- May 2, 2016
- 179
- 42
- Netherlands
- C?ID=143747
Hello People,
I have retrofit an VC to this Cupra before facelift. I have done all coding, but I can't get the CUPRA flag in the instrument.
I have read that need to change the coding in Byte 2 bit 3-6 to Variant 5. Have tried this but no result.
Here is log of the car:
Friday,20,November,2020,10:35:48:43540
VIN: VSSZZZ5FZGR221530 License Plate: CUPRA
Mileage: 73696km-45792mi Repair Order:
Chassis Type: 5F-SE37 (5Q0)
Scan: 01 02 03 08 09 10 14 15 16 17 19 32 42 44 52 55 5F A9
VIN: VSSZZZ5FZGRXXXXXX Mileage: 73696km-45792miles
Address 01: Engine (J623-CJXH) Labels:. 06K-907-425-V1.clb
Part No SW: 5G0 906 259 F HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0002
Revision: --H13---
Coding: 0B1D00122424010B0000
Shop #: WSC 00049 770 00126
ASAM Dataset: EV_ECM20TFS0205G0906259F 001004
ROD: EV_ECM20TFS0205G0906259F.rod
VCID: 313EE36181A3FBC3EDD-8064
Readiness: 1110 0001
Part No SW: 0D9 300 020 P HW: 02E 927 770 AS
Component: DQ250-6V MQB H54 5003
Revision: 06454104 Serial number: TFK01609031305
Shop #: WSC 04742 780 00200
ROD: EV_TCMDQ250021.rod
VCID: 221C1C2DD445505B647-8076
Address 03: ABS Brakes (J104) Labels:* 5Q0-907-379-ESP-V1.clb
Part No SW: 5Q0 614 517 AF HW: 5Q0 614 517 AF
Component: ESC H62 0398
Revision: 00000000 Serial number: 62616000003697
Coding: 20EE6B925422196D807C060341C36804D62A980160821676004100F1C00602
Shop #: WSC 00049 770 00222
ASAM Dataset: EV_Brake1UDSContiMK100ESP 035019
ROD: EV_Brake1UDSContiMK100ESP_035.rod
VCID: 75B61771354B97E3715-8020
Part No SW: 5F0 907 044 AG HW: 5F0 907 044 AG
Component: Climatronic H05 1601
Revision: 00001K09
Coding: 00000014200110011005000000101020
ASAM Dataset: EV_ACClimaBHBVW37X 006142
VCID: 6B823109630F5113971-803E
Air quality sensor:
Part No SW: 5Q0 937 084 CL HW: 5Q0 937 084 AN
Component: BCM MQBAB H H24 0175
Serial number: 01061625103977
Coding: 08101A46C24102F34BE44000401C07281000000000000000000000000000
Shop #: WSC 00049 770 00197
ROD: EV_BCMBOSCH_015.rod
VCID: 04507AB56E91BE6B76B-8050
Subsystem 1 - Part No SW: 5F1 955 119 A HW: 5F1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS370 160831 041 0574
Serial number: 160910145635
Coding: 0BC5FD
Component: RLHS 042 0105
Serial number: S4Y16M09D07H04M55S25
Coding: 00095D
Sun Roof:
Subsystem 3 - Part No SW: 6R0 959 591 D HW: 6R0 959 591 D
Component: J245 PS72.403 H03 0004
Serial number: 0000FST0015EFYX00000
Coding: 180102
Part No SW: 5Q0 919 294 K HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0054
Revision: -------- Serial number: 39361626110193
Coding: 0031051011
VCID: 43D2B9A92B1F79530F1-8016
Address 14: Susp. Elect. (J250) Labels: 5Q0-907-376.clb
Part No SW: 5Q0 907 376 B HW: 5Q0 907 376 A
Serial number: 17081641350080
ROD: EV_DRCONTITEMIC_VW37.rod
VCID: 3828DE4562D92A8BAA3-806C
Part No SW: 3Q0 959 655 AS HW: 3Q0 959 655 AS
Component: Airbag VW20 013 0200
Revision: -------- Serial number: 003SQPJRNWR
Coding: 98CCC000000000005C0000CC000800000065
ROD: EV_AirbaVW20TS6VW48X.rod
VCID: 0F7A459937D7CD33DB9-805A
Subsystem 1 - Part No SW: ----------- HW: 454 000 109 16
Serial number: 3576U000000DB528AD1S
Subsystem 2 - Part No SW: ----------- HW: 454 000 109 16
Serial number: 3586U000000EB559AD1Y
Subsystem 3 - Part No SW: ----------- HW: 454 802 408 16
Serial number: 3516R4762060C000000-
Subsystem 4 - Part No SW: ----------- HW: 454 802 508 16
Serial number: 3526R9DF2B60C000000P
Subsystem 5 - Part No SW: ----------- HW: 454 800 609 16
Serial number: 3556V8D72C50C000000N
Part No SW: 5Q0 953 507 GP HW: 5Q0 953 549 E
Revision: -------- Serial number: 19091604220382
Coding: 1410
VCID: 0A4C548D4CB5E81B0C7-805E
Part No SW: 5F0 920 790 A HW: 5F0 920 790 A
Component: KOMBI 610 1703
Coding: 04AD290839800008000860001000000000000000
ASAM Dataset: EV_DashBoardVDDMQBA0 001031
ROD: EV_DashBoardVDDMQBA0_SE37.rod
VCID: 270A0D39BF67B573339-8072
Part No SW: 5Q0 907 530 AM HW: 5Q0 907 530 F
Component: GW MQB High 128 1265
Revision: -------- Serial number: 0005373255
Coding: 030100F42F085900EB0002E99C0F00010001050000000000000000000000
ROD: EV_GatewLear_013.rod
VCID: 7CA002551661C6AB0EB-8028
Subsystem 2 - Part No SW: 5F0 959 537 A HW: 5F0 959 537 A
Component: E221__MFL-PR6 H04 0130
Serial number: 000000000B0595010816
Coding: 012000
Subsystem 3 - Part No SW: 5Q0 915 181 J HW: 5Q0 915 181 J
Serial number: 75410803001609082398
Address 32: Differential Locks (J492) Labels:* 0CQ-907-554.clb
Part No SW: 0CQ 907 554 E HW: 0CQ 907 554 E
Component: Quersperre H52 8042
Serial number: HA1-00028.07.16
Coding: 0101
ASAM Dataset: EV_LockElectHA1VW37X 001007
ROD: EV_LockElectHA1VW37X.rod
VCID: 47CAADB91F275573D39-8012
Part No SW: 5Q4 959 593 E HW: 5Q4 959 593 B
Component: TSG FS 010 0031
Serial number: 0000217591924
Coding: 00100320DC00040000001000
Subsystem 1 - Part No SW: 5Q0 959 811 A HW: 5Q0 959 811 A Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000011433237
Coding: 310000
Part No SW: 3Q0 909 144 K HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 506 5072
Coding: 8103
ROD: EV_SteerAssisMQB_013.rod
VCID: 3A2CC44D5CD5389B5C7-806E
Part No SW: 5Q4 959 592 E HW: 5Q4 959 592 B
Component: TSG BFS 010 0031
Serial number: 0000217628760
Coding: 00100320DE00040000001000
VCID: 46D4A0BD182D4C7B28F-8012
Subsystem 1 - Part No SW: 5Q0 959 812 A HW: 5Q0 959 812 A Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000011325300
Coding: 290000
Address 55: Headlight Range (J431) Labels:| 5Q0-907-357.clb
Part No SW: 5Q0 907 357 HW: 6R0 907 357 A
Component: LWR-ECU 005 0080
Coding: 0492030009000000
Address 5F: Information Electr. (J794) Labels:| 5F0-035-MIB-STD2.clb
Part No SW: 5QA 035 846 A HW: 5QA 035 846 A
Component: MU-S-N-ER H30 0359
Serial number: SEZAZ2S0150254
Coding: 04730001FF0A00001111000100080A002F03028401200100C6
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_MUStd6C3TSAT 001015
ROD: EV_MUStd6C3TSAT_SK25.rod
VCID: 42DCBCAD3405705B047-8016
Subsystem 1 - Part No SW: 5F0 919 604 F HW: 5F0 919 604 F
Component: ABTm_Std2_Nav H44 1031
Serial number: SEZ8Z9SLP0049R
Subsystem 2 - Part No SW: 6P0 919 866 H HW: -----------
Component: ECE1 2016/17 --- 0635
Part No SW: 5F0 907 159 C HW: 4H0 907 159 A
Component: SAS-GEN 2 H07 0001
Serial number: 160825201198
VCID: 2D06FF119D9B9F23C95-8078
End----------(Elapsed Time: 01:32, VBatt start/end: 12.1V/12.1V)-----------
