Hi All,
I did a Auto-Scan yesterday on a 2020 Seat Leon however I got back a very unusual report and a pile of errors including on one occasion an error saying that the vehicle is not supported by my interface and I should look to upgrade?
Is this just due to the vehicle being a 2020 vehicle and not fully supported at the moment?
Many thanks
Many thanks
Monday,16,November,2020,15:58:24:63324
VIN: VSSZZZ5FZLR0***** License Plate:
Mileage: 53662km-33344mi Repair Order: *****
Chassis Type: 5F-SE37 (3Q0)
Scan: 03 08 09 10 11 31 14 15 17 18 19 42 43 44 52 5B 5E 5F 60 61
77 81 8C 8E A6 AD AE BB BC C2 C7 CE D0 D4 D6 D7 D8 D9 E0 8105
8107 8108 810B 8111
VIN: VSSZZZ5FZLR0***** Mileage: 53662km-33344miles
04-Steering Angle -- Status: Not registered 0011
08-Auto HVAC -- Status: Not registered 0011
11-Engine II -- Status: Not registered 0011
31-Engine other -- Status: Not registered 0011
14-Susp. Elect. -- Status: Not registered 0011
18-Aux. Heat -- Status: Not registered 0011
42-Door Elect, Driver -- Status: Not registered 0011
43-Brake Assist -- Status: Not registered 0001
52-Door Elect, Pass. -- Status: Not registered 0011
5B-Seat,Rear,PS -- Status: Not registered 0001
5E-Ctrl Head LR -- Status: Not registered 0001
5F-Information Electr. -- Status: Not registered 0011
60-Trip Recorder -- Status: Not registered 0011
61-Battery Regul. -- Status: Not registered 0001
77-Telephone -- Status: Not registered 0011
81-Gear Shift -- Status: Not registered 0011
8C-Hybrid Battery -- Status: Not registered 0011
8E-Image Processing -- Status: Not registered 0011
A6-Microphone -- Status: Not registered 0011
AD-Brake Sensors -- Status: Not registered 0011
AE-Telemetry Diagnostic -- Status: Not registered 0001
C2-Auto Trans 2 -- Status: Not registered 0011
C7-Pedestrian Protec. -- Status: Not registered 0011
CE-Drive Motor 2 -- Status: Not registered 0001
D0-Frt Axle Lift -- Status: Not registered 0011
D4-Roll Control 1 -- Status: Not registered 0001
D8-LED HeadL. Pwr Left -- Status: Not registered 0001
D9-LED HeadL. Pwr Right -- Status: Not registered 0001
E0-Auxiliary Display 1 -- Status: Not registered 0001
8105-Unknown Address: 8105 -- Status: Not registered 0001
8107-Antenna -- Status: Not registered 0001
8108-Mascot/Hood Emblem -- Status: Not registered 0001
810B-Aux. Air Heat. 2 -- Status: Not registered 0001
8111-Rearview Mirror Right -- Status: Not registered 0001
Part No SW: 5Q0 614 517 FA HW: 5Q0 614 517 BR
Component: ESC H82 0190
Revision: 00000000 Serial number: 62359000002988
Coding: 19EE8A92202121720780060260CA2498510484E0600624733020F078D0024B0B0000000012121212B835351919323200
Shop #: WSC 00049 770 00103
ROD: EV_Brake1UDSContiMK100IPB_038.rod
VCID: 75B611F4A54E4363715-8020
4203 - Rear Left ABS Wheel Speed Sensor
C101C F1 [008] - Magnetic Field too Low
Reset counter: 86
Mileage: 21172 km
Date: 2020.04.27
Time: 20:12:58
16401 - Tire Pressure Warning
C102D 00 [008] - -
Fault Frequency: 11
Reset counter: 26
Mileage: 47877 km
Date: 2020.08.24
Time: 21:12:49
Part No SW: 5F0 907 044 BD HW: 5F0 907 044 BD
Component: Climatronic H06 2201
Revision: 00001K10
Coding: 02100004200114011005000000101024
Shop #: WSC 00049 770 00227
ASAM Dataset: EV_ACClimaBHBVW37X 006150
VCID: 698E4D84F9F69783E5D-803C
Air quality sensor:
Part No SW: 5Q0 937 084 DH HW: 5Q0 937 084 CG
Component: BCM MQBAB H H40 0312
Serial number: 01001923203871
Shop #: WSC 00049 770 00172
ASAM Dataset: EV_BCMMQB 020001
ROD: EV_BCMBOSCH_020.rod
VCID: 015E7524E1867FC35DD-8054
Subsystem 1 - Part No SW: 5F2 955 119 A HW: 057 4 Labels: 5QX-955-119-V1.CLB
Component: WWS370 190605 5F2955119 0574
Serial number: 190613165310
Coding: 0BC5FD
Serial number: 23306103X81A955555A0
Coding: 00005D
Serial number: 000000000ZY1906403R3
Subsystem 4 - Part No SW: 5Q0 951 605 B HW: 5Q0 951 605 B
Component: Sirene, DWA 004 0007
Serial number: 00000000000000563385
Steering Column Switch:
Subsystem 5 - Part No SW: 5Q1 953 507 B HW: 5Q1 953 549
Component: J527 SMLS MQB 004 0070
Serial number: 00000018081904220117
Part No SW: 5QA 919 294 G HW: 5QA 919 294
Component: PDC 8 Kanal H08 0061
Serial number: 000150058319241
Coding: 0471051001
ASAM Dataset: EV_EPHVA18AU3700000 009046
VCID: 50F880607A6C464B823-8004
Address 11: Engine II
Address 14: Susp. Elect.
Part No SW: 3Q0 959 655 CM HW: 3Q0 959 655 CM
Component: Airbag VW21 006 0720
Revision: -------- Serial number: 003Z2PENEK29
Coding: 98CCC000000000005C0000CC008800000065
ROD: EV_AirbaVW21TS6VW48X.rod
VCID: 0B42570CD3CA2593371-805E
Subsystem 1 - Part No SW: ----------- HW: 454 000 607 19
Serial number: 35700000000C823D6B3U
Subsystem 2 - Part No SW: ----------- HW: 454 000 407 19
Serial number: 008
Subsystem 3 - Part No SW: 358 000 000 00B HW: 454 800 707 19
Serial number: 351008D91EF18000000Z
Subsystem 4 - Part No SW: ----------- HW: 454 802 506 19
Serial number: 352007702F0180000007
Subsystem 5 - Part No SW: ----------- HW: 454 801 508 19
Serial number: 3550009C04D19000000I
Part No SW: 5F0 920 958 F HW: 5F0 920 958 F
Component: KOMBI 312 2720
Coding: 27A412002B80060001886A011001000080000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009069
VCID: 323CEAE814A0145B947-8066
9456681 - Key
B104C 29 [008] - Implausible Signal
Mileage: 45813 km
Date: 2020.08.13
Time: 05:15:52
Address 18: Aux. Heat
Part No SW: 3Q0 907 530 AC HW: 3Q0 907 530 C
Component: GW MQB High 442 4388
Revision: -------- Serial number: 0000057513
Coding: 030100F42F085700EB000248080F00010001070000000000000000000000
ROD: EV_GatewNF_SK26.rod
VCID: 70B820E0DA2C664BA23-8024
Component: 5-00-14-00-04
Subsystem 2 - Part No SW: 5F0 959 537 E HW: 5F0 959 537 E
Component: E221__MFL-PR6 H04 0130
Serial number: 000000000G1784250719
Coding: 002000
Subsystem 3 - Part No SW: 5Q0 915 181 J HW: 5Q0 915 181 J
Component: J367-BDMConti H03 1051
Serial number: 75886003001908170CB2
Address 42: Door Elect, Driver Labels:
VCID: 55F671744C0E2363515-FFFE
Address 43: Brake Assist
Address 44: Steering Assist
Address 52: Door Elect, Pass.
Address 5B: Seat,Rear,PS
Address 5E: Ctrl Head LR
Part No SW: 5F0 035 877 A HW: 5F0 035 877 A
Component: MU-S-ND-ER H50 0514
Serial number: SEZAZ2W0631939
Coding: 04738201D70A00001111010100880A002F0101C601200500CE
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_MUStd6C1TSAT 001015
ROD: EV_MUStd6C1TSAT_SK25.rod
VCID: 2A0CF2883C705C9B2C7-807E
Subsystem 1 - Part No SW: 5F0 919 606 HW: 5F0 919 606
Component: ABTm-2_8-CR H41 1042
Serial number: SEZ8Z9W6C085LU
Address 60: Trip Recorder
Address 61: Battery Regul.
Address 77: Telephone
Address 81: Gear Shift
Address 8C: Hybrid Battery
Address 8E: Image Processing
Address A6: Microphone
Address AD: Brake Sensors
Address AE: Telemetry Diagnostic
Address BB: Door Rear Drv
Address BC: Door Rear Pass
Address C2: Auto Trans 2
Address C7: Pedestrian Protec.
Address CE: Drive Motor 2
Address D0: Frt Axle Lift
Address D4: Roll Control 1
Address D6: Light Ctrl Left 2 (A31) Labels: 7P5-941-591.clb
Part No SW: 7P5 941 591 AH HW: 7P5 941 591 A
Component: LED1L H07 0009
ROD: EV_LED_PLUS_L_KEBODAVW416_SE37.rod
VCID: 025C7A28E48064DB447-8056
Address D7: Light Ctrl Right 2 (A27) Labels: 7P5-941-591.clb
Component: LED1R H07 0009
Address D8: LED HeadL. Pwr Left
Address D9: LED HeadL. Pwr Right
Address E0: Auxiliary Display 1
Address 8105: Unknown Address: 8105
Address 8107: Antenna
Address 8108: Mascot/Hood Emblem
Address 810B: Aux. Air Heat. 2
Address 8111: Rearview Mirror Right
End----------(Elapsed Time: 03:00, VBatt start/end: 14.9V/14.9V)-----------
