2013 MY14 Audi SQ5 3.0 TDI
S-Quattro
Australia
C?ID=149802
I haven't found a definitive Audi SQ5 tweak thread, so I thought I'd create one as I worked my way through finding, configuring and testing the tweaks I wanted to try, and maybe keep on a permanent basis.
I'll update the thread with a new post for each tweak I confirm works for my platform/model.
My original unmodified scan is below...
Tuesday,10,November,2020,08:45:08:52113
VIN: WAUZZZ8R7EA050011   License Plate:
Chassis Type: 8R-AU48 (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 36 42 44 46 47 52 53 56 5F 62
          6C 6D 72 A9 C0
VIN: WAUZZZ8R7EA050011   Mileage: 90400km-56171miles
C0-Act. for Ext. Noise --  Status: OK 0000
Address 01: Engine (J623-CGQB)       Labels:. 059-907-401-V2.clb
   Part No SW: 8K5 907 589     HW: 4G0 907 589
   Component: 3.0BTD EDC17  H25 0008
   Revision: 57H25---
   Coding: 2A2A4032252603020000
   Shop #: WSC 63311 001 1048576
   ASAM Dataset: EV_ECM30BTD0118K5907589 001011
   ROD: EV_ECM30BTD011_AU48.rod
   VCID: 7EA5F5C9E07BCCEB20F-802A
   Part No SW: 8R0 927 158 AE    HW: 0BK 927 156 AM
   Component: 0BK 30RTDIRdW H16 1005
   Revision: --H16---
   VCID: 00598B319A8FBA1B523-8054
Address 03: ABS Brakes (J104)       Labels:. 8R0-907-379-V2.clb
   Part No SW: 8R0 907 379 AF    HW: 8R0 907 379 AF
   Component: ESP8 quattro  H09 0030
   Coding: 245D0C01
   Shop #: WSC 06335 000 00000
   VCID: 045187218E17A63B76B-8050
   Part No SW: 8K0 907 064 HR    HW: 8K0 907 064 GR
   Component: BCM2 2.0      H13 0641
   Coding: 05B54000000000000000
   VCID: 074B902DBF218D23139-8052
Address 08: Auto HVAC (J255)       Labels:. 8Kx-820-043-3Z.clb
   Part No SW: 8K2 820 043 S    HW: 8K2 820 043 S
   Revision: D0000000    Serial number: 01081020130030
   Coding: 3625628080
   VCID: 392F26D5B9552BD355D-806C
   Part No SW: 8K0 907 063 DG    HW: 8K0 907 063 DG
   Revision: 07016001    Serial number: 00000051040201
   Coding: 260000108034AFE0018140C000001D0D0F9DC70827090201000008004401030100000034000000
   VCID: 77ABE0EDCFC1FDA3639-8022
   Subsystem 1 - Part No SW: 8R2 955 119 A    HW: 8R2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS416 130919  H11 0050
   Serial number: 90243015130829081359
   Coding: 01DD13
   Serial number: 21820779
   Coding: 02005C
   Component: E1 - LDS  H03 0031
   Serial number: 00000000000210130980
   Serial number: A03840D6000000000001
02988 - Left-Hand/Right-Hand Traffic Switchover Active
                    Reset counter: 204
                    Mileage: 90409 km
                    Date: 2020.11.10
                    Time: 08:42:02
Address 15: Airbags (J234)       Labels:* 8R0-959-655.clb
   Part No SW: 8R0 959 655 G    HW: 8R0 959 655 G
   Component: AirbagVW-AU10 H47 0610
   Serial number: 003JPDB0T50J
   Coding: 304A3431313030303030554A305238523053
   ROD: EV_AirbaAU10SMEAU416.rod
   VCID: 48C95311F23F425BDA3-801C
   Serial number: 6334MSME7E063344E
   Serial number: 6344MSME7F20396CS
   Serial number: 6352QSME3F3A5650O
   Serial number: 6362QSME2E37476CX
   Serial number: 63732SME66361054U
   Serial number: 63832SME68392E5EI
   Part No SW: 8K0 953 568 Q    HW: 8K0 953 568 Q
   Component: Lenks.Modul   H03 0003
   Revision: C0062331    Serial number: 90862MJC000AZ
   Coding: 000037
   VCID: 48C95311F2BF425BDA3-801C
Address 17: Instruments (J285)       Labels:. 8R0-920-xxx-17.clb
   Part No SW: 8R0 920 931 F    HW: 8R0 920 931 F
   Component: KOMBIINSTR.   H35 0564
   Revision: 00000000    Serial number: ZDK2107AE
   Coding: B3A7220003010008010000
   VCID: 382923D1825F32DBAA3-806C
   Part No SW: 8R0 907 468 N    HW: 8R0 907 468 C
   Component: GW-BEM 4CAN-M H11 0056
   Revision: 1Y070028    Serial number: 2841Y1392103E2
   Coding: 80CD07FF00
   VCID: 4ACD6919ECB3B04BCC7-801E
   Subsystem 1 - Part No SW: 8R0 915 181     HW: 8R0 915 181
   Component: J367-BDM  H07 0141
   Serial number: 30268A39091461150185
   Subsystem 2 - Part No SW: 8K0 959 663 B    HW: 8K0 959 663 B
   Serial number: 13275000688011200410
   Part No SW: 8R0 959 760 D    HW: 8R0 959 760 B
   Component: MEM-FS        H07 0076
   Revision: AA000000    Serial number: 00000077378134
   Coding: 01781B00000000000000
   VCID: 42DD4139D483680B047-8016
   Component: TSG FA        H02 0510
   Revision:             Serial number: 0000077228569
   Coding: 011D12205E01440004
   VCID: 4FFB780D17D195639B9-801A
   Part No SW: 8R0 909 144 F    HW: 8R0 909 144 B
   Component: RCEPS         H38 0507
   Revision: 00001000    Serial number: 0001913779
   Coding: 100000010001
   ROD: EV_RCEPSAU48X_008.rod
   VCID: 3B233CDDB3E919C3471-806E
   Revision: 00002001    Serial number: 0316756467
   Coding: 01000E2A20B930958420053680040047
   Subsystem 1 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
   Component: J245EE04SKB03  H03 0090
   Subsystem 2 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
   Component: J394EE04SKB03  H03 0090
   Revision: 00005001    Serial number: 94813020647603
   VCID: 2D0702857D1D8773C95-8078
   Component: TSG BF        H02 0510
   Revision:             Serial number: 0000077590692
   VCID: 4EC5650910DB9C6B90F-801A
   Part No SW: 8K0 907 801 M    HW: 8K0 907 801 J
   Component: EPB-4         H01 0004
   Revision: --------    Serial number: 20000000346430
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 392F26D5B9D52BD355D-806C
   Part No SW: 4G0 035 061 L    HW: 4G0 035 061
   Component: Radio U DAB   H60 0133
   Revision: AB001007    Serial number: 109J10D7710587
   Coding: 040103010000000001
   VCID: 2615FDA958EBB42B08F-8072
   Part No SW: 8R2 035 754 F    HW: 8R2 035 754 C
   Component: H-BN-RW       H46 0739
   Revision: --------    Serial number: 210JX0D7517155
   Coding: 1A0A01060205A1EF45808B4E00000403FC0000020000000000
   VCID: 3A2D39D9BC5320CB5C7-806E
   Subsystem 1 - Part No: 8R0 060 884 AS
   Component: ROW 2013  0506
   Component: DU7 High  H42 0104
   Serial number: A130JY0D2844832
   Subsystem 3 - Part No SW: 8T0 919 611 L    HW: 8T0 919 611 C
   Serial number: 00000001638599
   Component: CD-Database  5298
   Component: TSG HL        H01 0510
   Revision:             Serial number: 0000077617426
   Coding: 010C12204001240004
   VCID: 46D55D29F8AB542B28F-8012
   Part No SW: 8R0 907 441 A    HW: 4L0 907 441 B
   Revision: --H08---    Serial number: 525PA8-J37AA8L
   Coding: 1020010
   VCID: 343117E19237D6BB86B-8060
Address 6D: Trunk Elect. (J605)       Labels: 4L0-910-945.clb
   Part No SW: 8R0 827 851 B    HW: 8R0 827 851 B
   Component: J605  Master  H52 0330
   Revision: --------    Serial number: 8R0827851B
   VCID: 3B233CDDB36919C3471-806E
   Subsystem 1 - Part No SW: 8R0 827 852 B    HW: 8R0 827 852 B
   Component: J756  Slave  H52 0330
   Serial number: 8R0827852B
   Component: TSG HR        H01 0510
   Revision:             Serial number: 0000077786928
   Part No SW: 8R0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0007
   Serial number: 130927201659
   VCID: 79AFE6D5F955EBD315D-802C
Address C0: Act. for Ext. Noise (J943)       Labels: 4G0-907-160.clb
   Part No SW: 8R0 907 160     HW: 4G0 907 160 B
   Component: SAS-GEN 2 AGA H09 0002
   Serial number: 131025201558
   ASAM Dataset: EV_ActuaForExterNoiseUDS 003013
   ROD: EV_ActuaForExterNoiseUDS.rod
   VCID: 71BFDEF5A125A393ADD-8024
End----------(Elapsed Time: 01:49, VBatt start/end: 14.6V/14.6V)-----------
S-Quattro
Australia
C?ID=149802
We'll start off with a simple one...
Activate Green menu
Summary...
5F Information Elec > Adaptation - 10 > Channel 06 > Set value to 1
Step 1) Select Control Module
Step 2) Select, 5F Information Elec.
Step 3) Select, Security Access - 16
Step 4) Enter security code, and click 'Do it!'
Step 5) Select, Adaptation - 10
Step 6) Enter Channel 06 and click 'Read'
Step 7) Enter '1' into the New value
Step 8) Click Test
Step 9) Click Save
Reboot the MMI by pressing <MENU>, <CONTROL KNOB> and <TOP RIGHT BUTTON>
To access the Green Menu, press the MMI <MENU> and <CAR> buttons together
NOTE: No long coding changes to module 5F required.
S-Quattro
Australia
C?ID=149802
Activate Video In Motion
Summary...
5F Information Elec > Adaptation - 10 > Channel 48 > Set value to 255
Step 6) Enter Channel 48 and click 'Read'
Step 7) Enter '255' into the New value
Step 8) Click Test
Step 9) Click Save
S-Quattro
Australia
C?ID=149802
Disable Seat Belt Warning
Summary...
17 Instruments > Coding - 07 > Byte 0 > Bits 2-4 > '00 Seat Belt Warning inactive'
Step 2) Select, 17 Instruments
Step 3) Select, Coding - 07
Step 4) Select Long Coding Helper
Step 5) Select Byte 0
Step 6) Select the drop-down associated with Bits 2-4, and choose '00 Seat Belt Warning inactive'.
Step 7) Close the Long Coding Helper
Step 8) Click 'Do it!'
Byte 0 changed...
To: A3 (10100011)
Long coding changed...
To: A3A7220003010008010000
S-Quattro
Australia
C?ID=149802
Enable Lap Timer
Summary...
17 Instruments > Coding - 07 > Byte 1 > Bit 3
Step 5) Select Byte 1
Step 6) Check the checkbox for Bit 3 'Lap Timer Active'.
Byte 1 changed...
To: AF (10101111)
To: B3AF220003010008010000
S-Quattro
Australia
C?ID=149802
Deactivate Start/Stop
Summary...
09 Cent Elec > Adaptation - 10 > Channel 34
Step 2) Select, 09 Cent Elec.
Step 6) Enter Channel 34 and click 'Read'
Step 7) Add 32 to the value so the last state is retained - i.e. the car remembers if the stop/start was switched off or not
Step 7) Add 64 to the value to invert the illumination on start/stop button - i.e. illumination is off when stop/start is inactive
Step 8) Click Test
Step 9) Click Save
My original value was 28
New value so the last state is retained : 60
New value so the last state is retained and the button's illumination is inverted : 124
NOTE: No long coding changes to module 09 required.
sportmotor
Czech Republic
C?ID=14747
Are You sure this:
can Disable door open chime ?
S-Quattro
Australia
C?ID=149802
Are You sure this:
Sorry, yes the title was incorrect... I've fixed it up now... it is indeed the Disable Seat Belt Warning chime
