missing adaptation channels and CP removed device displaying wrong PN
madmacka
Australia
C?ID=415075
HI,
I'm trying to retrofit a "hacked" MIB2 unit to my 2019 octavia vrs with virtual dash.
hardware
MIB2 565 035 045b
the unit has had the CP disabled by a 3rd party ( not the person i bought it off)
the unit functions as expected however t reports it self as a 5e0 035 045b(mib1??) and is not showing Dashboard_Display_Configuration options in the adaptation menu
can this be worked around with a label file re direct ?
here is my auto scan which is now in a state with all my mucking around trying to get it working ( I have all my default values recorded so i can role back easily)
Tuesday,17,November,2020,09:45:46:21556
VIN:   License Plate: NA
Mileage: 8627km-5360mi   Repair Order:
Chassis Type: NE-SK37 (3Q0)
Scan: 01 02 03 08 09 10 13 15 16 17 19 32 42 44 47 4B 52 5F 6C A9
          D6 D7
VIN: TMBBU7NE3K0051585   Mileage: 8627km-5360miles
47-Sound System -- Status: Cannot be reached 0100
Address 01: Engine (J623-DLBA)       Labels:. 06K-907-425-V1.clb
   Part No SW: 5G0 906 259 N    HW: 06K 907 425 J
   Component: 2.0l R4 TFSI  H13 0003
   Revision: --H13---
   Coding: 0C2500124464010B0000
   Shop #: WSC 73430 031 00063
   ASAM Dataset: EV_ECM20TFS0205G0906259N 002004
   ROD: EV_ECM20TFS0205G0906259N_002.rod
   VCID: 392F2980E9DCD18355D-806C
   Part No SW: 0GC 300 020 B    HW: 0GC 927 711 H
   Component: GSG DQ381     H06 2301
   Revision: 00H06V07
   ROD: EV_TCMDQ381061.rod
   VCID: 211FE1E0614CA9437DD-8074
   Part No SW: 5Q0 614 517 DE    HW: 5Q0 614 517 AD
   Component: ESC           H25 0524
   Revision: 00000000    Serial number: 62538000001019
   Coding: 240793915425216D407C060860C86824C92A8402600616763641F031C009430B00000012121212B835351919323200
   ROD: EV_Brake1UDSContiMK100IPB_037_VW37.rod
   VCID: 77ABEFB89F4807F3639-8022
   Part No SW: 5E0 820 047 R    HW: 5E0 820 047 R
   Component: AC Manuell    H06 1803
   Revision: 00001K00
   Coding: 01110004000100001000000000401008
   VCID: 313F11A031AC19C3EDD-8064
   Part No SW: 5Q0 937 084 DD    HW: 5Q0 937 084 CG
   Component: BCM MQBAB H   H38 0273
   Serial number: 00001825301124
   Shop #: WSC 73430 790 00063
   ROD: EV_BCMBOSCH_019.rod
   VCID: 7DA7FD90BD742DA3395-8028
   Subsystem 1 - Part No SW: 5E2 955 119 A    HW: 5E2 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS371 180817  051 0916
   Serial number: 887253F0401822901502
   Coding: 164DDD
   Subsystem 2 - Part No SW: 5Q0 955 559 B    HW: 5Q0 955 559 B  Labels: 5Q0-955-547.CLB
   Component: RLS  050 0105
   Serial number: S2Y18M09D10H21M03S11
   Coding: 00885D
   Part No SW: 5QA 919 283 C    HW: 5QA 919 283
   Component: PDC 4 KanalH07 0050
   Serial number: 000308419618244
   Coding: 0601150011
   ASAM Dataset: EV_EPHVA14AU3700000 009037
   ROD: EV_EPHVA14AU3700000_009_SK37.rod
   VCID: 4ACD664CBC3A4A1BCC7-801E
   Part No SW: 5Q0 907 572 P    HW: 3QF 907 572 A
   Coding: 3300608109FFC728949C810520400600000000000000000004
   VCID: 44D148749E1E9C6B36B-8010
   Part No SW: 3Q0 959 655 BH    HW: 3Q0 959 655 BH
   Component: Airbag VW21   006 0712
   Revision: --------    Serial number: 003W4PJPMS3W
   Coding: 98CCC000000000005C540000008800000065
   ROD: EV_AirbaVW21TS6VW48X.rod
   VCID: 05579570D5A46563615-8050
   Subsystem 1 - Part No SW: -----------    HW: 454 000 809 18
   Serial number: 35700000000A1044B136
   Subsystem 2 - Part No SW: -----------    HW: 454 000 409 18
   Serial number: 358000000005D79C323R
   Subsystem 3 - Part No SW: -----------    HW: 454 800 909 18
   Serial number: 351005F591816000000G
   Subsystem 4 - Part No SW: -----------    HW: 454 800 909 18
   Serial number: 35200E04227160000003
   Subsystem 5 - Part No SW: -----------    HW: 454 802 708 18
   Serial number: 355005B2AB515000000K
   Part No SW: 5Q0 953 507 HB    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 24091804400023
   Coding: 6410
   Part No SW: 5E0 920 790 A    HW: 5E0 920 790 A
   Component: KOMBI         507 1691
   Coding: 25AD11082D800008018AF7011001000080000000
   ASAM Dataset: EV_DashBoardVDDMQBA0 001026
   ROD: EV_DashBoardVDDMQBA0_VW37.rod
   VCID: 2615F2FC08624E7B08F-8072
16777026 - Function Restricted due to Interrupted Communications
          U1110 00 [009] - -
          [BAP_MFL_Jokerfunktion_0x34 keine Kommunikation]
                    Reset counter: 247
                    Mileage: 7596 km
                    Date: 2020.11.08
                    Time: 18:47:56
16777056 - Function Restricted due to Interrupted Communications
          U1110 00 [009] - -
          [BAP_SDS_0x46 keine Kommunikation]
                    Reset counter: 247
                    Mileage: 7596 km
                    Date: 2020.11.08
                    Time: 18:47:56
   Part No SW: 3Q0 907 530 Q    HW: 3Q0 907 530 C
   Component: GW MQB High   439 4344
   Revision: --------    Serial number: 0008530682
   Coding: 030100047F085900EB0000FB1C0F00010001070000000000000000000000
   Shop #: WSC 73430 790 00000
   ASAM Dataset: EV_GatewNF 013044
   ROD: EV_GatewNF_VW37.rod
   VCID: 3D273D90FDF4EDA3795-8068
   Subsystem 2 - Part No SW: 3V0 919 719 F    HW: 3V0 919 719 F
   Serial number: 000000000B0516100918
   Serial number: 758860020018091424AA
          U1101 00 [008] - Active
                    Fault Frequency: 37
                    Reset counter: 46
                    Mileage: 7596 km
                    Date: 2020.11.08
                    Time: 18:50:04
                    Supply voltage: Terminal 30: 11.9 V
                    Terminal 15: On
Address 32: Differential Locks (J492)       Labels:* 0CQ-907-554.clb
   Part No SW: 0CQ 907 554 P    HW: 0CQ 907 554 P
   Component: Quersperre    H52 8043
   Serial number: HA1-00016.07.18
   Coding: 0201
   ASAM Dataset: EV_LockElectHA1VW37X 001007
   ROD: EV_LockElectHA1VW37X.rod
   VCID: 52FD7E2C546A02DBB47-8006
   Part No SW: 5Q4 959 393 F    HW: 5Q4 959 393 F
   Component: TSG FS        006 0246
   Serial number: 0000343922217
   Coding: 001C01208001020000001100
   VCID: 46D5527CA822AE7B28F-8012
   Subsystem 1 - Part No SW: 5Q0 959 812 E    HW: 5Q0 959 812 E
   Serial number: 00000000000023791972
   Coding: 1D0200
   Part No SW: 3Q0 909 144 L    HW: 3Q0 909 144 L
   Component: EPS_MQB_ZFLS  507 5081
   Coding: 81170000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 3B233388E3E0E393471-806E
Address 47: Sound System
   Component: FCM MQB Low   002 0342
   Serial number: 20091810520375
   Coding: 000000070900046E00003D00010000000000000000000000000000000000
   ASAM Dataset: EV_MultiModulContiVW48X 002004
   ROD: EV_MultiModulContiVW48X_002_VW41.rod
   VCID: 353725B0C5C435E3B15-8060
   Part No SW: 5Q4 959 392 F    HW: 5Q4 959 392 F
   Component: TSG BFS       006 0246
   Serial number: 0000343018955
   VCID: 45D755709524A563215-8010
   Subsystem 1 - Part No SW: 5Q0 959 811 E    HW: 5Q0 959 811 E
   Serial number: 00000000000023855198
   Coding: 050200
   Part No SW: 5E0 000 045 B    HW: 5E0 035 045
   Component: MU-H-N-RW     H42 0293
   Serial number: A314L0D7503273
   Coding: 03735108FFFFFFFF41510004001100102F0209E671210A00FF
   Shop #: WSC 12345 123 61029
   ASAM Dataset: EV_MUHig6C3HBAS 001041
   ROD: EV_MUHig6C3HBAS_VW37.rod
   VCID: 1577C530A504D5E3915-8040
   Subsystem 1 - Part No SW: 5E0 919 606 D    HW: 5E0 919 606 D
   Component: ABT_High-2  H50 9130
   Serial number: SKZ6ZHT3174679
   Subsystem 2 - Part No SW: V03 959 806 GR    HW: -----------
   Component: ROW 2020  --- 0085
18 Faults Found:
1586 - invalid data record
          B2005 00 [009] - -
          [Control module (data record download) - invalid data record for speed shutoff thresholds]
                    Reset counter: 0
                    Mileage: 7859 km
                    Date: 2020.11.12
                    Time: 14:08:47
                    Voltage terminal 30: 11.8 V
1587 - invalid data record
          B2005 00 [009] - -
          [Control module (data record download) - invalid data record for language]
                    Reset counter: 0
                    Mileage: 7859 km
                    Date: 2020.11.12
                    Time: 14:08:47
1588 - invalid data record
          B2005 00 [009] - -
          [Control module (data record download) - invalid data record for visible MMI system languages]
                    Reset counter: 0
                    Mileage: 7859 km
                    Date: 2020.11.12
                    Time: 14:08:47
1589 - invalid data record
          B2005 00 [009] - -
          [Control module (data record download) - invalid data record for power management timer]
                    Reset counter: 0
                    Mileage: 7859 km
                    Date: 2020.11.12
                    Time: 14:08:47
1595 - invalid data record
          B2005 00 [009] - -
          [Control module (data record download) - invalid data record for audio management HMI constants]
                    Reset counter: 0
                    Mileage: 7859 km
                    Date: 2020.11.12
                    Time: 14:08:47
1652 - ROD - Unknown Error Code
          - 00 [009]
                    Reset counter: 0
                    Mileage: 7859 km
                    Date: 2020.11.12
                    Time: 14:08:47
1597 - Data Set Implausible
          B2012 00 [009] - -
          [Control module (data record download) - implausible data record for language]
                    Reset counter: 0
                    Mileage: 7859 km
                    Date: 2020.11.12
                    Time: 14:08:47
1598 - Data Set Implausible
          B2012 00 [009] - -
          [Control module (data record download) - implausible data record for visible MMI system languages]
                    Reset counter: 0
                    Mileage: 7859 km
                    Date: 2020.11.12
                    Time: 14:08:47
          U1014 00 [009] - -
                    Reset counter: 0
                    Mileage: 7859 km
                    Date: 2020.11.12
                    Time: 14:08:47
                    Voltage terminal 30: 11.7 V
                    Byte_Coding_Condition-byte_5_condition: ERROR
                    Byte_Coding_Condition-byte_6_condition: ERROR
                    Byte_Coding_Condition-byte_7_condition: ERROR
          B201A 00 [009] - -
                    Reset counter: 4
                    Mileage: 7859 km
                    Date: 2020.11.12
                    Time: 14:08:52
                    Status_Software_Version_Management-SW_VersMgtInfo: MDUK623/Main
15361024 - Component Protection
          U1101 00 [009] - Active
          [Anti-theft protection - component protection active (0xEA6400)]
                    Reset counter: 0
                    Mileage: 7859 km
                    Date: 2020.11.12
                    Time: 14:08:47
0532 - Subwoofer
          B106C 13 [009] - Open Circuit
          [Tieftonlautsprecher Kanal 5: Unterbrechung]
                    Reset counter: 0
                    Mileage: 7859 km
                    Date: 2020.11.12
                    Time: 14:08:54
0533 - Loudspeaker Channel 5
          B13A4 01 [009] - Electrical Failure
                    Reset counter: 0
                    Mileage: 7859 km
                    Date: 2020.11.12
                    Time: 14:08:51
0537 - Center speaker
          B1069 13 [009] - Open Circuit
          [Tieftonlautsprecher Kanal 6: Unterbrechung]
                    Reset counter: 0
                    Mileage: 7859 km
                    Date: 2020.11.12
                    Time: 14:08:54
6726 - ROD - Unknown Error Code
          - 00 [009]
                    Reset counter: 0
                    Mileage: 7859 km
                    Date: 2020.11.12
                    Time: 14:08:48
                    Network diagnosis-Status: Enabled
6672 - Optical Data Bus for Display in Instruments
          U10CF 00 [008] - Intermittent Disruption
          [Optical data bus: sporadic open circuit in instrument cluster display]
                    Mileage: 7859 km
                    Date: 2020.11.12
                    Time: 14:15:56
                    Temperature of MOST transceiver-max.value: -50 °C
                    Temperature of MOST transceiver-min.value: -7 °C
                    Temperature of MOST transceiver-Current: 41 °C
6678 - Digital sound System control module
          U106A 00 [009] - No Communication
          [Control module for sound system: no communication]
                    Reset counter: 0
                    Mileage: 7859 km
                    Date: 2020.11.12
                    Time: 14:09:13
7199 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Reversible belt tensioner (0x1F) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 0
                    Mileage: 7859 km
                    Date: 2020.11.12
                    Time: 14:08:49
                    BAP-BAP_Function_ID: 02
   Component: RVC Compact   H15 0231
   Coding: 0473010122002017000040
   Part No SW: 5E0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0001
   Serial number: 180814200210
   VCID: 698FB9C0D9FCA103E5D-803C
   ROD: EV_LED_PLUS_L_KEBODAVW416_VW37.rod
   VCID: 7EA5FA9CB07236BB20F-802A
0800 - Bulb for Low-Beam Headlamp
          C1198 F6 [040] - Over-Temp Protection Active
                    Reset counter: 0
                    Mileage: 1580 km
                    Date: 2019.12.31
                    Time: 14:58:41
   ROD: EV_LED_PLUS_R_KEBODAVW416_VW41.rod
                    Reset counter: 0
                    Mileage: 1580 km
                    Date: 2019.12.31
                    Time: 14:57:22
1129 - Bulb for DRL and Parking Light
          C123A F7 [040] - Overtemp Protection Active
                    Reset counter: 0
                    Mileage: 2981 km
                    Date: 2020.03.11
                    Time: 10:25:23
End----(Elapsed Time: 01:45, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
Spacewalker
Poland
C?ID=159607
you can try :
1) edit 5E-5F.clb and add REDIRECT your part number (like that REDIRECT,5E0-000-MIB-HGH1.CLB,5E0-035-045)
then it should recognize proper CLB file
if not, use long code helper manually , but not sure if they load all desctription
what i will do is a fix part number
