i, in the shop is a 2012MY Caddy that's lost the ABS coding after the customer fitted a used ecu kit i have now put it all back to oe just need coding for abs In VCDS there is no long coding helper for the module. Below is the autoscan, hope somebody can kindly help with the coding, thanks
VCDS Version: 20.4.2.0 (x64)
VIN: WV1ZZZ2KZCX049525 License Plate:
Chassis Type: 2K-VN35 (7N0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52
VIN: WV1ZZZ2KZCX049525 Mileage: 125740km-78131miles
56-Radio -- Status: Malfunction 1110
Address 01: Engine (J623-CAYD) Labels:. 03L-906-023-CAY.clb
Part No SW: 03L 906 023 PC HW: 03L 907 425 C
Component: 1,6l R4 CR td H43 0869
Revision: --H43--- Serial number: 00000000000000
Coding: 00114014030500080000
Shop #: WSC 35110 790 50316
ASAM Dataset: EV_ECM16TDI02103L906023PC 003002
ROD: EV_ECM16TDI02103L906023B_003.rod
VCID: 76E30A2EC9DED63639-8022
9772 - Internal Control Module
P0606 00 [032] - Processor Fault
Mileage: 125679 km
Date: 2020.09.18
Time: 06:13:37
Engine speed: 2809.00 /min
Normed load value: 79.2 %
Vehicle speed: 71 km/h
Coolant temperature: 92 °C
Intake air temperature: 24 °C
Voltage terminal 30: 14.456 V
Accelerator monitoring level-PV_AV_MON: 73.437500 %
Injection release status-LF_INJ_AD_ACT: 0
ASR-torque request-LV_TCS_INC_40: 00000000
Cruise control torque request-LV_TQ_CRU_ACT_40: 00000000
Transmission control module torque request-LV_ETCU_INC_40: 00000000
RPM monitoring level-N_32_MON: 2816 /min
Engine torque-TQI_SP: 217.13 Nm
Part No SW: 1K0 907 379 BH HW: 1K0 907 379 BH
Component: ESP MK60EC1 H31 0121
Revision: 00H31001
Shop #: WSC 35110 377 08192
VCID: 79F90112F0C0B94E54-802C
Reset counter: 67
Count: 20992
Count: 195
Count: 41728
Fault Status: 01100101
Reset counter: 67
Mileage: 125747 km
Date: 2015.02.12
Time: 00:00:05
Count: 2
Count: 2
Count: 20992
Count: 279
Count: 41216
Count: 65280
Reset counter: 67
Mileage: 125747 km
Date: 2015.02.12
Time: 00:00:05
Count: 2
Count: 2
Count: 20992
Count: 295
Count: 41216
Count: 65280
Reset counter: 67
Mileage: 125747 km
Date: 2015.02.12
Time: 00:00:05
Count: 2
Count: 2
Count: 20992
Count: 270
Count: 41216
Count: 65280
Part No SW: 7N0 907 426 AT HW: 7N0 907 426 AT
Component: AC Manuell H19 0304
Revision: 00001016
Coding: 0000004002
VCID: 06037AEEB93EC6B629-8052
13701936 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
Fault Frequency: 11
Reset counter: 67
Mileage: 146934 km
Date: 2012.01.19
Time: 21:18:50
B10AB F0 [009] - Too Low
Reset counter: 67
Mileage: 146934 km
Date: 2012.01.19
Time: 21:18:50
Address 09: Cent. Elect. Labels: None
VCID: 55A16DA2BC18BD2E10-FFFE
No Faults Found
Part No SW: 7E0 959 655 B HW: 7E0 959 655 B
Component: VW10Airbag00U H06 0013
Revision: -------- Serial number: 003HL007D5UA
Coding: 000000000000000000000000000000003055
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 3561CD2294589D2EF0-8060
Part No SW: 1K5 953 507 M HW: 5K0 953 549
Revision: -------- Serial number: 90440KI6000V1
Coding: 0080060000
ROD: EV_SMLSNGKUDS_A05.rod
VCID: 3B75DB1AB27C4B5E06-806E
Part No SW: 2K0 920 965 E HW: 2K0 920 965 E
Component: KOMBI H03 0606
Coding: 480001
VCID: 3169F9326030B10EAC-8064
Part No SW: 7N0 907 530 H HW: 1K0 907 951
Component: J533 Gateway H42 1620
Revision: H42 Serial number: 030911F1000780
Coding: 357401
VCID: 3561CD229C589D2EF0-8060
01304 - Radio
Fault Status: 01110100
Reset counter: 67
Mileage: 146934 km
Date: 2012.01.19
Time: 21:18:56
Fault Frequency: 9
Mileage: 146934 km
Date: 2012.01.19
Time: 21:20:43
Component: IMMO H03 0606
VCID: 6ADB2E5E8D6602D6AD-803E
9456128 - Engine Control Module (ECM) not authorized
B104A 00 [008] - -
9456681 - Key
B104C 29 [008] - Implausible Signal
Mileage: 125747 km
Date: 2020.09.21
Time: 00:01:57
Part No SW: 1T0 959 701 T HW: 1T0 959 701 T
Component: Tuer-SG 009 2110
Coding: 0000560
VCID: 489FB4D63BAA10C69B-801C
Part No: 1K0 909 144 M
Component: EPS_ZFLS Kl. 140 3201
Revision: 00H20000
VCID: 3467F02657228426C7-8060
Fault Status: 11100101
Battery Volts: 11.7 V
PD
Temperature: 25.0°C
Count: 3
Steering Angle: -10.85°
SteerAng n.Init
Address 46: Central Conv.
Part No SW: 1T0 959 702 R HW: 1T0 959 702 R
Coding: 0000560
VCID: 479DB7EA36B41FBE92-8012
End-------------------------(Elapsed Time: 01:53)--------------------------
