Hi all.
Its my first post on here so if i make a mess of it please excuse me.
I've got an 2007 Audi a3 with the 1.9 PD BXE engine.
Its been having long crank issues for a couple of weeks now so I've decided this weekend to have a look at it.
I Have a fault code stored P3007 Cam Position Sensor G40 No Signal - Intermittent.
First of all i have checked on advanced measuring blocks on cam speed and torsion value and found the sensor to drop out.
The next step of diagnosis i removed the connector for the cam sensor and checked the terminals for any corrosion etc.
Ive then checked voltage at my wiring and found Pin 1 - 5v Pin 2 - 5v and Pin 3 - 0v (Ground)?
I know that the wiring looms can rub through on the front of the engine so ive pulled the trunking off and inspected the loom but couldn't find any faults.
I've then removed the ECU and checked resistance through the wiring back to the cam sensor -
Pins 27 - 28 - 12 on the ecu to Pins 1 - 2 - 3 of the Cam sensor to find 0.01Ohms.
Happy with my figures i have then gone ahead and replaced the cam sensor.
After replacing the cam sensor i found a different fault to appear being P0341 - Camshaft Position Sensor (G40): Implausible Signal
When checking on advanced measuring blocks i have the correct cam speed but on torsion value to sit 0.0kw
I've tried clearing the fault code but it comes straight back.
I've now checked the engine timing and found to be perfect.
I'm starting to think the new cam sensor purchased is at fault. This is also a Lucas cam sensor. Have i been stupid here and should have just gone genuine?
I've got a scan of the vehicle but im unsure how to upload so i will post it in here.
Sunday,08,November,2020,13:08:59:43516
Dealer/Shop Name:
VIN: License Plate:
Mileage: 252730km-157039mi Repair Order:
Chassis Type: 8P (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 77
VIN: WAUZZZ8P38A087706 Mileage: 252730km-157039miles
42-Door Elect, Driver -- Status: Sporadic communication error 1000
72-Door, Rear Right -- Status: Sporadic communication error 1000
Address 01: Engine Labels: 03G-906-016-BKC.clb
Part No SW: 03G 906 021 LS HW: 03G 906 021 AN
Component: R4 1,9L EDC 000SG 9182
Revision: --H07--- Serial number: AUX7Z0G9FN909U
Coding: 0000071
Shop #: WSC 06314 000 00000
VCID: 7BA207CC2FEFFF13071-802E
012295 - Camshaft Position Sensor (G40)
P3007 - 000 - No Signal - Intermittent
Fault Status: 00110000
Fault Frequency: 9
Mileage: 252722 km
Date: 2020.10.27
Time: 15:28:19
RPM: 819 /min
Voltage: 14.06 V
Bin. Bits: 11000000
Idle Stabilization: 0.0°KW
(no units): 48.0
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0021121
VCID: 73B22FEC07BFB7535F1-8026
Address 08: Auto HVAC Labels: None
Part No: 8P0 820 047
Component: J255 Klima Man H07 0030
VCID: 6D863994619B61A3895-8038
Address 09: Cent. Elect. Labels:. 8P0-907-279-30-B.lbl
Part No SW: 8P0 907 279 J HW: 8P0 907 279 J
Component: Bordnetz-SG H54 2501
Revision: 00H54000 Serial number: 00000007707726
Coding: 00880F01B01410004F1600001600000000085A175C010000000000000000
Shop #: WSC 06314 000 08192
VCID: 44D0BC30129140EB36B-8010
Subsystem 1 - Part No: 8P2 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer AU350 H01 0130
Coding: 00062736
Shop #: WSC 06314
Fault Status: 00111010
Reset counter: 123
Mileage: 251648 km
Date: 2020.10.02
Time: 17:13:00
Voltage: 14.05 V
Reset counter: 84
Mileage: 200551 km
Date: 2017.10.31
Time: 17:32:00
Voltage: 12.20 V
Reset counter: 84
Mileage: 245745 km
Date: 2020.06.15
Time: 09:15:00
Voltage: 13.95 V
Address 15: Airbags Labels: 8P0-959-655-94.lbl
Part No SW: 8P0 959 655 L HW: 8P0 959 655 L
Component: Airbag 9.41 H01 4210
Revision: 91H01421 Serial number: 003CP0018PC0
Coding: 0071612
VCID: 4BC2970C3FCF8F93F71-801E
Subsystem 1 - Serial number: 6332DRB405F61524L
Subsystem 2 - Serial number: 6342DRB405F54EA93
Subsystem 3 - Serial number: 63528RB40316A77DR
Subsystem 4 - Serial number: 63628RB40316AA10C
Subsystem 5 - Serial number: 63747RB402FA76C0Z
Subsystem 6 - Serial number: 63847RB402FA899D7
Part No SW: 1K0 953 549 AH HW: 1K0 953 549 AH
Component: J0527 036 0070
Coding: 0000002
VCID: 78A818C01ED9D40B6A3-802C
Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
Part No SW: 8P0 920 951 G HW: 8P0 920 951 G
Component: KOMBIINSTR. VDO H20 0630
Revision: D0H20001 Serial number: 1249G001100086
Coding: 0004423
Shop #: WSC 00779 067 57207
VCID: 392EDDC465530D0355D-806C
Address 19: CAN Gateway Labels:. 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 P HW: 1K0 907 951
Component: J533__Gateway H16 0191
Revision: H16 Serial number: 2000K07A03851E
Coding: E9807F060006022103
VCID: 3430ECF04231F06B86B-8060
Reset counter: 84
Mileage: 200551 km
Date: 2017.10.31
Time: 17:32:12
Reset counter: 84
Mileage: 245721 km
Date: 2020.06.14
Time: 15:52:52
Revision: D0H20001 Serial number: AUX7Z0G9FN909U
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN3.lbl
Part No SW: 8P0 959 801 K HW: 8P0 959 801 K
Component: Tuer-SG H03 0050
Coding: 0000688
VCID: 43D2BF2C179F47D30F1-8016
Address 44: Steering Assist Labels: 1Kx-909-144-G2V3.clb
Part No: 1K2 909 144 M
Component: EPS_ZFLS Kl.078 H08 1901
Shop #: WSC 02069 000 90108
VCID: 3634D6F8544DE27BB8F-8062
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 J
Component: KSG H11 0080
Coding: 1980202002186D0985054C9FC637
Subsystem 2 - Part No: 1K0 907 719 C
Component: Neigungssensor 005 0003
Subsystem 3 - Part No: 8P0 951 177
Component: Innenraumueberw.H04 0020
Part No SW: 8P0 959 802 K HW: 8P0 959 802 K
Coding: 0000688
Address 56: Radio Labels: 8J0-035-1xx-56.clb
Part No SW: 8P0 035 152 C HW: 8P0 035 152 C
Component: R Chorus2+ H16 0240
Revision: 00H16000 Serial number: AUZ1Z2G9266817
Coding: 0400221
VCID: 2B02F78C9F0FAF93D71-807E
00871 - Bass Speaker Front Right (R23)
Fault Status: 00101011
Reset counter: 123
Mileage: 250597 km
Date: 2020.09.08
Time: 14:39:47
Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
Part No SW: 8P4 959 801 E HW: 8P4 959 801 E
Component: Tuer-SG H04 0040
Coding: 0000144
Shop #: WSC 06314 000 1012544
VCID: 41DEB5240D8355C31DD-8014
Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
Part No SW: 8P4 959 802 E HW: 8P4 959 802 E
Coding: 0000144
VCID: 42DCBA2808854EDB047-8016
Part No SW: 8P0 862 335 Q HW: 8P0 862 335 Q
Component: FSE_255x BT H26 0350
Revision: 00000000 Serial number: 00000005261472
Coding: 0000120
End----------(Elapsed Time: 01:22, VBatt start/end: 12.7V/12.7V)-----------
