Hello everyone. New to this forum. I have a Golf GTI 2018 which has electrical issues here's what I know.
1. The vehicle stalled while driving on the highway. It was taken to VW. VW dealership unable to diagnose and wrote vehicle off. So no warranty.
2. Dealer installed new ECM.
3. Original Battery was Dead not even able to take a charge.
4. After replacing with alternative battery (not programed to vehicle) vehicle is not turning over.
5. When push start Im getting some buzzing and humming noises from engine and error: "Brakes Please service vehicle" then "Error Airbag" then "Only exit vehicle in P position. Please service vehicle" and finally "Error: Adaptive Front Lighting System (AFS)". These are all appearing on the dash.
Here is the Scan.
Help Would be appreciated.
Here is the Scan.
Tuesday,17,November,2020,12:39:23:41100
VIN: 3VW447AU7JM287543 License Plate:
Mileage: 20180km-12539mi Repair Order:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 02 03 05 08 09 15 16 17 19 29 2B 32 39 42 44 47 4B 52 5F
A9 D6 D7
VIN: 3VW447AU7JM287543 Mileage: 20180km-12539miles
02-Auto Trans -- Status: Cannot be reached 0100
03-ABS Brakes -- Status: Cannot be reached 0100
29-Left Light -- Status: Malfunction 0010
32-Differential Locks -- Status: Cannot be reached 0100
39-Right Light -- Status: Malfunction 0010
44-Steering Assist -- Status: Cannot be reached 0100
A9-Struct. Borne Sound -- Status: Malfunction 0010
Address 01: Engine (J623-CXCB) Labels:. 06K-907-425-V1.clb
Part No SW: 5G0 906 259 L HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0002
Revision: --H13---
Coding: 091D00122424012F1000
Shop #: WSC 58101 001 1048576
ASAM Dataset: EV_ECM20TFS0205G0906259L 001004
ROD: EV_ECM20TFS0205G0906259L.rod
VCID: 372B20DEEFC78C73A39-8062
7 Faults Found:
15048 - Coolant Fan Control Circuit 1
P0480 00 [039] - Electrical Malfunction
Mileage: 20180 km
Date: 2020.11.14
Time: 12:57:04
Engine speed: 0.00 /min
Vehicle speed: 255 km/h
Coolant temperature: 5 °C
Intake air temperature: 7 °C
Voltage terminal 30: 11.914 V
Engine: operating status: ES
STATE_LS_SAE[1]: INI
T_AST_SAE: 0 s
MAP_MES_SAE: 100 kPa
Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.997 V
FAC_TPS_1_SAE: 16.015625 %
FUP_H_SAE: 1010.0 kPa
15034 - Fuel Pressure Sensor (G247)
P0190 00 [038] - Circuit Malfunction
Mileage: 20180 km
Date: 2020.11.14
Time: 00:01:51
Coolant temperature: 2 °C
Intake air temperature: 1 °C
Voltage terminal 30: 11.796 V
T_AST_SAE: 0 s
MAP_MES_SAE: 99 kPa
FUP_H_SAE: 28000.0 kPa
16992 - Production Mode Active
U1103 00 [167] - -
Mileage: 20180 km
Date: 2020.11.14
Time: 12:57:02
T_AST_SAE: 0 s
26363 - Manifold Pressure / Boost Sensor (G31)
P0236 00 [039] - Implausible Signal
Mileage: 20180 km
Date: 2020.11.14
Time: 12:57:23
Voltage terminal 30: 11.992 V
STATE_LS_SAE[1]: OL_CDN
T_AST_SAE: 0 s
FUP_H_SAE: 980.0 kPa
22055 - No Communications with Power Steering Control Module
U0131 00 [039] - -
Mileage: 20180 km
Date: 2020.11.14
Time: 12:57:02
ECU_STATE: ENG_STOP
Engine oil temperature: 3.0 °C
Time since engine start: 0.0 s
T_ES: 2 min
Cruise control switch actuation-Main switch: not activated
Cruise control switch actuation-Setting: not activated
Cruise control switch actuation-Activation: not activated
Cruise control switch actuation-Accelerate: not activated
Cruise control switch actuation-Decelerate: not activated
Cruise control switch actuation-Cancel: not activated
Cruise control switch actuation-Main switch hardware: not activated
Cruise control switch actuation-Limit button: not activated
Cruise control switch actuation-Main switch CAN: not activated
Cruise control switch actuation-Large increment: not activated
T_AST_SAE: 0 s
19875 - No Communication with ABS Brake Control Module
U0121 00 [167] - -
Mileage: 20180 km
Date: 2020.11.14
Time: 12:57:02
ECU_STATE: ENG_STOP
T_ES: 2 min
T_AST_SAE: 0 s
21654 - No Communication with Transmission Control Module
U0101 00 [167] - -
Mileage: 20180 km
Date: 2020.11.14
Time: 12:57:02
ECU_STATE: ENG_STOP
T_ES: 2 min
T_AST_SAE: 0 s
Readiness: 1110 1101
Address 02: Auto Trans
Address 03: ABS Brakes
Part No SW: 5Q0 959 435 C HW: 5Q0 959 435
Component: VWKESSYMQB 021 0803
Revision: 00021000 Serial number: 0471877433
Coding: 032C0C
Shop #: WSC 01383 790 50316
VCID: 3C213FF2D6E1AF2B4EB-8068
Part No SW: 5GM 907 044 G HW: 5GM 907 044 G
Component: Climatronic H04 2001
Revision: 00001K05
Coding: 0002001420011801100400000010140E
VCID: 48C953229239F38BDA3-801C
459012 - Databus
[ESP-Steuergerät - kein Signal/Kommunikation]
Reset counter: 25
Mileage: 20180 km
Date: 2020.11.14
Time: 12:01:26
459023 - Databus
[Motorsteuergerät - kein Signal/Kommunikation]
Reset counter: 65
Mileage: 20180 km
Date: 2020.11.14
Time: 00:00:46
Part No SW: 5Q0 937 087 AR HW: 5Q0 937 087 AN
Component: BCM PQ37BOSCH 034 0246
Revision: -------- Serial number: C86424051801AB
Shop #: WSC 00066 790 00147
ROD: EV_BCMBOSCH_018.rod
VCID: 0B43AC2EC3CF5893371-805E
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 180329 043 0551
Serial number: 97022066180407075657
Component: RLHS 050 0107
Serial number: SAY18M05D16H22M42S32
Coding: 00A8DD
Sun Roof:
Subsystem 3 - Part No SW: 5GD 959 591 A HW: 5GD 959 591 A
Component: J245 PS60.006 H07 0170
Serial number: 03691622512208171646
Coding: 181803
12 Faults Found:
533781 - Databus
[ESP_02 Datenbus fehlende Botschaft]
Reset counter: 25
Mileage: 20180 km
Date: 2020.11.14
Time: 12:03:49
554517 - Databus
[ESP_05_alt aktiv]
Reset counter: 25
Mileage: 20180 km
Date: 2020.11.14
Time: 12:03:49
533525 - Databus
[ESP_07_alt aktiv]
Reset counter: 25
Mileage: 20180 km
Date: 2020.11.14
Time: 12:03:49
533269 - Databus
[ESP_20 Datenbus fehlende Botschaft]
Reset counter: 25
Mileage: 20180 km
Date: 2020.11.14
Time: 12:03:49
555797 - Databus
[Getriebe_11_alt aktiv]
Reset counter: 25
Mileage: 20180 km
Date: 2020.11.14
Time: 12:03:49
556053 - Databus
[LH_EPS_02_alt aktiv]
Reset counter: 25
Mileage: 20180 km
Date: 2020.11.14
Time: 12:03:49
555285 - Databus
[LWI_01_alt aktiv]
Reset counter: 25
Mileage: 20180 km
Date: 2020.11.14
Time: 12:03:49
541973 - Databus
[Motor_04 Datenbus fehlende Botschaft]
Reset counter: 65
Mileage: 20180 km
Date: 2020.11.14
Time: 00:00:46
555541 - Databus
[Motor_12_alt aktiv]
Reset counter: 65
Mileage: 20180 km
Date: 2020.11.14
Time: 00:00:46
542229 - Databus
[Motor_14 Datenbus fehlende Botschaft]
Reset counter: 65
Mileage: 20180 km
Date: 2020.11.14
Time: 00:00:46
528917 - Databus
[ESP_21 Datenbus fehlende Botschaft]
Reset counter: 25
Mileage: 20180 km
Date: 2020.11.14
Time: 12:03:49
918792 - Signal for Brake Lights
B1313 29 [009] - Signal Implausible
Reset counter: 25
Mileage: 20180 km
Date: 2020.11.14
Time: 00:00:50
Part No SW: 5Q0 959 655 T HW: 5Q0 959 655 T
Component: AirbagVW20 011 0830
Serial number: 003MHM04EYM9
VCID: 51FF7E46616332438DD-8004
Occupant Detection:
Component: BF-Gewichtss. H13 0022
Serial number: IBH0000000000095193U
Coding: 30305A
Subsystem 2 - Part No SW: ----------- HW: 480 002 104 18
Serial number: 35700000000BC09C5D2-
Subsystem 3 - Part No SW: ----------- HW: 480 002 104 18
Serial number: 358000000007D09C5D2Y
Subsystem 4 - Part No SW: ----------- HW: 480 401 105 18
Serial number: 35100019F29E7325D5EM
Subsystem 5 - Part No SW: ----------- HW: 480 401 105 18
Serial number: 3520001A329E7324B1E5
Subsystem 6 - Part No SW: ----------- HW: 480 400 505 18
Serial number: 3550001B129E65D493BG
Front Sensor Passenger:
Subsystem 7 - Part No SW: ----------- HW: 480 400 505 18
Component: FrontSensor_P 000 6149
Serial number: 3560001B129E65D292AD
B10B3 00 [137] - Function Restriction due to Implausible Message(s)
Reset counter: 25
Mileage: 20180 km
Date: 2020.11.14
Time: 12:04:08
9482752 - Seat Occupied Recognition
B10B2 00 [137] - Function Restriction due to Missing Message(s)
Reset counter: 25
Mileage: 20180 km
Date: 2020.11.14
Time: 12:03:52
B13BC F2 [137] - No function
Mileage: 20180 km
Date: 2020.11.14
Time: 12:03:52
1052928 - Databus
[NWD: 0x0FD ESP_21 Timeout]
Reset counter: 25
Mileage: 20180 km
Date: 2020.11.14
Time: 12:03:52
1052672 - Databus
[NWD: 0x392 ESP_07 Timeout]
Reset counter: 25
Mileage: 20180 km
Date: 2020.11.14
Time: 12:03:53
10492928 - Supply Voltage
B201C 00 [008] - Implausible Signal
[Powersupply implausible signal]
Reset counter: 65
Mileage: 20180 km
Date: 2020.11.14
Time: 00:02:49
Part No SW: 5Q0 953 507 HL HW: 5Q0 953 549 E
Revision: -------- Serial number: 12041804401268
Coding: 0410
VCID: 074B901EDFA73CF3139-8052
Part No SW: 5G1 920 756 C HW: 5G1 920 756 C
Component: KOMBI 342 0310
Coding: 0BAD091AA980880902086B0010000000A0000000
Shop #: WSC 00066 790 00424
VCID: 2D0702B61D9B36A3C95-8078
7 Faults Found:
16776968 - Databus
[ESP_24 keine Kommunikation]
Reset counter: 25
Mileage: 20180 km
Date: 2020.11.14
Time: 12:03:54
16776971 - Databus
[Motor_04 keine Kommunikation]
Reset counter: 65
Mileage: 20180 km
Date: 2020.11.14
Time: 00:00:43
16776973 - Databus
[RKA_01 keine Kommunikation]
Reset counter: 25
Mileage: 20180 km
Date: 2020.11.14
Time: 12:03:54
16776978 - Databus
[LH_EPS_01 keine Kommunikation]
Reset counter: 25
Mileage: 20180 km
Date: 2020.11.14
Time: 12:03:54
16776983 - Databus
[WBA_03 keine Kommunikation]
Reset counter: 25
Mileage: 20180 km
Date: 2020.11.14
Time: 12:03:54
16776988 - Databus
[TSK_07 keine Kommunikation]
Reset counter: 65
Mileage: 20180 km
Date: 2020.11.14
Time: 00:00:43
16776993 - Databus
[ESP_21 keine Kommunikation]
Reset counter: 25
Mileage: 20180 km
Date: 2020.11.14
Time: 12:03:54
Part No SW: 3Q0 907 530 L HW: 3Q0 907 530 C
Component: GW MQB High 518 5323
Serial number: 23051800840242
Coding: 030100047F085900FB00026B1C0F00010001070000000000000000000000
ROD: EV_GatewNF_VW37.rod
VCID: 382923E2E2D9830BAA3-806C
Subsystem 2 - Part No SW: 5G0 959 442 Q HW: 5G0 959 442 Q Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H11 0103
Serial number: 29170002051680087383
Coding: 31FFFF
8 Faults Found:
131602 - Power Steering Control Module
U101D 00 [009] - No Communication
[Timeout Knoten 0x12 / 44 - Steuergerät für Lenkhilfe]
Reset counter: 25
Mileage: 20180 km
Date: 2020.11.14
Time: 00:01:10
Supply voltage: Terminal 30: 11.9 V
Terminal 15: On
131603 - No Communication with ABS Brake Control Module
U0121 00 [009] - -
[Timeout Knoten 0x13 / 03 - Steuergerät für ABS Bremse]
Reset counter: 25
Mileage: 20180 km
Date: 2020.11.14
Time: 00:01:10
Terminal 15: On
131614 - Differential Lock Control Module
U1040 00 [009] - No communication
[Timeout Knoten 0x1E / 32 - Steuergerät für Quersperren]
Reset counter: 25
Mileage: 20180 km
Date: 2020.11.14
Time: 00:01:10
Terminal 15: On
131702 - No Communication with Engine Control Module (SAE ECM/PCM)
U0100 00 [008] - -
[Timeout Knoten 0x76 / 01 - Motorsteuergerät]
Reset counter: 65
Mileage: 20180 km
Date: 2020.11.14
Time: 00:00:46
Terminal 15: On
131703 - No Communication with Transmission Control Module
U0101 00 [009] - -
[Timeout Knoten 0x77 / 02 - Steuergerät für Getriebe]
Reset counter: 25
Mileage: 20180 km
Date: 2020.11.14
Time: 00:01:10
Terminal 15: On
65794 - Data Bus for Suspension
U10AE 00 [009] - 1-Wire Mode
[Eindrahtfehler CAN-Fahrwerk]
Reset counter: 25
Mileage: 20180 km
Date: 2020.11.14
Time: 00:01:09
Supply voltage: Terminal 30: 11.8 V
Terminal 15: On
66562 - Data Bus for Suspension
U10A9 00 [008] - Defective
[Bus defekt CAN-Fahrwerk]
Reset counter: 65
Mileage: 20180 km
Date: 2020.11.14
Time: 12:03:56
Terminal 15: On
66567 - Local Databus
U1030 00 [009] - Electrical Malfunction
[LIN#1 (LIN-Energie) elektrischer Fehler]
Reset counter: 25
Mileage: 20180 km
Date: 2020.11.14
Time: 12:03:58
Terminal 15: On
Address 29: Left Light (J1018) Labels: 8V0-907-399.clb
Part No SW: 8V0 907 399 D HW: 8V0 907 399 D
Component: LCM_MLBevoH08 0014
VCID: 47CB501E9F27FCF3D39-8012
0279 - Databus
[databus - message missing]
Reset counter: 65
Mileage: 20180 km
Date: 2020.11.14
Time: 00:00:44
0281 - ROD - Unknown Error Code
- 00 [009]
Reset counter: 25
Mileage: 20180 km
Date: 2020.11.14
Time: 12:01:35
0036 - Terminal 15
U1405 00 [008] - Implausible signal
[Clamp 15 implausible signal]
Reset counter: 65
Mileage: 20180 km
Date: 2020.11.14
Time: 00:02:48
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 18000102061008
Coding: 5D00000000000000
Shop #: WSC 00066 790 00199
ROD: EV_ELVMarquMQB.rod
VCID: 343117D2FEB1676B86B-8060
12666369 - Databus
[Timeout Message Motor_14]
Reset counter: 65
Mileage: 20180 km
Date: 2020.11.14
Time: 00:00:43
ELV State: 24
Information Clamps: 77 6A
CoCo State: E0 01
WFS State: 17 0E
Vehicle speed: 655.34 km/h
Voltage: 68
AD-Value H-bridge: 33
Clamp15 flip flop: SSTx: button contacts: 06
CAN signals: 05
12666370 - Databus
[Timeout Message ESP_10]
Reset counter: 25
Mileage: 20180 km
Date: 2020.11.14
Time: 12:01:37
ELV State: 04
Information Clamps: 77 60
CoCo State: E0 01
WFS State: 17 06
Voltage: 66
AD-Value H-bridge: 32
CAN signals: 05
12666381 - Databus
[Timeout Message Motor_09]
Reset counter: 65
Mileage: 20180 km
Date: 2020.11.14
Time: 00:00:43
ELV State: 24
Information Clamps: 77 68
CoCo State: E0 01
WFS State: 17 0E
Voltage: 67
CAN signals: 05
Address 32: Differential Locks
Address 39: Right Light (J1023) Labels: 8V0-907-399.clb
0279 - Databus
Reset counter: 65
Mileage: 20180 km
Date: 2020.11.14
Time: 00:00:43
- 00 [009]
Reset counter: 25
Mileage: 20180 km
Date: 2020.11.14
Time: 12:01:38
0036 - Terminal 15
Reset counter: 65
Mileage: 20180 km
Date: 2020.11.14
Time: 00:02:47
Part No SW: 5Q4 959 593 E HW: 5Q4 959 593 B
Component: TSG FS 011 0032
Serial number: 5038814800726
Coding: 003E13200000020000000000
Subsystem 1 - Part No SW: 5Q4 959 811 F HW: 5Q4 959 811 F Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG DRV 010 0004
Serial number: 00000000000000421787
Coding: 011000
Reset counter: 25
Mileage: 20180 km
Date: 2020.11.14
Time: 12:01:39
458803 - Databus
Reset counter: 65
Mileage: 20180 km
Date: 2020.11.14
Time: 00:00:48
Address 44: Steering Assist
Address 47: Sound System (J525) Labels:| 5Q0-035-456.clb
Part No SW: 5Q0 035 456 A HW: 5Q0 035 456 A
Component: MIB2_lite_amp H40 0200
Revision: 00000001 Serial number: VWZ8Z1JMD024N5F
Coding: 2200000000AAAAAA000000000000
ROD: EV_AMPMst12C1Gen2ALPI.rod
VCID: 2E0505BA109D4DBBF0F-807A
Address 4B: Multifunc. Module (J745) Labels:| 3Q0-907-338-V1.clb
Part No SW: 3Q0 907 338 HW: 3Q0 907 338
Component: FCM MQB Low 002 0286
Serial number: 26031800840682
Coding: 000000050100214A01110F01030000000000000000000000000000000000
VCID: 72BDD1CAC425295B547-8026
13705472 - Databus
U1121 00 [137] - Missing Message
[ESP_19 data bus missing message]
Reset counter: 25
Mileage: 20180 km
Date: 2020.11.14
Time: 12:03:57
13705474 - Databus
[LWI_01 data bus missing message]
Reset counter: 25
Mileage: 20180 km
Date: 2020.11.14
Time: 12:03:57
13705475 - Databus
[Motor_14 data bus missing message]
Reset counter: 65
Mileage: 20180 km
Date: 2020.11.14
Time: 00:00:44
Part No SW: 5Q4 959 592 E HW: 5Q4 959 592 B
Component: TSG BFS 011 0032
Serial number: 6038815200236
VCID: 46D55D1A982DE5FB28F-8012
Subsystem 1 - Part No SW: 5Q4 959 812 F HW: 5Q4 959 812 F Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG PSG 010 0004
Serial number: 00000000000000417958
Coding: 091000
458803 - Databus
Reset counter: 65
Mileage: 20180 km
Date: 2020.11.14
Time: 00:00:48
Part No SW: 3Q0 035 876 B HW: 3Q0 035 876 B
Component: MU-S-NS-US 851 0867
Coding: 027310020000000051220002001828009F0503F401200505C6
ROD: EV_MUStd4CDELP_VW37.rod
VCID: 333314CEFBBF60539F1-8066
Subsystem 1 - Part No SW: 5G6 919 605 D HW: 5G6 919 605 D
Component: ABT_Std-2_Nav H52 8130
Serial number: VWZ6ZJV1100765
B11CF 53 [009] - Deactivated
Reset counter: 25
Mileage: 20180 km
Date: 2020.11.14
Time: 12:02:10
Voltage terminal 30: 11.8 V
SDARS_tuner_status_2-Satellite radio antenna status: Electrical OK
SDARS_tuner_status_2-Audio Signal: Available
SDARS_tuner_status_2-Antenna current: 101 mA
SDARS_tuner_status_2-Reception quality: optimum_signal
SDARS_tuner_status_2-Satellite radio tuner: pre-activation status: 02
SDARS_tuner_status_2-Satellite radio tuner: pre-activation value: 02
6702 - Databus
[ESP: no communication]
Reset counter: 25
Mileage: 20180 km
Date: 2020.11.14
Time: 12:01:44
Network diagnosis-Status: Enabled
6708 - Databus
[Engine: no communication]
Reset counter: 65
Mileage: 20180 km
Date: 2020.11.14
Time: 00:00:52
Voltage terminal 30: 11.9 V
U1111 00 [009] - -
[Tire pressure monitoring (0x07) - function restriction due to communication error - BapErr_retry not successful]
Reset counter: 25
Mileage: 20180 km
Date: 2020.11.14
Time: 12:55:20
BAP-BAP_Function_ID: 02
7206 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[Brake (0x26) - function restriction due to communication error - BapErr_retry not successful]
Reset counter: 25
Mileage: 20180 km
Date: 2020.11.14
Time: 12:55:20
Part No SW: 5G0 907 159 G HW: 4H0 907 159 A
Component: SAS-GEN 2 H07 0001
Serial number: 180320200703
VCID: 323D11CA04A5695B947-8066
0010 - Databus
[Keine Funktion durch CAN FehlerMotorsteuergerätebotschaft fehlt--> keine Klangerzeugung]
Mileage: 20180 km
Date: 2020.11.14
Time: 00:00:44
0014 - Databus
[Keine Funktion durch CAN FehlerESPsteuergerätebotschaft fehlt--> keine Klangerzeugung]
Reset counter: 25
Mileage: 20180 km
Date: 2020.11.14
Time: 12:04:00
Part No SW: 7P5 941 572 A HW: 7P5 941 572 A
Component: LED1L H06 0002
ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
ROD: EV_LEDMinMaxL_KEBODAVW481.rod
VCID: 392F26E6D9D39A0355D-806C
Component: LED1R H06 0002
ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
ROD: EV_LEDMinMaxRKEBODVW481.rod
End----(Elapsed Time: 01:38, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
Gateway Installation List: 3Q0 907 530 L
Address 19,3Q0 907 530 L,channel IDE00002-Transport mode,adapted from,not active ,to,not active ,
De-activating transport mode...Done.
A9 D6 D7
Revision: --H13---
Mileage: 20180 km
Date: 2020.11.17
Time: 12:40:46
Intake air temperature: 2 °C
T_AST_SAE: 0 s
MAP_MES_SAE: 99 kPa
FUP_H_SAE: 1050.0 kPa
U1103 00 [167] - -
Mileage: 20180 km
Date: 2020.11.17
Time: 12:40:44
T_AST_SAE: 0 s
MAP_MES_SAE: 99 kPa
U0131 00 [039] - -
Mileage: 20180 km
Date: 2020.11.17
Time: 12:40:44
ECU_STATE: ENG_STOP
Engine oil temperature: 1.0 °C
T_ES: 5 min
T_AST_SAE: 0 s
U0121 00 [167] - -
Mileage: 20180 km
Date: 2020.11.17
Time: 12:40:44
ECU_STATE: ENG_STOP
T_ES: 5 min
T_AST_SAE: 0 s
U0101 00 [167] - -
Mileage: 20180 km
Date: 2020.11.17
Time: 12:40:44
ECU_STATE: ENG_STOP
T_ES: 5 min
T_AST_SAE: 0 s
Coding: 032C0C
Revision: 00001K05
459012 - Databus
Reset counter: 25
Mileage: 20180 km
Date: 2020.11.17
Time: 12:40:42
Coding: 00A8DD
Sun Roof:
Coding: 181803
8 Faults Found:
533781 - Databus
Reset counter: 25
Mileage: 20180 km
Date: 2020.11.17
Time: 12:40:41
554517 - Databus
[ESP_05_alt aktiv]
Reset counter: 25
Mileage: 20180 km
Date: 2020.11.17
Time: 12:40:42
533525 - Databus
[ESP_07_alt aktiv]
Reset counter: 25
Mileage: 20180 km
Date: 2020.11.17
Time: 12:40:41
533269 - Databus
Reset counter: 25
Mileage: 20180 km
Date: 2020.11.17
Time: 12:40:41
555797 - Databus
Reset counter: 25
Mileage: 20180 km
Date: 2020.11.17
Time: 12:40:41
556053 - Databus
Reset counter: 25
Mileage: 20180 km
Date: 2020.11.17
Time: 12:40:42
555285 - Databus
[LWI_01_alt aktiv]
Reset counter: 25
Mileage: 20180 km
Date: 2020.11.17
Time: 12:40:42
528917 - Databus
Reset counter: 25
Mileage: 20180 km
Date: 2020.11.17
Time: 12:40:41
Occupant Detection:
Coding: 30305A
Reset counter: 25
Mileage: 20180 km
Date: 2020.11.17
Time: 12:40:58
Reset counter: 25
Mileage: 20180 km
Date: 2020.11.17
Time: 12:40:42
Mileage: 20180 km
Date: 2020.11.17
Time: 12:40:42
1052928 - Databus
Reset counter: 25
Mileage: 20180 km
Date: 2020.11.17
Time: 12:40:42
1052672 - Databus
Reset counter: 25
Mileage: 20180 km
Date: 2020.11.17
Time: 12:40:43
Coding: 0410
16776968 - Databus
Reset counter: 25
Mileage: 20180 km
Date: 2020.11.17
Time: 12:40:41
16776973 - Databus
Reset counter: 25
Mileage: 20180 km
Date: 2020.11.17
Time: 12:40:41
16776978 - Databus
Reset counter: 25
Mileage: 20180 km
Date: 2020.11.17
Time: 12:40:41
16776983 - Databus
Reset counter: 25
Mileage: 20180 km
Date: 2020.11.17
Time: 12:40:41
16776993 - Databus
Reset counter: 25
Mileage: 20180 km
Date: 2020.11.17
Time: 12:40:41
Coding: 31FFFF
U10A9 00 [009] - Defective
Reset counter: 25
Mileage: 20180 km
Date: 2020.11.17
Time: 12:40:42
Terminal 15: On
Reset counter: 25
Mileage: 20180 km
Date: 2020.11.17
Time: 12:40:44
Terminal 15: On
- 00 [009]
Reset counter: 25
Mileage: 20180 km
Date: 2020.11.17
Time: 12:40:41
12666370 - Databus
Reset counter: 25
Mileage: 20180 km
Date: 2020.11.17
Time: 12:40:41
ELV State: 04
CoCo State: E0 01
WFS State: 17 06
Voltage: 66
CAN signals: 05
- 00 [009]
Reset counter: 25
Mileage: 20180 km
Date: 2020.11.17
Time: 12:40:41
Coding: 011000
Reset counter: 25
Mileage: 20180 km
Date: 2020.11.17
Time: 12:40:42
13705472 - Databus
Reset counter: 25
Mileage: 20180 km
Date: 2020.11.17
Time: 12:40:42
13705474 - Databus
Reset counter: 25
Mileage: 20180 km
Date: 2020.11.17
Time: 12:40:42
Coding: 091000
Reset counter: 25
Mileage: 20180 km
Date: 2020.11.17
Time: 12:41:21
SDARS_tuner_status_2-Antenna current: 100 mA
SDARS_tuner_status_2-Reception quality: weak_signal
6702 - Databus
Reset counter: 25
Mileage: 20180 km
Date: 2020.11.17
Time: 12:40:43
0014 - Databus
Reset counter: 25
Mileage: 20180 km
Date: 2020.11.17
Time: 12:40:42
End----(Elapsed Time: 01:37, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
