Light switch and shifter illumination OFF when ignition ON
TechAm
Laval, Canada
C?ID=401793
Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: Release 20.4.2(x64) Data version: 20200730 DS317.0
Dealer/Shop Name: Parc Auto
Workshop Code: 000 00000 000000
Self-Diagnosis Log
Wednesday,18,November,2020,16:27:25:39039
VIN: 1V2LR2CAXKC570588 License Plate:
Mileage: 48km-29mi Repair Order:
Chassis Type: CA-VW41 (3Q0)
Scan: 01 02 03 05 08 09 13 15 17 19 22 2B 3C 42 44 4B 52 5F 69 6C
 6D D6 D7
VIN: 1V2LR2CAXKC570588 Mileage: 48km-29miles
D6-Light Ctrl Left 2 -- Status: Malfunction 0010
D7-Light Ctrl Right 2 -- Status: Malfunction 0010
Self-Diagnosis Log
Page 2
Address 01: Engine (J623-CDVC) Labels:. 03H-907-309-V1.clb
 Part No SW: 03H 906 026 S HW: 03H 907 309 K
 Component: VR6 3.6l FSI H21 9970
 Revision: 52H21000
 Coding: 012A001244740108F0000000000000000000000000000000
 Shop #: WSC 93382 999 00000
 ASAM Dataset: EV_ECM36FSI01103H906026S 001007
 ROD: EV_ECM36FSI01103H906026AG.rod
 VCID: 353724D405C8F153B15-8060
 CAN Converter 01:
17161 - Implausible Data Received from Comforts System 2 (BCM B)
 U0443 00 [038] - -
 Mileage: 48 km
 Date: 2020.11.17
 Time: 15:25:54
 Engine speed: 0.00 /min
 Coolant temperature: 28 °C
 Intake air temperature: 25 °C
 Voltage terminal 30: 13.860 V
 Acceleration: 0.000 m/s²
 Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7: 0
 Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7: 128
 Drivetrain coordinator: brake fault status-Bits 0-7: 0
Readiness: 0010 0101
Self-Diagnosis Log
Page 3
Address 02: Auto Trans (J217) Labels: 09G-927-749-V2.clb
 Part No SW: 09G 927 158 DR HW: 09G 927 158
 Component: AISIN AQ8 206 3536
 Coding: 0000000100000000000000000000000000000000
 Shop #: WSC 06050 062 00200
 ROD: EV_TCMAQ450031_VW37.rod
 VCID: 0655931828AEAACB68F-8052
No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb
 Part No SW: 5Q0 614 517 DT HW: 5Q0 614 517 BP
 Component: ESC H35 0108
 Revision: 00000000 Serial number: 51199000000680
 Coding: 44FC6B8D80271A6CC57C0308A2CB6922D60158A3C045967618415058D28A4A0B004023641C12141A1D8DDB45506CC8CF
 ROD: EV_Brake1UDSContiMK100IPB_038.rod
Self-Diagnosis Log
Page 4
 Part No SW: 3Q0 959 435 L HW: 3Q0 959 435 L
 Component: VWKESSYMQB 037 1204
 Revision: 00037000 Serial number: 0509802183
 Coding: 1F20000723
 ASAM Dataset: EV_KessyHellaMQBAB 004046
 ROD: EV_KessyHellaMQBAB.rod
 VCID: 43D34A0C5B1C5FE30F1-8016
65794 - Function Restricted due to Insufficient Voltage
 U1400 00 [008] - -
 [Function restriction due to temp low voltage]
 Reset counter: 55
 Mileage: 39 km
 Date: 2020.10.09
 Time: 08:48:55
 Terminal_15_Kessy_specified_value: On
 Terminal_15_Kessy_actual_value: On
 Terminal_15_central electric_actual_value: On
 Terminal_15red_Kessy_specified_value: On
 Terminal_15red_Kessy_actual_value: On
 Terminal_S_Kessy_specified_value: On
 Terminal_S_Kessy_actual_value: On
 Terminal_S_central electric_actual_value: On
 Terminal_50_Kessy_specified_value: OFF
 Terminal_50_Kessy_actual_value: OFF
 ZAT_pressed: OFF
 Request active: Condition not met
 Enabling Steering Column Lock: Condition not met
 Enabling immobilizer: Condition met
 Control Module Voltage: 8.943 V
 Vehicle speed: 0.0 km/h
 Engine speed: 153.0 /min
 Status of vehicle locking: Vehicle unlocked
Self-Diagnosis Log
Page 5
 Coding information: coded
 Driver door: closed
 Front Passenger Door: closed
 Left rear door: closed
 Right rear door: closed
 Active_LF_scans: Init
 ID sensor 1 authentication: status: No response
 ID sensor 2 authentication: status: No response
 ID sensor 3 authentication: status: No response
 ID sensor 4 authentication: status: No response
 SPN_Byte 0: 00
 SPN_Byte 1: 00
 SPN_Byte 2: 00
Self-Diagnosis Log
Page 6
Address 08: Auto HVAC (J255) Labels:* None
 Part No SW: 3CN 907 044 L HW: 3CN 907 044 L
 Component: Climatronic H04 2009
 Revision: 00001K03
 Coding: 1602000620001C011004210C4010142C
 ASAM Dataset: EV_ACClimaBHBVW416 002012
 ROD: EV_ACClimaBHBVW416.rod
 VCID: 48C95D20623A7CBBDA3-801C
 Fresh Air Blower Back:
 B10CD 00 [009] - -
 Fault Frequency: 16
 Reset counter: 17
 Mileage: 48 km
 Date: 2020.11.16
 Time: 20:03:01
 Voltage terminal 30: 13.9 V
 CAN input signal(s) status-Energy management deactivation stage: Deactivation stage 1
 CAN input signal(s) status-Back-up light: On
Self-Diagnosis Log
Page 7
 Part No SW: 5Q0 937 085 BS HW: 5Q0 937 085 BF
 Component: BCM MQBAB MNA H38 0273
 Serial number: 9097033702ÿÿÿÿ
 ROD: EV_BCMBOSCH_019.rod
 VCID: 0B43A22C33CCD7A3371-805E
 Subsystem 1 - Part No SW: 5Q0 955 555 HW: 5Q0 955 555
 Component: RLHSS 052 0122
 Serial number: S6Y19M04D12H13M09S07
 Coding: 00382D
 Steering Column Switch:
 Subsystem 2 - Part No SW: 5Q1 953 521 R HW: 5Q1 953 569 B
 Component: Lenks.Modul H23 0170
 Serial number: 0300300420190C200289
11 Faults Found:
11274 - Bulb for Center Brake Light
 B12C6 15 [008] - Open or Short to Plus
 Reset counter: 57
 Mileage: 48 km
 Date: 2020.11.17
 Time: 15:35:54
12554 - Bulb for Left Back-up Light
 B12CB 15 [008] - Open or Short to Plus
 Reset counter: 57
 Mileage: 48 km
 Date: 2020.11.17
 Time: 15:27:02
12810 - Bulb for Right Back-up Light
 B12CC 15 [008] - Open or Short to Plus
Self-Diagnosis Log
Page 8
 Reset counter: 57
 Mileage: 48 km
 Date: 2020.11.17
 Time: 15:31:33
14602 - Bulb for Left Brake Lamp / Tail Lamp
 B133A 15 [008] - Open or Short to Plus
 Reset counter: 57
 Mileage: 48 km
 Date: 2020.11.17
 Time: 14:54:02
14858 - Bulb for Right Brake Lamp / Tail Lamp
 B133C 15 [008] - Open or Short to Plus
 Reset counter: 57
 Mileage: 48 km
 Date: 2020.11.17
 Time: 15:25:52
567062 - Databus
 [LCM links - Tagfahrlicht defekt]
 Reset counter: 57
 Mileage: 48 km
 Date: 2020.11.17
 Time: 14:11:59
567318 - Databus
 [LCM rechts - Tagfahrlicht defekt]
 Reset counter: 57
Self-Diagnosis Log
Page 9
 Mileage: 48 km
 Date: 2020.11.17
 Time: 14:13:34
579350 - Databus
 [LCM links - Standlicht defekt]
 Reset counter: 57
 Mileage: 48 km
 Date: 2020.11.17
 Time: 14:11:59
579606 - Databus
 [LCM rechts - Standlicht defekt]
 Reset counter: 57
 Mileage: 48 km
 Date: 2020.11.17
 Time: 14:13:34
919560 - Light Switch
 B126A 29 [008] - Signal Implausible
 Reset counter: 57
 Mileage: 48 km
 Date: 2020.11.17
 Time: 14:23:43
13762560 - Component protection
 U1114 00 [008] - GFA key
 Reset counter: 46
 Mileage: 20 km
 Date: 2020.08.10
Self-Diagnosis Log
Page 10
 Time: 14:31:15
Self-Diagnosis Log
Page 11
Address 13: Auto Dist. Reg (J428) Labels:| 3Q0-907-572.clb
 Part No SW: 5Q0 907 572 P HW: 3QF 907 572 A
 Coding: 3200078911FFC728949C810530400600000000000000000004
 VCID: 44D149105E1258DB36B-8010
2172 - Databus
 [FAULT_BRAKINGLIGHT_FAIL]
 Reset counter: 57
 Mileage: 48 km
 Date: 2020.11.17
 Time: 15:25:55
 Control Module temperature: 48 °C
 Voltage terminal 15: 13.8 V
2068 - Databus
 [FAULT_TSK_IRREV_FAIL]
 Reset counter: 57
 Mileage: 48 km
 Date: 2020.11.17
 Time: 15:25:55
Self-Diagnosis Log
Page 12
 Part No SW: 3Q0 959 655 DB HW: 3Q0 959 655 DB
 Component: Airbag VW21 006 0720
 Revision: -------- Serial number: 00310M6YK4NR
 Coding: 8CCCDC00000000005000001A420800000065
 ROD: EV_AirbaVW21TS6VW48X.rod
 VCID: 015F800401808DF35DD-8054
 Occupant Detection:
 Component: Occ.Detection H13 0022
 Serial number: IBH0000J19000BF4DP0E
 Coding: 303030
 Subsystem 2 - Part No SW: ----------- HW: 454 002 802 19
 Serial number: 35700000000F7581993T
 Subsystem 3 - Part No SW: ----------- HW: 454 001 402 19
 Serial number: 35800000000C921DF83-
 Subsystem 4 - Part No SW: ----------- HW: 454 802 304 19
 Serial number: 35100712686180000005
 Subsystem 5 - Part No SW: ----------- HW: 454 800 305 19
 Serial number: 3520029B3AD17000000N
 Subsystem 6 - Part No SW: ----------- HW: 454 802 304 19
 Serial number: 3550096784718000000K
 Front Sensor Passenger:
 Subsystem 7 - Part No SW: ----------- HW: 454 802 304 19
 Component: FrontSensor_P 304 0149
 Serial number: 3560044744718000000A
Self-Diagnosis Log
Page 13
No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels:* None-SRI3
 Part No SW: 3CN 920 750 B HW: 3CN 920 750 B
 Component: KOMBI 350 2700
 Coding: 0BA4171DAF88880902886B0950000000A0000000
 ASAM Dataset: EV_DashBoardVDDMQBAB 009068
 VCID: 3D273CF43DF82913795-8068
13697024 - Component Protection
 U1100 00 [008] - No Basic Setting
 [Komponentenschutz keine oder falsche Grundeinstellung bzw. Adaption]
 Reset counter: 46
 Mileage: 20 km
 Date: 2020.08.10
 Time: 14:30:55
Self-Diagnosis Log
Page 14
 Part No SW: 3Q0 907 530 AA HW: 3Q0 907 530 C
 Component: GW MQB High 521 5366
 Serial number: 17041900840616
 Coding: 030500347F087300FB0322581E0F00010001070000000000000000000000
 ROD: EV_GatewNF_VW37.rod
 VCID: 6E85CBB8201E828BB0F-803A
 Component: 0-01-0e-01-04
 Subsystem 2 - Part No SW: 5G0 959 442 AB HW: 5G0 959 442 AB Labels: 3C8-959-537.CLB
 Component: E221__MFL-DC1 H17 0052
 Serial number: 33190000503600061439
 Coding: 2EFFFF
 Subsystem 3 - Part No SW: 5QA 915 181 D HW: 5QA 915 181 D
 Serial number: 4436346500
197149 - Generator
 U1052 00 [008] - No Communication
 [Generator (LIN#1) Timeout]
 Reset counter: 56
 Mileage: 44 km
 Date: 2020.10.30
 Time: 14:20:55
 Supply voltage: Terminal 30: 11.1 V
 Terminal 15: On
 Reset counter: 46
 Mileage: 20 km
 Date: 2020.08.10
 Time: 14:30:32
Self-Diagnosis Log
Page 15
 Supply voltage: Terminal 30: 12.2 V
 Terminal 15: On
8526361 - LV Energy Management
 B1802 F1 [009] - Warning Triggered
 Fault Frequency: 16
 Reset counter: 17
 Mileage: 48 km
 Date: 2020.11.17
 Time: 14:02:30
 Supply voltage: Terminal 30: 13.2 V
 Terminal 15: On
------------------------------------------------------------------------------- Address 22: AWD (J492) Labels:* 0CQ-907-554.clb
 Part No SW: 0CQ 907 554 J HW: 0CQ 525 130
 Component: Haldex4Motion H55 7084
 Serial number: HA1-00006.02.19
 Coding: 0301
 VCID: 4CC161307642909BFEB-8018
No fault code found. ------------------------------------------------------------------------------- Address 2B: Steer. Col. Lock (J764) Labels:* 5Q0-905-861.clb
 Part No SW: 3Q0 905 861 B HW: 3Q0 905 861 B
 Component: ELV-MQBB H05 0020
 Serial number: 19000004163013
 Coding: 0800000000000000
 ROD: EV_ELVMarqMQBA0_VW41.rod
 VCID: 33331ACC0BBCEF639F1-8066
Self-Diagnosis Log
Page 16
Address 3C: Lane Change (J1086) Labels:| 5Q0-907-686.clb
 Part No SW: 5Q0 907 686 C HW: 5Q0 907 686 C
 Component: HRE_Master H12 0081
 Serial number: 0510016114
 Coding: 01012103
 ROD: EV_HREntryHella_VW27.rod
 Lane Change Assistant 2:
 Subsystem 1 - Part No SW: 5Q0 907 685 C HW: 5Q0 907 685 C
 Component: HRE_Slave H12 0081
 Serial number: 0510890501
 Coding: 010121
No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb
 Part No SW: 5Q0 959 593 F HW: 5Q0 959 593 F
 Component: TSG FS001 0287
 Serial number: YA008SD3008Y3
 Coding: 00301B208000020000000000
 Subsystem 1 - Part No SW: 5Q4 959 812 G HW: 5Q4 959 812 G
 Component: Fond FHSG DRV 010 0004
 Serial number: 00000000000002199906
 Coding: 011000
No fault code found. ------------------------------------------------------------------------------- Address 44: Steering Assist (J500) Labels:* None
 Part No SW: 3QF 909 144 B HW: 3QF 909 144 A
 Component: EPS_MQB_ZFLS 570 1582
 Coding: 891F0000
 ROD: EV_SteerAssisMQB_015.rod
 VCID: 47CB5E1C6F2473C3D39-8012
Self-Diagnosis Log
Page 17
Address 4B: Multifunc. Module (J745) Labels:| 3Q0-907-338-V2.clb
 Part No SW: 3Q0 907 338 C HW: 3Q0 907 338 C
 Component: FCM MQB Low 002 0345
 Serial number: 08041900840198
 Coding: 000000070900135200010000000000000000000000000000000000000000
 ASAM Dataset: EV_MultiModulContiVW48X 002006
 ROD: EV_MultiModulContiVW48X_002_VW41.rod
13706005 - Databus
 [BCM1_LDS_Stellung received error value]
 Reset counter: 57
 Mileage: 48 km
 Date: 2020.11.17
 Time: 14:23:45
------------------------------------------------------------------------------- Address 52: Door Elect, Pass. (J387) Labels:| 5QX-959-X92-52.clb
 Part No SW: 5Q0 959 592 F HW: 5Q0 959 592 F
 Component: TSG BFS001 0287
 Serial number: YA008SCS00AVE
 Coding: 003013208000020000000000
 Subsystem 1 - Part No SW: 5Q4 959 811 G HW: 5Q4 959 811 G
 Component: Fond FHSG PSG 010 0004
 Serial number: 00000000000002210121
 Coding: 091000
Self-Diagnosis Log
Page 18
 Part No SW: 3Q0 035 844 B HW: 3Q0 035 844 B
 Component: MU-S-S-US 724 0890
 Coding: 02140600FF00000051220001001828001F0500C40120050002
 ROD: EV_MUStd4CDELP_VW37.rod
 VCID: 2E050BB8E09EC28BF0F-807A
No fault code found. ------------------------------------------------------------------------------- Address 69: Trailer (J345) Labels:| 5Q0-907-383.clb
 Part No SW: 5Q0 907 383 L HW: 5Q0 907 383 L
 Component: Anhaenger H27 0260
 Revision: 8C001004 Serial number: 0513938829
 Coding: 0200000200000000
 VCID: 40D945004A0A44FB123-8014
No fault code found. ------------------------------------------------------------------------------- Address 6C: Back-up Cam. (J772) Labels:| 5Q0-980-556.clb
 Component: RVC Compact H15 0231
 Coding: 01140602A1002017300040
 VCID: 392F28E429D0153355D-806C
Self-Diagnosis Log
Page 19
 Part No SW: 5Q0 959 107 P HW: 5Q0 959 107 J
 Component: HDSG-Modul H13 0266
 Revision: -------- Serial number: A2-C758-8680-2
 Coding: 0988
 VCID: 45D75414552861D3215-8010
0032 - Warning Buzzer for Rear Lid
 B11DF 13 [008] - Open Circuit
 Reset counter: 57
 Mileage: 48 km
 Date: 2020.11.17
 Time: 15:34:06
0040 - Motor for Rear Trunk/Hatch Closing Assistance
 B12E0 15 [008] - Open or Short to Plus
 Reset counter: 57
 Mileage: 48 km
 Date: 2020.11.17
 Time: 15:34:06
 Motors for tailgate: activation-Motor 1 for tailgate: status: OFF
 Motors for tailgate: activation-Motor 2 for tailgate: status: OFF
 Motors for tailgate: activation-Closing Assist Motor: OFF
 Motors for tailgate: activation-Luggage compartment cover motor: OFF
Self-Diagnosis Log
Page 20
Address D6: Light Ctrl Left 2 (A31) Labels: 7P5-941-591.clb
 Part No SW: 7P5 941 591 AH HW: 7P5 941 591 A
 Component: LED1L H07 0009
 ROD: EV_LED_PLUS_L_KEBODAVW416_VW37.rod
 VCID: 025D8F08048696EB447-8056
1121 - Voltage Supply for DRL
 C11B4 13 [040] - Open Circuit
 Reset counter: 11
 Mileage: 48 km
 Date: 2020.11.17
 Time: 14:11:59
------------------------------------------------------------------------------- Address D7: Light Ctrl Right 2 (A27) Labels: 7P5-941-591.clb
 Component: LED1R H07 0009
 ROD: EV_LED_PLUS_R_KEBODAVW416_VW41.rod
 Reset counter: 11
 Mileage: 48 km
 Date: 2020.11.17
 Time: 14:13:34
End----------(Elapsed Time: 01:41, VBatt start/end: 12.9V/12.9V)-----------
Hello, i,m working on Atlas 2020 and i'm looking to turn off the light switch illumination as well as the shifter lever display ( P R N DS) illumination so they work only with lights on and not with ignition on. I manage to do the push to start button but can't figure out for those two.
thanks
Hi and welcome.
I suspect the an Adaptation Channel Map from your BCM at address 09 would be useful.
Admin Note: Please do not use the [Print] function in VCDS to post data here. The formatting it produces is intended for a sheet-fed printer, but it's much harder to read here than the native text that VCDS produces. That native text can be had using the [Copy] button in VCDS, or by opening any of the .txt files in your Logs or Scans sub-folder with Notepad and then copying the data to paste here.
TechAm
Laval, Canada
C?ID=401793
Hello Uwe, thanks for the reply. Sorry for the print, the computer in the shop is pretty basic. I'm gonna try like you said with the copy and paste in notepad. As i can understand, you want me to make a channel map of (09) central electric and then what? i have already done one as back up in case i screw something up but i guess you don't want me to post de log file number? So how do i open the log and copy paste what is inside and i beleive it is going to be a big amount of information. Is it what you need?
thank you.
TBAx
C?ID=287144
You should be able to open the adpmap-09-....csv with Notepad. Then copy all text included in this file and past it here in a code block.
TechAm
Laval, Canada
C?ID=401793
;SW:5Q0-937-085-BS   HW:5Q0-937-085-BF ---  Cent. Elect.
;Component:BCM MQBAB MNA H38 0273, Coding:000000000000000000000000000000000000000000000000000000000000
;EV_BCMMQB,019001,EV_BCMBOSCH_019.rod
;Thursday,19,November,2020,08:37:19:39039
;VCDS Version: Release 20.4.2 (x64)  Data version: 20200730 DS317.0
;VCID: 0B43A22C33CCD7A3371-805E
Production mode,04FE,3,00 00 00
Transport mode,04FF,1,01
Activating and deactivating all development messages,0902,1,00
Characteristics in production mode,287A,4,14 00 00 00
Acknowledgement signals,0D0E,10,CB 03 00 14 14 00 00 00 00 00
Deactivate production mode,04FC,3,00 00 00
Rear Window Wiper,0D20,8,2E 77 35 88 00 00 00 00
static AFS light,0D1D,16,1F 02 00 50 00 80 50 78 64 C8 BE A0 00 00 00 00
Activate left/right hand drive switch-over,2D29,1,00
Window heater,0D06,11,E6 08 06 AA AA 00 06 00 60 00 00
Anti-theft device,0D07,8,00 12 18 00 00 00 00 00
Writing parameter,0D09,5,FE 00 00 00 82
Read parameter address,0D0A,3,FE 00 00
Light configuration,0D0B,224,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 36 00 1A 0B 0F 7F 00 00 00 00 00 00 00 00 00 05 40 00 1B 0C 0F 7F 00 00 00 00 00 00 00 00 00 05 3A 00 49 46 00 7F 08 09 7F 00 00 00 00 00 00 05 44 00 4A 46 00 7F 08 0A 7F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0A 38 00 22 12 16 64 00 00 00 00 00 00 00 00 00 0A 42 00 23 13 17 64 00 00 00 00 00 00 00 00 00
Seat heater level current consumption allocation,0D1E,30,01 00 48 4A 48 4A 66 68 66 68 AA AC AA AC 07 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00
Roller test bench mode: functional,04FB,1,00
Button in center console,0A29,8,07 60 00 00 00 00 00 00
A/C heater function via remote control,0D0F,8,77 00 00 00 00 00 00 00
After-run for park light,0D13,6,07 1E 00 00 00 00
Assistance light functions,0D0C,9,1E 01 00 00 00 00 00 00 00
Int. light: 2nd generation,50C4,19,02 00 02 03 01 32 32 02 32 32 32 80 FF BF 70 00 00 00 00
Interior light: light configuration,50C5,5,80 00 01 00 00
Seat fan charac. curve,50C8,17,1E 1E 1E 1E 32 32 32 32 4B 4B 50 50 02 00 00 00 00
Interior lighting: parameter,09DB,256,00 00 00 00 00 00 00 00 00 00 00 00 00 00 14 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 64 64 64 64 64 64 00 64 64 64 64 64 64 64 64 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 28 00 46 7E 7F 46 46 7E 46 46 46 7F 46 46 46 46 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 01 01 00 00 00 00 00 00 00 00 00 00 00 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Ambient light color list,0A28,30,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Keyless access and start authorization,0A9A,3,2B 00 00
Identification of sub-bus participant,0AEC,6,00 00 00 00 00 00
LIN Ambient light color list,0B3F,30,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Energy management,0D11,5,12 00 00 00 00
Light sensor,0A30,24,1E 3C 6E 64 3C 6E 00 00 00 00 00 00 00 02 00 00 00 00 00 00 00 00 00 00
Aktivierung_Entwicklungsdiagnose,0C0D,9,00 00 00 00 00 00 00 00 00
Allwetterlicht_Spoiler,0531,4,18 00 00 00
Ambience_lightning_color_list_2,0586,60,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Ambience_lightning_color_list_lin_2,0587,60,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
ambient_lighting_lin_slaves_groups,0584,30,04 64 04 64 04 64 04 64 04 64 04 64 04 64 04 64 04 64 04 64 04 64 04 64 04 64 04 64 04 64
ambient_lighting_lin_slaves_modules,0585,60,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Ambientelicht Zuordnung der Farbe zum Fahrprofil,0588,23,01 01 01 01 01 01 01 01 01 01 01 01 01 01 01 01 00 00 00 00 00 00 00
Außenlicht_Blinker,0A5E,10,3A 00 00 34 05 00 00 00 00 00
Außenlicht_Front,0A58,9,04 46 46 38 05 05 00 00 00
Aussenlicht_Heck,0A59,5,00 00 00 00 00
Außenlicht_uebergreifend,0A57,18,05 81 06 00 62 0A 00 75 0A 74 06 55 00 00 00 00 00 00
debug_light_function,0582,11,00 00 00 00 00 00 00 00 00 00 00
digital_key,12A0,3,00 00 00
Dimmunt_KL_58xs_PWM,051B,6,00 64 C8 00 64 C8
Fernlicht_assistent,0A60,6,24 10 00 00 00 00
Front_wiper,0A72,6,A3 23 03 13 00 00
Head area heater,1690,2,11 00
HW_Verbau,0A55,8,79 04 00 00 00 00 00 00
Kennlinie_sLWR_Soll,0A9C,30,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 C8 B4 A0 8C 78 64 50 3C 1E 00
Leuchte 0 BLK VL B36,0550,16,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Leuchte 35 LED Warnblinktaster C48,055F,16,29 00 00 63 4C 00 64 00 00 00 00 00 00 00 00 00
Leuchte10SHUTTER LB23,055A,16,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Leuchte11SHUTTER RB22,055B,16,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Leuchte12NL LB45,055C,16,0A 38 00 22 12 16 64 00 00 00 00 00 00 00 00 00
Leuchte13NL RB5,055D,16,0A 42 00 23 13 17 64 00 00 00 00 00 00 00 00 00
Leuchte16BLK SLB35BLK SL KC9,0560,16,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Leuchte17TFL R BLK SRB3TFL R BLK SR KC3,0561,16,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Leuchte18BLK HLA60,0562,16,0C 08 00 16 02 00 64 00 00 00 00 00 00 00 00 00
Leuchte19BLK HRC31,0563,16,0C 18 00 18 04 00 64 00 00 00 00 00 00 00 00 00
Leuchte1BLK VRB20,0551,16,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Leuchte20BR LA71,0564,16,0D 00 00 39 08 00 19 18 00 64 00 00 00 00 00 00
Leuchte21BR RC8,0565,16,0D 00 00 3A 08 00 19 18 00 64 00 00 00 00 00 00
Leuchte22BR MA57,0566,16,2A 00 00 2C 18 00 7F 00 00 00 00 00 00 00 00 00
Leuchte23SL HLC10,0567,16,09 0A 00 35 08 00 99 00 00 00 00 00 00 00 00 00
Leuchte24SL HRA65,0568,16,09 1A 00 36 08 00 99 00 00 00 00 00 00 00 00 00
Leuchte25KZL HA59,0569,16,2B 28 00 30 08 00 7F 00 00 00 00 00 00 00 00 00
Leuchte26NSL LA72,056A,16,2B 00 00 00 08 00 64 00 00 00 00 00 00 00 00 00
Leuchte27NSL RC6,056B,16,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Leuchte28RFL LC11,056C,16,09 00 00 31 19 00 64 00 00 00 00 00 00 00 00 00
Leuchte29RFL RA64,056D,16,09 00 00 32 19 00 64 00 00 00 00 00 00 00 00 00
Leuchte2SL VLB10,0552,16,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Leuchte30FR LC72,056E,16,24 00 00 02 2B 00 64 00 00 00 00 00 00 00 00 00
Leuchte31AMBL 1C61,056F,16,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Leuchte32AMBL 2C35,0570,16,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Leuchte33AMBL 3C36,0571,16,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Leuchte34AMBL 4C37,0572,16,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Leuchte3SL VRB21,0553,16,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Leuchte4TFL LB4,0554,16,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Leuchte5 TFL RB32,0555,16,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Leuchte6ABL LC5,0556,16,05 36 00 1A 0B 0F 7F 00 00 00 00 00 00 00 00 00
Leuchte7ABL RB1,0557,16,05 40 00 1B 0C 0F 7F 00 00 00 00 00 00 00 00 00
Leuchte8FL LB39,0558,16,05 3A 00 49 46 00 7F 08 09 7F 00 00 00 00 00 00
Leuchte9FL RB2,0559,16,05 44 00 4A 46 00 7F 08 0A 7F 00 00 00 00 00 00
Leuchtenkonfiguration_Aussenlich_Heck,0A62,192,0C 08 00 16 02 00 64 00 00 00 00 00 00 00 00 00 0C 18 00 18 04 00 64 00 00 00 00 00 00 00 00 00 0D 00 00 39 08 00 19 18 00 64 00 00 00 00 00 00 0D 00 00 3A 08 00 19 18 00 64 00 00 00 00 00 00 2A 00 00 2C 18 00 7F 00 00 00 00 00 00 00 00 00 09 0A 00 35 08 00 99 00 00 00 00 00 00 00 00 00 09 1A 00 36 08 00 99 00 00 00 00 00 00 00 00 00 2B 28 00 30 08 00 7F 00 00 00 00 00 00 00 00 00 2B 00 00 00 08 00 64 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 09 00 00 31 19 00 64 00 00 00 00 00 00 00 00 00 09 00 00 32 19 00 64 00 00 00 00 00 00 00 00 00
Leuchtenkonfiguration_Sonstiges,0A63,128,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 24 00 00 02 2B 00 64 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 29 00 00 63 4C 00 64 00 00 00 00 00 00 00 00 00
Leuchtweitenregulierung,0A97,62,80 00 64 00 00 00 00 00 00 00 00 28 0F 00 14 B4 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 64 00 00 00 00 0A BE 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Lichttaster,1130,7,AD 79 64 01 14 0A 00
LIN-Mirrormode,0583,1,00
LIN-SMLS_konfig_1,170D,27,04 04 04 04 04 06 04 04 00 00 05 0A 04 01 01 59 5D 61 32 82 05 32 04 01 6E 1E 00
LIN-SMLS_konfig_2,170E,2,04 02
LuB Lichtrouter Kennlinie 1,051E,12,00 0A 64 96 DC FD 00 0C 20 3C 78 C8
lwr_ofs_RSw_Ah1S,0A9D,20,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Networking,0A53,8,0F 00 00 00 00 00 00 00
OCU,0530,8,10 C8 50 14 03 00 00 00
Personalization,16F0,16,F3 04 06 00 00 00 00 00 00 00 00 00 00 00 00 00
Querschnitts_funktionen,0A56,5,40 6A 00 00 00
RLS_close_glazing,1526,1,03
RLS_lights_for_autobahn,1527,3,54 09 07
RLS_Lights_on_at_Rain,152B,2,1B 44
RLS_LIN_Communication,1529,1,02
RLS_Night_Sensitivity,152C,1,14
RLS_tunel_gateway_recognize,152A,1,3D
RLS_Washer_Front,1528,1,05
RLS_wiper_position_parking,1525,1,02
Scheinwerferreinigung,0A73,10,02 0A 00 50 C8 50 00 00 00 00
SMLS_konfig_entw,170F,48,02 0A 14 1E 32 1E 32 1E 32 00 00 02 0A 14 1E 32 02 1E 32 1E 32 0A 14 1E 32 06 32 14 00 00 00 00 00 B4 B4 55 A5 00 00 9B 55 02 00 00 14 00 00 00
Sonderfunktionen,0A61,4,04 00 00 00
Spiegelverstellung,0A6E,5,A2 00 00 00 00
Steering Column Switch,0C0C,10,01 0A 0A FA 04 00 00 00 00 00
Suchbeleuchtung_58_xs_Bus_Kennlinie,0A98,10,00 10 64 A0 C8 0C 0C 28 64 C8
Suchbeleuchtung_58xt_Bus_Kennlinie,0A99,10,00 10 64 A0 C8 0C 0C 28 64 C8
Suchbeleuchtung_Abdimmen,0512,22,00 0A 14 1E 28 32 3C 46 50 5A 64 C8 C8 BE A0 50 28 14 0A 06 02 00
Suchbeleuchtung_allgemein,0A64,21,06 14 19 04 64 00 00 00 00 00 00 1E C8 02 00 00 00 00 00 00 00
Suchbeleuchtung_Fotosensor,0513,22,00 32 64 C8 FD 00 00 00 00 00 00 00 19 32 64 FA 00 00 00 00 00 00
Suchbeleuchtung_Hochdimmen,0511,22,00 0A 14 1E 28 32 3C 46 50 5A 64 00 02 06 0A 16 2C 50 A0 BE C8 C8
Suchbeleuchtung_KL 58xs max,0515,8,00 04 19 FA C8 C8 C8 C8
Suchbeleuchtung_KL 58xs min,0514,8,00 04 19 FF 0C 0C C8 C8
Suchbeleuchtung_KL_58xd_log_Bus,051A,12,00 0C 20 3C 78 C8 0A 0A 64 96 DC FD
Suchbeleuchtung_KL_58xd_max,0519,10,00 04 64 96 FA 20 20 C8 C8 C8
Suchbeleuchtung_KL_58xd_min,0518,10,00 04 6E 96 FA 0C 0C C8 C8 C8
Suchbeleuchtung_KL_58xd_PWM,051D,12,00 0A 32 64 DC FD 04 04 0C 14 A0 C8
Suchbeleuchtung_KL_58xt min,0516,8,00 04 19 FA 0C 0C C8 C8
Suchbeleuchtung_KL_58xt_max,0517,8,00 04 19 FA C8 C8 C8 C8
Suchbeleuchtung_KL_58xt_PWM,051C,6,00 64 C8 00 64 C8
Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie,051F,12,00 02 14 64 A0 CC 00 0A 28 5A 96 FA
Suchbeleuchtung_Tasterdimmung,0510,10,00 64 96 C8 FF 02 0A 1E 50 C8
Sunroof,0A76,4,00 00 00 00
Verdecksteuergeraet,0A68,9,FE C7 04 00 00 00 00 00 00
Vernetzungs- Diagnosefunktionen,0502,20,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
ZV allgemein,0A65,7,7B 14 02 00 00 00 00
ZV Autolock,0A6A,3,0F 00 00
ZV Crash,0A6F,4,01 00 00 00
ZV Heck,0A67,7,28 0D 10 00 00 00 00
ZV Komfort,0A69,8,87 78 21 02 00 00 00 00
ZV Türkonfiguration,0A66,5,0D 00 00 00 00
;135 Lines
;Elapsed Time: 01:45
Thanks TBAx, here is the 09 adaptation log file. Hope this is the good thing.
Scratching head. ^^^ That ^^^ does not look like a channel map from an MQB BCM. There should be a a couple of thousand lines in a map.
TechAm
Laval, Canada
C?ID=401793
;Thursday,19,November,2020,12:15:16:39039
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking,Decelerate ,10
IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global,active ,10
IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln,active ,10
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn,short ,10
IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung,active ,10
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen,active ,10
IDE02269-ENG133345-Acknowledgement signals-Quittierton bei zweitem ZV-ZU-Befehl,active ,10
IDE02269-ENG142246-Acknowledgement signals-ZV-Blinken_Hellzeit,0 ms,10
IDE02711-ENG116690-Rear Window Wiper-Automatisches Heckwischen,not active ,8
IDE02711-ENG133397-Rear Window Wiper-Einzelansteuerung Heckintervallwischen,not active ,8
IDE02711-ENG133395-Rear Window Wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 1,8 s,8
IDE02711-ENG133396-Rear Window Wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 2,16 s,8
IDE02711-ENG112304-Rear Window Wiper-Heckwischer,logikgesteuert ,8
IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1,5 s,8
IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2,3 s,8
IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik,7 s,8
IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall,7 s,8
IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW,active ,8
IDE02711-ENG154784-Rear Window Wiper-Spannungsanforderung_konfig_Wischer,Keine_Spannungsanforderung ,8
IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck,active ,8
IDE02711-ENG154831-Rear Window Wiper-Zeit_wasch_min_heck,0 ms,8
IDE03638-IDE04231-static AFS light-Steering wheel angle: offset,0.3 °,16
IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit,50.0 %/s,16
IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt,both sides ,16
IDE03638-ENG116675-static AFS light-Lower speed threshold,0.0 km/h,16
IDE03638-ENG116682-static AFS light-Maximaltemperatur,100.0 °C,16
IDE03638-ENG116679-static AFS light-obere Grenztemperatur,95.0 °C,16
IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel,120 °,16
IDE03638-ENG116680-static AFS light-untere Grenztemperatur,80.0 °C,16
IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel,80 °,16
IDE03638-ENG116676-static AFS light-Upper speed threshold,40.0 km/h,16
IDE03638-ENG116674-static AFS light-Vorschrift,ECE R119 ,16
IDE03638-ENG115830-static AFS light-Zeitwert Einschaltzeit Abbiegelicht,15 min,16
IDE04927-IDE01446-Window heater-Running time of heated front window,240 s,11
IDE04927-ENG126845-Window heater-FSH Automatik,active ,11
IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert,320 s,11
IDE04927-ENG246969-Window heater-HZG_Wischer_Ablage,not installed ,11
IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH,active ,11
IDE04927-ENG246996-Window heater-WAH_Temp_Wischer_aktiv,-2.0 °C,11
IDE04928-MAS01577-Anti-theft device-Parking heater,not installed ,8
IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn,not active ,8
IDE04928-ENG115864-Anti-theft device-Alarmsignal,frequency modulated ,8
IDE04928-ENG141960-Anti-theft device-Anti-theft alarm system,active ,8
IDE04928-ENG154588-Anti-theft device-Deaktivierung DWA-Sensoren via Doppelklick,activ ,8
IDE04928-ENG154589-Anti-theft device-Deaktivierung_DWA_Sensoren_HMI,not_active ,8
IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung,not active ,8
IDE04928-ENG115812-Anti-theft device-DWA Camper Modus,not active ,8
IDE04928-ENG142007-Anti-theft device-DWA_Einfachhorn_oder_Sounder,Horn_verbaut ,8
IDE04928-ENG141961-Anti-theft device-Heckscheibenbruchsensor,not installed ,8
IDE04928-ENG142006-Anti-theft device-IRUE_NGS_Deaktivierungstaster_direkt_am BCM_verdrahtet,No ,8
IDE04928-ENG142249-Anti-theft device-OBD Alarm,not_active ,8
IDE04928-ENG154722-Anti-theft device-RHF_Panikalarm,activ ,8
IDE04928-ENG142009-Anti-theft device-Schliesszylinder in_Richtung Oeffnen_aktiv (Thatcham inaktiv),No ,8
IDE04928-ENG142010-Anti-theft device-Sensor_fuer_Innenraumueberwachung,No ,8
IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl,10 Alarme ,8
IDE04928-ENG142008-Anti-theft device-tilt_sensor,No ,8
IDE04928-ENG126842-Anti-theft device-Ueberwachung Innenentriegelungshebel,not active ,8
IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm,keine verzoegerung ,8
IDE05143-MAS02985-Writing parameter-Value,130 ,5
IDE05143-MAS04381-Writing parameter-Parameter address,FE 00 00 ,5
IDE05144-Read parameter address,FE 00 00 ,3
IDE05145-Light configuration,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 36 00 1A 0B 0F 7F 00 00 00 00 00 00 00 00 00 05 40 00 1B 0C 0F 7F 00 00 00 00 00 00 00 00 00 05 3A 00 49 46 00 7F 08 09 7F 00 00 00 00 00 00 05 44 00 4A 46 00 7F 08 0A 7F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0A 38 00 22 12 16 64 00 00 00 00 00 00 00 00 00 0A 42 00 23 13 17 64 00 00 00 00 00 00 00 00 00 ,224
IDE06089-ENG246993-Seat heater level current consumption allocation-SIH_PWM_Teiler,0 ,30
IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss,1 s,30
IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle,18.50 °C,30
IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle,18.00 °C,30
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle,18.50 °C,30
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle,18.00 °C,30
IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle,26.00 °C,30
IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle,25.50 °C,30
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle,26.00 °C,30
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle,25.50 °C,30
IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle,43.00 °C,30
IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle,42.50 °C,30
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle,43.00 °C,30
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle,42.50 °C,30
IDE06089-ENG154774-Seat heater level current consumption allocation-Sitzheizung.Aufheizphase HI,Keine_Spannungsanforderung ,30
IDE06089-ENG154785-Seat heater level current consumption allocation-Spannungsoffset SIH_75,15.7 V,30
IDE06507-MAS13132-Button in center console-Function of button 3,not coded/not installed ,8
IDE06507-MAS13135-Button in center console-Function of button 4,Steering wheel heater ,8
IDE07007-ENG142253-A/C heater function via remote control-Abbruch_d_Warnblinker_moeglich,active ,8
IDE07007-ENG142252-A/C heater function via remote control-Abbruch_Hupen_RSt,not active ,8
IDE07007-ENG142255-A/C heater function via remote control-Aktivierung_Drehzahlanzeige,active ,8
IDE07007-ENG142254-A/C heater function via remote control-Kombi_Fahrerhinweis_m_Akustik,active ,8
IDE07007-ENG128461-A/C heater function via remote control-Kombi_Fahrerhinweis_m_Uebernahme_RSt,active ,8
IDE07007-ENG115720-A/C heater function via remote control-Remote Start,installed ,8
IDE07007-ENG246992-A/C heater function via remote control-Remotestart_externe_FFB_verbaut,not installed ,8
IDE07007-ENG128460-A/C heater function via remote control-Rueckmeldung_bei_Aktivierung,active ,8
IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs,abschalten ueber Abschaltstufen des Energiemanagements oder nach der Nachlaufzeit ,6
IDE07470-ENG126843-After-run for park light-ZV verriegeln bei Klemme 15 Ein,active ,6
IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabe,not active ,9
IDE08786-ENG124476-Assistance light functions-Sunlight Sensor,installed ,9
IDE09731-ENG154511-Int. light: 2nd generation-Ambiente_Fahrprofil_Individual,7 ,19
IDE09731-ENG154512-Int. light: 2nd generation-Ambiente_Farbliste_HMI_mit_Farbtransformation,not active ,19
IDE09731-ENG154513-Int. light: 2nd generation-Ambiente_Farbwahl_FPA_waehlbare_Kopplung,not active ,19
IDE09731-ENG154514-Int. light: 2nd generation-Ambiente_Farbwahl_FPA_waehlbare_Kopplung_Status_hmi_default,not active ,19
IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit,0.10 s,19
IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1,2 ,19
IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2,3 ,19
IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3,1 ,19
IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach,50 %,19
IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe,2 ,19
IDE09731-ENG115822-Int. light: 2nd generation-Defaultwert Ambienteprofil Fussraum,50 %,19
IDE09731-ENG125027-Int. light: 2nd generation-Defaultwert Ambienteprofil Mittelkonsole,50 %,19
IDE09731-ENG116685-Int. light: 2nd generation-Defaultwert Ambienteprofil Tuer,50 %,19
IDE09731-ENG115823-Int. light: 2nd generation-Defaultwert Ambienteprofil Vorn,50 %,19
IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen,active ,19
IDE09731-ENG142233-Int. light: 2nd generation-Helligkeit_Tuertafelbeleuchtung_nicht_berechnen,active ,19
IDE09731-ENG116596-Int. light: 2nd generation-Innenlicht bei offenem Heckdeckel einschalten,active ,19
IDE09731-ENG98648-Int. light: 2nd generation-Interior light,Keine_Spannungsanforderung ,19
IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig,not active ,19
IDE09731-ENG142184-Int. light: 2nd generation-Weckfaehigkeit_klemme_30G,installed ,19
IDE09732-ENG154509-Interior light: light configuration-Ambience_light_colorlist_default,1 ,5
IDE09732-ENG133384-Interior light: light configuration-Ambient_Farbliste_HMI,not active ,5
IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafel,not installed ,5
IDE09732-ENG126836-Interior light: light configuration-Ambientemenue mit alle Zonen,not active ,5
IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus,not active ,5
IDE09732-ENG114629-Interior light: light configuration-Foot well lighting,installed ,5
IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz,30 %,17
IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz,30 %,17
IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne,50 %,17
IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz,50 %,17
IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne,50 %,17
IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz,50 %,17
IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne,75 %,17
IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz,75 %,17
IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne,80 %,17
IDE09761-ENG142183-Seat fan charac. curve-Sitzlueftung_reduzierbar,installed ,17
IDE11477-ENG128619-Interior lighting: parameter-p_adaption_kundenwunsch_dach,1.00 ,256
IDE11477-ENG128539-Interior lighting: parameter-p_adaption_kundenwunsch_fussraum,0.40 ,256
IDE11477-ENG128571-Interior lighting: parameter-p_adaption_kundenwunsch_itafel,0.00 ,256
IDE11477-ENG128523-Interior lighting: parameter-p_adaption_kundenwunsch_tuer,0.00 ,256
IDE11477-ENG128659-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI,00000000  ,256
IDE11477-ENG128660-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_2,00000000  ,256
IDE11477-ENG128656-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_2,00000000  ,256
IDE11477-ENG128628-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_dach,100 %,256
IDE11477-ENG128548-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_fussraum,70 %,256
IDE11477-ENG128580-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_itafel,0 %,256
IDE11477-ENG128532-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_tueren,0 %,256
IDE11477-ENG128625-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_dach,100 %,256
IDE11477-ENG128545-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_fussraum,70 %,256
IDE11477-ENG128577-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_itafel,0 %,256
IDE11477-ENG128529-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_tueren,0 %,256
IDE11477-ENG128627-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_dach,100 %,256
IDE11477-ENG128547-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_fussraum,70 %,256
IDE11477-ENG128579-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_itafel,0 %,256
IDE11477-ENG128531-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_tueren,0 %,256
IDE11477-ENG128624-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_dach,100 %,256
IDE11477-ENG128544-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_fussraum,70 %,256
IDE11477-ENG128576-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_itafel,0 %,256
IDE11477-ENG128528-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_tueren,0 %,256
IDE11477-ENG128629-Interior lighting: parameter-p_helligkeit_einausstieg_dach,100 %,256
IDE11477-ENG128549-Interior lighting: parameter-p_helligkeit_einausstieg_fussraum,70 %,256
IDE11477-ENG128581-Interior lighting: parameter-p_helligkeit_einausstieg_itafel,0 %,256
IDE11477-ENG128533-Interior lighting: parameter-p_helligkeit_einausstieg_tueren,0 %,256
IDE11477-ENG128620-Interior lighting: parameter-p_helligkeit_entriegelt_dach,100 %,256
IDE11477-ENG128572-Interior lighting: parameter-p_helligkeit_entriegelt_itafel,0 %,256
IDE11477-ENG128524-Interior lighting: parameter-p_helligkeit_entriegelt_tueren,0 %,256
IDE11477-ENG128634-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_dach,100 %,256
IDE11477-ENG128554-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_fussraum,70 %,256
IDE11477-ENG128586-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_itafel,0 %,256
IDE11477-ENG128538-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_tueren,0 %,256
IDE11477-ENG128630-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_dach,100 %,256
IDE11477-ENG128582-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_itafel,0 %,256
IDE11477-ENG128534-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_tueren,0 %,256
IDE11477-ENG128626-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_dach,126 %,256
IDE11477-ENG128578-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_itafel,0 %,256
IDE11477-ENG128530-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_tueren,0 %,256
IDE11477-ENG128623-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_dach,100 %,256
IDE11477-ENG128575-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_itafel,0 %,256
IDE11477-ENG128527-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_tueren,0 %,256
IDE11477-ENG128622-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_dach,100 %,256
IDE11477-ENG128542-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_fussraum,126 %,256
IDE11477-ENG128574-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_itafel,0 %,256
IDE11477-ENG128526-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_tueren,0 %,256
IDE11477-ENG128621-Interior lighting: parameter-p_helligkeit_max_dach,100 %,256
IDE11477-ENG128541-Interior lighting: parameter-p_helligkeit_max_fussraum,70 %,256
IDE11477-ENG128573-Interior lighting: parameter-p_helligkeit_max_itafel,0 %,256
IDE11477-ENG128525-Interior lighting: parameter-p_helligkeit_max_tueren,0 %,256
IDE11477-ENG128631-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_dach,100 %,256
IDE11477-ENG128551-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_fussraum,70 %,256
IDE11477-ENG128583-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_itafel,0 %,256
IDE11477-ENG128535-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_tueren,0 %,256
IDE11477-ENG128632-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_dach,100 %,256
IDE11477-ENG128552-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_fussraum,70 %,256
IDE11477-ENG128584-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_itafel,0 %,256
IDE11477-ENG128536-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_tueren,0 %,256
IDE11477-ENG128633-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_dach,100 %,256
IDE11477-ENG128553-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_fussraum,70 %,256
IDE11477-ENG128585-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_itafel,0 %,256
IDE11477-ENG128537-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_tueren,0 %,256
IDE11477-ENG128480-Interior lighting: parameter-p_t_verzoegerung_einstieg_fussraum,2.0 s,256
IDE11714-ENG126827-Ambient light color list-Blauwert Farbe 1,0 ,30
IDE11714-ENG133432-Ambient light color list-Blauwert Farbe 10,0 ,30
IDE11714-ENG126830-Ambient light color list-Blauwert Farbe 2,0 ,30
IDE11714-ENG126833-Ambient light color list-Blauwert Farbe 3,0 ,30
IDE11714-ENG133414-Ambient light color list-Blauwert Farbe 4,0 ,30
IDE11714-ENG133417-Ambient light color list-Blauwert Farbe 5,0 ,30
IDE11714-ENG133420-Ambient light color list-Blauwert Farbe 6,0 ,30
IDE11714-ENG133426-Ambient light color list-Blauwert Farbe 8,0 ,30
IDE11714-ENG126826-Ambient light color list-Gruenwert Farbe 1,0 ,30
IDE11714-ENG133431-Ambient light color list-Gruenwert Farbe 10,0 ,30
IDE11714-ENG126829-Ambient light color list-Gruenwert Farbe 2,0 ,30
IDE11714-ENG126832-Ambient light color list-Gruenwert Farbe 3,0 ,30
IDE11714-ENG133416-Ambient light color list-Gruenwert Farbe 5,0 ,30
IDE11714-ENG133419-Ambient light color list-Gruenwert Farbe 6,0 ,30
IDE11714-ENG133422-Ambient light color list-Gruenwert Farbe 7,0 ,30
IDE11714-ENG133425-Ambient light color list-Gruenwert Farbe 8,0 ,30
IDE11714-ENG133428-Ambient light color list-Gruenwert Farbe 9,0 ,30
IDE11714-ENG126825-Ambient light color list-Rotwert Farbe 1,0 ,30
IDE11714-ENG133430-Ambient light color list-Rotwert Farbe 10,0 ,30
IDE11714-ENG126828-Ambient light color list-Rotwert Farbe 2,0 ,30
IDE11714-ENG126831-Ambient light color list-Rotwert Farbe 3,0 ,30
IDE11714-ENG133412-Ambient light color list-Rotwert Farbe 4,0 ,30
IDE11714-ENG133415-Ambient light color list-Rotwert Farbe 5,0 ,30
IDE11714-ENG133418-Ambient light color list-Rotwert Farbe 6,0 ,30
IDE11714-ENG133424-Ambient light color list-Rotwert Farbe 8,0 ,30
IDE11944-ENG246971-Keyless access and start authorization-Kessy BewegungsüberwachungIDGeber,not active ,3
IDE11944-ENG116655-Keyless access and start authorization-Kessy Komfortbedienung Reichweitenbegrenzung,active ,3
IDE11944-ENG179142-Keyless access and start authorization-Kessy Protokollvariante EntryExit,not active ,3
IDE11944-ENG179143-Keyless access and start authorization-Kessy Ruhephase EntryExit,not active ,3
IDE11944-ENG116626-Keyless access and start authorization-Oeffnung Heckdeckel bei Wiederentriegelung,not active ,3
IDE12302-SFT271873-Identification of sub-bus participant-Control Unit For Wiper Motor,Not available ,6
IDE12302-SFT271874-Identification of sub-bus participant-Rain Light Recognition Sensor,Not available ,6
IDE12302-SFT271875-Identification of sub-bus participant-Light switch,Not available ,6
IDE12302-SFT271876-Identification of sub-bus participant-Garage door opener control module,Not available ,6
IDE12302-SFT271877-Identification of sub-bus participant-Garage Door Opener Operating Unit,Not available ,6
IDE12302-SFT271894-Identification of sub-bus participant-Sensor For Anti Theft Alarm System,Not available ,6
IDE12302-SFT271896-Identification of sub-bus participant-Alarm horn,Not available ,6
IDE12302-SFT271904-Identification of sub-bus participant-Sun Roof,Not available ,6
IDE12302-SFT271910-Identification of sub-bus participant-Ceiling Light Module,Not available ,6
IDE12302-SFT271928-Identification of sub-bus participant-Roof Blind,Not available ,6
IDE12302-SFT271947-Identification of sub-bus participant-Relative Air Humidity Interior Sender,Not available ,6
IDE12302-SFT271966-Identification of sub-bus participant-Neck Heating Left,Not available ,6
IDE12302-SFT271967-Identification of sub-bus participant-Neck Heating Right,Not available ,6
IDE12302-SFT272065-Identification of sub-bus participant-Seat Backrest Fan 1 Front Left,Not available ,6
IDE12302-SFT272067-Identification of sub-bus participant-Seat Cushion Fan 1 Front Left,Not available ,6
IDE12302-SFT272069-Identification of sub-bus participant-Seat Backrest Fan 1 Front Right,Not available ,6
IDE12302-SFT272071-Identification of sub-bus participant-Seat Cushion Fan 1 Front Right,Not available ,6
IDE12302-ENG246961-Identification of sub-bus participant-Remote_Control,Not available ,6
IDE12302-ENG246960-Identification of sub-bus participant-steering_column_switch,Not available ,6
IDE12412-ENG154557-LIN Ambient light color list-Blauwert_Farbe_3_lin,0 ,30
IDE12412-ENG154560-LIN Ambient light color list-Blauwert_Farbe_4_lin,0 ,30
IDE12412-ENG154561-LIN Ambient light color list-Blauwert_Farbe_5_lin,0 ,30
IDE12412-ENG154562-LIN Ambient light color list-Blauwert_Farbe_6_lin,0 ,30
IDE12412-ENG154656-LIN Ambient light color list-Gruenwert_Farbe_2_lin,0 ,30
IDE12412-ENG154676-LIN Ambient light color list-Gruenwert_Farbe_3_lin,0 ,30
IDE12412-ENG154679-LIN Ambient light color list-Gruenwert_Farbe_4_lin,0 ,30
IDE12412-ENG154680-LIN Ambient light color list-Gruenwert_Farbe_5_lin,0 ,30
IDE12412-ENG154681-LIN Ambient light color list-Gruenwert_Farbe_6_lin,0 ,30
IDE12412-ENG154682-LIN Ambient light color list-Gruenwert_Farbe_7_lin,0 ,30
IDE12412-ENG154683-LIN Ambient light color list-Gruenwert_Farbe_8_lin,0 ,30
IDE12412-ENG154733-LIN Ambient light color list-Rotwert_Farbe_1_lin,0 ,30
IDE12412-ENG154744-LIN Ambient light color list-Rotwert_Farbe_2_lin,0 ,30
IDE12412-ENG154767-LIN Ambient light color list-Rotwert_Farbe_4_lin,0 ,30
IDE12412-ENG154768-LIN Ambient light color list-Rotwert_Farbe_5_lin,0 ,30
IDE12412-ENG154769-LIN Ambient light color list-Rotwert_Farbe_6_lin,0 ,30
IDE12412-ENG154771-LIN Ambient light color list-Rotwert_Farbe_8_lin,0 ,30
MAS08228-ENG133444-Light sensor-ECE_Lichteinschaltschwelle,0 lx,24
MAS08228-ENG133445-Light sensor-Helligkeitsgrenze_Licht_ausschalten_red,00 00 ,24
MAS08228-ENG133436-Light sensor-Helligkeitsgrenze_sehr_hell,2000 lx,24
MAS08228-ENG133442-Light sensor-Maximale_Ausgangsspannung,0 mV,24
MAS08228-ENG133440-Light sensor-Maximale_Beleuchtungsstaerke,0 lx,24
MAS08228-ENG133441-Light sensor-Minimale_Ausgangsspannung,0 mV,24
ENG141683-ENG116672-Allwetterlicht_Spoiler-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren,active ,4
ENG141683-ENG116671-Allwetterlicht_Spoiler-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT,active ,4
ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1,00 ,60
ENG153712-ENG154510-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Ambiente,Keine_Spannungsanforderung ,23
ENG153712-ENG154603-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_1,1 ,23
ENG153712-ENG154604-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_10,1 ,23
ENG153712-ENG154611-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_3,1 ,23
ENG153712-ENG154612-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_4,1 ,23
ENG153712-ENG154613-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_5,1 ,23
ENG141649-ENG122211-Außenlicht_Blinker-Richtungs_blinken_links,not active ,10
ENG141649-ENG122210-Außenlicht_Blinker-Richtungs_blinken_rechts,not active ,10
ENG141649-ENG246997-Außenlicht_Blinker-Warnblinken_TP_max,120 min,10
ENG141649-ENG122214-Außenlicht_Blinker-Warnblinken_Zuendung_AUS,not active ,10
ENG141649-ENG122213-Außenlicht_Blinker-Warnblinken_Zuendung_EIN,not active ,10
ENG141647-ENG246962-Außenlicht_Front-ABL Redundanz Check sperren,not active ,9
ENG141647-ENG122184-Außenlicht_Front-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten,active ,9
ENG141647-ENG115734-Außenlicht_Front-Tagfahrlicht nur in Schalterstellung AUTO,active ,9
ENG141647-ENG115860-Außenlicht_Front-Zahl der aktiven Scheinwerfer auf 2 limitieren,limitieren ,9
ENG141648-ENG115782-Aussenlicht_Heck-Nebelschlusslicht Warngeschwindigkeit,0 km/h,5
ENG141648-ENG116636-Aussenlicht_Heck-Notbremsanzeige NBA,not active ,5
ENG141656-ENG142020-Außenlicht_uebergreifend-All-weather lights,not installed ,18
ENG141656-ENG133381-Außenlicht_uebergreifend-Bedingungen zur Parklichtbegrenzung,begrenzen auf Mindestverfügbarkeit ,18
ENG141656-ENG133380-Außenlicht_uebergreifend-Bedingungen zur Standlichtbegrenzung,begrenzen auf Mindestverfügbarkeit ,18
ENG141656-ENG246968-Außenlicht_uebergreifend-CHo_LHo_Nachlauf,0 ms,18
ENG141656-ENG130581-Außenlicht_uebergreifend-Fahrlicht_Hinweis_mehrfach,not active ,18
ENG141656-ENG126818-Außenlicht_uebergreifend-Fahrlichtwarnung_Hinweis_Konfig,kein_Hinweis ,18
ENG141656-ENG154619-Außenlicht_uebergreifend-Fernlicht_LH,Sollspannungsanforderung 13.5 ,18
ENG141656-ENG154177-Außenlicht_uebergreifend-Fog light,Sollspannungsanforderung 13.5 ,18
ENG141656-ENG116608-Außenlicht_uebergreifend-Helligkeitsschwelle Forward-Messung,46400 lx,18
ENG141656-ENG141991-Außenlicht_uebergreifend-LDS_mit_Nebel_Schlusslicht,No ,18
ENG141656-ENG98354-Außenlicht_uebergreifend-Low beam,Sollspannungsanforderung 13.5 ,18
ENG141656-ENG116603-Außenlicht_uebergreifend-Menueeinstellung Cominghome,10 seconds ,18
ENG141656-ENG116607-Außenlicht_uebergreifend-Menueeinstellung Leaving-home Zeit per BAP,10 seconds ,18
ENG141656-ENG115859-Außenlicht_uebergreifend-Parklicht ueber LSS aktiviert,not active ,18
ENG141656-ENG115829-Außenlicht_uebergreifend-Standlichtreduzierung mit beidseitigem Parklicht,not active ,18
ENG141656-ENG133383-Außenlicht_uebergreifend-Standlicht-Verfügbarkeit,6 s,18
ENG141656-ENG154174-Außenlicht_uebergreifend-Turn signal,Sollspannungsanforderung 13.5 ,18
ENG246955-ENG246967-digital_key-central_locking_digital_key_general,not installed ,3
ENG246955-ENG246972-digital_key-komfortbedienung_fh_oeffnen_ueber_btle,not active ,3
ENG246955-ENG246973-digital_key-komfortbedienung_fh_oeffnen_ueber_btle_sonderfunktion,not active ,3
ENG246955-ENG246974-digital_key-komfortbedienung_fh_oeffnen_ueber_nfc_fahrertuer,not active ,3
ENG246955-ENG246975-digital_key-komfortbedienung_fh_schliessen_ueber_btle,not active ,3
ENG246955-ENG246976-digital_key-komfortbedienung_fh_schliessen_ueber_btle_sonderfunktion,not active ,3
ENG246955-ENG246977-digital_key-komfortbedienung_fh_schliessen_ueber_nfc_fahrertuer,not active ,3
ENG141650-ENG141973-Fernlicht_assistent-Erweiterte_Fernlichtsteuerung,AFS: Fernlicht ueber AFS ,6
ENG141650-ENG116639-Fernlicht_assistent-Fernlichtassistent Reset,not active ,6
ENG141650-ENG116637-Fernlicht_assistent-Menuesteuerung Fernlichtassistent,Not Present ,6
ENG141682-ENG154620-Front_wiper-Frontwischer Spannungsanforderung_konfig,Sollspannungsanforderung 13.5 ,6
ENG141682-ENG141966-Front_wiper-Frontwischertyp,Direct ,6
ENG141682-ENG115770-Front_wiper-Variable Regensensoraktivierung,not active ,6
ENG141660-ENG115658-Kennlinie_sLWR_Soll-x0,-100.00 %,30
ENG141660-ENG101574-Kennlinie_sLWR_Soll-X1,-100.00 %,30
ENG141660-ENG99557-Kennlinie_sLWR_Soll-X2,-100.00 %,30
ENG141660-ENG102140-Kennlinie_sLWR_Soll-X3,-100.00 %,30
ENG141660-ENG102936-Kennlinie_sLWR_Soll-X4,-100.00 %,30
ENG141660-ENG103548-Kennlinie_sLWR_Soll-X5,-100.00 %,30
ENG141660-ENG113992-Kennlinie_sLWR_Soll-X6,-100.00 %,30
ENG141660-ENG115661-Kennlinie_sLWR_Soll-x7,-100.00 ,30
ENG141660-ENG115662-Kennlinie_sLWR_Soll-x8,-100.00 %,30
ENG141660-ENG115663-Kennlinie_sLWR_Soll-x9,-100.00 %,30
ENG141660-ENG115659-Kennlinie_sLWR_Soll-y0,100.0 %,30
ENG141660-ENG99777-Kennlinie_sLWR_Soll-Y1,90.0 %,30
ENG141660-ENG100480-Kennlinie_sLWR_Soll-Y2,80.0 %,30
ENG141660-ENG100773-Kennlinie_sLWR_Soll-Y3,70.0 %,30
ENG141660-ENG100631-Kennlinie_sLWR_Soll-Y4,60.0 %,30
ENG141660-ENG102174-Kennlinie_sLWR_Soll-Y5,50.0 %,30
ENG141660-ENG113993-Kennlinie_sLWR_Soll-Y6,40.0 %,30
ENG141660-ENG115665-Kennlinie_sLWR_Soll-y7,30.0 %,30
ENG141660-ENG115666-Kennlinie_sLWR_Soll-y8,15.0 %,30
ENG141660-ENG115667-Kennlinie_sLWR_Soll-y9,0.0 %,30
ENG141657-ENG116159-Leuchte 35 LED Warnblinktaster C48-Fehlerort mittleres Byte DTC-DFCC 15,63 ,16
ENG141657-ENG116160-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion A 15,Warnblinktaster_Suchbeleuchtung ,16
ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12,10 - allgemeine Scheinwerfer ,16
ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12,Abbiegelicht links ,16
ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13,10 - allgemeine Scheinwerfer ,16
ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13,Abbiegelicht rechts ,16
ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16,0 ,16
ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16,00 ,16
ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16,00 ,16
ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16,not active ,16
ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16,not active ,16
ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17,0 ,16
ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17,00 ,16
ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17,00 ,16
ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17,not active ,16
ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17,not active ,16
ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18,100 ,16
ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18,12 - Blinkleuchten ,16
ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19,100 ,16
ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19,12 - Blinkleuchten ,16
ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1,0 ,16
ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1,00 ,16
ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1,not active ,16
ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1,not active ,16
ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20,25 ,16
ENG116956-ENG116261-Leuchte20BR LA71-Dimmwert CD 20,100 ,16
ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20,39 ,16
ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20,00 ,16
ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20,13 - Bremsleuchten ,16
ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20,Brake light ,16
ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21,25 ,16
ENG116957-ENG116280-Leuchte21BR RC8-Dimmwert CD 21,100 ,16
ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21,3A ,16
ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21,00 ,16
ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21,13 - Bremsleuchten ,16
ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21,Brake light ,16
ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22,127 ,16
ENG116958-ENG116574-Leuchte22BR MA57-Lampendefektbitposition 22,00 ,16
ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23,25 ,16
ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23,0 ,16
ENG116959-ENG116311-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 23,35 ,16
ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23,9 - allgemeine Glühlampe 27W: auch H15 ,16
ENG116959-ENG116315-Leuchte23SL HLC10-Lichtansteuerung HD AB 23,only_if_closed ,16
ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23,not active ,16
ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23,not active ,16
ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24,25 ,16
ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24,0 ,16
ENG116960-ENG116330-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 24,36 ,16
ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24,9 - allgemeine Glühlampe 27W: auch H15 ,16
ENG116960-ENG116334-Leuchte24SL HRA65-Lichtansteuerung HD AB 24,only_if_closed ,16
ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24,not active ,16
ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24,not active ,16
ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26,100 ,16
ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26,00 ,16
ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26,00 ,16
ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26,43 - allgemeine LED ,16
ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27,0 ,16
ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27,00 ,16
ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27,00 ,16
ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27,not active ,16
ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27,not active ,16
ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28,100 ,16
ENG116964-ENG116580-Leuchte28RFL LC11-Lampendefektbitposition 28,00 ,16
ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28,9 - allgemeine Glühlampe 27W: auch H15 ,16
ENG116965-ENG116581-Leuchte29RFL RA64-Lampendefektbitposition 29,00 ,16
ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29,9 - allgemeine Glühlampe 27W: auch H15 ,16
ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2,0 ,16
ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2,not active ,16
ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2,not active ,16
ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30,36 - LED Kleinleistung ,16
ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3,0 ,16
ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3,not active ,16
ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3,not active ,16
ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4,0 ,16
ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4,not active ,16
ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4,not active ,16
ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5,0 ,16
ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5,not active ,16
ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5,not active ,16
ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6,0 ,16
ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6,Lichthupe generell ,16
ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6,not active ,16
ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7,0 ,16
ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7,Lichthupe generell ,16
ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7,not active ,16
ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8,49 ,16
ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8,3A ,16
ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8,5 - LED Abblendlicht ,16
ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9,4A ,16
ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9,44 ,16
ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9,5 - LED Abblendlicht ,16
ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9,Parking light right ,16
ENG141661-Leuchtenkonfiguration_Aussenlich_Heck,0C 08 00 16 02 00 64 00 00 00 00 00 00 00 00 00 0C 18 00 18 04 00 64 00 00 00 00 00 00 00 00 00 0D 00 00 39 08 00 19 18 00 64 00 00 00 00 00 00 0D 00 00 3A 08 00 19 18 00 64 00 00 00 00 00 00 2A 00 00 2C 18 00 7F 00 00 00 00 00 00 00 00 00 09 0A 00 35 08 00 99 00 00 00 00 00 00 00 00 00 09 1A 00 36 08 00 99 00 00 00 00 00 00 00 00 00 2B 28 00 30 08 00 7F 00 00 00 00 00 00 00 00 00 2B 00 00 00 08 00 64 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 09 00 00 31 19 00 64 00 00 00 00 00 00 00 00 00 09 00 00 32 19 00 64 00 00 00 00 00 00 00 00 00 ,192
ENG141662-Leuchtenkonfiguration_Sonstiges,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 24 00 00 02 2B 00 64 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 29 00 00 63 4C 00 64 00 00 00 00 00 00 00 00 00 ,128
ENG141658-ENG142219-Leuchtweitenregulierung-Achsabstand_des_Fahrzeuges,0 mm,62
ENG141658-ENG142211-Leuchtweitenregulierung-Ansteuerung_obere_grenze,90.0 %,62
ENG141658-ENG142210-Leuchtweitenregulierung-Ansteuerung_untere_grenze,10.0 %,62
ENG141658-ENG154591-Leuchtweitenregulierung-Delay_DC_Motor_Versorgung,-127.0 ms,62
ENG141658-ENG142214-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_1,-8.00 mm/%,62
ENG141658-ENG142216-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_2,-8.00 mm/%,62
ENG141658-ENG154599-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_3,-8.00 mm/%,62
ENG141658-ENG142213-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_1,-8.00 mm/%,62
ENG141658-ENG142215-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_2,-8.00 mm/%,62
ENG141658-ENG154600-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_3,-8.00 mm/%,62
ENG141658-ENG142204-Leuchtweitenregulierung-Fail_Safe_sLWR,0.0 %,62
ENG141658-ENG142223-Leuchtweitenregulierung-fFiltEinf,0.00 Hz,62
ENG141658-ENG142212-Leuchtweitenregulierung-Lineare_Abbildung,normal ,62
ENG141658-ENG142220-Leuchtweitenregulierung-lwr_lFzg_Sw_Abstand,0 mm,62
ENG141658-ENG142221-Leuchtweitenregulierung-lwr_lFzg_Sw_Hoehe,0 mm,62
ENG141658-ENG142227-Leuchtweitenregulierung-max_v_slwr,0 km/h,62
ENG141658-ENG142224-Leuchtweitenregulierung-pa_fFiltSwNeigung,0.00 Hz,62
ENG141658-ENG142042-Leuchtweitenregulierung-sensor_headlight_range_control_installed,not installed ,62
ENG141658-ENG142199-Leuchtweitenregulierung-sLWR_bei_Abblendlicht,active ,62
ENG141658-ENG142208-Leuchtweitenregulierung-sLWR_Hysterese,20.0 %,62
ENG141658-ENG142207-Leuchtweitenregulierung-sLWR_SW_Grad,0.0 %/s,62
ENG141658-ENG142206-Leuchtweitenregulierung-sLWR_Touristenlicht,-100.0 %,62
ENG246957-ENG246963-Lichttaster-Anzeigezeit_LTM_PopUp1,2.0 s,7
ENG246957-ENG246964-Lichttaster-Anzeigezeit_LTM_PopUp1_lang,10 s,7
ENG246957-ENG246965-Lichttaster-Beleuchtung_Auto_LED_bei_Nebelfunktion,active ,7
ENG246957-ENG246966-Lichttaster-Beleuchtung_LTM_Auto_LED_58xt_logik,active ,7
ENG246957-ENG246978-Lichttaster-Licht_anforderung_FAS,Nicht_verbaut ,7
ENG246957-ENG246979-Lichttaster-Licht_anforderung_Pilopark,not active ,7
ENG246957-ENG246980-Lichttaster-Licht_Reaktivierungs_grenze,100 m,7
ENG246957-ENG246981-Lichttaster-Lichttastermodul,lds ,7
ENG246957-ENG246982-Lichttaster-LTM_Anzeige_Config,00000001  ,7
ENG246957-ENG246983-Lichttaster-LTM_Beleuchtung_Geschwindigkeits_Schwelle,30 km/h,7
ENG246957-ENG246984-Lichttaster-LTM_BGL_Geschwindigkeitsabhängig,not active ,7
ENG246957-ENG246985-Lichttaster-LTM_BGL_Geschwindigkeitsabhängig_Parameter,active ,7
ENG246957-ENG246986-Lichttaster-LTM_BGL_Wegabhängig,active ,7
ENG246957-ENG246987-Lichttaster-LTM_GlobalOFF_Geschwindigkeitsabhängig,not active ,7
ENG246957-ENG246988-Lichttaster-LTM_GlobalOFF_Geschwindigkeitsabhängig_Parameter,active ,7
ENG246957-ENG246989-Lichttaster-LTM_GlobalOFF_Wegabhängig,active ,7
ENG246957-ENG246990-Lichttaster-LTM_GlobalOFF_Zündungsabhängig,not active ,7
ENG153727-ENG154566-LIN-SMLS_konfig_1-blinker_entprellen,40 ms,27
ENG153727-ENG154578-LIN-SMLS_konfig_1-blinker_gra_entprellen,40 ms,27
ENG153727-ENG154579-LIN-SMLS_konfig_1-blinker_sperrzeit,100 ms,27
ENG153727-ENG154597-LIN-SMLS_konfig_1-erkennung_fahrt,10 ms,27
ENG153727-ENG154618-LIN-SMLS_konfig_1-fas_entprellen,40 ms,27
ENG153727-ENG154624-LIN-SMLS_konfig_1-grahebel_entprellen,40 ms,27
ENG153727-ENG154634-LIN-SMLS_konfig_1-grenze_v,1 km/h,27
ENG153727-ENG154686-LIN-SMLS_konfig_1-hupe_entprellen,40 ms,27
ENG153727-ENG154690-LIN-SMLS_konfig_1-hupe_indien_entprellen,500 ms,27
ENG153727-ENG154692-LIN-SMLS_konfig_1-k_i,0.50 ,27
ENG153727-ENG154693-LIN-SMLS_konfig_1-k_i_offset,5 °C,27
ENG153727-ENG154694-LIN-SMLS_konfig_1-k_p,13.0 %,27
ENG153727-ENG154695-LIN-SMLS_konfig_1-leistung_lrh,110 W,27
ENG153727-ENG154699-LIN-SMLS_konfig_1-lrh_entprellen,40 ms,27
ENG153727-ENG154713-LIN-SMLS_konfig_1-pwm_lrh,25 Hz,27
ENG153727-ENG154773-LIN-SMLS_konfig_1-s_NWDF_spg,0 ,27
ENG153727-ENG154777-LIN-SMLS_konfig_1-soll_0,39 °C,27
ENG153727-ENG154778-LIN-SMLS_konfig_1-soll_1,43 °C,27
ENG153727-ENG154779-LIN-SMLS_konfig_1-soll_2,47 °C,27
ENG153727-ENG154786-LIN-SMLS_konfig_1-speedlimiter_entprellen,40 ms,27
ENG153727-ENG154788-LIN-SMLS_konfig_1-temlenkradheizung_aus,50 °C,27
ENG153727-ENG154804-LIN-SMLS_konfig_1-verriegelt_entprellen,0 ms,27
ENG153727-ENG246995-LIN-SMLS_konfig_1-w_zss_direktansteuerung,0 ms,27
ENG153727-ENG154811-LIN-SMLS_konfig_1-wischer_entprellen,40 ms,27
ENG153727-ENG154823-LIN-SMLS_konfig_1-wischer_intervall_entprellen,40 ms,27
ENG153727-ENG154824-LIN-SMLS_konfig_1-wischer_winterstellung,60 s,27
ENG153727-ENG154830-LIN-SMLS_konfig_1-zeit_temperatur_statisch_lrh,30 s,27
ENG153728-IDE00329-LIN-SMLS_konfig_2-Buttons for multi-function display,not installed ,2
ENG153728-IDE02694-LIN-SMLS_konfig_2-Signal horn activation,Always ,2
ENG153728-IDE02711-LIN-SMLS_konfig_2-Rear Window Wiper,installed ,2
ENG153728-IDE02745-LIN-SMLS_konfig_2-Ignition key removal lock,not installed ,2
ENG153728-MAS00128-LIN-SMLS_konfig_2-Distance Regulation,not installed ,2
ENG153728-MAS00242-LIN-SMLS_konfig_2-Driver assistance systems button,not installed ,2
ENG153728-MAS05091-LIN-SMLS_konfig_2-CCS Switch,not installed ,2
ENG153728-MAS06090-LIN-SMLS_konfig_2-CCS on turn signal switch,not installed ,2
ENG153728-MAS06091-LIN-SMLS_konfig_2-Contact bounce suppression for signal horn,not active ,2
ENG153728-MAS08540-LIN-SMLS_konfig_2-reading P locked,not active ,2
ENG153728-ENG154465-LIN-SMLS_konfig_2-diagnosis limitation,not active ,2
ENG153728-ENG154623-LIN-SMLS_konfig_2-gra_grahebel_2_st,installed ,2
ENG153728-ENG154461-LIN-SMLS_konfig_2-speed_limiter_button,not installed ,2
ENG141659-ENG115658-lwr_ofs_RSw_Ah1S-x0,-5.00 %,20
ENG141659-ENG101574-lwr_ofs_RSw_Ah1S-X1,-5.00 %,20
ENG141659-ENG99557-lwr_ofs_RSw_Ah1S-X2,-5.00 %,20
ENG141659-ENG102140-lwr_ofs_RSw_Ah1S-X3,-5.00 %,20
ENG141659-ENG102936-lwr_ofs_RSw_Ah1S-X4,-5.00 %,20
ENG141659-ENG115659-lwr_ofs_RSw_Ah1S-y0,-5.00 ,20
ENG141659-ENG99777-lwr_ofs_RSw_Ah1S-Y1,-5.00 ,20
ENG141659-ENG100480-lwr_ofs_RSw_Ah1S-Y2,-5.00 ,20
ENG141659-ENG100773-lwr_ofs_RSw_Ah1S-Y3,-5.00 ,20
ENG141659-ENG100631-lwr_ofs_RSw_Ah1S-Y4,-5.00 ,20
ENG122979-ENG141968-Networking-Anhaengeranschlussgeraet,installed ,8
ENG124714-ENG142260-OCU-Honk DWA_Ausgabe_Fanfare,active ,8
ENG124714-ENG246970-OCU-IAA -Nutzer_management,not installed ,8
ENG98831-ENG126849-Personalization-Aktivierungsoption_im_HMI-Menue_sichtbar,active ,16
ENG98831-ENG133401-Personalization-Anzahl_Benutzerkonten,4 ,16
ENG98831-ENG126850-Personalization-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar,active ,16
ENG98831-ENG126848-Personalization-Personalisierung_aktiv,active ,16
ENG98831-ENG141994-Personalization-Personalisierung_Profilfunkion,profiles_active ,16
ENG98831-ENG126851-Personalization-Personalisierungsfunktionen_in_HMI-Menue_sichtbar,active ,16
ENG98831-ENG142030-Personalization-Profil_Variante,Konto (v. 1.x) ,16
ENG98831-ENG133404-Personalization-PSO_FSG_Setup2_Bit_1,active ,16
ENG98831-ENG133405-Personalization-PSO_FSG_Setup2_Bit_2,active ,16
ENG141646-MAS01065-Querschnitts_funktionen-Brand,VW ,5
ENG141646-ENG154685-Querschnitts_funktionen-Hupe,Sollspannungsanforderung 13.5 ,5
ENG122932-ENG123007-RLS_Night_Sensitivity-p_lx_rs_dawn,200 lx,1
ENG122932-ENG123006-RLS_Night_Sensitivity-p_lx_rs_day,500 lx,1
ENG115729-ENG116609-Scheinwerferreinigung-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung,10 ,10
ENG115729-ENG141949-Scheinwerferreinigung-Headlamp washer system,not installed ,10
ENG115729-ENG115769-Scheinwerferreinigung-SRA bei Waschwassermangel,active ,10
ENG115729-ENG115767-Scheinwerferreinigung-SRA Einweichpausenzeit,2000 ms,10
ENG115729-ENG115768-Scheinwerferreinigung-SRA Nachwaschzeit,800 ms,10
ENG115729-ENG115766-Scheinwerferreinigung-SRA Waschzeit,800 ms,10
ENG153742-ENG154567-SMLS_konfig_entw-blinker_err_el_kurzschluss,200 ms,48
ENG153742-ENG154568-SMLS_konfig_entw-blinker_err_el_unterbrechung,1000 ms,48
ENG153742-ENG154569-SMLS_konfig_entw-blinker_err_fernlicht_haengt_aus,5000 ms,48
ENG153742-ENG154570-SMLS_konfig_entw-blinker_err_fernlicht_haengt_ein,300 s,48
ENG153742-ENG154571-SMLS_konfig_entw-blinker_err_gra_haengt_aus,5000 ms,48
ENG153742-ENG154572-SMLS_konfig_entw-blinker_err_gra_haengt_ein,300 s,48
ENG153742-ENG154573-SMLS_konfig_entw-blinker_err_lichthupe_haengt_aus,5000 ms,48
ENG153742-ENG154574-SMLS_konfig_entw-blinker_err_lichthupe_haengt_ein,300 s,48
ENG153742-ENG154575-SMLS_konfig_entw-blinker_err_unplausibel,200 ms,48
ENG153742-ENG154576-SMLS_konfig_entw-blinker_err_weckkontakthaengt_aus,0 ms,48
ENG153742-ENG154577-SMLS_konfig_entw-blinker_err_weckkontakthaengt_ein,0 ms,48
ENG153742-ENG154594-SMLS_konfig_entw-entprellung_unplausibel,0 ms,48
ENG153742-ENG154595-SMLS_konfig_entw-entprellzeit_ueberspannung,90000 ms,48
ENG153742-ENG154596-SMLS_konfig_entw-entprellzeit_unterspannung,90000 ms,48
ENG153742-ENG154622-SMLS_konfig_entw-gra_ea_error,200 ms,48
ENG153742-ENG154625-SMLS_konfig_entw-grahebel_err_el_kurzschluss,200 ms,48
ENG153742-ENG154626-SMLS_konfig_entw-grahebel_err_el_unterbrechung,1000 ms,48
ENG153742-ENG154627-SMLS_konfig_entw-grahebel_err_gra_haengt_aus,5000 ms,48
ENG153742-ENG154628-SMLS_konfig_entw-grahebel_err_gra_haengt_ein,300 s,48
ENG153742-ENG154629-SMLS_konfig_entw-grahebel_err_unplausibel,200 ms,48
ENG153742-ENG154687-SMLS_konfig_entw-hupe_err_hinweis,2000 ms,48
ENG153742-ENG154688-SMLS_konfig_entw-hupe_err_hupe_haengt_aus,5000 ms,48
ENG153742-ENG154689-SMLS_konfig_entw-hupe_err_hupe_haengt_ein,60 s,48
ENG153742-ENG154700-SMLS_konfig_entw-lrh_kurzschluss_entprellen,20 ms,48
ENG153742-ENG154701-SMLS_konfig_entw-lrh_unterbrechung_entprellen,0 ms,48
ENG153742-ENG154701-SMLS_konfig_entw-lrh_unterbrechung_entprellen,0 s,48
ENG153742-ENG154707-SMLS_konfig_entw-n_fehler_verriegelt,0 ,48
ENG153742-ENG154780-SMLS_konfig_entw-spannung_obere_schwelle,16.5 V,48
ENG153742-ENG154781-SMLS_konfig_entw-spannung_obere_schwelle_funkt_einschr,15.5 V,48
ENG153742-ENG154782-SMLS_konfig_entw-spannung_untere_schwelle,8.5 V,48
ENG153742-ENG154783-SMLS_konfig_entw-spannung_untere_schwelle_funkt_einschr,8.5 V,48
ENG153742-ENG154805-SMLS_konfig_entw-verriegelt_err_el_kurzschluss,0 ms,48
ENG153742-ENG154806-SMLS_konfig_entw-verriegelt_err_unplausibel_aus,0 ms,48
ENG153742-ENG154807-SMLS_konfig_entw-verriegelt_err_unplausibel_ein,0 ms,48
ENG153742-ENG154808-SMLS_konfig_entw-verriegelt_err_unplausibel_in_parkposition_aus,0 ms,48
ENG153742-ENG154809-SMLS_konfig_entw-verriegelt_err_unplausibel_in_parkposition_ein,0 s,48
ENG153742-ENG154812-SMLS_konfig_entw-wischer_err_el_kurzschluss,200 ms,48
ENG153742-ENG154813-SMLS_konfig_entw-wischer_err_el_unterbrechung,1000 ms,48
ENG153742-ENG154814-SMLS_konfig_entw-wischer_err_intervallpoti_haengt_aus,0.0 s,48
ENG153742-ENG154815-SMLS_konfig_entw-wischer_err_intervallpoti_haengt_ein,0 s,48
ENG153742-ENG154816-SMLS_konfig_entw-wischer_err_mfa_haengt_aus,5000 ms,48
ENG153742-ENG154817-SMLS_konfig_entw-wischer_err_mfa_haengt_ein,300 s,48
ENG153742-ENG154818-SMLS_konfig_entw-wischer_err_unplausibel,200 ms,48
ENG153742-ENG154819-SMLS_konfig_entw-wischer_err_waschen_haengt_aus,5000 ms,48
ENG153742-ENG154820-SMLS_konfig_entw-wischer_err_waschen_haengt_ein,300 s,48
ENG153742-ENG154821-SMLS_konfig_entw-wischer_err_wischen_haengt_aus,5000 ms,48
ENG153742-ENG154822-SMLS_konfig_entw-wischer_err_wischen_haengt_ein,300 s,48
ENG116588-ENG248517-Sonderfunktionen-Blinkerueberwachug Sonderfunktions-SG,not installed ,4
ENG116588-ENG116589-Sonderfunktionen-Signalprioritaet fuer Blinker,MFG ,4
ENG141635-ENG116658-Spiegelverstellung-Funk Spiegelanklappen,not active ,5
ENG141635-ENG116665-Spiegelverstellung-Funk Spiegelanklappung Modus,by convenience operation via remote control key ,5
ENG141635-ENG116660-Spiegelverstellung-Menuesteuerung Funk Spiegel anklappen,not active ,5
ENG141635-ENG116657-Spiegelverstellung-Menuesteuerung Spiegelabsenkung,not active ,5
ENG141635-ENG116659-Spiegelverstellung-Menuesteuerung synchrone Spiegelverstellung,active ,5
ENG141635-ENG126841-Spiegelverstellung-Profilfunktion fuer Anklappung der Aussenspiegel,active ,5
ENG141635-ENG126610-Spiegelverstellung-Signalisierung_Spiegelanklappung,not active ,5
ENG141635-ENG116650-Spiegelverstellung-Spiegelabsenkung bei Rueckwaertsfahrt,not active ,5
ENG141635-ENG133411-Spiegelverstellung-Spiegelanklappen_bei_Wiederverriegelung,not active ,5
ENG141635-ENG116656-Spiegelverstellung-Spiegelverstellung Synchron,active ,5
ENG153700-ENG154803-Steering Column Switch-Verbauort_Lenkstockschalter,LIN ,10
ENG153700-ENG154828-Steering Column Switch-Zeit_erkennung_fahrt_für_P_plausibel,1000 ms,10
ENG141663-ENG142242-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Abdimmen,20.0 s,21
ENG141663-ENG142241-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Aufdimmen,3.0 s,21
ENG141663-ENG142243-Suchbeleuchtung_allgemein-pa_Hysterese_RLS,2 ,21
ENG141663-ENG115819-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Aktivierung,parking light activated ,21
ENG141663-ENG115820-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Grundwert,10.0 %,21
ENG141668-ENG102140-Suchbeleuchtung_KL 58xs min-X3,510 lx,8
ENG141677-ENG99557-Suchbeleuchtung_KL_58xd_PWM-X2,50 ,12
ENG141677-ENG102140-Suchbeleuchtung_KL_58xd_PWM-X3,100 ,12
ENG141677-ENG115659-Suchbeleuchtung_KL_58xd_PWM-y0,2.0 %,12
ENG141677-ENG99777-Suchbeleuchtung_KL_58xd_PWM-Y1,2.0 %,12
ENG141677-ENG100480-Suchbeleuchtung_KL_58xd_PWM-Y2,6.0 %,12
ENG141677-ENG100773-Suchbeleuchtung_KL_58xd_PWM-Y3,10.0 %,12
ENG141677-ENG100631-Suchbeleuchtung_KL_58xd_PWM-Y4,80.0 %,12
ENG141680-ENG101574-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X1,10 lx,12
ENG141680-ENG99557-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X2,100 lx,12
ENG141680-ENG102140-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X3,500 lx,12
ENG141680-ENG99777-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y1,20 ,12
ENG141680-ENG100480-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y2,80 ,12
ENG141680-ENG100773-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y3,180 ,12
ENG141680-ENG100631-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y4,300 ,12
ENG141632-ENG116646-Sunroof-SAD Komfort schliessen,not active ,4
ENG141632-ENG116645-Sunroof-SAD Richtung Komfortoeffnen,Open ,4
ENG141634-ENG126630-Verdecksteuergeraet-Reichweitenbegrenzung fuer Servoheck schliessen,active ,9
ENG141634-ENG125652-Verdecksteuergeraet-Servoheck Schlossansteuerung,nur wenn mind. 1 Raste zu ,9
ENG141634-ENG142011-Verdecksteuergeraet-trunk_lid_conrol_unit,installed ,9
ENG141634-ENG126611-Verdecksteuergeraet-virtuelles_pedal_HMI_einstellbar,not active ,9
ENG141634-ENG246994-Verdecksteuergeraet-Virtuelles_Pedal_Version,Version_1_2 ,9
ENG141651-ENG115754-ZV allgemein-Funk bei Klemme 15 ein,active ,7
ENG141651-ENG141957-ZV allgemein-Radio freq.,315MHz ,7
ENG141651-ENG133390-ZV allgemein-Wiederverriegelung_Laderaum,ZV_Wiederveriegelung ,7
ENG141651-ENG116623-ZV allgemein-ZV Tuerentriegelung,Einzeltuerentriegelung ,7
ENG141651-ENG141996-ZV allgemein-ZV_ohne_Safe_Funktion,installed ,7
ENG141654-ENG116706-ZV Autolock-Autounlock NAR,active ,3
ENG141654-ENG116634-ZV Autolock-Menuesteuerung ZV Autolock-Unlock,not active ,3
ENG141655-ENG116661-ZV Crash-SAD PreCrash Konturschliessen,not active ,4
ENG141653-ENG142016-ZV Heck-Heckdeckelentriegelung_HDF_Innentaster,via_CAN ,7
ENG141653-ENG142245-ZV Heck-Heckoeffnung_ueber_2_Bedienhandlungen,active ,7
ENG141653-ENG141995-ZV Heck-Heckschloss_Steuerung,Kontaktsteuerung mit Mindestansteuerzeit ,7
ENG141681-IDE02022-ZV Komfort-Comfort opening,not active ,8
ENG141681-ENG116664-ZV Komfort-Fahrertuerbedienung Fensterheber schliessen,not active ,8
ENG141681-ENG116652-ZV Komfort-Funk Komfort oeffnen,not active ,8
ENG141681-ENG116651-ZV Komfort-Funk Komfort schliessen,not active ,8
ENG141681-ENG246991-ZV Komfort-pa_Two_Keys,not active ,8
ENG141681-ENG116643-ZV Komfort-Schliesszylinder Komfort oeffnen,not active ,8
ENG141681-ENG116644-ZV Komfort-Schliesszylinder Komfort schliessen,not active ,8
Elapsed Time: 02:29
well that's what i was expecting too but this is what i had. So i did it again and i got this, is it good now?
Much better. Now hopefully one of the MQB BCM experts will see this and give you some suggestions.
@TechAm : Hi. I'm not a German speaker and I'm more than happy to be proven wrong - but this might be the delicious futility of an impossible task!!:D.
Thought that an alternative approach might be the physical route; pull the T58 wire to the Selector-lever-display-illumination-bulb (i.e. L101 in the WD) and hope that it's not monitored. But alas my WD s don't provide much information about pin-outs - see below
TechAm
Laval, Canada
C?ID=401793
Hello Don. Well, i have to admit it seams impossible to do with VCDS. So i go with the other option. But, for the light swith i'm pretty sure it is possible as the signal wire for the light comes from the central electric module.
TechAm
Laval, Canada
C?ID=401793
By the way, how do you paste a pisture? i want to post the wiring diagram of the light switch but it ask for URL???
TechAm
Laval, Canada
C?ID=401793
Thanks, here is the wirind diagram. So the black/yellow wire is the one for the illumination of the light switch when key is ON, and it comes from the J519 (central eletric module. That's why i'm pretty sure it has some channel somewhere i can change to turn it off or turn it on only if parking light are on.
Sorry for the link but i tried to upload the picture like this :
in the insert image but it doesn't work. So here is the link for picture:
thanks,
Thanks, here is the wiring diagram. So the black/yellow wire is the one for the illumination of the light switch when key is ON, and it comes from the J519 (central eletric module. That's why i'm pretty sure it has some channel somewhere i can change to turn it off or turn it on only if parking light are on.
@TechAm :Hi again.
OK - so regarding the LDS (rotary light switch) - I'm a tad confused because AFAIK, the operation of the bezel lights are like this :
  1. Only for the Fog-lights and the AUTO indicator around the bezel - the LEDs illuminate when the switch is in that position
  2. ALL indicators around the bezel illuminate with background lighting when the dashboard lighting is switched-on
  3. The Parking light symbol on the bezel is always illuminated when T15 is present (i.e. ignition switched-on) regardless of switch position)
  4. The LEDs on the LDS turret are always illuminated when T15 voltage is present
IMO, lighting effects 1, 3 and 4 are "hard-wired" inside the LDS by internal circuits and cannot be altered (easily)
So - the black/yellow wire in your WD is the signal wire for 0 position on the LDS; it is a signal TO the BCM telling the module that zero position has been selected - importantly, this wire is not a signal FROM the BCM that switches ON/OFF the 0 position indicator on the bezel ring.
As can be seen from your WD, the background lighting to the bezel lights is generated by the "KL58d" wire (not to be confused with separate "KL58" wire which is the signal TO the BCM when the Parking Light position is selected on the LDS).
Also as shown (or rather implied) on your WD - the grey, KL58d wire also goes to other places to illuminate other lamps when the dashboard lighting is switched-on. This strongly suggests (to me at least) that the BCM doesn't separately (and specifically) control the background illumination to the LDS - rather, this lighting is simply part of the general dashboard lights in the cabin. So - I don't believe that you will find a way of achieving your wants through an adaptation channel in the hex09 module, alas.
However, If you want to disable the background lighting on the bezel indicators - I suggest that you pull the wire from pin #10 on the rear connector on the LDS (assess to the connector and de-pinning the wire is a relatively easy task). Alas, this will mean that the background lighting to the bezel lights will be disabled entirely; not just when the LDS is in the 0 position.
I manage to do the push to start button but can't figure out for those two.
How did you "do the push to start button"?
South Molton, UK
Just because the illumination is software controlled doesn't mean that VAG have included the ability in their software to change how/when the illumination is turned on - no diagnostic tool can do something that isn't included in the software.
TechAm
Laval, Canada
C?ID=401793
Yes, i understand. That's why i'm asking pros if somebody did it already. Your are right it might be impossible to turn this off as the purpose of this light is to find the light switch when it's dark in the car.
TechAm
Laval, Canada
C?ID=401793
@DV52
You are right, the light i want to turn off (or change to parking light if possible) is the one on the turret that illuminates when T15 voltage is present. But now you put me in doubt. I'm gonna double check for wire color.
For the push to start button:
- 05 ACC/start auth. module
-adaptation
-Search light-ZAT active during clamp 58t on (channel)
-changed it for not activated
I also did change the hazard light switch illumination to parking light instead of always ON, but this is in 09 central electric.
TechAm
Laval, Canada
C?ID=401793
@TechAm :Hi again.
Hi Don, again you are right. After double checking, the black/yellow is the OFF position. The wire i need to cut is the black/red (KL15a) and it comes from fuse block. So there is no way it can be changed with VCDS. I had already cut the wire on another car and it's not monitored and it doesn't code anywhere.
In conclusion, i will have to do it old fashion way for the shifter light and switch light. Thanks for your time.
