Audi A1 Sportback 2019 - activation of the high beam assistant (FLA)
hm1975
C?ID=72358
I have seen on German websites that it's possible to activate of the high beam assistant (FLA) using front camera on Audi A1 Sportback but it appears to be on an OBD app.
Does anyone know the coding for VCDS to enable this feature?
South Molton, UK
Please post a full unedited VCDS Auto-Scan of your A1 so we can see how it is equipped to be able to suggest possible methods to activate FLA.
hm1975
C?ID=72358
Scan below, think I got it right;
Sunday,22,November,2020,11:10:01:03630
VIN: WAUZZZGB9LR015280   License Plate:
Chassis Type: GB-AU27 (3Q0)
Scan: 01 02 03 08 09 10 13 15 17 19 42 44 47 4B 52 5F 6C 75 A5 BB
          BC D6 D7 DE
VIN: WAUZZZGB9LR015280   Mileage: 5692km-3536miles
Address 01: Engine (J623-DPCA)       Labels: None
   Part No SW: 05E 906 018 AP    HW: 05E 907 309 H
   Component: R4 1.5l TFS   H20 9643
   Revision: 8AH20000
   Coding: 022500322324050800000000000000000000000000000000
   ASAM Dataset: EV_ECM15TFS01105E906018AP 003003
   ROD: EV_ECM15TFS01105E906018AP_AU27.rod
   VCID: 73B3DE51FB35CA735F1-8026
5464 - Ignition Switch; Run/Start Position Circuit
          P2535 00 [032] - Short to Plus
19305 - Exhaust Pressure Control Valve
          P0475 00 [032] - Electrical Malfunction
   Part No SW: 0CW 300 050 A    HW: 0AM 927 769 E
   Component: GSG DQ200G2_M H05 1702
   Revision: 00005009    Serial number: CU501909177041
   Shop #: WSC 00049 770 00121
   ROD: EV_TCMDQ200021_VW27.rod
   VCID: 33331E51BBB58A739F1-8066
Address 03: ABS Brakes (J104)       Labels: Redir Fail!
   Part No SW: 2Q0 614 517 AG    HW: 2Q0 614 517 N
   Component: ESC_base_vFGS H23 0242
   Serial number: 08507562190921
   Coding: 42094D4F354242B2B2FEAC1E37DA23A649125126336A24582454285545ECC46592488A64CC56241A242A14AAA255D243BDAA4BC2BD
   ASAM Dataset: EV_Brake1BOSCHESPMQBA0 004036
   ROD: EV_Brake1BOSCHESPMQBA0_004.rod
   Part No SW: 83A 820 043 J    HW: 83A 820 043 J
   Component: AC Automat    H04 0052
   Revision: 20026000    Serial number: 00000000240702
   Coding: 231000040000000110000000000011040000000000000000
   ASAM Dataset: EV_AirCondiFrontVaAU326 001005
   ROD: EV_AirCondiFrontVaAU326.rod
   VCID: 270BFA017F6DF6D3339-8072
   Part No SW: 5Q0 937 084 DH    HW: 5Q0 937 084 CG
   Component: BCM MQBAB H   H40 0312
   Serial number: 01001926500075
   ASAM Dataset: EV_BCMMQB 020001
   ROD: EV_BCMBOSCH_020.rod
   VCID: 015F8499B189E8E35DD-8054
   Subsystem 1 - Part No SW: 81A 955 555 A    HW: 81A 955 555
   Component: G397_RLFSS  H06  0002
   Serial number: 23563669X81A955555A0
   Coding: 80004D
   Subsystem 2 - Part No SW: 4K2 941 501     HW: 4K2 941 501
   Component: E1 - LTM  H05  0053
   Serial number: 16S30.09.1900300884
   Subsystem 3 - Part No SW: 5Q0 951 177     HW: 5Q0 951 172
   Component: Sensor, DWA  005  0316
   Serial number: 000000000ZY1923520T1
   Component: Sirene, DWA  005  0314
   Serial number: 00000000000031625116
   Steering Column Switch:
   Subsystem 5 - Part No SW: 82A 953 521 DS    HW: 5Q1 953 549
   Component: J527 SMLS MQB  004  0070
   Serial number: 00000030091904400976
   Part No SW: 5QA 919 294 G    HW: 5QA 919 294
   Component: PDC 8 Kanal   H08 0061
   Serial number: 000150058419269
   Coding: 0471151011
   ASAM Dataset: EV_EPHVA18AU3700000 009046
   ROD: EV_EPHVA18AU3700000_009_VW27.rod
   VCID: 50F971DD2A63D16B823-8004
   Part No SW: 2Q0 907 572 R    HW: 5Q3 907 572
   Component: ACCCONTIMQB   H03 0372
   Coding: 3200008248FF8728747C61450050A700080000000000000004
   ROD: EV_ACCMRRCONTIVW376_003_VW27.rod
   VCID: 43D34E91EB153AF30F1-8016
   Part No SW: 2Q0 959 655 AM    HW: 2Q0 959 655 AM
   Component: VW22Airbag    012 0351
   Revision: --------
   Coding: 88CCC0C0000000005C5400DF008840A80065
   Shop #: WSC 00049 770 00083
   ASAM Dataset: EV_AirbaVW22BPAVW27X 001020
   ROD: EV_AirbaVW22BPAVW27X_VW37.rod
   VCID: 084999BD92B3D9AB1A3-805C
   Subsystem 1 - Part No SW: -----------    HW: 442 060 210 19
   Serial number: 3577Y50A73229F837277
   Subsystem 2 - Part No SW: -----------    HW: 442 060 210 19
   Serial number: 3587Y50C53180762054T
   Subsystem 3 - Part No SW: -----------    HW: 442 0B2 009 19
   Serial number: 3517780B133B2863C3BJ
   Subsystem 4 - Part No SW: -----------    HW: 442 0B2 309 19
   Serial number: 35277129B33DB1C1739O
   Subsystem 5 - Part No SW: -----------    HW: 442 132 709 19
   Component: FrontSensor_D  290 118A
   Serial number: 355AG11B730D10213466
   Part No SW: 82A 920 710 A    HW: 82A 920 710 A
   Component: KOMBI         H02 4192
   Coding: 24A50008698026000180E0401000000000000000
   ASAM Dataset: EV_DashBoardVDDMQBA0 001041
   ROD: EV_DashBoardVDDMQBA0_AU27.rod
   VCID: 1F1BE2E1273D3E134B9-804A
   Part No SW: 3Q0 907 530 AC    HW: 3Q0 907 530 C
   Component: GW MQB High   521 5388
   Serial number: 01101910523263
   Coding: 030100F42F0857005B100248180B00000000000000000000000000000000
   ROD: EV_GatewNF_AU27.rod
   VCID: 70B9D15D8A23F16BA23-8024
   Component: 5-01-14-01-04
   Subsystem 2 - Part No SW: 82A 951 523 B    HW: 82A 951 523 B
   Component: E221__MFL  H06 0003
   Subsystem 3 - Part No SW: 2Q0 915 181 B    HW: 2Q0 915 181 B
   Component: J367-BDMBOSCH  H02 2012
   Serial number: 10014ACD
Address 42: Door Elect, Driver (J386)       Labels:* Redir Fail!
   Part No SW: 5Q4 959 593 K    HW: 5Q4 959 593 K
   Component: TSG FS        007 0485
   Serial number: 0000390546705
   Coding: 00180220F001020000001000
   VCID: 4DC768A93D51FC83E95-8018
   Subsystem 1 - Part No SW: 5Q0 959 408     HW: 5Q0 959 164
   Component: FOND_FHSG_DRV  007 0010
   Serial number: 00000000000034393927
   Coding: 2D0000
Address 44: Steering Assist (J792)       Labels:* None
   Part No SW: 2Q2 909 144 M    HW: 2Q2 909 144 F
   Component: TRW_G4L_MQBA0 621 6041
   Serial number: 1483107CB4K2803
   Coding: 010000000100000101010201010001010000010101
   ASAM Dataset: EV_SteerAssisTRWG4LMQBA0 011016
   ROD: EV_SteerAssisTRWG4LMQBA0.rod
   VCID: 3D2738698DF14C03795-8068
10591488 - Internal Fault
          B200F F0 [008] - Unknown Error Elaboration
          [DEM_LATE_HALL_EDGE_FAULT]
                    Reset counter: 46
                    Mileage: 4659 km
                    Date: 2020.06.19
                    Time: 13:58:23
                    Engine speed: 927 /min
                    System status: Driving mode
                    Terminal 15 status: On
                    Voltage terminal 30: 14.15 V
                    Power steering current consumption: 0.5 A
                    max.value: 0.5 A
                    End stage temperature: 29 ∞C
                    Steering assistance: engine output: 100 %
                    Engine angle: 9 ∞
                    Electric motor speed: 0 /min
                    Steering assistance: target engine torque: 0.0 Nm
                    Steering torque: -0.1 Nm
   Part No SW: 83A 035 465 A    HW: 83A 035 465
   Component: MIB2_amp_P_Q3 H01 0130
   Revision: 00000001    Serial number: AUZ8ZAK7F006QC%
   Coding: 0172000000AAA0A0AA0000010000
   ASAM Dataset: EV_AMPMst16C3Gen2pALPI 001001
   ROD: EV_AMPMst16C3Gen2pALPI.rod
   VCID: 2411ED0D0E5B1DCB16B-8070
   Part No SW: 3Q0 907 338 E    HW: 3Q0 907 338 E
   Component: FCM MQB Low   003 0367
   Serial number: 24091911601731
   Coding: 000000070900204600002900020000000000000000000000000000000000
   Shop #: WSC 00049 770 00087
   ROD: EV_MultiModulContiVW48X_003_VW41.rod
   VCID: 372B2A41AFCD6653A39-8062
Address 52: Door Elect, Pass. (J387)       Labels:* Redir Fail!
   Part No SW: 5Q4 959 592 K    HW: 5Q4 959 592 K
   Component: TSG BFS       007 0485
   Serial number: 0000389484840
   Coding: 00180020FC01020000001000
   VCID: 4CC165ADC64BF58BFEB-8018
   Subsystem 1 - Part No SW: 5Q0 959 407     HW: 5Q0 959 163
   Component: FOND_FHSG_PSG  007 0010
   Serial number: 00000000000034167589
   Coding: 350000
   Part No SW: 83A 035 063 B    HW: 83A 035 063
   Component: MU-H-LND-EU   054 2647
   Coding: 017200010000000043111102400800302F0001E601700000CE
   Subsystem 1 - Part No: V03 959 807 SB
   Component: MIB2P_EU_Q220  0450
   Subsystem 2 - Part No SW: 82A 919 605 B    HW: 82A 919 605 B
   Component: DU AU270 High  H42 0137
   Serial number: MA18X1AEA0260100
   Compact Disc Database:
   Component: Gracenote2  1010
   Volume Control 1:
   Subsystem 4 - Part No SW: 82A 919 616 A    HW: 82A 919 616
   Serial number: 00004419000101879042
   Media socket:
          B2000 87 [008] - Missing message
                    Reset counter: 204
                    Mileage: 5596 km
                    Date: 2020.11.03
                    Time: 11:09:20
                    Voltage terminal 30: 14.7 V
                    Software module: status-SW_Status_Consistency: 00 00 01
                    Software module: status-SW_Status_Device: NavDB
1561 - predictive route data
          B1630 02 [008] - Signal Failure
                    Reset counter: 207
                    Mileage: 5618 km
                    Date: 2020.11.08
                    Time: 14:12:34
                    Voltage terminal 30: 14.9 V
   Coding: 0272000102002001400040
   VCID: 392F2C7999D9702355D-806C
   Part No SW: 5WA 035 282     HW: 5WA 035 282
   Component: OCUGen3Low    H14 0083
   Serial number: 0000000907NVJH3
   Coding: 013260101FE8208480054601200D0000
   ASAM Dataset: EV_OCUGen3Low 002036
   ROD: EV_OCUGen3Low_AU27.rod
   Part No SW: 3Q0 980 654 M    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H12 0451
   Serial number: 23091915P13515
   Coding: 0402070000000401000223448156440084000E20000000
   ROD: EV_MFKBoschMQBB_002.rod
   VCID: 41DF4499F10928E31DD-8014
Address BB: Door Rear Drv
Address BC: Door Rear Pass
Address D6: Light Ctrl Left 2 (A31)       Labels: None
   Part No SW: 4K0 941 572 CC    HW: 4K0 941 572 C
   Component: LMS_MQB       H06 0031
   ROD: EV_LMSLeftHELLAAU58X_AU27.rod
   VCID: 71BFD4598129F863ADD-8024
Address D7: Light Ctrl Right 2 (A27)       Labels: None
   ROD: EV_LMSRightHELLAAU58X_AU27.rod
Address DE: Charger 1 for mobile dev (J1146)       Labels:* 4N0-035-502.clb
   Part No SW: 4N0 035 502 B    HW: 4N0 035 502 B
   Component: WLC Front     H14 0061
   Coding: 400080
   VCID: 2313EE110B551AF36F1-8076
End----------(Elapsed Time: 01:24, VBatt start/end: 12.2V/12.1V)-----------
@hm1975 Hi - nice job including scan in your almost inaugural post above!
Not sure about the Audi A1 (GB) specifically, but the tweak instructions for MQB vehicles generally for High-beam assist goes something like this:
Enter magic number 31347 as SA
Go to Adaptation
Enter "141650" into search box and change channel settings below:
  • ENG141650-MAS13782-Fernlicht_assistent-Will Beam assistant: responsivity adjustable via BAP > present
  • ENG141650-ENG141973-Fernlicht_assistent-Erweiterte_Fernlichtsteuerung > if current setting is AFS: BCM-Fernlicht, change to AFS: FLA: BCM-Fernlicht or if current setting is AFS: Fernlicht ueber AFS change to to AFS: FLA: Fernlicht ueber AFS
  • ENG141650-ENG116639-Fernlicht_assistent-Fernlichtassistent Reset > active
  • ENG141650-ENG116637-Fernlicht_assistent-Menuesteuerung Fernlichtassistent > present
  • ENG141650-ENG116641-Fernlicht_assistent-Menuesteuerung Fernlichtassistent Werkseinstellung > present
After these changes, you should see "Light Assist" in car MENU
On MMI, select: CAR -> Exterior lighting -> Automatic headlights -> main beam assist (place tick in box)
Select Coding
Byte 21, Bit 5=1 (Byte 21 should be hex20 after change)
hm1975
C?ID=72358
That worked, one other question is it also possible to enable Activation of the camera-based traffic sign display, apparently the same camera can show traffic signs in virtual cockpit.
stefan147
Greece
C?ID=361962
Try to copy these and see what happens:
5F adaptations
ENG122229-ENG117754-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21,activated ,64
ENG122229-ENG117755-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21_msg_bus,Databus extended ,64
ENG122227-ENG117636-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification,activated ,60
ENG122227-ENG117640-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_after_disclaimer,not activated ,60
ENG122227-ENG117637-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_clamp_15_off,not activated ,60
ENG122227-ENG117638-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_over_threshold_high,activated ,60
ENG122227-ENG117639-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_standstill,not activated ,60
A5 adaptations
IDE04733-Road sign detection fusion mode,Road sign fusion ,1 (this only if the car is equipped with navigation I think)
Then try to tick every box in the Long Coding sections that has to do with Road sign, VZA etc in modules 5F, 17 and A5.
Hope I'm not missing something.
Tazman3
Scotland
C?ID=420770
I was wanting to try adding hba on my my16 TT but on getting to A5 my byte only goes up to 16? Im new to this so maybe I’m not reading it right or something
any help appreciated.
Tazman3
Scotland
C?ID=420770
Sorted now by the way
Tazman3
Scotland
C?ID=420770
Yeah sure
id done the coding to the A9 module which enabled me to select it on my mmi. Then one of the lads off the uk tt forum remoted into my computer and changed some other coding in another module. He’s very knowledgeable his name is Ryan goes by north east vag adaptions.
MELenium
C?ID=427074
Hi
I have an Audi A1 2019 and I have been trying to add High Beam Assist. The coding that I did seems to work, the stalk when pushed forward shows the icon on the screen and the on/off on the mmi is there ( not tried at night yet) but I have noticed that on the mmi the Activation Time where you can change from high to medium and low has disappeared from the screen, it was there before I coded the High Beam Assist.
My coding for this is on my vcds is as follows:
Select control module
09 Central electrics
Security access 31347
Adaption 10
Channel
ENG10578-ENG116637-Fernlicht assistant menuesteuerung fernlichtassistant Change to Present
ENG10578-ENG116641-Fernlicht assistant menuesteuerung fernlichtassistant werkseinstellung Change to Present
ENG10578-ENG10901-Fernlicht assistant erweiterte fernlichtassistant AFS: BCM-Fernlicht erweiterte fernlichtassistant AVF: FLA: BCA-Fernlicht setzen
Select Control Module
A5 Get sens. drv. assist
Coding 07
Long code helper
Byte 21
Bit 5-7 20 AFS coding light assist high beam assist
Is anything that I have coded that could have deleted on the mmi the Activation Time.
Thanks for any advice
@MELenium: Hello again. As I indicated in another place (the Vortex forum) when I suggested (some of) those changes "I'm always wary of "cross-pollinating" tweak instructions across variants of MQB platform vehicles". I'm not sure what you mean by the "Activation Time" and how, or if at all - it is compatible with HBA.
Perhaps to expedite a response to your questions, it might be prudent to start by posting-up a FULL (meaning unedited) copy of an auto-scan for the vehicle and maybe also include a more fulsome explanation of the "Activation Time" facility - please?
MELenium
C?ID=427074
Hi DV52
Hello we meet again, my car is Audi A1 2019, the Activation Time is in the Audi mmi screen under Lights and Vision where you can set the sensitivity of the dark and the light which you can be set to either Low, Medium or High depending on personal preferences. This was there before I did the coding. It should have been on the same screen as the new High Beam Assist button where you can turn it on or off. I have seen You Tube videos where they have shown the Activation Time buttons just sitting above the High Beam Assist button on the same screen.
Here is my Auto-scan taken after I had coded the High Beam Assist. I have omitted the VIN number.
Tuesday,05,January,2021,10:11:52:35634
VCDS Version: 20.12.0.1 (x64)  HEX-V2 CB: 0.4529.4
VIN:                                         License Plate:
Mileage: 6268km-3894mi   Repair Order:
Scan: 01 03 08 09 10 13 15 17 19 42 44 4B 52 5F 75 A5 D6 D7
VIN:                                                         Mileage: 6268km-3894miles
Address 01: Engine (J623-DKRF)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04C 906 025 M    HW: 04C 907 309 BB
   Component: R3 1.0l TFS   H20 6196
   Revision: D7H20000
   Coding: 02190032232405080000
   Shop #: WSC 00049 770 00000
   ASAM Dataset: EV_ECM10TFS01104C906025M 002003
   ROD: EV_ECM10TFS01104C906025K.rod
   VCID: 2A0D09206C779A7B0D6-807E
Readiness: 0010 0001
   Serial number: 08503995190330
   Coding: 41094D4F354682AFB203AC1F27DF43A649124D26224A24584454185445E4C2659248B2644452241A222A182AA255D242BDAA4B42BD
   VCID: 73B3D444FB3D9BB37E0-8026
   Part No SW: 83A 820 047 A    HW: 83A 820 047 A
   Component: AC Manuell el H04 0020
   Revision: 20026000    Serial number: 00000000551066
   Coding: 231000030000000010000000000001000000000000000000
   ASAM Dataset: EV_AirCondiFrontManAU326 001003
   ROD: EV_AirCondiFrontManAU326.rod
   VCID: 221DE1001447423B456-8076
   Part No SW: 5Q0 937 084 DD    HW: 5Q0 937 084 CG
   Component: BCM MQBAB H   H38 0273
   Serial number: 01001910302795
   Shop #: WSC 00049 770 00149
   ROD: EV_BCMBOSCH_019_VW27.rod
   VCID: 7DA7F27CCD79DDC3184-8028
   Subsystem 1 - Part No SW: 81A 955 559 A    HW: 81A 955 559
   Component: G397_RLS  H06 0002
   Serial number: 20222057X81A955559A0
   Coding: 80004D
   Serial number: 16S03.04.1900302579
   Serial number: 000000000ZY1906444JJ
   Serial number: 00000000000046782986
   Serial number: 00000018041904401294
   Part No SW: 5QA 919 283 C    HW: 5QA 919 283
   Component: PDC 4 KanalH07 0050
   Serial number: 000308419319101
   Coding: 0600040001
   ASAM Dataset: EV_EPHVA14AU3700000 009037
   ROD: EV_EPHVA14AU3700000_009_VW37.rod
   VCID: 4ACD69A0CC37BA7BED6-801E
   Part No SW: 2Q0 907 572 Q    HW: 5Q3 907 572
   Component: ACCCONTIMQB   H03 0342
   Coding: 2A00008108F78728747C61450050A700000000000000000000
   ASAM Dataset: EV_ACCMRRCONTIVW376 003015
   VCID: 42DD4180F407623B256-8016
   Part No SW: 2Q0 959 655 AK    HW: 2Q0 959 655 AK
   Component: VW22Airbag    010 0350
   Revision: --------
   ASAM Dataset: EV_AirbaVW22BPAVW27X 001014
   ROD: EV_AirbaVW22BPAVW27X.rod
   VCID: 06559D9098AF9E1B49E-8052
   Subsystem 1 - Part No SW: -----------    HW: 442 062 903 19
   Serial number: 3577Y50AB2DA7AF3425O
   Subsystem 2 - Part No SW: -----------    HW: 442 062 903 19
   Serial number: 3587Y50C92D00852D4FG
   Subsystem 3 - Part No SW: -----------    HW: 442 0B2 703 19
   Serial number: 35177129B2FAE64192D-
   Subsystem 4 - Part No SW: -----------    HW: 442 0B2 703 19
   Serial number: 3527712992FAE641621K
   Subsystem 5 - Part No SW: -----------    HW: 442 131 103 19
   Serial number: 355AG11BB3011B03E51G
   Part No SW: 82A 920 710     HW: 82A 920 710
   Component: KOMBI         H12 1712
   Coding: 24A40000698026000180A0001000000000000000
   ASAM Dataset: EV_DashBoardVDDMQBA0 001027
   VCID: 5EE595F060BF26DB21E-800A
1048578 - No Basic Setting
          B2010 00 [009] - -
          [Steuergerät keine oder falsche Grundeinstellung]
                    Reset counter: 169
                    Mileage: 6268 km
                    Date: 2021.01.04
                    Time: 11:42:12
   Serial number: 09041911601855
   Coding: 030100F42F0857005B000248080B00000000000000000000000000000000
   VCID: 6E85C530901FB65B91E-803A
   Generator:
   Component: 0-01-02-01-04
   Subsystem 2 - Part No SW: 82A 951 523 A    HW: 82A 951 523 A
   Component: E221__MFL  H07 0003
   Serial number: 10S07000338033919051
   Subsystem 3 - Part No SW: 2Q0 915 181     HW: 2Q0 915 181
   Component: J367-BDMBOSCH  H02 2011
   Serial number: 10101C3A
   Part No SW: 5Q4 959 393 F    HW: 5Q4 959 393 F
   Component: TSG FS        006 0246
   Serial number: 0000370517958
   Coding: 003C0220E001020000001000
   VCID: 46D55D90D82F5E1B09E-8012
   Serial number: 00000000000029378623
   Coding: 2D0000
   Component: TRW_G4L_MQBA0 621 TRW_G4L_MQBA0 621 60416041
   Serial number: 1146785CB4K1022
   ROD: N/A
   VCID: 3D27327C8DF91DC3584-8068
   Component: FCM MQB Low   002 0345
   Serial number: 14041910520670
   Shop #: WSC 53668 003 1048576
   ASAM Dataset: EV_MultiModulContiVW48X 002006
   ROD: EV_MultiModulContiVW48X_002_VW27.rod
   VCID: 35372A5CB5C9C583904-8060
   Part No SW: 5Q4 959 392 F    HW: 5Q4 959 392 F
   Component: TSG BFS       006 0246
   Serial number: 0000370379329
   Coding: 003C0020E001020000001000
   VCID: 45D75A9CE5295503004-8010
   Serial number: 00000000000029451087
   Coding: 350000
   Part No SW: 83A 035 842     HW: 83A 035 842
   Component: MU-S-D-ER     742 0051
   Coding: 01720000BE00000041111101C00800002F0007E60170000002
   ASAM Dataset: EV_MUStdGen2pDELP 001001
   ROD: EV_MUStdGen2pDELP.rod
   VCID: 629DA10054C7023B056-8036
   Multimedia System 1:
   Subsystem 1 - Part No SW: 82A 919 604 A    HW: 82A 919 604 A
   Component: DU AU270 Std  H42 0133
   Serial number: MA18X0AEA0133784
   Volume Control 1:
   Subsystem 2 - Part No SW: 82A 919 616     HW: 82A 919 616
   Component: LSR-D5/C8  H33 0108
   Serial number: 00004419000035730047
   Part No SW: 5NA 035 284 C    HW: 5NA 035 284 C
   Component: OCULowMQBLGE  H19 0825
   Revision: --------
   Coding: 01720601EA370A0F05109C0000354003804651
   ASAM Dataset: EV_OCULowMQBLGE 004049
   ROD: EV_OCULowMQBLGE_004_VW27.rod
   Component: MQB_B_MFK     H09 0451
   Serial number: 12041915P10640
   Coding: 0402070000000401000200448156440084000E20002000
   Shop #: WSC 00847 210 00000
   VCID: 41DF4E8CF10179233CC-8014
   ROD: EV_LMSLeftHELLAAU58X.rod
   VCID: 71BFDE4C8121A9A38CC-8024
End----------(Elapsed Time: 01:29, VBatt start/end: 12.1V/12.1V)-----------
MELenium
C?ID=427074
Hi DV52
I've deleted the old coding and started with a fresh code and everything is now working as it should
Mel_w
U.K
C?ID=426649
Hi All
I a novice with VCDS
on looking at the scan from the post this looks similar to my scan in the module 09 central elect and I have no HBA enabled how do you tell that the coding has been changed for the HBA
from the scan
Regards
Mel
MELenium
C?ID=427074
Hi Mel_w
As long as your car is the 2nd generation A1 then look in the mmi screen under Lights and Vision, then the Automatic Headlights there should be an option to switch HBA on, then make sure your Headlights are set at auto push the light stalk forward and the Auto icon will appear in the instrument screen as long as you have coded everything correctly using the proper vcds cable and have the latest software then as DV52 has done in the coding in the 4th message from the top.
