Dear Gentlemen,
I would like to ask you, if it is possible to check the battery conditions like actual voltage, actual charge, etc. without VCDS?
My car is a VW Passat B8 from 2019, off course I can read out them all with with VCDS through the CAN Gateway and the Advanced Measuring Values (DE01839 -- Battery charge condition), but I
would like to have it from menu on the instruments if possible on my car.
Reason is, that we use the Webasto auxiliary heater if it is cold outside because of our children, but drive only 10-15 minutes after the pre-heating., so actually I have to load the battery every day...
What I found till now does not work on my Passat, these are:
"Battery State of Charge percentage 17- Instruments 10- Adaptations Scroll down until you see Battery Charge, simply change it in the new value drop down to "active" and it's done." - I don't have Battery Charge under Instruments/Adaptions...
"Hidden menu in MMI high: STG 07 - Control Head - STG Adaptation -> Channel 8 - change 0 to 1" I don't have Control Head...
Other changes like changing the voltage for disabling the start/stop system, and the notification sound during closing and opening the doors are working perfectly.
Thank you in advance!
Regards
Toni
Regards
Toni
