adlmarcelo
Troquei os faróis da entrada a5 Item 8W6941005 Light Design Bi-Xenon Bulb Typ D5S com os led 8W6941035 Light Design LED Bulb LED e não funciona nem o drl, o pisca-pisca nem o farol, alguém poderia me ajudar?
I changed the headlights of the a5 entry Item 8W6941005 Bi-Xenon Typ D5S light design lamp with the LEDs 8W6941035 LED light design LED lamp and the drl, flasher and headlamp will not work, could someone help me?The language of this forum is English, you need to post in English not Portuguese to get help - and if your problem involves fault codes also post a full unedited VCDS Auto-Scan also in English.
We'll definitely need to see a full unedited Auto-Scan made using the English version of VCDS to be able to help with that.I changed the headlights of the a5 entry Item 8W6941005 Bi-Xenon Typ D5S light design lamp with the LEDs 8W6941035 LED light design LED lamp and the drl, flasher and headlamp will not work, could someone help me?
Quinta-feira, 19 de novembro de 2020, 15: 20: 52: 56.451
VCDS - Emulador VAG / VAS baseado em Windows em execução no Windows 10 x64
Versão VCDS: 20.4.2.0 (x64) HEX-V2 CB: 0.4513.4
Versão de dados: 20200730 DS317.0
VIN: WAUAFEF53JA082639 Matrícula:
Quilometragem: 30333km-18848mi Ordem de conserto:
Tipo de chassi: F5-AU49 (4M1)
Digitalizar: 01 02 03 08 09 15 16 17 19 29 39 42 44 46 52 5F 6C 6D 81 A9
BB BC
VIN: WAUAFEF53JA082639 Quilometragem: 30333km-18848 milhas
01-Motor - Status: Mau funcionamento 0010
02-Auto Trans - Status: Mau funcionamento 0010
03-Freios ABS - Status: Mau funcionamento 0010
08-Auto HVAC - Status: OK 0000
09-Cent. Eleger. - Status: Mau funcionamento 0010
15-airbags - status: mau funcionamento 0010
16-Volante - Status: Mau funcionamento 0010
17-Instrumentos - Status: OK 0000
19-CAN Gateway - Status: Mau funcionamento 0010
29-Luz esquerda - Status: OK 0000
39-Luz direita - Status: Mau funcionamento 0010
Eleito 42 portas, motorista - Status: OK 0000
44-Steering Assist - Status: Mau funcionamento 0010
46-Conv. Central - Status: Mau funcionamento 0010
Eleito de 52 portas, passe. - Status: Mau funcionamento 0010
5F-Informação Electr. - Status: Mau funcionamento 0010
6C-Back-up Cam. - Status: OK 0000
6D-Trunk Elect. - Status: OK 0000
81-Mudança de Marcha - Status: OK 0000
A9-Struct. Borne Sound - Status: OK 0000
BB-Porta Traseira Drv - Status: OK 0000
BC-Door Rear Pass - Status: Mau funcionamento 0010
Endereço 01: Motor (J623-CYRB) Etiquetas :. 06L-907-115-V1.clb
Peça Nº SW: 8W0 906 259 E HW: 06L 907 425 C
Componente: 2.0l R4 TFSI H15 0003
Revisão: --H15 ---
Codificação: 1A2500322326050B34080000000000000000000000000000
Loja nº: WSC 06314 790 00001
Conjunto de dados ASAM: EV_ECM20TFS0208W0906259E 001004
ROD: EV_ECM20TFS0208W0906259E.rod
VCID: 43D34C3D2B1810230F1-8016
7 falhas encontradas:
14828 - Válvula solenóide de suporte do motor esquerdo (N144)
P1572 00 [047] - Curto para o solo
Confirmado - testado desde a memória limpa
Quadro de congelamento:
Status de falha: 00000001
Prioridade de falha: 2
Frequência de falha: 1
Quilometragem: 30.302 km
Data: 2020.11.18
Horário: 15:28:56
Velocidade do motor: 775,00 / min
Valor de carga normalizado: 9,0%
Velocidade do veículo: 0 km / h
Temperatura do refrigerante: 96 ° C
Temperatura do ar de admissão: 59 ° C
Pressão do ar ambiente: 990 mbar
Terminal de tensão 30: 13,144 V
Contador de desaprendizagem de acordo com OBD: 40
FAC_TPS_1_SAE: 11,328125%
FUP_H_SAE: 8280,0 kPa
MAP_MES_SAE: 27 kPa
Motor: status operacional: IS
TAA: 48.500 ° C
T_AST_SAE: 1 s
Tensão da sonda lambda: banco 1: sonda 1 (sonda de banda larga): 1,948 V
14825 - Válvula solenóide de montagem do motor direita (N145)
P1576 00 [047] - Curto para o solo
Data: 2020.11.18
Horário: 15:28:56
MAP_MES_SAE: 27 kPa
TAA: 48.500 ° C
T_AST_SAE: 1 s
17792 - Circuito de controle da bomba de refrigerante
P2602 00 [047] - Curto para o solo
Freqüência de falha: 35
Data: 2020.11.18
Horário: 15:28:56
Velocidade do motor: 788,75 / min
Valor de carga normalizado: 9,8%
Terminal de tensão 30: 13,183 V
ECU_STATE: SYN_ENG_IGK_ON
RVC_AV: 40,45 °
RVC_SP: 40,00 °
T_AST_SAE: 0 s
T_ES_DC: 31 min
Temperatura do óleo do motor: 92,0 ° C
21471 - Databus
U1122 00 [047] - Mensagem Implausível
Frequência de falha: 28
Data: 2020.11.18
Horário: 15:28:55
Velocidade do motor: 778,25 / min
Valor de carga normalizado: 10,2%
Terminal de tensão 30: 13,066 V
Variantes ACC: ACC
Acionamento do interruptor de controle de cruzeiro - Interruptor principal: não ativado
Configuração de atuação do interruptor de controle de cruzeiro: não ativado
Ativação do interruptor de controle de cruzeiro - Ativação: não ativado
Status de acionamento do interruptor de controle de cruzeiro: OK
Aceleração do interruptor de controle de cruzeiro: não ativado
Acionamento-desacelerar do interruptor de controle de cruzeiro: não ativado
Acionamento do interruptor de controle de cruzeiro - Cancelar: não ativado
Acionamento do interruptor de controle de cruzeiro - Hardware do interruptor principal: operado
Acionamento da chave de controle de cruzeiro - Codificação: ERROR
Função limite de ativação do interruptor de controle de cruzeiro: não selecionado
Botão de limite de ativação do interruptor de controle de cruzeiro: não ativado
Acionamento do interruptor de controle de cruzeiro - interruptor principal CAN: operado
Acionamento do interruptor de controle de cruzeiro - Incremento grande: não ativado
Acionamento do interruptor de controle de cruzeiro - componente de controle verificado: Sim
Chave CCS: Limitador somente unidade operacional
Variantes ACC (codificação): CCS
17169 - Verifique a codificação de ECUs no barramento de dados do trem de força
P1647 00 [175] - -
MIL ON - Confirmado - Testado desde a limpeza da memória
Data: 2020.11.18
Horário: 15:28:55
Velocidade do motor: 781,50 / min
Coolant temperature: 96 °C
Intake air temperature: 59 °C
Voltage terminal 30: 13.027 V
ACC variants: ACC
Engine: operating status: IS
Cruise control switch actuation-Main switch: not activated
Cruise control switch actuation-Setting: not activated
Cruise control switch actuation-Activation: not activated
Cruise control switch actuation-Accelerate: not activated
Cruise control switch actuation-Decelerate: not activated
Cruise control switch actuation-Cancel: not activated
Cruise control switch actuation-Main switch hardware: operated
Cruise control switch actuation-Coding: ERROR
Cruise control switch actuation-Limit button: not activated
Cruise control switch actuation-Main switch CAN: operated
Cruise control switch actuation-Large increment: not activated
CCS Switch: Limiter only operating unit
ACC variants (coding): CCS
23039 - Dados implausíveis recebidos do módulo de controle ABS
U0415 00 [047] - -
Frequência de falha: 5
Data: 2020.11.18
Horário: 21:50:02
Velocidade do motor: 1267,75 / min
Valor de carga normalizado: 17,6%
Velocidade do veículo: 34 km / h
Temperatura do refrigerante: 73 ° C
Temperatura do ar de admissão: 56 ° C
Pressão do ar ambiente: 1000 mbar
Terminal de tensão 30: 14,335 V
LF_MVB_PDU_INTC_DIAG_1: 0
LF_MVB_PDU_INTC_DIAG_2: 49152
LF_MVB_PDU_INTC_DIAG_3: 3
LF_MVB_PDU_INTC_DIAG_4: 12288
LF_MVB_PDU_INTC_DIAG_5: 0
LF_MVB_PDU_INTC_DIAG_6: 61472
LF_MVB_BUS_INTC_DIAG: 256
26386 - Dados implausíveis recebidos do módulo de controle ABS
U0415 00 [175] - -
Data: 2020.11.18
Horário: 21:50:02
Intake air temperature: 56 °C
Voltage terminal 30: 14.335 V
Readiness: 0010 0001
Address 02: Auto Trans (J217) Labels:| 0CJ-927-156.clb
Part No SW: 8W2 927 155 AT HW: 0CJ 927 156
Component: 0CL 20TFSIRdW H05 0001
Revision: --H05--- Serial number: 0000002464
ASAM Dataset: EV_TCMDL382021 002027
ROD: EV_TCMDL382021_AU49.rod
VCID: 1373BC7D1BF840A3FF1-8046
Subsystem 1 - Part No SW: 0CK 927 152 AA HW: 0CK 321 281 L
Component: V553 MTFP 003 0576
Serial number: 75145041180023001045
20973 - Internal Control Module A/D Processing Performance
P060B 00 [047] - -
Fault Frequency: 73
Mileage: 30302 km
Date: 2020.11.18
Time: 15:28:55
Engine speed: 776 /min
Driving position: P
Transmission fluid temperature: 55 °C
Voltage terminal 30: 13.2 V
Engine torque: 0 Nm
selected gear: 1
Ctrl. mod.: operating condition: regular operation
Auxiliary pump for transmission: requesting function: Fill hydraulic press. accum.
Auxiliary hydraulic pump for transmission oil: current: 6 A
Oil pressure reservoir: pressure: 28.2 bar
Pressure of clutch 1: actual value: 0.0 bar
Pressure of clutch 2: actual value: 0.0 bar
Clutch status: Neutral
Occurrence_counter_over_length_of_life: 255
Safety_interface_voltage_state-Voltage_supply_1: valid
Safety_interface_voltage_state-Voltage_supply_2: valid
Safety_interface_voltage_state-Voltage_supply_3: valid
Safety_interface_voltage_state-Voltage_supply_speed_sensor: valid
Safety_interface_drive_position_sensor_signal_state-Sensor_1: valid
Safety_interface_drive_position_sensor_signal_state-Sensor_2: valid
Safety_interface_gear_selector_signal_state-Gear_selector_1: valid
Safety_interface_gear_selector_signal_state-Gear_selector_2: valid
Safety_interface_gear_selector_signal_state-Gear_selector_3: valid
Safety_interface_gear_selector_signal_state-Gear_selector_4: valid
Safety_interface_can_signal_state-brakes: gehalten
Safety_interface_can_signal_state-brakes: invalid
Safety_interface_can_signal_state-NAn: invalid
Safety_interface_can_signal_state-NAn: gehalten
Safety_interface_can_signal_state-VFzg: invalid
Safety_interface_can_signal_state-VFzg: gehalten
Safety_interface_can_signal_state-VRad (front left): invalid
Safety_interface_can_signal_state-VRad (front left): gehalten
Safety_interface_can_signal_state-VRad (front right): Current
Safety_interface_can_signal_state-VRad (front right): invalid
Safety_interface_can_signal_state-VRad (rear left): Current
Safety_interface_can_signal_state-VRad (rear left): invalid
Safety_interface_can_signal_state-VRad (traseiro direito): inválido
Safety_interface_can_signal_state-VRad (traseiro direito): Atual
Endereço 03: Freios ABS (J104) Etiquetas: 8W0-907-379-PLU-V1.clb
Part No SW: 8W0 907 379 K HW: 8W0 907 379 J
Componente: ESP9 Plus H10 0766
Codificação: 14AA409A28AA0A9811A4489400865292E4A5C0280214508812004A4927A503
Loja nº: WSC 06334 790 00001
Conjunto de dados ASAM: EV_ESP9BOSCHCMP 002013
ROD: EV_ESP9BOSCHCMP_002.rod
VCID: 4DC76A05FD5CD653E95-8018
2 falhas encontradas:
417536 - Circunferência da roda implausível; Frente Direita
C11DB 00 [175] - -
Prioridade de falha: 4
Data: 2020.11.18
Horário: 15:28:55
84 00 83 00 CA 00 00 00 00 00
Contador de desaprendizado de acordo com o contador de desaprendizado OBD-OBD: 28
4523782 - Sensor de velocidade da roda; Frente Direita
C0507 00 [229] - Sinal Implausível
MIL ON - Não confirmado - Testado desde a memória limpa
Data: 2020.11.18
Horário: 21:50:02
90 00 80 11 88 24 00 00 80 50
Endereço 08: Auto HVAC (E87) Etiquetas: * Nenhum
Part No SW: 8W0 820 043 P HW: 8W0 820 043 P
Componente: Klima Zona 1 H40 0241
Coding: 140801885140000510000100080000000000000000000000000000000000
Shop #: WSC 06335 790 00001
ROD: EV_AirCondiBHTCAU491.rod
VCID: 40D943313A0E0B3B123-8014
Subsystem 1 - Part No SW: 4M1 820 021 B HW: 4M1 820 021 B
Component: J126 FLuftV H09 0003
Serial number: 00000000000002130749
Subsystem 2 - Part No SW: 4G0 907 658 B HW: 4G0 907 658 B
Component: Humidity_Sens H02 0007
Serial number: 65A11E0900PAG0FSA002
Address 09: Cent. Elect. (J519) Labels:* None
Part No SW: 8W0 907 063 CF HW: 8W0 907 063 BF
Component: BCM1 MLBevo H13 0267
Coding: C2501142C11800CD05148714182900F9111B3108000000000000000020001A0100410022025605
VCID: 015F86357184C2335DD-8054
Subsystem 1 - Part No SW: 8W6 955 119 HW: 8W6 955 119 Labels: 1KX-955-119.CLB
Component: 494 LL 151217 036 0471
Serial number: 00000001712120302245
Coding: 5FC7F7
Serial number: 21092088X81A955555A0
Coding: 02005D
Subsystem 3 - Part No SW: 4M0 941 531 AG HW: 4M0 941 531 AG
Component: E1 - LDS H06 0008
Serial number: 29 11 2017 01196043
Subsystem 4 - Part No SW: 8W0 857 511 HW: 8W0 857 511
Component: Y7_Innenspieg H09 0002
Serial number: GX1CE113121723610799
Interior Light Module:
Subsystem 5 - Part No SW: 8W0 947 135 D HW: 8W0 947 135
Component: J528-Dachele H14 0130
Serial number: B00665350
Subsystem 6 - Part No SW: 8W0 925 301 BC HW: 8W0 925 301 BC
Component: SL-B9/Q5NF H17 0010
Serial number: 2817000299487001
9 Faults Found:
66679 - Databus
[Right LCM: implausible data record]
Redefinir contador: 131
Data: 2020.11.18
Horário: 19:32:05
Average_Voltage_terminals: 11,70 V
Resistência do sensor de temperatura do ar externo: 0,00 kOhm
Sensor de temperatura do ar externo - Temperatura do ar externo no CAN: 49,00 ° C
temperatura_ interior: 35,50 ° C
Velocidade do veículo: 0,00 km / h
Controle do Terminal - Status do Terminal 75: Ligado
Controle do Terminal - Sinal de status do Terminal 15: Ligado
Terminal de controle - Terminal 15 via CAN: Ligado
Controle de terminal - Termo 75: qualificação: DESLIGADO
66964 - Databus
U1123 00 [009] - Mensagem de erro recebida
[LCM direito: sinal de mudança de direção com defeito]
Prioridade de falha: 6
Data: 2020.11.18
Horário: 19:32:05
131349 - Databus
[Brake control module: received error value in signal ESP_FR_wheel-speed]
Reset counter: 131
Mileage: 30302 km
Date: 2020.11.18
Time: 21:50:02
average_Voltage_terminals: 14.40 V
Outside air temperature sensor-Outside air temperature on CAN: 35.50 °C
interior_temperature: 33.50 °C
Vehicle speed: 34.53 km/h
Terminal control-Terminal 75 status: On
Terminal control-Terminal 15 status signal: On
Terminal control-Terminal 15 via CAN: On
Terminal control-Term 75: qualification: OFF
131353 - Power Output Module for LED Headlamps; Left
U1170 00 [008] - No Communications
[Left LED headlamp power output module: no communication]
Reset counter: 171
Mileage: 30302 km
Date: 2020.11.18
Time: 19:32:05
average_Voltage_terminals: 11.70 V
Outside air temperature sensor-Outside air temperature on CAN: 49.00 °C
interior_temperature: 35.50 °C
Vehicle speed: 0.00 km/h
131361 - Power Output Module for LED Headlamps; Right
U1171 00 [008] - No Communications
[Right LED headlamp power output module: no communication]
Reset counter: 171
Mileage: 30302 km
Date: 2020.11.18
Time: 19:32:05
131895 - Databus
[NightVision control module: no signal/communication]
Reset counter: 171
Mileage: 30302 km
Date: 2020.11.18
Time: 19:53:51
average_Voltage_terminals: 13.80 V
Outside air temperature sensor-Outside air temperature on CAN: 49.50 °C
interior_temperature: 35.00 °C
196751 - Databus
[Brake control module: received error value in signal ESP front right distance pulse]
Fault Frequency: 18
Reset counter: 132
Mileage: 30302 km
Date: 2020.11.18
Time: 21:50:02
average_Voltage_terminals: 14.30 V
Vehicle speed: 34.78 km/h
196755 - Databus
[Módulo de controle de freio: valor de erro recebido no sinal de velocidade da roda dianteira direita ESP]
Frequência de falha: 18
Reiniciar contador: 132
Data: 2020.11.18
Horário: 21:50:02
Average_Voltage_terminals: 14,30 V
Sensor de temperatura do ar externo - Temperatura do ar externo no CAN: 35,50 ° C
temperatura_interiores: 33,50 ° C
Velocidade do veículo: 34,78 km / h
196758 - Databus
[Módulo de controle de freio: valor de erro recebido no sinal de status do sistema ESP]
Data: 2020.11.18
Horário: 21:50:02
Velocidade do veículo: 34,75 km / h
Endereço 15: Airbags (J234) Etiquetas: | 8W0-959-655.clb
Part No SW: 8W0 959 655 F HW: 8W0 959 655 F
Component: Airbag10.44 H03 0107
Serial number: 003UP00CJ46D
Coding: AACCF0000080000058000033D04C00000000
ASAM Dataset: EV_AirbaAU10BPAAU736 006016
ROD: EV_AirbaAU10BPAAU736_006_AU49.rod
VCID: 4CC167010646DF5BFEB-8018
Subsystem 1 - Part No SW: ----------- HW: 442 061 301 18
Serial number: 3577Y009925777D2403
Subsystem 2 - Part No SW: ----------- HW: 442 061 301 18
Serial number: 3587Y009925777D262FC
Subsystem 3 - Part No SW: ----------- HW: 442 0B0 801 18
Serial number: 35177009928FA394A14L
Subsystem 4 - Part No SW: ----------- HW: 442 0B2 111 17
Serial number: 3527700A3289D253F3BM
Subsystem 5 - Part No SW: ----------- HW: 442 0C2 207 17
Component: FrontSensor_D 1C5 014A
Serial number: 35575009D2665760B2BH
Front Sensor Passenger:
Subsystem 6 - Part No SW: ----------- HW: 442 0C2 207 17
Component: FrontSensor_P 1C5 014A
Serial number: 35675009D266576552DJ
7 Faults Found:
9437210 - Igniter for Driver's Airbag
B1000 1A [137] - Resistance Too Low
Mileage: 30302 km
Data: 2020.11.18
Horário: 15:28:55
9438491 - Ignitor para airbag da cabeça do motorista
B1005 1B [137] - Resistência muito alta
Data: 2020.11.18
Horário: 15:28:55
9438225 - Ignitor para airbag da cortina de cabeça do passageiro dianteiro
B1004 11 [136] - Curto para o solo
MIL ON - Intermitente - Confirmado - Testado desde a limpeza da memória
Quilometragem: 30333 km
Data: 19/11/2020
Horário: 14:35:37
9438235 - Ignitor para airbag da cortina de cabeça do passageiro dianteiro
B1004 1B [137] - Resistência muito alta
Data: 2020.11.18
Horário: 15:28:55
9682162 - Freio de colisão múltipla
B13BC F2 [137] - Sem função
Freqüência de falha: 8
Quilometragem: 29.174 km
Data: 2020.10.29
Horário: 13:50:29
1055237 - Databus
U1123 00 [137] - Mensagem de erro recebida
[NWD: 0x11E ESP_08 valor de erro ESP_v_ref]
Data: 2020.11.18
Horário: 21:50:03
1049350 - Databus
[NWD: 0x103 ESP_03 valor de erro ESP_VR_Radgeschw]
Reset counter: 131
Mileage: 30302 km
Date: 2020.11.18
Time: 15:28:54
Part No SW: 4M0 907 129 GT HW: 4M0 907 129 GT
Component: Lenks.Modul H11 0009
ROD: EV_SMLSKLOAU736_006.rod
VCID: 08499B1152BEF37B1A3-805C
4203520 - Databus
[Fehlerwert Raddrehzahlen (ESP_03)]
Reset counter: 131
Mileage: 30302 km
Date: 2020.11.18
Time: 15:28:53
Address 17: Instruments (J285) Labels:* Redir Fail!-SRI2
Part No SW: 8W5 920 790 D HW: 8W5 920 790 D
Component: FBenRDW H18 0373
Coding: 04A441C6288000081A03E9401000000000000000
Part No SW: 4M1 907 468 F HW: 4M1 907 468 E
Component: Gateway H22 0123
Revision: 7K010001 Serial number: 0147K023118118
Coding: 0301000100000640290700000059001268180000100000000100000000000000
ASAM Dataset: EV_GatewCONTIAU736 003111
VCID: 3A2D31D95CD251EB5C7-806E
Subsystem 1 - Part No SW: 8W0 951 523 F HW: 8W0 951 523 F
Component: J453 MFL H04 0002
Serial number: 20180123121904 21489
Subsystem 2 - Part No SW: 8S0 915 181 C HW: 8S0 915 181 C
Serial number: 6697636604
8519683 - Energy Management Active
U140B 00 [008] - -
Reset counter: 171
Mileage: 30302 km
Date: 2020.11.18
Time: 19:31:29
EM_vehicle_state: 02 3C
Static current shutdown level: Deactivation stage 1
Auxiliary heater activation restriction request-Parking heater: Permitted
Auxiliary heater activation restriction request-Allowed parking heater runtime: 0 min
Address 29: Left Light (J1018) Labels: 4M0-907-397.clb
Part No SW: 4M0 907 397 AA HW: 4M0 907 397 A
Component: LCM_MLBevoH05 0024
VCID: 76B5E5E9284AF58B78F-8022
Address 39: Right Light (J1023) Labels: 4M0-907-397.clb
Part No SW: 4M0 907 397 AD HW: 4M0 907 397 D
VCID: 79AFEED519549AF315D-802C
0018 - Data Set Implausible
B2012 00 [009] - -
[Conjunto de dados implausível]
Data: 2020.11.18
Horário: 15:28:52
Endereço 42: Porta Eleita, Motorista (J386) Etiquetas: * Nenhum
Peça Nº SW: 8W0 959 593 H HW: 8W0 959 593 F
Componente: TSG FS 005 0129
Número de série: 0000298334459
Codificação: 001F5A624100000000001482
Loja nº: WSC 06335 790 00001
Conjunto de dados ASAM: EV_DCU2DriveSideMAXHCONT 001005
VCID: 4FFB700DF750E4439B9-801A
Nenhum código de falha encontrado.
Endereço 44: Etiquetas do Steering Assist (J500): * Nenhum
Peça Nº SW: 8W0 909 144 H HW: 8W0 909 144 B
Componente: EPS_MLBEVO_ZF H08 0410
Codificação: 09000380008000
Conjunto de dados ASAM: EV_EPSZFAU49X 003023
ROD: EV_EPSZFAU49X_003.rod
VCID: 42DD49393402192B047-8016
28160 - Databus
[KFC_ESP_03_SNA]
Prioridade de falha: 5
Data: 2020.11.18
Hora: 15:28:53
Dados ambientais expandidos 1-Motor em execução: Engine_Running_Stable
Expanded ambient data 1-Supply voltage: 0.00 V
Expanded ambient data 1-Temperature: -70 °C
Expanded ambient data 1-System status: 5
Expanded ambient data 1: 00
Expanded ambient data 1-driving_direction: 0
Expanded ambient data 1-KFA: 0
Expanded ambient data 1-KFC: 110
Expanded ambient data 1-Ready_To_Drive_Bit: 0
Expanded ambient data 1-StartStop Info: 0
Expanded ambient data 1-Steering_Angle_Calculated: 1 °
Expanded ambient data 1-Steering_Angle_Calculated_Sign: 1
Expanded ambient data 1-Steering_torque: 0.20 Nm
Expanded ambient data 1-Steering_Torque_Sign: 0
Expanded ambient data 15-MsgStateFifo_Byte0: 00 00 00 00
Expanded ambient data 15-MsgStateFifo_Byte1: 00 00 00 00
Expanded ambient data 15-MsgStateFifo_Byte2: FF FF FF FF
Expanded ambient data 15-MsgStateFifo_Byte3: FF FF FF FF
Expanded ambient data 15-NumOfMsgCntFaults: 00
Expanded ambient data 15-NumOfMsgCrcFaults_2: 00
Expanded ambient data 15-NumOfMsgNoFaults_3: 00
Expanded ambient data 15-NumOfMsgTimoFaults_1: 00
17664 - Databus
[KFC_ESP_22_SNA]
Fault Frequency: 17
Reset counter: 132
Mileage: 30302 km
Date: 2020.11.18
Time: 15:28:53
Expanded ambient data 1-Engine running: Engine_Running_Stable
Expanded ambient data 1-KFC: 69
Expanded ambient data 15-MsgStateFifo_Byte2: 00 00 00 00
Expanded ambient data 15-MsgStateFifo_Byte3: 00 00 00 00
Part No SW: 8W0 907 064 EC HW: 8W0 907 064 DC
Component: BCM2 MLBevo 025 0387
Coding: 013400000F310040630180000E00080033024000804300502F0400000504803F001E0001000000
ASAM Dataset: EV_BCM2HellaAU736 014014
ROD: EV_BCM2HellaAU736_014_AU49.rod
Subsystem 1 - Part No SW: 5Q0 951 177 HW: 5Q0 951 172
Serial number: 000000000ZY173411BS2
Subsystem 2 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Serial number: 00000000000099843203
Subsistema 3 - Parte No SW: 3AA 962 243 H HW: 3AA 962 243 H
Componente: GEB.F.Heckoef H16 0905
Número de série:> 1204447
1 falha encontrada:
65896 - Databus
U1121 00 [008] - Mensagem ausente
[Módulo de controle Climatronic: Klima_03: sem sinal / comunicação]
Intermitente - Confirmado - Testado desde que a memória foi apagada
Redefinir contador: 172
Data: 2020.11.18
Horário: 15:39:34
Tensões de alimentação - Tensão de alimentação: Terminal 30: 12,881 V
Tensão de alimentação - Terminal de tensão de alimentação 30 - 2: 12,935 V
Tensão de alimentação - Terminal de tensão de alimentação 30 - 3: 12,881 V
general_additional_freeze_frame-Ambient_temperature_not_filtered: -50,0 ° C
general_additional_freeze_frame-interior_temperature: -50,0 ° C
general_additional_freeze_frame-production_mode: não ativo
general_additional_freeze_frame-Stall_current_cutoff_level: Estágio de desativação 0
general_additional_freeze_frame-Stall_Current_Measuring_Mode: não ativo
general_additional_freeze_frame-terminal_control_intern_status: 40 04 0A 14 00 80
general_additional_freeze_frame-Transport_Mode: não ativo
general_additional_freeze_frame -Velocidade do veículo: 0,00 km / h
Endereço 52: Porta Eleita, Passe. (J387) Etiquetas: * Nenhum
Peça Nº SW: 8W0 959 592 H HW: 8W0 959 592 F
Componente: TSG BFS 005 0129
Número de série: 0000294308540
Codificação: 001F5A224100000000001480
Conjunto de dados ASAM: EV_DCU2PasseSideMAXHCONT 001005
VCID: 4EC56D09F05AED4B90F-801A
Endereço 5F: Informações Electr. (J794) Etiquetas: * Nenhum
Peça Nº SW: 8W5 035 039 B HW: 8W5 035 039
Componente: MU-P-LN-RW 034 1177
Número de série: A801A0JB010786
Codificação: 01940303FF0A000013220001001A00102F000EE401700100DE
Conjunto de dados ASAM: EV_MUHig6C3Gen2HBAS 001115
Meio de dados:
Subsistema 1 - Parte No SW: V03 959 801 PT HW: -----------
Componente: ROW 2017/2018 --- 0065
Número de série: --------------------
Unidade de exibição 1 para sistema multimídia:
Subsistema 2 - Parte No SW: 8W1 919 605 HW: 8W1 919 605
Componente: DU High AU49x H32 0170
Número de série: TPO00128101700820936
Unidade Operacional Multimídia:
Subsistema 3 - Parte No SW: 8W0 919 614 T HW: 8W0 919 614 T
Componente: ControlUnit_H H30 0206
Número de série: APVAK118121700020734
Banco de dados de discos compactos:
Subsistema 4 - Parte No SW: V03 959 800 EG HW: -----------
Componente: Gracenote2 --- 4012
1 falha encontrada:
3084 - antena GSM 2
B1533 13 [009] - Circuito Aberto
Data: 2020.11.18
Horário: 15:28:56
Terminal de tensão 30: 13,4 V
Endereço 6C: Back-up Cam. (J772) Rótulos: * Falha de redirecionamento!
Peça Nº SW: 4M0 980 556 A HW: 4M0 980 556 A
Componente: RVC Compact H12 0250
Codificação: 0294030102002001400040
Conjunto de dados ASAM: EV_CamSysRVRVCPANAMLBEv 005010
ROD: EV_CamSysRVRVCPANAMLBEv_005_AU49.rod
VCID: 33331CFD7BB8A0A39F1-8066
Endereço 6D: Trunk Elect. (J605) Etiquetas: | 5Q0-959-107.clb
Part No SW: 8W8 959 107 B HW: 8W8 959 107
Componente: HDSG-Modul H13 0163
Revisão: -------- Número de série: 31757109400000
Codificação: 0630
Conjunto de dados ASAM: EV_DeckLidCONTIAU736 001015
VCID: 48C95B11123E337BDA3-801C
Address 81: Gear Shift (J587) Labels: 4MX-713-041-81.clb
Part No SW: 8W1 713 041 G HW: 8W1 713 041 J
Component: GSM-LL H09 0077
Revision: 0L0D5012 Serial number: 18012945796015
ROD: EV_GSMWaehlZFAU736.rod
VCID: 372B28ED6FC04C83A39-8062
Address A9: Struct. Borne Sound (J869) Labels: None
Part No SW: 8W0 907 159 H HW: 4H0 907 159 A
Component: SAS-GEN 2 H07 0008
Serial number: 180124202467
VCID: 46D55529182A250B28F-8012
Part No SW: 8W0 959 595 H HW: 8W0 959 595 F
Component: TSG HFS 005 0129
Número de série: 0000302249582
Codificação: 000F58220000000000001080
Conjunto de dados ASAM: EV_DCU2RearDriveMAXHCONT 001005
VCID: 51FF7675E164F2B38DD-8004
Endereço BC: Passagem da porta traseira (J389) Etiquetas: * Nenhum
Peça Nº SW: 8W0 959 595 H HW: 8W0 959 595 F
Componente: TSG HBFS 005 0129
Número de série: 0000302249757
Conjunto de dados ASAM: EV_DCU2RearPasseMAXHCONT 001005
ROD: EV_DCU2RearPasseMAXHCONT_AU49.rod
1 falha encontrada:
196660 - Motor para regulador de janela
B1487 54 [009] - Calibração ausente / configuração básica
Data: 2020.11.18
Horário: 15:28:58
Fim ---------- (Tempo decorrido: 01:48, início / fim VBatt: 12,1 V / 12,2 V) -----------
BB BC
Revisão: --H15 ---
Data: 2020.11.18
Horário: 15:28:56
MAP_MES_SAE: 27 kPa
TAA: 48.500 ° C
T_AST_SAE: 1 s
Data: 2020.11.18
Horário: 15:28:56
MAP_MES_SAE: 27 kPa
TAA: 48.500 ° C
T_AST_SAE: 1 s
Data: 2020.11.18
Horário: 15:28:56
RVC_AV: 40,45 °
RVC_SP: 40,00 °
T_AST_SAE: 0 s
T_ES_DC: 31 min
21471 - Databus
Data: 2020.11.18
Horário: 15:28:55
Variantes ACC: ACC
P1647 00 [175] - -
Data: 2020.11.18
Horário: 15:28:55
Terminal de tensão 30: 13,027 V
Variantes ACC: ACC
U0415 00 [047] - -
Data: 2020.11.18
Horário: 21:50:02
U0415 00 [175] - -
Data: 2020.11.18
Horário: 21:50:02
Prontidão: 0010 0001
Endereço 02: Auto Trans (J217) Etiquetas: | 0CJ-927-156.clb
Peça No SW: 8W2 927 155 AT HW: 0CJ 927 156
Componente: 0CL 20TFSIRdW H05 0001
Revisão: --H05 --- Número de série: 0000002464
Codificação: 000001
Loja nº: WSC 00000 000 00000
Conjunto de dados ASAM: EV_TCMDL382021 002027
Bomba de fluido de transmissão manual:
Subsistema 1 - Parte No SW: 0CK 927 152 AA HW: 0CK 321 281 L
Componente: V553 MTFP 003 0576
Número de série: 75145041180023001045
1 falha encontrada:
20973 - Desempenho de processamento A / D do módulo de controle interno
P060B 00 [047] - -
Frequência de falha: 73
Data: 2020.11.18
Horário: 15:28:55
Velocidade do motor: 776 / min
Posição de condução: P
Temperatura do fluido de transmissão: 55 ° C
Velocidade de saída de transmissão: 0 / min
Terminal de tensão 30: 13,2 V
Torque do motor: 0 Nm
engrenagem selecionada: 1
Ctrl. mod .: condição de operação: operação regular
Bomba auxiliar para transmissão: função solicitante: Encher a prensa hidráulica. acum.
Bomba hidráulica auxiliar para óleo de transmissão: corrente: 6 A
Reservatório de pressão de óleo: pressão: 28,2 bar
Pressão da embreagem 1: valor real: 0,0 bar
Pressão da embreagem 2: valor real: 0,0 bar
Status da embreagem: Neutro
Safety_interface_voltage_state-Voltage_supply_1: válido
Safety_interface_can_signal_state-brakes: inválido
Safety_interface_can_signal_state-NAn: inválido
Safety_interface_can_signal_state-VFzg: inválido
Safety_interface_can_signal_state-VRad (frente esquerda): inválido
Safety_interface_can_signal_state-VRad (frente à esquerda): gehalten
Safety_interface_can_signal_state-VRad (frente à direita): Atual
Safety_interface_can_signal_state-VRad (frente direita): inválido
Safety_interface_can_signal_state-VRad (traseiro esquerdo): Atual
Safety_interface_can_signal_state-VRad (traseiro esquerdo): inválido
C11DB 00 [175] - -
Data: 2020.11.18
Horário: 15:28:55
Data: 2020.11.18
Horário: 21:50:02
Codificação: 140801885140000510000100080000000000000000000000000000000000
Conjunto de dados ASAM: EV_AirCondiBHTCAU491 001013
Frente do soprador de ar fresco:
Subsistema 1 - Parte No SW: 4M1 820 021 B HW: 4M1 820 021 B
Componente: J126 FLuftV H09 0003
Número de série: 00000000000002130749
Sensor de umidade relativa no duto de entrada de ar fresco:
Subsistema 2 - Parte No SW: 4G0 907 658 B HW: 4G0 907 658 B
Componente: Humidity_Sens H02 0007
Número de série: 65A11E0900PAG0FSA002
Endereço 09: Cent. Eleger. (J519) Etiquetas: * Nenhum
Componente: BCM1 MLBevo H13 0267
Codificação: C2501142C11800CD05148714182900F9111B31080000000000000000000020001A0100410022025605
Conjunto de dados ASAM: EV_BCM1BOSCHAU736 018006
Unidade de controle para motor do limpador:
Subsistema 1 - Parte No SW: 8W6 955 119 HW: 8W6 955 119 Etiquetas: 1KX-955-119.CLB
Componente: 494 LL 151217 036 0471
Número de série: 00000001712120302245
Codificação: 5FC7F7
Sensor de reconhecimento de luz de chuva:
Subsistema 2 - Parte No SW: 81A 955 555 A HW: 81A 955 555
Componente: G397_RLFSS H06 0002
Número de série: 21092088X81A955555A0
Codificação: 02005D
Interruptor:
Subsistema 3 - Parte No SW: 4M0 941 531 AG HW: 4M0 941 531 AG
Componente: E1 - LDS H06 0008
Número de série: 29 11 2017 01196043
Espelho interno diurno noturno automático:
Subsistema 4 - Parte No SW: 8W0 857 511 HW: 8W0 857 511
Componente: Y7_Innenspieg H09 0002
Número de série: GX1CE113121723610799
Codificação: 010000
Módulo de luz interna:
Subsistema 5 - Parte No SW: 8W0 947 135 D HW: 8W0 947 135
Componente: J528-Dachele H14 0130
Número de série: B00665350
Unidade operacional de conveniência e assistência ao motorista:
Subsistema 6 - Parte No SW: 8W0 925 301 BC HW: 8W0 925 301 BC
Componente: SL-B9 / Q5NF H17 0010
Número de série: 2817000299487001
Codificação: 000000
9 falhas encontradas:
66679 - Databus
[LCM direito: registro de dados implausível]
Data: 2020.11.18
Horário: 19:32:05
66964 - Databus
Data: 2020.11.18
Horário: 19:32:05
131349 - Databus
[Módulo de controle de freio: valor de erro recebido no sinal ESP_FR_wheel-speed]
Data: 2020.11.18
Horário: 21:50:02
Average_Voltage_terminals: 14,40 V
Velocidade do veículo: 34,53 km / h
131353 - Módulo de saída de energia para faróis de LED; Esquerda
U1170 00 [008] - Sem Comunicações
[Módulo de saída de energia do farol LED esquerdo: sem comunicação]
Redefinir contador: 171
Data: 2020.11.18
Horário: 19:32:05
131361 - Módulo de saída de energia para faróis de LED; Direito
U1171 00 [008] - Sem Comunicações
[Módulo de saída de energia do farol LED direito: sem comunicação]
Data: 2020.11.18
Horário: 19:32:05
131895 - Databus
[Módulo de controle NightVision: sem sinal / comunicação]
Data: 2020.11.18
Horário: 19:53:51
Average_Voltage_terminals: 13,80 V
Sensor de temperatura do ar externo - Temperatura do ar externo no CAN: 49,50 ° C
temperatura_interiores: 35,00 ° C
196751 - Databus
[Módulo de controle de freio: valor de erro recebido no sinal de pulso de distância direita frontal ESP]
Data: 2020.11.18
Horário: 21:50:02
196755 - Databus
Data: 2020.11.18
Horário: 21:50:02
196758 - Databus
Data: 2020.11.18
Horário: 21:50:02
Peça Nº SW: 8W0 959 655 F HW: 8W0 959 655 F
Componente: Airbag 10,44 H03 0107
Número de série: 003UP00CJ46D
Codificação: AACCF0000080000058000033D04C00000000
Conjunto de dados ASAM: EV_AirbaAU10BPAAU736 006016
Frente do driver do sensor lateral:
Subsistema 1 - Parte No SW: ----------- HW: 442 061 301 18
Componente: SideSensor_Df 1E2 0887
Número de série: 3577Y009925777D2403
Codificação: 2D2D2D
Sensor lateral frontal do passageiro:
Subsistema 2 - Parte No SW: ----------- HW: 442 061 301 18
Componente: SideSensor_Pf 1E2 0887
Número de série: 3587Y009925777D262FC
Codificação: 2D2D2D
Traseira do driver do sensor lateral:
Subsistema 3 - Parte No SW: ----------- HW: 442 0B0 801 18
Componente: SideSensor_Dr 1C7 0148
Número de série: 35177009928FA394A14L
Codificação: 2D2D2D
Sensor lateral traseiro do passageiro:
Subsistema 4 - Parte No SW: ----------- HW: 442 0B2 111 17
Componente: SideSensor_Pr 1C7 0148
Número de série: 3527700A3289D253F3BM
Codificação: 2D2D2D
Driver do sensor frontal:
Subsistema 5 - Parte No SW: ----------- HW: 442 0C2 207 17
Componente: FrontSensor_D 1C5 014A
Número de série: 35575009D2665760B2BH
Codificação: 2D2D2D
Passageiro do sensor frontal:
Subsistema 6 - Parte No SW: ----------- HW: 442 0C2 207 17
Componente: FrontSensor_P 1C5 014A
Número de série: 35675009D266576552DJ
Codificação: 2D2D2D
9437210 - Dispositivo de ignição para airbag do motorista
B1000 1A [137] - Resistência muito baixa
Data: 2020.11.18
Horário: 15:28:55
Data: 2020.11.18
Horário: 15:28:55
Data: 19/11/2020
Horário: 14:35:37
Data: 2020.11.18
Horário: 15:28:55
Data: 2020.10.29
Horário: 13:50:29
1055237 - Databus
Data: 2020.11.18
Horário: 21:50:03
1049350 - Databus
Data: 2020.11.18
Horário: 15:28:54
Endereço 16: Volante (J527) Etiquetas: 4M0-907-129.clb
Número da peça SW: 4M0 907 129 GT HW: 4M0 907 129 GT
Componente: Lenks.Modul H11 0009
Conjunto de dados ASAM: EV_SMLSKLOAU736 006008
1 falha encontrada:
4203520 - Databus
Data: 2020.11.18
Hora: 15:28:53
Endereço 17: Instrumentos (J285) Etiquetas: * Redir Fail! -SRI2
Peça Nº SW: 8W5 920 790 D HW: 8W5 920 790 D
Componente: FBenRDW H18 0373
Codificação: 04A441C6288000081A03E9401000000000000000
Conjunto de dados ASAM: EV_DashBoardAU736 001027
Endereço 19: Etiquetas do CAN Gateway (J533): * Nenhum
Peça Nº SW: 4M1 907 468 F HW: 4M1 907 468 E
Componente: Gateway H22 0123
Revisão: 7K010001 Número de série: 0147K023118118
Codificação: 0301000100000640290700000059001268180000100000000100000000000000
Conjunto de dados ASAM: EV_GatewCONTIAU736 003111
Módulo de controle multifuncional do volante:
Subsistema 1 - Parte No SW: 8W0 951 523 F HW: 8W0 951 523 F
Componente: J453 MFL H04 0002
Número de série: 20180123121904 21489
Módulo de controle de monitoramento de bateria:
Subsistema 2 - Parte No SW: 8S0 915 181 C HW: 8S0 915 181 C
Componente: J367-BDMHella H10 9070
Número de série: 6697636604
1 falha encontrada:
8519683 - Gerenciamento de energia ativo
U140B 00 [008] - -
Data: 2020.11.18
Horário: 19:31:29
Nível de desligamento de corrente estática: Estágio de desativação 1
Solicitação de restrição de ativação do aquecedor auxiliar - Aquecedor de estacionamento: Permitido
Solicitação de restrição de ativação do aquecedor auxiliar - Tempo de execução do aquecedor de estacionamento permitido: 0 min
Endereço 29: Left Light (J1018) Etiquetas: 4M0-907-397.clb
Peça Nº SW: 4M0 907 397 AA HW: 4M0 907 397 A
Componente: LCM_MLBevoH05 0024
Conjunto de dados ASAM: EV_LCMLeftHELLAAU736 001012
Endereço 39: Luz direita (J1023) Etiquetas: 4M0-907-397.clb
Peça Nº SW: 4M0 907 397 AD HW: 4M0 907 397 D
Conjunto de dados ASAM: EV_LCMRightHELLAAU736 001012
1 falha encontrada:
0018 - Conjunto de dados implausível
B2012 00 [009] - -
Data: 2020.11.18
Horário: 15:28:52
28160 - Databus
[KFC_ESP_03_SNA]
Data: 2020.11.18
Hora: 15:28:53
Dados ambientais expandidos 1-Tensão de alimentação: 0,00 V
Dados ambientais expandidos 1-Temperatura: -70 ° C
Dados ambientais expandidos 1 - Status do sistema: 5
Dados ambientais expandidos 1: 00
Dados ambientais expandidos 1-driving_direction: 0
Dados ambientais expandidos 1-KFA: 0
Dados ambientais expandidos 1-KFC: 110
Dados ambientais expandidos 1-Ready_To_Drive_Bit: 0
Dados do ambiente expandidos 1-StartStop Info: 0
Dados ambientais expandidos 1-Steering_Angle_Calculated: 1 °
Dados ambientais expandidos 1-Steering_Angle_Calculated_Sign: 1
Dados ambientais expandidos 1-Steering_torque: 0,20 Nm
Dados ambientais expandidos 1-Steering_Torque_Sign: 0
Dados ambientais expandidos 15-MsgStateFifo_Byte0: 00 00 00 00
Dados ambientais expandidos 15-MsgStateFifo_Byte1: 00 00 00 00
Dados ambientais expandidos 15-MsgStateFifo_Byte2: FF FF FF FF
Dados ambientais expandidos 15-MsgStateFifo_Byte3: FF FF FF FF
Dados de ambiente expandidos 15-NumOfMsgCntFaults: 00
Dados de ambiente expandidos 15-NumOfMsgCrcFaults_2: 00
Dados do ambiente expandido 15-NumOfMsgNoFaults_3: 00
Dados de ambiente expandidos 15-NumOfMsgTimoFaults_1: 00
17664 - Databus
[KFC_ESP_22_SNA]
Frequência de falha: 17
Data: 2020.11.18
Hora: 15:28:53
Dados ambientais expandidos 1-KFC: 69
Dados ambientais expandidos 15-MsgStateFifo_Byte2: 00 00 00 00
Dados ambientais expandidos 15-MsgStateFifo_Byte3: 00 00 00 00
Endereço 46: Central Conv. (J393) Etiquetas: * Nenhum
Componente: BCM2 MLBevo 025 0387
Codificação: 013400000F310040630180000E00080033024000804300502F0400000504803F001E0001000000
Conjunto de dados ASAM: EV_BCM2HellaAU736 014014
Sensor para sistema de alarme antifurto:
Subsistema 1 - Parte No SW: 5Q0 951 177 HW: 5Q0 951 172
Componente: Sensor, DWA 005 0316
Número de série: 000000000ZY173411BS2
Buzina de alarme:
Subsistema 2 - Parte No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Componente: Sirene, DWA 005 0314
Número de série: 00000000000099843203
Tampa traseira de energia controlada por sensor:
1 falha encontrada:
65896 - Databus
Data: 2020.11.18
Horário: 15:39:34
Meio de dados:
1 falha encontrada:
3084 - antena GSM 2
Data: 2020.11.18
Horário: 15:28:56
Codificação: 0630
Endereço 81: Mudança de marcha (J587) Etiquetas: 4MX-713-041-81.clb
Peça Nº SW: 8W1 713 041 G HW: 8W1 713 041 J
Componente: GSM-LL H09 0077
Revisão: 0L0D5012 Número de série: 18012945796015
Conjunto de dados ASAM: EV_GSMWaehlZFAU736 001017
Endereço A9: Struct. Rótulos de Borne Sound (J869): Nenhum
Peça Nº SW: 8W0 907 159 H HW: 4H0 907 159 A
Componente: SAS-GEN 2 H07 0008
Número de série: 180124202467
Conjunto de dados ASAM: EV_SoundActuaGen2AU64X 003010
Endereço BB: Drv traseiro da porta (J388) Etiquetas: * Nenhum
Componente: TSG HFS 005 0129
1 falha encontrada:
Data: 2020.11.18
Horário: 15:28:58
As said before we need the Auto-Scan to be made using the English version of VCDS - very few of us speak or understand PortugueseCode:Quinta-feira, 19 de novembro de 2020, 15: 20: 52: 56.451 VCDS - Emulador VAG / VAS baseado em Windows em execução no Windows 10 x64 Versão VCDS: 20.4.2.0 (x64) HEX-V2 CB: 0.4513.4 Versão de dados: 20200730 DS317.0 www.Ross-Tech.com
sorry google chrome is automatically translatingAs said before we need the Auto-Scan to be made using the English version of VCDS - very few of us speak or understand Portuguese
The English version of VCDS can be downloaded from the Ross-Tech website here and installed alongside your Portugese(?) version.
Thursday,19,November,2020,15:20:52:56451
VIN: WAUAFEF53JA082639 License Plate:
Mileage: 30333km-18848mi Repair Order:
Chassis Type: F5-AU49 (4M1)
Scan: 01 02 03 08 09 15 16 17 19 29 39 42 44 46 52 5F 6C 6D 81 A9
BB BC
VIN: WAUAFEF53JA082639 Mileage: 30333km-18848miles
39-Right Light -- Status: Malfunction 0010
Address 01: Engine (J623-CYRB) Labels:. 06L-907-115-V1.clb
Part No SW: 8W0 906 259 E HW: 06L 907 425 C
Component: 2.0l R4 TFSI H15 0003
Revision: --H15---
Coding: 1A2500322326050B34080000000000000000000000000000
Shop #: WSC 06314 790 00001
ASAM Dataset: EV_ECM20TFS0208W0906259E 001004
7 Faults Found:
14828 - Left Engine Mount Solenoid Valve (N144)
P1572 00 [047] - Short to Ground
Mileage: 30302 km
Date: 2020.11.18
Time: 15:28:56
Engine speed: 775.00 /min
Normed load value: 9.0 %
Voltage terminal 30: 13.144 V
FAC_TPS_1_SAE: 11.328125 %
FUP_H_SAE: 8280.0 kPa
MAP_MES_SAE: 27 kPa
TAA: 48.500 °C
T_AST_SAE: 1 s
Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.948 V
14825 - Right Engine Mount Solenoid Valve (N145)
P1576 00 [047] - Short to Ground
Mileage: 30302 km
Date: 2020.11.18
Time: 15:28:56
MAP_MES_SAE: 27 kPa
TAA: 48.500 °C
T_AST_SAE: 1 s
17792 - Coolant Pump Control Circuit
P2602 00 [047] - Short to Ground
Fault Frequency: 35
Mileage: 30302 km
Date: 2020.11.18
Time: 15:28:56
Engine speed: 788.75 /min
Normed load value: 9.8 %
Voltage terminal 30: 13.183 V
RVC_AV: 40.45 °
RVC_SP: 40.00 °
T_AST_SAE: 0 s
T_ES_DC: 31 min
Engine oil temperature: 92.0 °C
21471 - Databus
U1122 00 [047] - Implausible Message
Fault Frequency: 28
Mileage: 30302 km
Date: 2020.11.18
Time: 15:28:55
Engine speed: 778.25 /min
Normed load value: 10.2 %
Voltage terminal 30: 13.066 V
ACC variants: ACC
17169 - Check Coding of ECUs on Powertrain Data Bus
P1647 00 [175] - -
Fault Frequency: 28
Mileage: 30302 km
Date: 2020.11.18
Time: 15:28:55
Engine speed: 781.50 /min
ACC variants: ACC
23039 - Implausible Data Received from ABS Control Module
U0415 00 [047] - -
Mileage: 30302 km
Date: 2020.11.18
Time: 21:50:02
Engine speed: 1267.75 /min
Normed load value: 17.6 %
Vehicle speed: 34 km/h
Coolant temperature: 73 °C
26386 - Implausible Data Received from ABS Control Module
U0415 00 [175] - -
Mileage: 30302 km
Date: 2020.11.18
Time: 21:50:02
P060B 00 [047] - -
Fault Frequency: 73
Mileage: 30302 km
Date: 2020.11.18
Time: 15:28:55
Driving position: P
Engine torque: 0 Nm
selected gear: 1
Safety_interface_can_signal_state-VRad (rear right): invalid
Safety_interface_can_signal_state-VRad (rear right): Current
Address 03: ABS Brakes (J104) Labels: 8W0-907-379-PLU-V1.clb
Component: ESP9 Plus H10 0766
Coding: 14AA409A28AA0A9811A4489400865292E4A5C0280214508812004A4927A503
Shop #: WSC 06334 790 00001
417536 - Wheel Circumference Implausible; Right Front
C11DB 00 [175] - -
Mileage: 30302 km
Date: 2020.11.18
Time: 15:28:55
Unlearning counter according OBD-OBD unlearning counter: 28
4523782 - Wheel Speed Sensor; Right Front
C0507 00 [229] - Implausible Signal
Mileage: 30302 km
Date: 2020.11.18
Time: 21:50:02
Address 08: Auto HVAC (E87) Labels:* None
Component: Klima Zone 1 H40 0241
Coding: 5FC7F7
Coding: 02005D
9 Faults Found:
66679 - Databus
Reset counter: 131
Mileage: 30302 km
Date: 2020.11.18
Time: 19:32:05
66964 - Databus
[Right LCM: turn signal faulty]
Reset counter: 131
Mileage: 30302 km
Date: 2020.11.18
Time: 19:32:05
131349 - Databus
Reset counter: 131
Mileage: 30302 km
Date: 2020.11.18
Time: 21:50:02
Reset counter: 171
Mileage: 30302 km
Date: 2020.11.18
Time: 19:32:05
Reset counter: 171
Mileage: 30302 km
Date: 2020.11.18
Time: 19:32:05
131895 - Databus
Reset counter: 171
Mileage: 30302 km
Date: 2020.11.18
Time: 19:53:51
196751 - Databus
Fault Frequency: 18
Reset counter: 132
Mileage: 30302 km
Date: 2020.11.18
Time: 21:50:02
196755 - Databus
[Brake control module: received error value in signal ESP front right wheel speed]
Fault Frequency: 18
Reset counter: 132
Mileage: 30302 km
Date: 2020.11.18
Time: 21:50:02
196758 - Databus
[Brake control module: received error value in signal ESP system status]
Fault Frequency: 18
Reset counter: 132
Mileage: 30302 km
Date: 2020.11.18
Time: 21:50:02
Vehicle speed: 34.75 km/h
Address 15: Airbags (J234) Labels:| 8W0-959-655.clb
7 Faults Found:
Mileage: 30302 km
Date: 2020.11.18
Time: 15:28:55
9438491 - Igniter for Driver head airbag
B1005 1B [137] - Resistance Too High
Mileage: 30302 km
Date: 2020.11.18
Time: 15:28:55
9438225 - Igniter for Front passenger's Head Curtain Airbag
B1004 11 [136] - Short to Ground
Mileage: 30333 km
Date: 2020.11.19
Time: 14:35:37
9438235 - Igniter for Front passenger's Head Curtain Airbag
B1004 1B [137] - Resistance Too High
Mileage: 30302 km
Date: 2020.11.18
Time: 15:28:55
B13BC F2 [137] - No function
Fault Frequency: 8
Reset counter: 131
Mileage: 29174 km
Date: 2020.10.29
Time: 13:50:29
1055237 - Databus
[NWD: 0x11E ESP_08 error value ESP_v_ref]
Reset counter: 131
Mileage: 30302 km
Date: 2020.11.18
Time: 21:50:03
1049350 - Databus
[NWD: 0x103 ESP_03 error value ESP_VR_Radgeschw]
Reset counter: 131
Mileage: 30302 km
Date: 2020.11.18
Time: 15:28:54
4203520 - Databus
Reset counter: 131
Mileage: 30302 km
Date: 2020.11.18
Time: 15:28:53
U140B 00 [008] - -
Reset counter: 171
Mileage: 30302 km
Date: 2020.11.18
Time: 19:31:29
B2012 00 [009] - -
[Implausible dataset]
Reset counter: 131
Mileage: 30302 km
Date: 2020.11.18
Time: 15:28:52
Part No SW: 8W0 959 593 H HW: 8W0 959 593 F
Component: TSG FS 005 0129
Serial number: 0000298334459
Coding: 001F5A624100000000001482
Part No SW: 8W0 909 144 H HW: 8W0 909 144 B
Component: EPS_MLBEVO_ZF H08 0410
Coding: 09000380008000
ASAM Dataset: EV_EPSZFAU49X 003023
28160 - Databus
[KFC_ESP_03_SNA]
Reset counter: 131
Mileage: 30302 km
Date: 2020.11.18
Time: 15:28:53
17664 - Databus
[KFC_ESP_22_SNA]
Fault Frequency: 17
Reset counter: 132
Mileage: 30302 km
Date: 2020.11.18
Time: 15:28:53
Subsystem 3 - Part No SW: 3AA 962 243 H HW: 3AA 962 243 H
Component: GEB.F.Heckoef H16 0905
Serial number: >1204447
65896 - Databus
[Climatronic control module: Klima_03: no signal/communication]
Fault Frequency: 28
Reset counter: 172
Mileage: 30302 km
Date: 2020.11.18
Time: 15:39:34
Supply voltages-Supply voltage: Terminal 30: 12.881 V
Supply voltages-Supply voltage Terminal 30 - 2: 12.935 V
Supply voltages-Supply voltage Terminal 30 - 3: 12.881 V
Part No SW: 8W0 959 592 H HW: 8W0 959 592 F
Component: TSG BFS 005 0129
Serial number: 0000294308540
Coding: 001F5A224100000000001480
Part No SW: 8W5 035 039 B HW: 8W5 035 039
Component: MU-P-LN-RW 034 1177
Serial number: A801A0JB010786
Coding: 01940303FF0A000013220001001A00102F000EE401700100DE
Subsystem 1 - Part No SW: V03 959 801 PT HW: -----------
Component: ROW 2017/2018 --- 0065
Subsystem 2 - Part No SW: 8W1 919 605 HW: 8W1 919 605
Component: DU High AU49x H32 0170
Serial number: TPO00128101700820936
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 8W0 919 614 T HW: 8W0 919 614 T
Component: ControlUnit_H H30 0206
Serial number: APVAK118121700020734
Compact Disc Database:
Component: Gracenote2 --- 4012
3084 - GSM antenna 2
B1533 13 [009] - Open Circuit
Reset counter: 131
Mileage: 30302 km
Date: 2020.11.18
Time: 15:28:56
Voltage terminal 30: 13.4 V
Address 6C: Back-up Cam. (J772) Labels:* Redir Fail!
Part No SW: 4M0 980 556 A HW: 4M0 980 556 A
Component: RVC Compact H12 0250
Coding: 0294030102002001400040
Component: HDSG-Modul H13 0163
Revision: -------- Serial number: 31757109400000
Coding: 0630
ASAM Dataset: EV_DeckLidCONTIAU736 001015
Serial number: 0000302249582
Coding: 000F58220000000000001080
Component: TSG HBFS 005 0129
Serial number: 0000302249757
Reset counter: 131
Mileage: 30302 km
Date: 2020.11.18
Time: 15:28:58
End----------(Elapsed Time: 01:48, VBatt start/end: 12.1V/12.2V)-----------
friend I don't have access, but you do, you could ask someone who has an audi a5 2018 to send photos of the power station for me to copyAs said before we need the Auto-Scan to be made using the English version of VCDS - very few of us speak or understand Portuguese
I don't have an A5 either, if ou could explain what you mean by "power station" maybe someone with access to an A5 could help?friend I don't have access, but you do, you could ask someone who has an audi a5 2018 to send photos of the power station for me to copy
