hi we are trying to get in to basic settings to regen dpf on a skoda octavia 1.6 diesel and it will not accept the security code and says cannot send seed ,i have also tried the same car with another garages computer and lead to the same effect
Friday,20,November,2020,13:50:59:15602
VCDS Version: 20.4.2.0 (x64)
VIN: TMBKG7NEXG0078975 License Plate: WF65FWU
Mileage: 118973km-73926mi Repair Order:
Chassis Type: NE-SK37 (5Q0)
Scan: 01 03 08 09 10 15 16 17 19 42 44 52 5F
VIN: TMBKG7NEXG0078975 Mileage: 118973km-73926miles
Address 01: Engine (2D2D2-CXXB) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 056 CL HW: 04L 907 445 B
Component: R4 1.6l TDI H06 2370
Revision: 22004001
Coding: 01114032432519090000
Shop #: WSC 73430 031 00000
ASAM Dataset: EV_ECM16TDI03004L906056CL 002005
ROD: EV_ECM16TDI03004L906056_002_VW37.rod
VCID: 79FE64E6F8E5A04E54-802C
8 Faults Found:
13174 - Mass Air Flow Sensor (G70)
P0103 00 [032] - Signal too High
Mileage: 118973 km
Date: 2020.11.18
Time: 12:03:23
Engine speed: 0.00 /min
Coolant temperature: 11 °C
Intake air temperature: 10 °C
Voltage terminal 30: 11.250 V
Mass airflow sensor 1 bank 1 airflow: raw value: 0.0 mg/stroke
Standardised airflow ratio: 1.000 counts
Exhaust recirc.valve 1 bank 1: posit.feedback - Act.value: 0.00 %
Throttl.valve adapt. 1 bank 1: posit feedback - Act.value: 0.00 %
Charge air pressure specified value: 0.000 bar
Absolute intake pressure: 102 kPa abs
Mean injection quantity: 0 mg/stroke
25810 - No Communication with Instrument Cluster
U0155 00 [032] - -
28239 - Fuel Pump
P3045 00 [032] - Electronics Defective
28242 - Fuel Pump
P3043 00 [032] - Mechanical Malfunction
27237 - Power Supply Terminal 15
P3325 00 [032] - Implausible
30357 - Intake Air Temp. Sensor (G42)
P0113 00 [032] - Signal too High
Date: 2000.01.00
Intake air temperature: 11 °C
Voltage terminal 30: 11.257 V
25126 - Databus
27108 - Oxygen (Lambda) Sensor B1 S2
P0136 00 [096] - Malfunction in Circuit
Readiness: N/A
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-ESP-V1.clb
Part No SW: 3Q0 907 379 T HW: 3Q0 907 379 C
Component: ESC H32 0393
Revision: 00000000 Serial number: 52185000000293
Coding: 1C078A91142709740080060741C8243851289000608224F20043F072C002
Shop #: WSC 73430 031 00063
VCID: 4B92EE2EE2F9E2DEB6-801E
16401 - Tire Pressure Warning
C102D 00 [008] - -
Reset counter: 20
Mileage: 88277 km
Date: 2019.08.19
Time: 04:49:13
Part No SW: 5E0 907 044 Q HW: 5E0 907 044 Q
Component: Climatronic H04 1002
Revision: 00001K07
Coding: 02110104000100011005000000101000
ROD: EV_ACClimaBHBVW37X_004_VW37.rod
VCID: 336296CE9A099A1EDE-8066
Air quality sensor:
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 086 AH HW: 5Q0 937 086 AH
Revision: -------- Serial number: 86581908150614
Coding: 0F000842424700DB07A04082B10407280000000000000000000000000000
Shop #: WSC 73430 790 00000
ROD: EV_BCMBOSCH_015.rod
VCID: 000809029B3FF18613-8054
Subsystem 1 - Part No SW: 5E2 955 119 HW: 5E2 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS371 150622 041 0570
Serial number: 150724074036
Coding: 065DDD
Subsystem 2 - Part No SW: 5Q0 951 171 HW: 5Q0 951 171
Serial number: 000000000ZY151670T04
Subsystem 3 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Serial number: 00000000000063324240
Subsystem 4 - Part No SW: 8U0 955 559 HW: 8U0 955 559
Component: G355_FeuchteS H07 0002
Serial number: 21179303
8 Faults Found:
6666 - Bulb for Low Beam Headlamp Left
B1217 15 [008] - Open or Short to Plus
14858 - Bulb for Right Brake Lamp / Tail Lamp
B133C 15 [008] - Open or Short to Plus
6922 - Bulb for Low Beam Headlamp Right
B1218 15 [008] - Open or Short to Plus
12298 - License Plate Light
B12CA 15 [008] - Open or Short to Plus
12307 - License Plate Light
B12CA 01 [009] - Electrical Failure
Fault Frequency: 24
Reset counter: 10
Mileage: 115483 km
Date: 2020.09.10
Time: 22:35:37
204290 - Remote key 1
B1479 18 [008] - Current Too Low
204546 - Remote key 2
B147A 18 [008] - Current Too Low
206085 - Remote Control
B1311 54 [008] - Missing Calibration / Basic Setting
Part No SW: 5Q0 919 298 K HW: 5Q0 919 298
Component: PARKHILFE PLA H12 0054
Revision: -------- Serial number: 39431523004405
Coding: 0131061041
Shop #: WSC 73430 790 00063
ASAM Dataset: EV_EPHVA2CAU3700000 003021
ROD: EV_EPHVA2CAU3700000_003.rod
VCID: 479AD21EFE9106BE92-8012
Part No SW: 3Q0 959 655 AS HW: 3Q0 959 655 AS
Component: Airbag VW20 013 0200
Revision: -------- Serial number: 003SQPH5X5BO
Coding: 98CCC000000000005C5400CC008800000065
ROD: EV_AirbaVW20TS6VW48X.rod
VCID: 0F2A3A3ED6619EFE9A-805A
Subsystem 1 - Part No SW: ----------- HW: 454 001 708 15
Serial number: 3576U0000002C2E4851D
Subsystem 2 - Part No SW: ----------- HW: 454 001 508 15
Serial number: 3586U000000BA31DC51M
Subsystem 3 - Part No SW: ----------- HW: 454 800 608 15
Serial number: 3516R186F0E080000008
Subsystem 4 - Part No SW: ----------- HW: 454 801 408 15
Serial number: 3526RAAE9E207000000N
Subsystem 5 - Part No SW: ----------- HW: 454 802 106 15
Serial number: 3556V9F8D4A07000000U
Part No SW: 5Q0 953 521 M HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0195
Revision: FF033033 Serial number: 20150903500456
Coding: 1400
ROD: EV_SMLSVALEOMQB.rod
VCID: 3C70BDF2B75755660F-8068
Part No SW: 5E0 920 951 B HW: 5E0 920 951 B
Component: KOMBI 323 6422
Coding: 27A40A002190A60001086A001000000000000000
VCID: 26447F9A59DBFFB649-8072
9456681 - Key
B104C 29 [008] - Implausible Signal
Mileage: 116106 km
Date: 2020.09.14
Time: 00:02:55
Part No SW: 5Q0 907 530 AE HW: 5Q0 907 530 E
Component: GW MQB Mid 127 1224
Revision: -------- Serial number: 0003869179
Coding: 030100040F087300EB000248080F00010001050000000000000000000000
ROD: EV_GatewLear_013.rod
VCID: 74E055D2DF87DD2607-8020
Subsystem 2 - Part No SW: 3V0 919 719 A HW: 3V0 919 719 A
Component: E221__MFL-PR6 H02 0150
Serial number: 000000000C2001190815
Subsystem 3 - Part No SW: 5Q0 915 181 H HW: 5Q0 915 181 H
Component: J367-BDMConti H02 1011
Serial number: 74185704001508141610
Part No SW: 5Q4 959 393 E HW: 5Q4 959 393 B
Component: TSG FS 010 0031
Serial number: 0000163616536
Coding: 001000208001040000001100
VCID: 4586D816C49D14AE60-8010
Subsystem 1 - Part No SW: 5Q0 959 812 A HW: 5Q0 959 812 A Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000007100345
Coding: 1D0200
Part No SW: 5Q0 909 144 R HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 125 1061
Coding: 8303
VCID: 4382C60ECAA92A9E4E-8016
22016 - Databus
Fault Frequency: 9
Reset counter: 254
Mileage: 154701 km
Date: 2019.03.19
Time: 15:49:00
Motor status: 00
Supply voltage: 11.75 V
Temperature: 23.0 °C
KFC: 56
KFA: 00 00
Environmental conditions: 20
uioUdNotFilt_xdu16: 11.98 V
uAdSensI_SwitchedKl30_xdu16: 11.94 V
ASC_CTRL_GET_ILWS_ERR_FLAGS: 00
Part No SW: 5Q4 959 392 E HW: 5Q4 959 392 B
Component: TSG BFS 010 0031
Serial number: 0000163896923
VCID: 4480C512CFA72DA677-8010
Subsystem 1 - Part No SW: 5Q0 959 811 A HW: 5Q0 959 811 A Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000006837397
Coding: 050200
Address 5F: Information Electr. (J794) Labels:| 3V0-035-MIB-STD2.clb
Part No SW: 5Q0 035 874 A HW: 5Q0 035 874 A
Component: MU-S-ND-ER H24 0241
Serial number: SKZAZ2R8804842
Coding: 03730201FF00000011111201008800002F0200C601200100C6
ROD: EV_MUStd4CTSAT_VW37.rod
VCID: 326C93CA65139316D5-8066
Subsystem 1 - Part No SW: 5E0 919 605 J HW: 5E0 919 605 J
Component: ABT_Std-2_Nav H41 1028
Serial number: SKZ8Z9RBT00L2N
Subsystem 2 - Part No SW: 5L0 051 236 E HW: -----------
Component: ECE 2015/16 --- 0430
End-------------------------(Elapsed Time: 03:45)--------------------------
