
Part No SW: 3QF 909 144 B HW: 3QF 909 144 A
Component: EPS_MQB_ZFLS 570 1582
Coding: 991F0000
ROD: EV_SteerAssisMQB_015.rod
VCID: C7DE38A57E56D7BE12-8092
Address 4B: Multifunc. Module (J745) Labels:| 3Q0-907-338-V2.clb
Part No SW: 3Q0 907 338 C HW: 3Q0 907 338 C
Component: FCM MQB Low 002 0345
Serial number: 16021900841773
Coding: 000000070900135200010000000000000000000000000000000000000000
ASAM Dataset: EV_MultiModulContiVW48X 002006
ROD: EV_MultiModulContiVW48X_002_VW41.rod
VCID: B522426D14BA552E70-80E0
Part No SW: 5Q0 959 592 F HW: 5Q0 959 592 F
Component: TSG BFS001 0287
Serial number: YA008SAE003YA
Coding: 003413200000020000000000
Subsystem 1 - Part No SW: 5Q4 959 811 G HW: 5Q4 959 811 G
Component: Fond FHSG PSG 010 0004
Serial number: 00000000000001720891
Coding: 091000
Part No SW: 3Q0 035 844 B HW: 3Q0 035 844 B
Component: MU-S-S-US 724 0890
Coding: 02140600FF00000051220001001808001F0506C40120050002
ROD: EV_MUStd4CDELP_VW37.rod
VCID: AE106D01F1EC66F631-80FA
Subsystem 1 - Part No SW: 5G6 919 605 C HW: 5G6 919 605 C
Component: ABT_Std-2 H52 8130
Serial number: VWZ6ZJW0162147
0528 - Rear Left Treble Speaker
B1066 13 [009] - Open Circuit
[Hochtonlautsprecher Kanal 4: Unterbrechung (AC-Diagnose)]
Reset counter: 141
Mileage: 44334 km
Date: 2020.11.20
Time: 10:22:31
Voltage terminal 30: 12.2 V
Part No SW: 5Q0 907 383 L HW: 5Q0 907 383 L
Component: Anhaenger H27 0260
Revision: 8C001004 Serial number: 0503175469
Coding: 0200000200000000
VCID: C0CC23B95B78E086D3-8094
Component: RVC Compact H15 0231
Coding: 01140602A1002017300040
VCID: B93A4E5D38A2B14E94-80EC
Part No SW: 5Q0 959 107 P HW: 5Q0 959 107 J
Component: HDSG-Modul H13 0266
Revision: -------- Serial number: A2-C758-8680-2
Coding: 0988
VCID: C5C232AD445AC5AEE0-8090
Address 75: Telematics (J949) Labels:| 5QE-035-285.clb
Part No SW: 5QE 035 285 A HW: 5QE 035 285 A
Component: OCULowMQBUS 009 0570
Coding: 02140602C2823A017F1E06020000
ROD: EV_OCULowMQB.rod
Part No SW: 3Q0 980 654 L HW: 3Q0 980 654 A
Component: MQB_B_MFK H09 0610
Serial number: 16111815P21792
Coding: 0004010600010201002200558150490084000E20010000
ROD: EV_MFKBoschMQBB_002.rod
Part No SW: 4M0 907 594 J HW: 4M0 907 594
Component: SAD_STG_1 014 0005
Coding: 00804074160C
ROD: EV_SunRoofCONTIAU736_006.rod
Address D6: Light Ctrl Left 2 (A31) Labels: 7P5-941-591.clb
Part No SW: 7P5 941 591 AA HW: 7P5 941 591 A
Component: LED1L H06 0003
ROD: EV_LED_PLUS_L_KEBODAVW416_VW37.rod
VCID: FBB69455721E435EC6-80AE
Address D7: Light Ctrl Right 2 (A27) Labels: 7P5-941-591.clb
Component: LED1R H06 0003
ROD: EV_LED_PLUS_R_KEBODAVW416_VW41.rod
End----------(Elapsed Time: 01:51, VBatt start/end: 13.2V/13.0V)-----------
