Golf VII gateway upgrade and MFSW retrofit
amigokola
Poland
C?ID=281040
Hi Guys...
This is my first gateway upgrade to high in MQB so I must ask some questions :)
I ordered 5Q0907530T/M High gateway. As I know after CP will be done I must parametrize gateway properly.
I must read admap from old gateway and write it to new high one ??
I have VCP and for Golf VII gateway I can see only 5Q0907530AJ.zdc parameters.
Any help is appreciated.
Rgs.
Saturday,14,November,2020,11:36:43:58906
VCDS Version: 20.4.2.0  HEX-NET CB: 0.4513.4
VIN: WVWZZZAUZFPXXXXXX   License Plate:
Mileage: 186524km-115900mi   Repair Order: Golf VII MFSW bez ACC GTW LOw
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 08 09 10 15 16 17 19 42 44 52 5F
VIN: WVWZZZAUZFPxxxxxx   Mileage: 186524km-115900miles
Address 01: Engine (J623-CLHA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 M    HW: 04L 907 309 B
   Component: R4 1,6L EDC   H22 5517
   Revision: 84H22---
   Coding: 01110012030411092000
   Shop #: WSC 00028 028 00072
   ASAM Dataset: EV_ECM16TDI01104L906021M 002009
   ROD: EV_ECM16TDI01104L906021P.rod
   VCID: 2F2E096D76FB56FEBA-807A
5231 - Fuel Rail/System Pressure
          P0087 00 [096] - Too Low
4640 - Engine Oil Temp. Sensor (G8)
          P0197 00 [032] - Signal too Low
   Part No SW: 5Q0 907 379 CK    HW: 5Q0 907 379 G
   Component: ESC           H31 0472
   Revision: 00000000    Serial number: 61294000000489
   Coding: 04FA62A12420096D037C060441C62520462490C06082A4F300400078C002
   ROD: EV_Brake1UDSContiMK100IPB_033.rod
   VCID: 075E81CDBECB2EBE52-8052
   Part No SW: 5G0 907 426 Q    HW: 5G0 907 426 Q
   Component: AC Manuell    H02 0907
   Revision: 00001K06
   Coding: 02020104202100001000000000000000
   Shop #: WSC 00028 028 00204
   VCID: 393A3735B8BF884E14-806C
   Part No SW: 5Q0 937 086 S    HW: 5Q0 937 086 S
   Component: BCM PQ37BOSCH 028 0106
   Revision: --------    Serial number: 86581505141380
   Coding: 00000842C24102730BA44080B10403081000000000000000000000000000
   Shop #: WSC 00028 028 00068
   ASAM Dataset: EV_BodyContrModul1UDSBosc 013005
   ROD: EV_BCMBOSCH_013.rod
   VCID: 4AD878F9ED5913D68D-801E
   Component: WWS    140503  042 0551
   Serial number:         140507042743
   Subsystem 2 - Part No SW: 5Q0 955 559 A    HW: 5Q0 955 559 A  Labels: 5Q0-955-547.CLB
   Component: RLS  037 0059
   Serial number: S4Y14M05D21H21M18S50
   Coding: 00A8DD
   Serial number: 000000000ZY140942FUW
   Serial number: 00000000000059571641
          U1400 00 [008] - -
          [Funktionseinschränkung durch Unterspannung - unterer Grenzwert unterschritten >]
204290 - Remote key 1
          B1479 18 [008] - Current Too Low
204546 - Remote key 2
          B147A 18 [008] - Current Too Low
   Part No SW: 5Q0 919 294 E    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0048
   Revision: --------    Serial number: 39331413400463
   Coding: 0031051001
   VCID: 3D322325AC97B46E38-8068
   Part No SW: 5Q0 959 655 D    HW: 5Q0 959 655 D
   Serial number: 003F6R07H492
   Shop #: WSC 00028 028 00053
   VCID: 41CA5FD5D06FD08E5C-8014
   Subsystem 1 - Part No SW: -----------    HW: 480 001 505 14
   Serial number: 35767000000CAC409F04
   Subsystem 2 - Part No SW: -----------    HW: 480 001 505 14
   Serial number: 35867000000D43249F0-
   Subsystem 3 - Part No SW: -----------    HW: 480 401 405 14
   Serial number: 3516502B5157E9E02206
   Subsystem 4 - Part No SW: -----------    HW: 480 401 505 14
   Serial number: 3526502B9156E9F1721I
   Subsystem 5 - Part No SW: -----------    HW: 480 402 804 14
   Serial number: 3556502B5157E994306E
   Part No SW: 5Q0 953 521 L    HW: 5Q0 953 569 A
   Component: Lenks.Modul   075 0155
   Revision: FF028028    Serial number: 20140516500285
   Coding: 0600
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 3B362D3DB283BA5E06-806E
   Part No SW: 5G1 920 731     HW: 5G1 920 731
   Component: KOMBI         104 4270
   Coding: 07A4020023000008000808000400000000000000
   VCID: 6386B55D6AB3A29E6E-8036
   Part No SW: 5Q0 907 530 R    HW: 5Q0 907 530 K
   Component: GW MQB Low    210 2186
   Revision: --------    Serial number: 12051410800251
   Coding: 030000040B087300EF000048080E00010001050000000000000000000000
   Shop #: WSC 00999 123 04321
   ASAM Dataset: EV_GatewConti 011017
   ROD: EV_GatewConti_011.rod
   VCID: 40CC5AD1DB65D98653-8014
   Subsystem 2 - Part No SW: 5Q0 915 181 E    HW: 5Q0 915 181 E
   Serial number: 9167563403
   Part No SW: 5Q4 959 393 B    HW: 5Q4 959 393 B
   Component: TSG FS        009 0014
   Serial number: 0000103309799
   Coding: 003002208000020000001000
   VCID: 42C850D9D569CB9645-8016
   Subsystem 1 - Part No SW: 5Q4 959 811 A    HW: 5Q4 959 811 A  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000005313591
   Component: EPS_MQB_ZFLS  123 1043
   Coding: 0103
   ROD: EV_SteerAssisMQB_010.rod
   Part No SW: 5Q4 959 592 B    HW: 5Q4 959 592 B
   Component: TSG BFS       009 0014
   Serial number: 0000102603527
   Coding: 003000208E00020000801000
   VCID: 43C655DDCA73C29E4E-8016
   Subsystem 1 - Part No SW: 5Q4 959 812 A    HW: 5Q4 959 812 A  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000005305751
   Coding: 090000
   Part No SW: 5G0 035 819 A    HW: 5G0 035 819 A
   Component: MU-S--ER      041 0421
   Serial number: V1C01805140081
   Coding: 02730200FF00000011110001000800001F0100840100010001
   ROD: EV_MUStd4CPASE_VW37.rod
   VCID: 271EE14D5E0B0EBE72-8072
   Subsystem 1 - Part No SW: 5G0 919 605     HW: 5G0 919 605
   Component: ABT_Std_Radio  H60 0030
   Serial number: VWZ8Z9PS201GF8
End----------(Elapsed Time: 01:23, VBatt start/end: 12.1V/12.1V)-----------
downtime
Finland
C?ID=280813
You need dealer for it. Or someone with with online VW diagnostic access.
The gateway needs component protection removed, parameterized and FeC restore.
And you should be able to update the gateway to AF or AJ. HW index M is upgradeable.
amigokola
Poland
C?ID=281040
CP and Fec ok but parametrization restore all values from original one and I want to do MFSW retrofit. So you say that after I do CP, Fec, parametrization I have to update it to AF, AJ ?? Or first flash it and then Geko ??
downtime
Finland
C?ID=280813
CP and FeC stay even you upgrade the gateway software. Parameterization is lost which you need to do again then.
amigokola
Poland
C?ID=281040
So I must flash gateway with proper .frf matching VCP .zdc file to do parametrization ??
And I must do it before Geko ??
downtime
Finland
C?ID=280813
Small correction here. HW M is Continental gateway. SWs AF and AJ are for Lear gateway so they're not matching together. So no update to those with that gateway HW.
amigokola
Poland
C?ID=281040
But MFSW should work on this 5K0907530T/M ?? Wonder if geko gonna parametrize it and next I can code it for MFSW. Will check and report.
downtime
Finland
C?ID=280813
I would expect it to work as M is a high gateway. Parameterization might not work online. For that you might need the other tool.
