A 2009 Jetta 2.5 has been brought to me for coding/adaption/basic settings of the ABS system. There are no previous scans of the original module because that module lost CAN communication.
Client purchased a module from salvage yard of same year and model. The client had general repair shop replace ABS Unit. The VCDS long coding helper says contact Ross Tech. I have been warned in the past about lifting coding from the internet so I hope to find someone here who has a file or generator that won't create a dangerous code. Thank you for any assistance.
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 0F 15 16 17 19 25 42 44 46 52 56 62 65 72
VIN: 3VWRM71K49M013815 Mileage: 181790km-112959miles
Address 01: Engine (CBT) Labels: 07K-906-055-CBT.clb
Part No SW: 07K 906 055 P HW: 07K 906 055 M
Component: 2,5l R5/4V G 9970
Revision: G6H01--- Serial number: VWX7Z0H624717A
Coding: 0000075
Shop #: WSC 05074 444 12192
VCID: BB367FFEFAADA15E86-80EE
049441 - No Communication with ABS Brake Control Module
U0121 - 000 - - Intermittent
Mileage: 181791 km
Time: 05:14:11
Load: 0.0 %
Temperature: 35.0°C
Temperature: 33.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 11.684 V
Readiness: 0010 0101
Part No SW: 09G 927 750 JE HW: 09G 927 750 JE
Component: AQ 250 6F 1377
Revision: 00H76000 Serial number:
Coding: 0000840
Shop #: WSC 00066 000 00000
VCID: FDB2B1E6A4396F6EF8-80A8
Part No SW: 1K0 907 379 AH HW: 1K0 907 379 AH
Component: ESP MK60EC1 H30 0107
Revision: 00H30001
VCID: F8BCA0F24B1B4A46AB-80AC
03306 - Coding Not Valid
Reset counter: 80
Mileage: 181791 km
Count: 3
Count: 14
Count: 12288
Count: 4161
Count: 42752
Count: 65024
Reset counter: 80
Mileage: 181791 km
Count: 16391
Count: 12
Count: 16896
Count: 195
Count: 43264
Count: 65024
Fault Status: 01100101
Reset counter: 80
Mileage: 181791 km
Count: 3
Count: 14
Count: 12288
Count: 279
Count: 42752
Count: 65024
Reset counter: 80
Mileage: 181791 km
Count: 3
Count: 14
Count: 12288
Count: 295
Count: 42752
Count: 65024
Reset counter: 80
Mileage: 181791 km
Count: 3
Count: 14
Count: 12288
Count: 270
Count: 42752
Count: 65024
Part No SW: 1K0 820 047 HS HW: 1K0 820 047 HS
Component: Climatic PQ35 142 1111
Revision: 00142031 Serial number: 00000000000000
VCID: FCB4BCE2BF236666CF-80A8
Address 09: Cent. Elect. Labels:. 3C0-937-049-30-M.lbl
Part No SW: 3C0 937 049 AH HW: 3C0 937 049 AH
Revision: 00H54000 Serial number: 00000001005729
Coding: 14058E234004150007140000001400000008730B5C000120000000000000
VCID: EFAE9BAEFE550DFE7A-80BA
Component: Wischer 020708 021 0501
Coding: 00038805
Shop #: WSC 00066
02092 - Enabling Heated Seat
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 80
Mileage: 181791 km
Date: 2005.09.13
Time: 31:63:63
Voltage: 12.05 V
Revision: 00000000 Serial number: AUZ4Z7H0359570
Coding: 0000100
VCID: B32657DED2FD691E5E-80E6
00003 - Control Module
Fault Status: 00101110
Fault Frequency: 7
Reset counter: 53
Mileage: 123870 km
Time: 13:16:44
Reset counter: 80
Mileage: 181791 km
Time: 21:37:47
Component: 6A AIRBAG VW8R 034 8000
Revision: 05034000 Serial number: 003B6M05WH7H
Coding: 0013889
VCID: EC948CA2CF43F6E65F-80B8
Subsystem 1 - Part No: 1K0 959 339 H
Component: BF-Gewichtsens. 007 0006
Subsystem 2 - Serial number: 6332MSME29035975B
Subsystem 3 - Serial number: 6342MSME2F613A03C
Subsystem 4 - Serial number: 6351HSME1663112C%
Subsystem 5 - Serial number: 6361HSME16630625/
Subsystem 6 - Serial number: 63727SME157D0332.
Subsystem 7 - Serial number: 63827SME15581028Y
Part No SW: 1K0 953 549 BR HW: 1K0 953 549 BR
Component: J0527 051 0101
Coding: 0010021
VCID: 8346C71EC2DD199E8E-80D6
Part No SW: 1K0 920 954 S HW: 1K0 920 954 S
Component: KOMBIINSTRUMENT 3HL 1222
Revision: V0003000 Serial number: VWX7Z0H624717A
Coding: 0023203
Shop #: WSC 07207 067 57207
VCID: BC347CE2FFA3A6668F-80E8
Component: J533 Gateway H07 0062
Revision: H07 01 Serial number: 260508F2000324
Coding: ED807F070003021002
VCID: B52269C6DC89772E70-80E0
Component: IMMO 3HL 1222
Part No SW: 1K0 959 701 AC HW: 1K0 959 793 N
Component: J386 TUER-SG FT 1519
Revision: 72009005 Serial number: 00000853088703
Coding: 0001205
01552 - Motor for Central Locking; Drivers Door (V56); Lock
Fault Status: 01101100
Reset counter: 80
Mileage: 181791 km
Part No: 1K0 909 144 C
Component: EPS_ZFLS Kl. 70 2301
Revision: 00H15000
Shop #: WSC 02069 000 90108
VCID: AA184ABA053728D6ED-80FE
Coding: 13900F880186281B0904058FB0880F0488DCA0
VCID: 8444C402C7D31EA6B7-80D0
Part No SW: 1K0 959 702 AC HW: 1K0 959 792 N
Component: J387 TUER-SG BT 1519
Revision: 72009005 Serial number: 00000288588707
Coding: 0001204
VCID: F0AC98D2E36B120663-80A4
Component: Radio ZSW 019 0035
Revision: 00019000 Serial number: VWZ5Z7H6078504
Coding: 0040402
VCID: A91AB5B6003123CEE4-80FC
Part No SW: 1K0 959 703 AH HW: 1K0 959 795 T
Component: J388 TUER-SG HL 1401
Revision: 12006001 Serial number: 00000003280951
Coding: 0001168
VCID: F6A0AECA810F3C36B9-80A2
Component: RDK 0450
Coding: 0100101
Part No SW: 1K0 959 704 AH HW: 1K0 959 794 T
Component: J389 TUER-SG HR 1401
Revision: 12006001 Serial number: 00000003208214
Coding: 0001168
VCID: F7BEA3CE8605453EA2-80A2
