Grayed out measure blocks button- can't see tranny adaptation values
Markheggie
La Jolla
H11-2H
Trying to view the transmission adaptation values but when I go to tranny controller, then I'm supposed to go to measure block (73-77) but the button is grayed out. Did 20.4 lose this functionality? Older versions (17.x) seem to be able to from screen shots on older posts. 2010 Audi s5.
Best
Mark
Mari
C?ID=150535
Try Advanced Meas. Values?
mattylondon
United Kingdom
C?ID=219022
It looks to me that version 17 is using 09L-927-760.LBL label file, and version 20 is using 0B6-927-156.CLB label file.
You could try to find 09L-927-760.LBL, copy and paste it into your user label directory and rename it.
That won't work. There's no way those two screen-shots from the same transmission. The first one is from an 0B6, much newer transmission that uses the UDS protocol, which simply does not support the old-school Measuring Blocks. The second is from an 09L, a substantially older transmission that uses one of the earlier protocols that still do support Measuring Blocks.
@Markheggie please see:
mattylondon
United Kingdom
C?ID=219022
My bad, I mistakenly thought those two screenshots were both from Markheggie's S5.
Markheggie
La Jolla
H11-2H
So the moral of the story is my car can't talk to the software to obtain adaptation values? Also with older versions, I still can't get the adaptation values?
Markheggie
La Jolla
H11-2H
Yes, different transmission. Just showing someone else could view those blocks
Markheggie
La Jolla
H11-2H
auto scan
Sunday,22,November,2020,15:44:43:40490
VIN: WAUVVAFRXAA010823   License Plate:
Chassis Type: FR-AU48 (8T0)
Scan: 01 02 03 05 06 08 09 15 16 17 19 36 42 46 47 52 53 55 56 5F
VIN: WAUVVAFRXAA010823   Mileage: 86670km-53854miles
Address 01: Engine (J623-CAUB)       Labels:. 079-907-560-CAU.clb
   Part No SW: 8T0 907 560 T    HW: 8T0 907 560
   Component: 4.2l V8/4V    H12 0005
   Revision: 76H12---
   Coding: 01140009190F0120
   Shop #: WSC 58445 001 1048576
   VCID: 4BC3675C43CCF2F3F71-801E
Address 02: Auto Trans (J217)       Labels:| 0B6-927-156.clb
   Part No SW: 8K0 927 158 H    HW: 0B6 927 156
   Component: 0B6 42 FSIUSA H04 0005
   Revision: --H04---
   Coding: 001012
   Shop #: WSC 06325 000 00000
   ASAM Dataset: EV_TCMAL651 A01006
   ROD: EV_TCMAL651.rod
   VCID: 3B23379C13EC4273471-806E
   Part No SW: 8K0 907 379 CA    HW: 8K0 907 379 AN
   Component: ESP8 quattro  H04 0010
   Coding: 120D18
   VCID: 7AADF2985CD6BB7B1C7-802E
   Part No SW: 8K0 907 064 DG    HW: 8K0 907 064 DG
   Component: BCM2 1.1      H02 0321
   Coding: 0D0000
   VCID: 78A9E89062DAA96B6A3-802C
   Serial number: 0209000052091016
Address 06: Seat Mem. Pass (J521)       Labels:. 8T0-959-760.clb
   Part No SW: 8T0 959 760 C    HW: 8T0 959 760 C
   Component: MEM-BFS       H10 0073
   Revision: AA000000    Serial number: 00001001324593
   Coding: 00017025002C00000000
   VCID: 43D34F7C6B9C3AB30F1-8016
   Component: KLIMA 3 ZONEN H08 0171
   Revision: C1000000    Serial number: 01170720091475
   Coding: 48122000
   Shop #: WSC 06342 000 00000
   VCID: 005980703A0AE1AB523-8054
                    Fault Status: 00101101
                    Reset counter: 152
                    Mileage: 86583 km
                    Date: 2020.11.20
                    Time: 11:31:40
                    Temperature: 29.0°C
                    RPM: 560 /min
   Component: BCM1 1.0      H25 0380
   Revision: 10025001    Serial number: 00000000314856
   Coding: 26001091063CAF010000080300003D3D0F1C538800010161000000
   VCID: 3C2134801662454B4EB-8068
   Subsystem 1 - Part No SW: 8T1 955 119 D    HW: 8J1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 180709  H14 0070
   Serial number: SWF09070185271
   Coding: 00FD11
   Component: RLS  H04 0003
   Serial number: 10548569
   Coding: 02532C
   Subsystem 3 - Part No SW: 8K0 941 531 AN    HW: 8K0 941 531 AN
   Component: E1 - LDS  H08 0090
   Serial number: 00000000002206090998
   Subsystem 4 - Part No SW: 8K0 907 410 B    HW: 8K0 907 410 B
   Component: HOMELINK  H01 0010
   Part No SW: 8K0 959 655 H    HW: 8K0 959 655 H
   Component: AirbagVW-AU10 H37 0520
   Serial number: 003EGD027TRP
   Coding: 303333334330303030304A55304C38543053
   VCID: 42DD4A78740633BB047-8016
   Subsystem 1 - Part No SW: 8K0 959 339     HW: 8K0 959 339
   Component: BF-Gewichtss.  H01 0050
   Serial number: 5810000R0900004HK4
   Serial number: 6334MSME46402D079
   Serial number: 6344MSME4970216EH
   Serial number: 6352QSME5234442EF
   Serial number: 6362QSME5B34113AG
   Serial number: 63732SME24362810P
   Serial number: 63832SME5D33281C4
   Revision: --------    Serial number: 90315IGH00054
   Coding: 000036
   VCID: 3D2739840D784C43795-8068
   Part No SW: 8T0 920 981 N    HW: 8T0 920 981 N
   Component: KOMBIINSTR.   H33 0253
   Revision: 00300000    Serial number: BYM62MH79
   Coding: 8B1701000300D705020000
   VCID: 47CB5B6C5FA41693D39-8012
   Part No SW: 8T0 907 468 T    HW: 8T0 907 468 K
   Component: GW-BEM 4CAN-M H09 0105
   Revision: EB800053    Serial number: 5300E097048010
   Coding: 00C303
   VCID: 52FD7A38A4E6A33BB47-8006
   Component: J367-BDM  H06 0160
   Serial number: 19085796010709
   Component: MEM-FS        H10 0073
   Revision: AA000000    Serial number: 00001001320479
   Coding: 00197B25002C00000000
   Part No SW: 8K0 959 793 H    HW: 8K0 959 793 D
   Component: TSG FA        H11 0306
   Revision:             Serial number: 0000009090466
   Coding: 011C13224E00120102
   VCID: 45D7516465A80483215-8010
   Revision: 00002001    Serial number: 0119910578
   Coding: 0106029A007A440500B0000000000000
   Component: GTO BF  H06 0050
   Serial number: 00000000000000157813
   Subsystem 3 - Part No SW: 8R0 959 591 A    HW: 8R0 959 591
   Component: J245EE19SKB12  H01 0220
02615 - Fuel Tank Cap; Lock
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 112
                    Mileage: 86590 km
                    Date: 2020.11.20
                    Time: 12:03:46
   Part No SW: 8T0 035 223 AK    HW: 8T0 035 223 AK
   Component: DSP Prem      H08 0170
   Revision: 00008001    Serial number: 34881004858303
   VCID: 77ABEBAC6FC4A613639-8022
   Part No SW: 8K0 959 792 H    HW: 8K0 959 792 D
   Revision:             Serial number: 0000009098616
   VCID: 44D14C606E923D8B36B-8010
   Component: EPB Audi B8   H09 0090
   Revision: 00000003    Serial number: 10000000285150
   VCID: 34311CA03E328D0B86B-8060
   Part No: 8K5 907 357
   Coding: 0000002
   Shop #: WSC 06324 000 00000
   VCID: 77ABEBAC63C4A613639-8022
   Part No SW: 4F0 035 082 A    HW: 4F0 035 082
   Component: Radio U SIRIU H45 0021
   Revision: AB001007    Serial number: 335GR097522162
   Coding: 020000010000000001
   VCID: 1D67D904ADB82C43595-8048
   Part No SW: 8T1 035 664 A    HW: 8T1 035 664 A
   Component: H-BN-NA       H41 0042
   Revision: --------    Serial number: 490GW097511923
   Coding: 010200020206A1EC41000B0C000000030000
   Shop #: WSC 54573 002 1048576
   VCID: 363526A8284E9F1BB8F-8062
   Subsystem 1 - Part No: 8R0 060 884 F
   Component: NAR 2009/2010  5304
   Component: DU7 High  H43 0306
   Serial number: 9356J-091086373
   Subsystem 3 - Part No SW: 8T0 919 609 G    HW: 8T0 919 609 G
   Serial number: 00000000325533
   Component: CD-Database  1293
                    Reset counter: 115
                    Mileage: 86678 km
                    Date: 2020.11.22
                    Time: 15:38:13
                    Voltage: 12.10 V
02244 - Button in Control Head is Stuck
                    Fault Status: 00100011
                    Reset counter: 138
                    Mileage: 86099 km
                    Date: 2020.11.15
                    Time: 15:50:19
                    Voltage: 12.80 V
End----(Elapsed Time: 01:36, VBatt start/end: 12.0V/12.0V. VIgn 12.0V)-----
Markheggie
La Jolla
H11-2H
Please elaborate.
Oh, and please post an Auto-Scan so we can see exactly what we're dealing with.
advanced measuring values does not have anything that has block 73-77, nor a description of anything like adaptation values (pics)adv mes vls.pngadv mes vls 2.pngadv mes vls 3.png
Again, UDS modules don't have or use old-school numbers measuring blocks.
I don't see anything obvious in the data for that transmission either. All I can tell you is that it's a totally different transmission than the other one you (and the instructions you're apparently trying to follow) are referring to. This is definitely not a VCDS version issue.
Markheggie
La Jolla
H11-2H
Ok, I get it now. If the adaptation values are anywhere, they'll be buried on the 700+ advanced measuring values. I'll click thru each plausible advanced measuring value and report back if I see any data that looks like adaptation values.
Markheggie
La Jolla
H11-2H
found them. analysis 2-21. about halfway down the advanced measuring values menu
Markheggie
La Jolla
H11-2H
here are my adaptation values for a 2010 audi s5. the reason to look at these is supposedly for the health of the automatic transmission, especially the charge pressure (i think)
Background from ZF transmission repair expert
Part 1
Part 2
the most important part
Audiworld post with a users transmission monitored for pressure changes over a year with a transmission flush and resetting adaptation values. Higher pressures mean your transmission needs service (new fluid, seal replacement, valve body (mechatronic unit) rebuild) or else the clutches will wear out and the whole transmission needs rebuilding or replacement (worn clutches)
Best
Mark
