Hi all,
Having trouble accessing a facelifted Audi A6 C7 to address 5F. I am trying to enable developer mode and video in motion but i cannot get the security access code correct. I have tried numerous recommended numbers from the forums such as S12345 and 20103 and tried to match the module part number to the login code. Neither of these worked. I also read about changing label file names to match the part number 4G1 035 044 S but i am not sure which label file to rename.
Vehicle auto-scan is available here;
And the software details of the infotainment module (5F) are here;
If i read the Advanced ID correctly, these has been on update carried on the module. Most likely in a dealership. Any help regarding this issue is more than appreciated. Thank you.
-jesse
Chassis Type: 4G-AU57 (4G8)
Scan: 01 02 03 05 08 09 15 16 17 19 20 28 3B 42 44 46 52 53 55 5F
62 69 6C 6D 72 8F 90 AC
VIN: WAUZZZ4G1FN043117 Mileage: 238189km-148003miles
20-High Beam Assist. -- Status: Malfunction 0010
Self-Diagnosis Log
Wednesday,18,November,2020,18:36:11:26423
Page 2
VIN: WAUZZZ4G1FN043117 License Plate:
Address 01: Engine (J623-CRTD) Labels:. 059-907-401-V2.clb
Part No SW: 4G2 907 401 B HW: 4G2 907 401
Component: 3.0TDI EDC17 H33 0007
Revision: 92H33---
Coding: 12254012053601030000
Shop #: WSC 42382 003 1048576
ASAM Dataset: EV_ECM30TDI0114G2907401B 001007
ROD: EV_ECM30TDI011_AU57.rod
VCID: 2404CCF62FBCC8A657-8070
Part No SW: 4G0 927 166 C HW: 0B5 927 156 K
Component: 0B5 30 TDIRdW H03 0006
Revision: --H03---
Coding: 100001
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_TCMDL501021 001021
ROD: EV_TCMDL501021.rod
VCID: 2D1229D27C7609EE88-8078
Self-Diagnosis Log
Page 3
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V2.clb
Part No SW: 4G0 907 379 Q HW: 4G0 907 379 Q
Component: ESP9 Premium H01 0420
Coding: 17A69E41E8657982BB00
ASAM Dataset: EV_ESP9BOSCHAU57X 003019
ROD: EV_ESP9BOSCHAU57X_003.rod
VCID: 3FCE639AA61A8B7E2A-806A
161024 - Tire Pressure Warning
C102D 00 [040] - -
Mileage: 236185 km
Date: 2020.11.11
Time: 16:57:34
VzRef: 69
Bit Info 1: 00
Bit Info 2: 40
Bit Info 3: 26
Bit Info 4: 1F
Uz: BC
Unlearning counter according OBD: 31
161536 - Tire Pressure Warning
C102D 00 [032] - -
161792 - Tire Pressure Warning
C102D 00 [032] - -
Self-Diagnosis Log
Page 4
Part No SW: 4H0 907 064 FN HW: 4H0 907 064 EN
Component: BCM2 2.0 H36 0560
Coding: 01A9700E000000000000
VCID: 7AB8D28EF5B86E565D-802E
00955 - Key 1
Reset counter: 53
Mileage: 235486 km
Date: 2020.09.02
Time: 07:07:52
Part No SW: 4G0 820 043 CD HW: 4G0 820 043 CD
Serial number: 19111400042421
Coding: 36021178290000
VCID: 63868FEA6A328F9E6E-8036
Self-Diagnosis Log
Page 5
Part No SW: 4H0 907 063 DH HW: 4H0 907 063 AH
Component: BCM1 2.0 H20 0311
Revision: 15020001 Serial number: 00000950522101
Coding: 0105001440349FE0C101408300001800CF9CE7082E08020100000894E101150200400034030000
VCID: 71AAF5A2A8CE2D0EEC-8024
Component: WWS57X 141107 H37 0080
Serial number: 141114130745
Coding: 0045F7
Component: G397_RLFS H06 0002
Serial number: 23482254
Coding: 02006D
Subsystem 3 - Part No SW: 4G0 941 531 BE HW: 4G0 941 531 BE
Component: E1 - LDS H07 0044
Serial number: 24 11 2014 00000307
Serial number: 9D784C57000000000001
Self-Diagnosis Log
Page 6
Revision: -------- Serial number: 003P1002F2HM
Coding: 30333130313930313932554A304C34473053
VCID: 3B36178AB202975E06-806E
Serial number: 3575HRB404R2QP0M1GJ6
Serial number: 3585HRB404R2QMK8EHMR
Serial number: 3515JRB405R322VAB8MO
Serial number: 3525JRB401A52RD2D8QB
Serial number: 3554VRB405H33252C11C
Serial number: 3564VRB405H33252C1R$
Part No SW: 4H0 953 568 K HW: 4H0 953 568 K
Component: Lenks.Modul H06 0005
Revision: C0068538 Serial number: 90862NKJ000T6
Coding: 000015
VCID: 3B36178ABA02975E06-806E
Subsystem 1 - Part No SW: 4G0 951 528 C HW: 4G0 951 528 C
Serial number: 05 11 2014 E0015258
Self-Diagnosis Log
Page 7
Part No SW: 4G8 920 933 Q HW: 4G8 920 933 Q
Component: TDieRdw H07 0043
Revision: 03001036 Serial number: 658221114592028
Coding: 13A712000B410008000000
ASAM Dataset: EV_RBD4K 004048
ROD: EV_RBD4K_AU57.rod
VCID: 3E301E9EA110827621-806A
Part No SW: 4G8 907 468 HW: 4G8 907 468
Revision: -------- Serial number: 00000001636272
Coding: C0CD078118
VCID: 75A2C1B2D4A6012E30-8020
Serial number: 8671943703
Voltage stabilizer:
Serial number: 1409030000000000060C
Self-Diagnosis Log
Page 8
Part No SW: 8T0 857 511 AD HW: 8T0 857 511 AD
Component: FLA H04 0012
Revision: AA001002
VCID: 7CB4D496FF8C50664F-8028
03576 - Contol Module for High Beam Assistant: Visibility Limited
Reset counter: 66
Mileage: 236262 km
Date: 2020.11.11
Time: 17:53:15
Part No SW: 4G0 919 158 Q HW: 4G0 919 158 Q
Component: KLIMA FOND H08 0112
Serial number: 22111400040159
Coding: 20
VCID: 3D321992AC16996E38-8068
0075 - Button or Switch in Operating Unit
B10C7 07 [008] - Mechanical Failure
Reset counter: 66
Mileage: 236258 km
Date: 2020.11.11
Time: 17:50:41
Outside air temperature: 3.5 °C
Left rear vent temperature: 23.9 °C
Self-Diagnosis Log
Page 9
Part No SW: 4G0 907 637 H HW: 4G0 907 637 D
Component: SARA 3D H04 0056
Revision: -------- Serial number: EJ1BPA720DVYLG
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2.rod
VCID: 33263FAA9A525F1EDE-8066
Part No SW: 4G8 959 793 J HW: 4G8 959 793 G
Component: TSG FA H03 0507
Coding: 011F17014C00628002080002
VCID: 47DE7B7AF6CAC3BE92-8012
Part No SW: 4G0 909 144 M HW: 4G0 909 144 G
Component: RCEPS H41 0011
Revision: 00001000 Serial number: 0012199337
Coding: 101000010001
ASAM Dataset: EV_RCEPS 009010
ROD: EV_RCEPS_009.rod
Self-Diagnosis Log
Page 10
Revision: 00002001 Serial number: 0353534522
Coding: 0100063820B93014C32009042A010F470000000000000000000000000000
Subsystem 1 - Part No SW: 4G9 959 591 HW: 8V3 959 591
Component: J245 PS20.008 H02 0007
Serial number: WOO33063155
Coding: 901F00
Subsystem 2 - Part No SW: 4G9 959 591 HW: 8V3 959 591
Component: J394 PS20.008 H02 0007
Serial number: WOO3287196A
Coding: 801F00
02616 - Fuel Tank Cap; Unlock
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 249
Mileage: 234415 km
Date: 2020.07.24
Time: 10:57:08
02615 - Fuel Tank Cap; Lock
Reset counter: 249
Mileage: 234415 km
Date: 2020.07.24
Time: 10:57:38
03128 - Switch 1 for Sunroof
Fault Status: 00101100
Reset counter: 69
Mileage: 237063 km
Self-Diagnosis Log
Page 11
Date: 2020.11.14
Time: 12:40:08
00204 - Sunroof Button (E325)
Reset counter: 69
Mileage: 237063 km
Date: 2020.11.14
Time: 12:40:08
Component: TSG BF H03 0507
Coding: 011F17014E00628002080002
VCID: 46C0767EF1C0DAB669-8012
Component: EPB-4 H04 0015
Revision: -------- Serial number: 00000001278679
ROD: EV_ParkiBrake_VW51.rod
Self-Diagnosis Log
Page 12
Part No SW: 4H4 907 357 D HW: 7P6 907 357 B
Component: MxB-ECU 001 0081
Coding: 04FA02102A630200
ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005003
Coding: E01E00
Coding: E01E00
Self-Diagnosis Log
Page 13
Part No SW: 4G1 035 044 S HW: 4G1 035 044
Component: MU-H-LN-EU 040 0389
Serial number: A589K0E7501320
Coding: 01750201FF0A000013110001000A00132F0006E5F1700100DF
VCID: 2F2E33DA767A7BFEBA-807A
Subsystem 1 - Part No SW: V03 959 801 FD HW: -----------
Component: ECE 2017/2018 --- 0161
Subsystem 2 - Part No SW: 4G1 919 605 HW: 4G1 919 605
Component: DU8 C7 SV H42 0007
Serial number: AUZ8Z9EL800AFM
Multimedia Operating Unit:
Serial number: 90349NKI000Y6
Compact Disc Database:
Component: Gracenote2 --- 1012
0512 - Rear Right Bass Speaker
B1067 13 [008] - Open Circuit
[Tieftonlautsprecher Kanal 1: Unterbrechung]
Reset counter: 53
Mileage: 235559 km
Date: 2020.10.15
Time: 13:02:27
Voltage terminal 30: 12.2 V
0527 - Rear Left Bass Speaker
B1065 13 [008] - Open Circuit
[Tieftonlautsprecher Kanal 4: Unterbrechung]
Self-Diagnosis Log
Page 14
Reset counter: 53
Mileage: 235559 km
Date: 2020.10.15
Time: 12:53:27
Voltage terminal 30: 12.3 V
3086 - Antenna for Telephone Mount
B1564 01 [009] - Electrical Failure
Reset counter: 34
Mileage: 234411 km
Date: 2020.07.24
Time: 10:32:29
Voltage terminal 30: 14.5 V
Status of telephone-Antenna diagnostic: OK
Status of telephone-Telephone baseplate diagnostic: not connected
Status of telephone-Handset in handset holder (cradle): not selected
Status of telephone-Handset holder (cradle): not connected
Component: TSG HL H03 0507
Coding: 010F15004000628002080002
VCID: 49DA7D42E0DE35CE84-801C
02123 - Door Warning Light / Entry Light
Reset counter: 53
Mileage: 235559 km
Date: 2020.10.15
Time: 12:48:30
Self-Diagnosis Log
Page 15
Address 69: Trailer (J345) Labels:| 4H0-907-383-V2.clb
Part No SW: 4G8 907 383 B HW: 4G8 907 383 B
Component: Anhaenger H14 0137
Revision: 7B001001 Serial number: 0352029073
Coding: 0100000202000000
Part No SW: 4S0 907 441 B HW: 5Q0 907 441 A
Component: D4-PA RVC Mid H07 0050
Coding: 027502010301000700
ASAM Dataset: EV_CamSysRearPANAAU914 002002
ROD: EV_CamSysRearPANAAU914.rod
VCID: 32283AAE65485616D5-8066
Part No SW: 4G9 959 107 C HW: 4G9 959 107 B
Component: HDSG-Modul H05 0150
Revision: 14005001 Serial number: 318400119
Coding: 093205C011
ROD: EV_HDSGAu571.rod
VCID: 362006BE89204A36F9-8062
Self-Diagnosis Log
Page 16
Component: TSG HR H03 0507
Reset counter: 53
Mileage: 235559 km
Date: 2020.10.15
Time: 12:57:47
Component: RGS-VL H13 0080
Coding: 00060000031F030000030801424CDA010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L_VW51.rod
VCID: 312A35A2604E6D0EAC-8064
Component: RGS-VR H13 0080
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R_VW51.rod
Self-Diagnosis Log
Page 17
Part No SW: 4G0 907 355 C HW: 4G0 907 355 B
Component: SCR-Stg-G2 H10 0010
Revision: 00000000 Serial number: 143060153
ROD: EV_RDCMA00100.rod
VCID: 2B1627CA426207DE96-807E
End----(Elapsed Time: 02:08, VBatt start/end: 11.7V/11.7V. VIgn 11.6V)-----
Control Module Part Number: 4G1 035 044 S
Component and/or Version: MU-H-LN-EU 040 0389
Software Coding: 01750201FF0A000013110001000A00132F0006E5F1700100DF
Work Shop Code: WSC 02391
Advanced Identification/FAZIT
Identification: JTB-074
Date: 26.11.14
Manufacturer number: 1166
Test stand number: 0B0E
Flash Status
Programming Attempts(application): 0/2
Programming Attempts(data): 0/2/2/2/2/2/2/0/2/2/1/0/0/0/0/2/0/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535
Successful Attempts(data): 0/2/2/2/2/2/2/0/2/2/1/0/0/0/0/2/0/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535
Flash Date: 00.01.01
Flash Tool Code(data): 1048576 002 04675
Misc.
Hardware number: 4G1 035 044
Workshop System Name: J794
Equipment/PR Code: 0000000DBF840672677A29DF
Dataset Number: 4G1909545D
Dataset Version: 0029
ASAM Dataset Revision: 001115
Car Info
Chassis Number: WAUZZZ4G1FN043117
VCDS Info:
Labels: None
-jesse
